Web Content Viewer
Actions
imageRUNNER ADVANCE DX 617iFZ
Multifunction Copiers
Solutions to help increase office efficiencies and productivity
Canon PRINT Business App
Features
  • 10.1" intuitive touchscreen with smartphone-like usability.
  • A unique, customized experience tailored to individual preferences using My ADVANCE.
  • Supports mobile solutions and integration with many popular cloud services like Google Drive.
  • Scan and convert documents to searchable digital files in a variety of file formats.
  • Integration with Canon and various third-party software with embedded application platform.
  • Hot Folders allow users to drag and drop a file into a hot folder, and automatically print with predefined settings such as number of copies and finishing requirements.
  • Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
  • Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
  • Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.
  • Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
  • Control access to the device and specific features, using a host of flexible authentication methods — PIN code, user name/password, or card access.
  • Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
  • Outstanding imaging technologies and toner allow for crisp text and consistent images in rich black-and-white tones.
  • Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
  • imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
  • Designed for quick, easy deployment.
  • Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
  • Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
  • Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
  • Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
  • Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
  • Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
  • Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
  • A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
  • Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
  • ENERGY STAR® certified and rated EPEAT® Gold.
imageRUNNER ADVANCE DX 617iF / 617iFZ
MAIN UNIT
TYPE Monochrome Laser Multifunction
CORE FUNCTIONS Print, Copy, Scan, Send, Fax
PROCESSOR 1.75 GHz Dual Core Processor
CONTROL PANEL 10.1" TFT LCD WSVGA Color Touch-panel
MEMORY 3.0 GB RAM
HARD DISK DRIVE 320 GB (available disk space: 250 GB)
INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 3,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND) Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 550-sheet (CASSETTE FEEDING UNIT-AR1), 2,650-sheet (HIGH CAPACITY CASSETTE FEEDING UNIT-D1), 550-sheet (CASSETTE MODULE-AG1), 75-envelope (ENVELOPE CASSETTE MODULE-A1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) Standard Model: 500 Sheets
Finisher Model: 1,000 Sheets
FINISHING CAPABILITIES Standard Model: Collate, Group
Finisher Model: Collate, Group, Offset, Staple
SUPPORTED MEDIA TYPES Cassettes: Thin, Plain, Recycled, Color, Heavy, Labels, Bond, Pre-punched
Multi-purpose Tray: Thin, Plain, Recycled, Color, Heavy, Transparency, Bond, Envelope
SUPPORTED MEDIA SIZES
Cassette (Std.): Letter, Executive, Statement, Custom size (3-7/8" x 5-7/8" to 8-1/2" x 11-3/4")
Cassettes (Opt.): Legal, Letter, Executive, Statement, Custom size (3-7/8" x 5-7/8" to 8-1/2 x 14")
Multi-purpose Tray: Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom size (3" x 5" to 8-1/2" x 14")
SUPPORTED MEDIA WEIGHTS Cassette: 16 lb. Bond to 36 lb. Bond (60 to 135 g/m2)
Multi-purpose Tray: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2)
Duplex: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
PRINT/COPY SPEED Up to 65 ppm (Letter); Up to 51 ppm (Legal)
WARM-UP TIME From Power On: 10 Seconds or Less1
From Sleep Mode:  10 Seconds or Less2
Quick Startup Mode: 4 Seconds or Less3
DIMENSIONS (W x D x H) Standard Model: 19-3/4" x 23-1/2" x 24-1/4" (500 mm x 598 mm x 617 mm)
Finisher Model: 19-3/4" x 23-1/2" x 32-1/8" (502 mm x 598 mm x 814 mm)
INSTALLATION SPACE (W x D x H) 41-3/8" x 32-3/8" (1,052 mm x 823 mm) (with left CRG door open + right door open + the cassette drawer open)
WEIGHT4 Standard Model: Approx. 81.6 lb. (37 kg)
Finisher Model: Approx. 101.4 lb. (46 kg)
PRINT SPECIFICATIONS
PRINT RESOLUTION 600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
SUPPORTED FILE TYPES FOR DIRECT PRINT PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Google Cloud Print, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
FONTS PCL: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),5 Barcode Fonts6
PS: 136 Roman
OPERATING SYSTEM 7 UFRII/PS: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019, Mac OS X(10.10 or later) PCL: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019
PPD: Windows® 7/8.1/10, MAC OS X(10.9 or later)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME As fast as 5 Seconds
COPY RESOLUTION (dpi) 600 x 600
MULTIPLE COPIES Up to 9,999
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTION / ENLARGEMENT 25%, 50%, 64%, 78%, 100% (1:1), 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE Single-pass Duplexing Automatic Document Feeder8
DOCUMENT FEEDER PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES Legal, Letter, Statement Custom Size: 1-7/8" x 5" to 8-1/2" x 14" (48.0 mm x 128.0 mm to 216.0 mm x 355.6 mm)
Business Card: 1-7/8" x 3-3/8" to 2-1/8" x 3-5/8" (48.0 mm x 85.0 mm to 55.0 mm x 91.0 mm)
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single-sided Scanning: 13.3 lb. Bond to 34 lb. Bond (50 to 128 g/m2) (BW), 17 to 34 lb bond (64 to 128 gsm) (CL)
Double-sided Scanning: 13.3 lb. Bond to 34 lb. Bond (50 to 128 g/m2) (BW), 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2) (CL)
Business Card: 21.3 lb. Bond to 80 lb. Cover (80 to 220 g/m2)
PLATEN MAXIMUM SCANNING SIZE Up to 8-1/2" x 14" (216.0 mm x 355.6 mm)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects
PULL SCAN Color Network ScanGear for both Twain and WIA
Supported OS: Windows 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION Scan for Copy: 600x600
Scan for Send: (Push) 600 x 600 (SMB/FTP/WebDAV/IFAX), (Pull) 600 x 600 Scan for Fax: 600x600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to mobile devices or cloud-based services depending on your requirements.
