Web Content Viewer
Actions
imageRUNNER ADVANCE C9280 PRO
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
The imageRUNNER ADVANCE C9200 PRO Series lets you quickly and easily produce professional, high-quality documents with every run. These dependable devices help you meet the most challenging demands and exceed expectations every day.
  • 4 Continuous Run
  • Long-running reliability
  • Robust paper handling
  • Professional control
  • Productive scanning flow
  • 4 Rich detail
  • 3 Consistent quality
  • 2 pQ Toner
  • 1 Precise registration
  • 1 Reliable color consistency
Today's fast-paced business world demands fast turnaround and exceptional quality. From time-saving connectivity solutions to tighter job control features, the Canon imageRUNNER ADVANCE C9200 PRO Series gives you the tools you need to consistently exceed expectations.
The imageRUNNER ADVANCE C9200 PRO Series, rated EPEAT® Gold, incorporates innovative, eco-conscious solutions that keep your business operating efficiently while helping to reduce your environmental footprint.
imageRUNNER ADVANCE C9200 Series Spec Sheet
MAIN UNIT
SYSTEM TYPE Color Digital Multifunction Imaging System
FUNCTIONS Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL 5c/6, Adobe® PostScript® 3™), Fax (Up to 4 Lines)
OPERATION PANEL 10.4" SVGA Full-Color, TFT Upright Screen
MEMORY Standard: 2GB RAM
Maximum: 2.5GB RAM
HARD DISK DRIVE Standard: 160GB
Maximum: 1TB
MIRRORING HARD DISK DRIVE Optional (160GB, 1TB), Method: RAID1
NETWORK INTERFACE CONNECTION Standard: 10Base-T/100Base-TX/1000Base-T
Optional: Wireless LAN (IEEE 802.1x via third-party adapter)
OTHER INTERFACE Standard: USB 2.0 (Host) x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x2], Serial Interface, Copy Control Interface
COPY / PRINT SPEED (BW/COLOR) Letter: Up to 80/70 ppm
Legal: Up to 47/41 ppm
11" x 17: Up to 40/35 ppm
FIRST-COPY-OUT-TIME (LETTER) BW: 4.4 Seconds
Color: 6.0 Seconds
PAPER SOURCES (20LB BOND) Standard: Dual 1,100-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck Unit, 3,500-sheet POD Deck Lite, or 6,000-sheet Multi-Drawer Paper Deck
Maximum: 9,300 Sheets (with Optional Multi-Drawer Paper Deck)
OUTPUT PAPER CAPACITY (20LB BOND) 4,250 Sheets (with Staple Finisher or Booklet Finisher)
OUTPUT PAPER SIZES Drawers: Letter
Cassette: 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4")
Bypass: 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelopes, Custom Size (4" x 5-7/8" to 13" x 19-1/4")
ACCEPTABLE PAPER WEIGHTS Drawers/ Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220g/m2 ) Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300g/m2 )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Up to 13" x 19")
Paper Weight: 14 lb. Bond to 80 lb. Cover (52 to 220g/m2 )
MEDIA SUPPORT Thin [14 lb. Bond to 16 lb. Bond (52 to 63g/m2 )], Plain 1 [17 lb. Bond to 21 lb. Bond (64 to 81g/m2 )], Plain 2 [22 lb. Bond to 28 lb. Bond (82 to 105g/m2 )], Heavy 1 [29 lb. Bond to 40 lb. Bond (106 to 150g/m2 )], Heavy 2 [56 lb. Cover to 80 lb. Cover (151 to 220g/m2 )], Heavy 3 [82 lb. Cover to 140 lb. Index (221 to 256g/m2 )], Heavy 4 [140 lb. Index to 110 lb. Cover (257 to 300g/m2 )], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab, Textured, Coated, Envelopes
WARM-UP TIME From Power On: 31 Seconds or Less
From Sleep: 30 Seconds or Less
Quick Startup Mode: 7 Seconds*
POWER REQUIREMENS / PLUG 208V AC, 60Hz, 12A/NEMA 6-15P
POWER CONSUMPTION Maximum: 2.5kW
Sleep Mode: 0.9W or Less
DIMENSIONS (W X D X H) 55-1/4" x 46-1/2" x 36-3/4"**
INSTALLATION SPACE (WXD) 63" x 36-3/4"
WEIGHT Approx. 615 lb. (279kg)***
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2kg)]
