Web Content Viewer
Actions
imageRUNNER ADVANCE C9065S PRO
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
  • Documents are output at amazing print speeds of up to 65 ppm (BW, letter)
  • Paper capacity can be extended to a maximum of 9,300 sheets to ensure that long jobs can run without having to stop for paper replenishment.
  • High toner and drum yields and the ability to replace toner on the fly help minimize downtime and maximize productivity.
  • The powerful Océ PRISMAsync operation management features an intelligent job Scheduler that enables up to eight hours of plan-ahead production in an efficient, media-driven workflow.
  • The optional Operator Attention Light signals upcoming operator interventions - such as needed media refills - several minutes before action is required, thereby allowing time to help prevent a halt in production.
  • Advanced paper handling and multiple finishing capabilities handle a wide range of jobs efficiently and cost effectively.
  • Print on coated, matte, or specialty stocks in weights from 14lb Bond to 110lb. Cover and sheet sizes from 5-1/2" x 7-1/8" to 13" x 19-1/4".
  • Choose one of three paper decks, a 3,500 letter-sized Paper Deck, a 3,500 sheet POD Deck Light that supports up to 13" x 19" paper and coated stock, or a 6,000 sheet Multi-Drawer Paper Deck that supports up to 13" x 19-1/4" paper and coated stock.
  • Choose from a wide range of inline finishing options, including multiposition stapling of up to 100 sheets; automatic 2- and 3-hole punching; professional punching with various punch patterns; preprinted media insertion for covers or page inserts; various folding capabilities including Z-, C-, Accordion Z-, Half-fold, Double-Parallel fold; and saddle-stitching and face-trimming of up to 20-sheet/80-page booklets.
  • True 1200 x 1200 dpi print resolution produces crisp text with smooth corners, while subtle gradient transitions give images remarkable clarity.
  • Flexible color control for accurate color management by any user. Color management with PRISMAsync includes Color Presets, Input/Output profiles, and spot color matching.
  • Precise eight-beam red lasers have a small diameter to produce high quality images with proper shading and accurate registration, without sacrificing productivity.
  • pQ toner is oil-free and uses small particles containing micro-dispersed wax so toner fixes evenly and lies flat. The result is sharp, vivid, dense images, improved gloss levels, and a smooth finish.
  • Auto Gradation Adjustment sets the ideal level for densities and halftones while Real-Time Calibration helps maintain this level by making automatic, real-time adjustments during print runs.
  • Accurate registration is achieved with an intelligent cassette design, manual adjustment features, and the ability to precisely match front-to-back registration within one millimeter for duplex documents.
  • Canon technology and Océ PRISMA operation management provide you throughput and production power to add services, respond to changing customer requirements, take on new work, and turn it around faster while reducing costs with a streamlined workflow.
  • A unique user interface with an intelligent job Scheduler displays every queued job and an overview of work scheduled for the day.
  • Media is defined once and used throughout the different steps of the printing process to minimize operator and prepress errors.
  • Océ PRISMAsync integrates seamlessly with other Océ PRISMA workflow software, including Océ PRISMAprepare® for WYSIWYG document preparation and Océ PRISMAaccess® for internal/intranet/Web-based job submission.
  • Canon's helps to reduce C02 emissions and uses less packaging for efficient transportation.
  • Designed with 100% recycled plastic and bio-based plastic for certain components.
  • Meets Energy Star standards.
  • pQ toner and new Induction Heat fusing system help to reduce overall energy consumption by minimizing heat and power requirements.
  • Meets and exceeds ROHS directive.
