Web Content Viewer
Actions
imageRUNNER ADVANCE C5240A
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
The imageRUNNER ADVANCE C5200 Series helps each user accomplish every task with outstanding ease. A center of extraordinary productivity, these models are simple to personalize, creating a truly customized way to work.
A powerful digital communications center, the imageRUNNER ADVANCE C5200 Series integrates enterprise applications, connects to the cloud, and gives you the freedom to work from wherever you are, efficiently and easily.
In today's networked world, you need greater control over your resources and data. The imageRUNNER ADVANCE C5200 Series delivers just that with the ability to configure a system, safeguard information, and track resources, all right at your fingertips.
Accomplish multiple tasks with impressive speed, produce professional-quality documents, and seamlessly link to business applications-all with performance you can count on.
It's all about a brighter, greener future. The imageRUNNER ADVANCE C5200 Series, registered in EPEAT®, incorporates innovative, eco-conscious solutions that propel your business while reducing your environmental footprint.
imageRUNNER ADVANCE C5200 Series Spec Sheet
MAIN UNIT
SYSTEM TYPE Color Digital Multifunction Imaging System
FUNCTIONS Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PostScript® 3), Fax (Up to 4 Lines)
OPERATION PANEL 8.4" SVGA Full-Color TFT Screen
MEMORY Standard: 2 GB RAM
Maximum: 2.5 GB RAM
HARD DISK DRIVE Standard: 160 GB
Maximum: 1 TB
MIRRORING HARD DISK DRIVE Optional (160 GB, 1 TB), Method: RAID1
NETWORK INTERFACE CONNECTION Standard: 1000Base-T/100Base-TX/10Base-T
Optional: Wireless LAN (IEEE 802.1x via third-party adapter)
OTHER INTERFACE Standard: USB 2.0 (Host) x 2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x 2], Serial Interface, Copy Control Interface
COPY / PRINT SPEED (BW/COLOR) Letter: Up to 40/35 ppm
Legal/11" x 17": Up to 20/18 ppm
FIRST-COPY-OUT-TIME (LETTER) As fast as 5.4 Seconds (BW), 8.1 Seconds (Color)
PAPER SOURCES (20LB BOND) Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: Dual 550 Sheet Paper Cassettes, 2,700-sheet Paper Deck
Maximum: 5,000 Sheets
OUTPUT PAPER CAPACITY (20LB BOND) Standard: 250 Sheets (Inner Tray)
Maximum: 3,250 Sheets (w/Staple Finisher or Booklet Finisher)
OUTPUT PAPER SIZES Cassettes: 12" x 18",* 11" x 17",* Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18") Bypass: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18")
Paper Deck: Letter
Other Options: Envelope Feeder Attachment (COM10 No.10, Monarch, DL, ISO-C5)** Tab Feeding Attachment Kit**
ACCEPTABLE PAPER WEIGHTS Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2 )
Bypass: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2 )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Executive to 12" x 18")
Paper Weights:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2 )
SPECIAL MEDIA SUPPORT Thin, Plain 1 [17 lb. Bond to 21 lb. Bond (64 g/m2 to 81 g/m2 ], Plain 2 [22 lb. Bond to 28 lb. Bond (82 g/m2 to 105 g/m2 )], Recycled, Color, Pre-Punched, Bond, Heavy 1 [29 lb. Bond to 60 lb. Cover (106 g/m2 to 163 g/m2 )], Heavy 2 [61 lb. Cover to 80 lb. Cover (164 g/m2 to 220 g/m2 )], Heavy 3 [82 lb. Cover to 140 lb. Index (221 g/m2 to 256 g/m2 )], Tracing, Coated, Labels, Transparency, Tab, Letterhead, and Envelopes
WARM-UP TIME From Power On: 31 Seconds, From Sleep: 15 Seconds Quick Startup Mode: 7 Seconds***
POWER REQUIREMENS / PLUG 120 V AC, 60 Hz, 15 A/NEMA 5-15P
POWER CONSUMPTION Maximum: 1.5 kW
Sleep Mode: 0.8 W
DIMENSIONS (W X D X H) 37-3/8" x 24-3/8" x 28-1/8" (950 mm x 620 mm x 715 mm)
INSTALLATION SPACE (WXD) 33-1/2” x 28-1/8" (850 mm x 715 mm)
WEIGHT Approx. 346 lb. (157 kg)†
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)]
MAXIMUM ORIGINAL SIZE Up to 11" x 17"
DOCUMENT FEEDER
SCAN METHOD Single-Pass Duplexing, Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weights:1-sided scanning: 11 lb. Bond to 58 lb. Cover (42 to 157 g/m2 ) 2-sided scanning: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2 )
SCAN SPEED (BW and Color; Letter) Simplex: Up to 75/75 ipm (300 dpi)/Up to 75/51 ipm (600 dpi) Duplex: Up to 120/120 ipm (300 dpi)/Up to 75/51 ipm (600 dpi)
PAPER CAPACITY (20lB. BOND) 150 Sheets
COPY SPECIFICATIONS
MULTIPLE COPIES 1to 999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25% - 400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying
SPECIAL COPY FEATURES Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
Maximum: 2.5 GB RAM
Maximum: 1 TB
ENGINE RESOLUTION 1200 x 1200 dpi
PDL SUPPORT Standard: UFR II
Optional: PCL 5c, PCL 6, Adobe PS 3
PRINT DRIVER SUPPORTED OS UFR II, PCL 5c/6, Adobe PS 3: Windows® (Windows XP/Windows Vista®/Windows 7/Server 2003/ Server 2008/Server 2008 R2/Windows 8/Server 2012/Small Business Server 2011), Windows Terminal Servers (Server 2003/ Server 2008/Server 2008 R2/Server 2012), Small Business Server 2011, Windows Clustering Server (Windows Server 2003/Server 2008/Server 2008 R2/Server 2012), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/6), Macintosh® (OSX 10.5.8 or later, UFR II and PS 3 Only), VMware (vSphere 4/5/5.1), SAP (PS and PCL Only)