MAXIMUM ORIGINAL SIZE Up to 11" x 17"
DOCUMENT FEEDER
SCAN METHOD Single-Pass Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
Paper Weights: 1-sided scanning: 13 lb. Bond to 80 lb. Cover (50 to 220g/m2 ) 2-sided scanning (Black-and-white original): 13 lb. Bond to 80 lb. Cover (50 to 220g/m2 ) 2-sided scanning (Color original): 17 lb. Bond to 80 lb. Cover (64 to 220g/m2 )
SCAN SPEED (BW and Color; Letter) Simplex: Up to 120/120 ipm (300 dpi) Up to 120/70 ipm (600 dpi) Duplex: Up to 200/140 ipm (300 dpi) Up to 120/70 ipm (600 dpi)
PAPER CAPACITY (20lB. BOND) 300 Sheets
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (LETTER) BW: 4.4 Seconds
Color: 6.0 Seconds
MULTIPLE COPIES 1to 9,999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25% - 400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying
SPECIAL COPY FEATURES Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
Maximum: 2.5GB RAM
Maximum: 1TB
ENGINE RESOLUTION 1200 x 1200 dpi
PDL SUPPORT Standard: UFR II
Optional: PCL 5c/6, Adobe PS 3
PRINT DRIVER SUPPORTED OS UFR II, PCL 5c/6, Adobe PS 3: Windows® (XP/Windows Vista®/7/8), Windows Server (2003/ 2008/2008 R2/SBS 2011/2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/2012), Microsoft® Clustering Server (Server 2003/Server 2003 R2/Server 2008/ Server 2008 R2), Citrix (Presentation Server 4.5, Xen App 5.0/ 6.0/6.5, Xen Desktop 4.0/5.0/5.5/5.6), Macintosh® (OS X 10.5.8 or later, UFR II and PS 3 only), VMware, SAP (PS and PCL Only)
DIRECT PRINT SUPPORT Standard: TIFF, JPEG
Optional: PDF, EPS,† XPS††
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secure Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Black-and-White Printing, Objective, Color/Black-and-White Auto Detect, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY Color Network ScanGear
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional)
COLOR MODE Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Searchable), PDF (Apply Policy), PDF (Optimize for Web), PDF/XPS (OCR), PDF/A-1b, XPS, XPS (Compact), OOXML (.pptx and .docx) Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/ XPS (Digital Signature), PDF (Reader Extensions)
I-FAX DATA FORMAT (BW and COLOR) Color: .tfx (JPEG)
BW: .tif (MH, MR, MMR)
UNIVERSAL SEND FEATURES Two-sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-mail Priority
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX FEATURES Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
6,000 Maximum Pages Stored
ADVANCED BOX Available Disk Space: Approx. 15GB (Standard HDD) Approx. 629GB (1TB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 2000/XP/7/8/Windows Vista)
Concurrent Connections (Max.): SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign-On H, Access Management System (Device and Function Level Log-in), Secure Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec , Adobe LiveCycle® Rights Management ES2.5 Integration
OPTIONAL Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification
ENVIRONMENTAL SPECIFICATIONS
ENERGY STAR Qualified
EPEAT Gold
EU RoHS Compliant
Ecomark
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-32
TONER YIELD (ESTIMATED @ 5% COVERAGE) Black: 72,000 Copies / Bottle
Color (C,M,Y): 54,000 Copies / Bottle
FOOTNOTES
* If "Quick Startup Settings for Main Power" is set to ON, it takes 7 seconds until the key operation on the touch-panel display is available after turning on the main power.
** To the right edge of the Upright Control Panel in the right-most position.
*** Including the toner bottle, Duplex Color Image Reader, and the Upright Control Panel.
† EPS can be printed directly only from Remote User Interface.