Specifications
Model Name
System Type
Color Digital Multifunction Imaging System
Functions
Copy, Scan, Print
Operation Panel
PRISMAsync 15 LCD Standard Configuration: imageRUNNER ADVANCE C9075S PRO/ C9065S PRO Main Unit, Duplex Color Image Reader Unit-A1, PRISMAsync iR-ADV C9000S PRO, Operator Panel, Scanning-B1,⟩ Scheduler-A1,⟩ Multiple Queues/Hot Folders-A1,⟩ E-shredding-B1,⟩ X-Rite Eye-One Spectrophotometer
Memory
Standard/Maximum: 2.5GB RAM
HDD Drive
Standard: 80GB
Maximum: 1TB
Network Interface Connection
Standard: Ethernet (10Base-T/100Base-TX/1000Base-T)
Other Interface
Standard: USB (at Operator Panel)
Copy/Print Speed (BW/Color)
Letter: Up to 65/65 ppm
Legal/11 x 17: Up to 39/39 ppm / Up to 33/33 ppm
Paper Source
(20 lb. Bond):
Standard: Dual 1,100-sheet Paper Drawers/Dual 550-sheet Cassettes/100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck-A1, 3,500-POD Deck Lite-A1, or 6,000-sheet/Multi-Drawer Paper Deck-A1
Maximum: 9,300 Sheets (with Multi-Drawer Paper Deck option)*
Output Paper Capacity
(20 lb. Bond):
With Copy Tray: 250 Sheets
With Staple or Booklet Finisher: 4,250 Sheets
Output Paper Sizes
Drawers: Letter
Cassettes: 13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2 x 7-1/8 to 13 x 19-1/4)
Bypass: 13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4 x 5-7/8 to 13 x 19-1/4)
Acceptable Paper Weights
Drawers/Cassettes: 14 lb. Bond to 80 lb. Cover
Bypass: 14 lb. Bond to 110 lb. Cover
Duplexing
Paper Size: Standard Automatic Trayless Duplexing (Up to 13 x 19)
Paper Weights: 14 lb. Bond to 80 lb. Cover
Special Media Support
Drawers: Transparency
Cassettes: Transparency, Tab
Bypass: Transparency, Tracing, Labels, Coated, Textured, Envelopes
Warm Up Time
From Power On: 5 Minutes
From Sleep Mode: 5 Minutes
From Energy Saver Mode: 90 Seconds
Power Requirements
Main Unit: 208V AC, 60Hz, 15A/NEMA 6-15P
PRISMAsync: 120V AC, 60Hz, 10-5A/NEMA 5-15P
Power Consumption
(Maximum): Main Unit: 2.5kW or Less; Sleep Mode: 1.5W
PRISMAsync: 181W or Less: Sleep Mode: 117W
Total: 2.68kW or Less; Sleep Mode: 118.5W
Plug
Main Unit: 15A/NEMA 6-15P
PRISMAsync: 10-5A/NEMA 5-15P
Dimensions
Main Unit: 55-1/10 x 44-1/10 x 36-3/4**
PRISMAsync: 16-1/2 x 7-9/10 x 16-9/10
Installation Space
50-1/5 x 57-1/10 (1275mm x 1450mm) (when Stack Bypass is extended, Operator Panel is in right-most position, and the Cassette is drawn)
Weight
Main Unit:♦ Approx. 635 lb.
PRISMAsync: Approx. 35.3 lb.
Total:♦ Approx. 670 lb.