SCAN SPEED (LETTER) Send (300 x 300 dpi)
Automatic Color Select "OFF"
Single-sided Scanning: 100
Double-sided Scanning: 200
Automatic Color Select "ON"
Single-sided Scanning: 50
Double-sided Scanning: 100 Copy (600 x 600 dpi)
Double-sided Scanning: 155
SEND SPECIFICATIONS
DESTINATION Standard: Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax
Optional IP Fax
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed Dial (200)
SCAN RESOLUTION Push: Up to 600 x 600
Pull: Up to 600 x 600
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB v3.0, WebDAV
Email: SMTP, POP
FILE FORMAT Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
FAX SPECIFICATIONS
MAXIMUM NUMBER OF CONNECTION LINES One
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 (Ultra Fine), 200 x 400 (Super Fine), 200 x 200 (Fine), 200 x 100 (Normal)
SENDING / RECORDING SIZE Statement to Legal
FAX MEMORY Up to 30,000 Pages (2,000 Jobs)
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCAST Max. 256 Addresses
MEMORY BACKUP Yes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored (2,000 Jobs)
ADVANCED BOX Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard: Universal Login Manager (Device and Function Level Log-in), User Authentication, Department ID Authentication, Access Management System, uniFLOW Online Express9
Optional: uniFLOW
DATA Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup,4 McAfee Embedded Contro9
Optional: IEEE 2600 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, Secure Watermark User Signature
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86º F
Humidity: 20 to 80% RH (Relative Humidity)
POWER REQUIREMENTS 110-127V, 60 Hz, 9.7 A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION Maximum: Approx. 1,500 W
Standby: Approx. 28.46 W10
Sleep Mode: Approx. 1.0 W11
Typical Electricity Consumption (TEC) Rating12 0.69 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold
CONSUMABLES
TONER
T03 Black (All-in-One Toner Cartridge)13
TONER YIELD
Black: 51,500 Images @ ISO 19752
FOOTNOTES
  1. Time from device power-on until copy ready (not print reservation).
  2. Time from exiting sleep mode to when printing is operational.
  3. Time from device power-on to when copy icon appears on the main menu of touch-panel.
  4. Includes consumables.
  5. Requires the optional PCL International Font Set-A1.
  6. Requires the optional Barcode Printer Kit-D1.
  7. Other operating systems and environments, including AS/400, UNIX, Linux, and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  8. Detect Feeder Multi Sheet Feed is supported.
  9. No charge for this solution; however, activation is required.
  10. Reference value (measured one unit).
  11. 1.0 W Sleep mode not available in all circumstances due to certain settings.
  12. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
  13. Includes toner, drum, developer, and waste toner hopper.
This is to make Misc appear on the page when needed.
Supplies
Toner T03 Black
Color: Black
Item Code: 2725C001AA
Estimated Toner Yield: 51,5000 Copies/Bottle (Estimated @ ISO 19752)
Accessories
Hardware Accessories
  • Cassette Module-AG1
  • Cassette Feeding Unit-AR1
  • High Capacity Cassette Feeding Unit-D1
  • Envelope Cassette Module-A1
  • Cabinet Type-U
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-B5
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Braille Label Kit-F1
  • USB Keyboard (Cherry)
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
  • Convenience Stapler-A1 (White)
System Connectivity Accessories
  • PCL International Font Set-A1
  • Barcode Printing Kit-D1
  • MEAP Web Connection Kit V5.6
  • IP FAX Expansion Kit-B1
  • HDD Data Erase Scheduler V3.1.3
  • HDD Data Erase Scheduler V3.1.3 NFR
  • iR-ADV Security Kit-AR1 for IEEE 2600 Common Criteria Certification
  • Connection Kit-A2 for Bluetooth LE
  • NFC Kit-E1
Click here to learn more about the imageRUNNER ADVANCE product line.
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Workflow Solutions
Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE DX 617iFZ model is equipped to support the needs of mobile users based on varying company policies, types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE DX 617iFZ model offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This model is designed with Document Capture and Distribution in mind.
The Output Management Solutions available for the Canon imageRUNNER ADVANCE DX 617iFZ model provide various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE DX 617iFZ model is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE DX 617iFZ model, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The imageRUNNER ADVANCE DX 617iFZ model can be a key business solution for information management and easier workflow.
Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class imageRUNNER ADVANCE DX 617iFZ model offers solid, fleet-based management tools to establish an integrated solution that can help reduce costs and minimize IT resources. These models are designed to help companies realize increased productivity and focus on day-to-day IT activities.
Videos
imageRUNNER ADVANCE DX Teaser Video
imageRUNNER ADVANCE DX Features Video
Advance Scanning with Cloud Filing Assist and imageRUNNER ADVANCE DX
imageRUNNER ADVANCE Control Video
Simplify, Control, and Evolve with imageRUNNER ADVANCE
 Return to Top