†† XPS cannot be printed directly from the Web Access software.
 Will be available Q4 2013.
▲▲ When the Auxiliary Tray is extended.
▼ Installs internally with Staple Finisher-K1 or Booklet Finisher-K1.
▼▼ Installs internally with Booklet Finisher-K1.
▼▼▼ Requires Staple Finisher-K1 or Booklet Finisher-K1.
● Requires the Copy Card Reader Attachment Kit-A2.
●● Requires PCL Printer Kit-AS1.
●●● Requires Additional Memory Type D (512MB).
■ Requires Direct Print Kit-H1 for printing PDF files.
■ ■ Requires Super G3 Fax Board-AD2.
◆ Requires Super G3 2nd Line Fax Board-AD1.
◆◆ Cannot be installed with Super G3 Fax Board-AD2.
◆◆◆ Requires USB Device Port-A2.
 Voice Guidance Kit-F2 and Voice Operation Kit-C2 cannot be installed together.
 Cannot be installed with Copy Card Reader-F1.
This is to make Misc appear on the page when needed.
Supplies
GPR-32 Toner
Color: Black
Item Code: 2791B003AA
Estimated Toner Yield: 72, 000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 2795B003AA
Estimated Toner Yield: 54, 000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 2799B003AA
Color: Yellow
Item Code: 2803B003AA
Accessories
Hardware Accessories
  • Booklet Finisher-K1
  • Staple Finisher-K1
  • Puncher Unit-BF1 (Option for Booklet Finisher-K1 or Staple Finisher-K1)
  • Inner Booklet Trimmer-A1 (Option for Booklet Finisher-K1)
  • Document Insertion Unit-H1 (Requires a Finisher)
  • Professional Puncher-C1/Professional Puncher Integration Unit-B1 (Requires a Finisher)
  • Paper Folding Unit-G1 (Require a Finisher)
  • Paper Deck Unit-C1
  • POD Deck Lite-A1
  • Multi-Drawer Paper Deck-A1
  • Copy Tray-P1
  • Utility Tray-A2
  • USB Keyboard
  • Universal Keyboard Stand-A1
  • Copy Card Reader-F1
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-B1
System Connectivity Accessories
  • PCL Printer Kit-AS1
  • PCL International Font Set-A1
  • PS Printer Kit-AS1
  • Direct Print Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Universal Send Advanced Feature Set-F1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AD2
  • Super G3 2nd Line Fax Board-AD1
  • Super G3 3rd/4th Line Fax Board-AE1
  • Remote Fax Kit-A1
  • Secure Watermark-B1
  • Document Scan Lock Kit-B1
  • HDD Data Encryption and Mirroring Kit -C1
  • Removable HDD Kit-AH1
  • Additional Memory Type D (512 MB)
  • 2.5 inch/160GB HDD-G1
  • 2.5 inch/1TB HDD-L1
  • iR-ADV Security Kit-G1 for IEEE 2600.1 Common Criteria Certification (Pending)
  • USB Device Port-A2
  • Multimedia Reader/Writer-A2
  • Voice Guidance Kit-F2
  • Voice Operation Kit-C2
  • Remote Operator's Software Kit-B1
  • imagePASS-A2
  • ColorPASS-GX-400
  • Silex Wireless Bridge SX-2500CG
  • SeeQuence Suite (for imagePASS-A2 or ColorPASS-GX400)
  • SeeQuence Impose (for imagePASS-A2 or ColorPASS-GX400)
  • SeeQuence Compose (for imagePASS-A2 or ColorPASS-GX400)
  • X-Rite Eye-One (for imagePASS-B2 & ColorPASS-GX400)
  • Productivity Package (for imagePASS-A2)
  • Integrated Interface & Stand-A1 (for ColorPASS-GX400)
  • Removable Hard Disk Drive Kit-B1 (for ColorPASS-GX400)
  • Graphic Arts Package Premium Edition (for ColorPASS-GX400)
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Videos
Conducting Business
RUN Use Cases
 Return to Top