Image Reader Unit
Scan Resolutions
Up to 600 x 600 dpi
Acceptable Originals
Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Maximum Original Size
Up to 11 x 17
Document Feeder
Scan Method
Single-Pass Duplexing Automatic Document Feeder
Paper Sizes: 11 x 17, Legal, Letter, Letter-R,Statement, or Statement-R
Paper Weights: BW Originals: 13 lb. Bond to 80 lb. Cover
Color Originals: 17 lb. Bond to 80 lb. Cover
Scanning Speed
Copy/Scan Simplex: 45/45 ipm (600 dpi)
Copy/Scan Duplex: 44/44 ipm (600 dpi)
Paper Capacity
(20 lb. Bond): 300 Sheets
Copy Specifications
First Copy Output Time
BW: 15 Seconds
Color: 15 Seconds
Multiple Copies
1 to 9,999
Color Mode
Black and White, Color
Magnification
25% - 400% (1% Increments)
Copy Features
Original: 1- or 2-sided, Original type, Size, Background
Output: 1- or 2-sided, Binding edge, Media, Cover, Layout, Zoom, Align, Shift, Print delivery, Margin erase, Adjust image, Color/Black & white, Punching,† Folding,† Binding,† Trimming†
Job: Job name, Number of sets, Destination, Separator sheets, Account ID
Print Specifications
Processor
Intel® Quad CoreTM i7
Type: External
Operating System: Windows® XPe® SP3
First-Print-Out-Time: (Letter):
BW: 8 Seconds
Color: 8 Seconds
Memory
4GB
Hard Disk
3 x 3.5 SATA II, 250GB, 7200 RPM
DVD-ROM: Standard
Interface Connections: 10/100/1000Base-T, TCP/IP (LPR/LPD), 9100 Socket (SMB), Static IP/Auto-IP (DHCP)
Engine Resolution
1200 x 1200 dpi
PDL Support
Adobe® PS3 (3019), PDF 1.7, [Extension Level 3 (for Acrobat® 9)], PDF/X, Optimized PS, Optimized PDF
Print Driver Supported OS
Windows Vista®, Windows 7 (32-bit and 64-bit), MAC® OS X10.4/10.5/10.6 (32-bit), PPD
Print Features
Waiting/scheduled jobs queues, printed jobs archive; One queue and job management for printing and copying; Streaming (spool-while-RIP-while-print while- clean-up), unlimited job length at constant print speed via clearing up while printing; Multiple standard and customizable workflow profiles; Media based operation with PRISMA media catalog; Web-based controller Settings Editor; Professional high-speed color management with Adobe ACE Color Management module and dedicated GPU; Calibration per media family and halftone; Spot color editing including CMYK value definition for spot color tints; Unlimited color pre-set definition for easy and timesaving re-use; Scheduler at operating panel: 8 hours plan-ahead functionality for multiple jobs simultaneously; Workflow automation via LPR queues and PDF/PS Hot Folders
Fonts: 136 Type 1 fonts for Roman languages; User import of PS fonts via Settings Editor
Spot Color Libraries: HKS K, HKS K3000+, HKS N, HKS N 3000+, PANTONE® Goe un/coated, PANTONE®+ Solid un/coated Scan Specifications
Standard: Scan-to-E-mail, Scan-to-FTP, Scan-to-USB
Option: Scan-to-PRISMAaccess
Scan Resolution: Up to 600dpi
File Format: (Single/Multi-page) TIFF, JPEG, PDF
Security Specifications
Standard: E-shredding, HTTPS, Password protection per user role (key operator, system administrator, service technician)
Optional: Removable HDD
Environmental Information
ENERGY STAR® Qualified RoHS Compliant WEEE Directive
Paper Supply Options
Description
Paper Deck Unit-A1
Paper Capacity
3,500 Sheets (20 lb. Bond)
No Of Drawers
1
Acceptable Paper Type
Thin, Plain, Heavy, Color, Recycled, Pre-Punched
Acceptable Paper Size
Letter
Power Source
From Main Unit
Maximum Power Consumption
44W
Dimensions
22-1/2 x 12-3/4 x 23
Weight
Approx. 81.6 lb
Description
POD Deck Lite-A1
Paper Capacity
No Of Drawers
1
Thin, Plain, Heavy, Color, Recycled, Pre-punched, Transparency, Labels, Bond, Letterhead, Coated, Textured
Power Requirement
120-127V AC, 60Hz, 5A
288W
Plug
NEMA 5-15P
Dimensions
22-1/2 x 23-5/8 x 24-1/2
Weight
Approx. 110 lb.
Description
Paper Capacity
6,000 Sheets (20 lb. Bond)
No Of Drawers
3 (2,000 Sheets each)
Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Tab, Bond, Letterhead, Coated, Textured
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Custom Size [5-1/2 x 7-1/8 to 13 x 19-1/4 (140mm x 182mm to 330mm x 488mm)]
Power Requirement
120-127V 60Hz 4A
Approx. 753W
Plug
NEMA 5-15P
Dimensions
41 x 37-3/8 x 31-3/8
Output Options
Description
Copy Tray-P1
Total Output Capacity
250 Sheets (20 lb. Bond)
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [4 x 5-7/8 to 13 x 19-1/4
Dimensions
6-7/8 x 16-1/2 x 15
Weight
Approx. 2.9 lb.