DIRECT PRINT SUPPORT Standard: TIFF, JPEG
Optional: PDF, XPS††, EPS†††
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Black and White Printing, Objective, Color/Black-and-White Auto Detect, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY Color Network ScanGear
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional)
COLOR MODE Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/XPS (OCR), PDF/A-1b, XPS, XPS (Compact), OOXML (OCR) (.pptx and .docx) Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions)
I-FAX DATA FORMAT (BW and COLOR) Color: .tfx (JPEG)
BW: .tif (MH, MR, MMR)
UNIVERSAL SEND FEATURES Two-Sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement to 11" x 17"
FAX FEATURES Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
6,000 Maximum Pages Stored
ADVANCED BOX Available Disk Space: Approx. 15 GB (Standard HDD) Approx. 629 GB (1 TB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows® (Windows 2000/XP/Windows Vista®)
Concurrent Connections (Max.): SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Port Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, HDD Data Erase Scheduler, IPSec, Adobe LiveCycle Rights Management ES2.5 Integration
OPTIONAL Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification‡
ENVIRONMENTAL SPECIFICATIONS
ENERGY STAR Qualified
Rated EPEAT Silver
EU RoHS Compliant
Ecomark
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-31 Toner
TONER YIELD (ESTIMATED @ 5% COVERAGE) Black: 36,000 Copies / Bottle
Color (C,M,Y): 27,000 Copies / Bottle
FOOTNOTES
* Not available on top cassette.
** Can be set to Cassette 2 only. Can not install Envelope Feeder Attachment and Tab Feeding Attachment at same time.
*** If "Quick Startup Settings for Main Power" is set to ON, it takes 7 seconds until the key operation on the touch panel display is available after turning on the main power.
† Includes consumables.
†† XPS cannot be printed directly from the Web Access software.
††† EPS can be printed directly only from Remote User Interface.
p Requires Cassette Feeding Unit-AD2. Cannot be installed with Cabinet Type-B1.
n The Inner 2-way Tray-F1, Inner Finisher-E1, Staple Finisher-J1, and Booklet Finisher-J1 cannot be installed at the same time.
‡ Specified configurations and settings need to be applied to the device in order to achieve and maintain IEEE 2600.1 Common Criteria Certification. Visit the product advisory page on www.usa.canon.com for certification status.
This is to make Misc appear on the page when needed.
Supplies
GPR-31 Toner
Color: Black
Item Code: 2790B03BA
Estimated Toner Yield: 36,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 2794B003AC
Estimated Toner Yield: 27,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 2798B003AC
Color: Yellow
Item Code: 2802B003AC
Accessories
Hardware Accessories
  • Inner 2-Way Tray-F1
  • Inner Finnisher-E1
  • Inner Finisher Additional Tray-A1 (Option for Inner Finisher)
  • Staple Finisher-J1
  • Booklet Finisher-J1
  • External 2/3 Hole Puncher-B2
  • Cassette Feeding Unit-AD2
  • Envelope Feeder Attachment Kit-D1
  • Tab Feeding Attachment Kit-B1
  • Cabinet Type-B1
  • Paper Deck Unit-B2
  • Copy Tray-J1
  • Utility Tray-A2
  • USB Keyboard
  • Universal Keyboard Stand-A1
  • Key Switch Unit-A2
  • Copy Card Reader Attachment Kit-B3
  • Copy Card Reader-F1
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-B1
System Connectivity Accessories
  • PCL Printer Kit-AR1
  • PCL International Font Set-A1
  • PS Printer Kit-AR1
  • Direct Printer Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Universal Send Advanced Feature Set-F1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AE2
  • Super G3 2nd Line Fax Board-AE1
  • Super G3 3rd/4th Line Fax Board-AE1
  • Remote Fax Kit-A1
  • Secure Watermark-B1
  • Document Scan Lock Kit-B1
  • HDD Data Encryption and Mirroring Kit -C1
  • HDD Data Erase Scheduler
  • Removable HDD Kit-AC1
  • Additional Memory Type D (512 MB)
  • 2.5 inch/160GB HDD-G1
  • 2.5 inch/1TB HDD-H1
  • iR-ADV Security Kit-C1 for IEEE 2600.1 Common Criteria Certification*
  • USB Device Port-E3
  • Multimedia Reader/Writer-A2
  • Voice Guidance Kit-F2
  • Voice Operation Kit-C2
  • Remote Operator's Software Kit-B1
  • imagePASS-B2
  • Hot Folder v3 (for imagePASS-B2)
  • Productivity Package (for imagePASS-B2)
  • ColorPASS-GX-400+
  • SeeQuence Impose (for imagePASS-B2 & Color PASS-GX-400)
  • SeeQuence Compose
  • SeeQuence Suite
  • Removable Hard Disk Drive Kit-B1 (for ColorPASS-GX400)
  • Graphic Arts Package, Premium Edition V2.2 (for ColorPASS-GX400)
  • X-Rite Eye-One (for imagePASS-B2 & ColorPASS-GX400)
  • Integrated Interface & Stand-A1 (for ColorPASS-GX400)
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
+ Only available for C5255.
Brochures
Loading...
Videos
Conducting Business
RUN Use Cases
 Return to Top