Description
Staple Finisher-A1
Number Of Trays
3
Tray Capacity
Tray A: 1,500 Sheets (Letter, Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Tray B: 250 Sheets (Letter) 125 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R, Executive)
Tray C: 2,500 Sheets (Letter) 1,250 Sheets (Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
4,250 Sheets (Letter, Statement-R,Executive)
Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [(4 x 5-7/8 to 13 x 19-1/4) (100mm x 148mm to 330mm x 488mm)]
Staple Positions
Corner/Double Stapling: 11 x 17, Legal, Letter, Letter-R,Executive
Max Stapling Capacity
100 Sheets (20 lb. Bond) (Letter, Executive)
50 Sheets (20 lb. Bond) (11 x 17, Legal, Letter-R)
Paper Capacity of Staple Mode
Tray A/C: 1,500 Sheets/100 Sets(Letter, Statement-R, Executive),750 Sheets/50 Sets (13 x 19, 12 x 18,11 x 17, Legal, Letter-R)
Type of Staples
Staple-G1 (5,000 x 3)
Power Requirement
100-240V, 50/60Hz, 2.8A
Max Power Consumption
207W
Plug
NEMA 5-15P
Dimensions
41 x 25-3/4 (30-3/4††) x 30-1/8
Weight
Approx. 134 lb.
Description
Booklet Finisher-A1
Number Of Trays
3
Tray Capacity
4,250 Sheets (Letter, Statement-R, Executive)
Thin, Plain, Heavy, Color, Recycled, Pre- Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size [4 x 5-7/8 to 13 x 19-1/4 (100mm x 148mm to 330mm x 488mm)]
Staple Positions
Corner Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Double Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Saddle-Stitch: 13 x 19, 12 x 18, 11 x 17, Legal, Letter-R
Max Saddle Stitch Capacity
20 Sheets (including one cover page 110 lb. Bond) (20 lb. Bond)
Paper Capacity Saddle Stich Mode
1 to 5 Sheets/25 Sets, 6 to 10 Sheets/ 15 Sets, 11 to 16 Sheets/10 Sets, 17 to 20 Sheets/5 Sets
Type of Staples
Staple-P1 (5,000 x 2)
Power Requirement
100-240V 50/60Hz, 2.8A
255W
Plug
NEMA 5-15P
Dimensions
41 x 30-1/4 (35-1/4††) x 30-1/8
Weight
Approx. 238 lb.
Description
Document Insertion Unit-H1ΔΔ
Number Of Trays
2
Acceptable Media
Covers and Inserts
Tray Capacity
Upper: 200 Sheets (20 lb. Bond)
Lower: 200 Sheets (20 lb. Bond)
Thin, Plain, Heavy, Color, Recycled, Pre-punched, Tab, Bond, Letterhead, Coated, Textured
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Custom Size [7-1/8 x 7-1/8 to 13 x 19-1/4 (140mm x 182mm to 330mm x 488mm)]
Power Requirement
100-240V/2.8A, 50/60Hz
103W
Plug
NEMA 5-15P
Dimensions
55-3/8 x 13-1/4 x 31-1/4
55-3/8 x 29-3/8 x 31-1/4 (with Insertion Feeding Tray)
Weight
Approx. 134 lb.
Description
Paper Folding Unit-G1ΔΔ
Folding Method
Roller Pressure Folding
Folding Type
Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold, Double Parallel Fold
14 lb. Bond to 28 lb. Bond
Thin, Plain, Color, Recycled, Bond
Accordion Z-Fold, C-Fold, Half-Fold: Letter-R Z-Fold: 11 x 17, Legal, Letter-R
Double Parallel Fold: Legal, Letter-R
Power Requirement
From Finisher
130W
Dimensions
46-7/8 x 13-1/4 x 31-1/4
Weight
Approx. 156.5 lb.
Description
Puncher Unit-BF1†††
Acceptable Punch Paper Weight
14 lb. Bond to 140 lb. Index
Acceptable Punch Paper Type
Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated, Textured
Acceptable Punch Paper Size
Punch Type
2 Holes (Legal, Letter-R)
3 Holes (11 x 17, Letter)
Distance Between Punch Holes
2 Holes: 2-3/4 (70mm)
3 Holes: 4-1/4 (108mm)
Punch Waste Tray Capacity
Approx. 5,000 Sheets (20 lb. Bond)
Power Requirement
From Finisher
Approx. 56W (when in operation)
Dimensions
Inside the Finisher (15-1/2 x 3-3/4 x 15-1/2)
Weight
Approx. 8.2 lb.
Description
Professional Puncher-C1/ Professional Puncher Integration Unit-B1ΔΔ
Letter (3-hole, 5-hole, Velo Bind 11-hole, Plastic Comb 19-hole, Twin Loop 21-hole/ 32-hole, Color Coil 44-hole): 20 lb. Bond to 80 lb. Cover
Letter (ProClick 32-hole): 20 lb. Bond to 65 lb. Cover
Plain, Heavy, Color, Recycled, Tab, Coated
Letter
Punch Patter Die Sets
Plastic Comb (19-hole)
Twin Loop (21/32-hole)
Color Coil (44-hole)
Velo Bind (11-hole)
Loose Leaf (3/5-hole)
ProClick (32-hole)
Approx. 25,000 Sheets or more of 20 lb. Bond with 4 holes punched
Power Requirement
120-127V/5.5A-60Hz
Professional Puncher-C1: 300W
Professional Puncher Integration Unit-B1: 130W Max.
Plug
NEMA 5-15P
Dimensions
Professional Puncher-C1: 41 x 12 x 31-1/4
Professional Puncher Integration Unit-B1: 41 x 9-7/8 x 31-1/4
Weight
Professional Puncher-C1: Approx. 176 lb.
Professional Puncher Integration Unit-B1: Approx. 88.2 lb.
Description
Inner Booklet Trimmer-A1Δ
Trimming Method
Face Trim
Trim Thickness
40 Sheets (2mm to 20mm Trimming Width)
Waste Tray Capacity
1,500 Sheets of Trimmed Strips (Width 0.78 (20mm), Letter, 20 lb. Bond)
16 lb. Bond to 110 lb. Cover
Thin, Plain, Heavy, Recycled, Color, Coated
30 Booklets
Power Requirement
From Finisher
51W (when in operation)
Dimensions
Inside the Finisher 15-7/8 x 9-7/8 x 24-5/8
Weight
Approx. 70.5 lb. Other Optional Accessories: Operator Attention Light Removable HDD Kit-AB1 3.5-inch/1TB HDD-B1 Key Switch Unit-B1 ADF Access Handle-A1 Remote Viewer-B1 Fontset Simplified Chinese-B1 Fontset Traditional Chinese-B1 Fontset Japanese-B1 Fontset Korean-B1⟩ PRISMAsync license accessories.
* Stack Bypass is not available when Multi-Drawer Paper Deck is installed.
** With Operator Panel in left-most position.
*** With Operator Panel in right-most position.
♦ Includes ADF, consumables, Operator Panel.
† Requires optional accessories.
†† When the Auxiliary Tray is extended.
††† Puncher Unit-BF1 installs internally with either Staple Finisher-A1 or Booklet Finisher-A1.
Δ Option for Booklet Finisher-A1.
ΔΔ Requires Staple Finisher-A1 or Booklet Finisher-A1.
Supplies
GPR-32 Toner
Color: Black
Item Code: 2791B003AA
Estimated Toner Yield: 72,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 2795B003AA
Estimated Toner Yield: 54,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 2799B003AA
Color: Yellow
Item Code: 2803B003AA
This is to make Misc appear on the page when needed.
Brochures
Loading...
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video.
  • Click here to access Canon's Generation Green Website
Product Configurator
  • Click here for the imageRUNNER ADVANCE 9000S Series Configurator.
 Return to Top
