Web Content Viewer
Actions
imageRUNNER ADVANCE DX C357iF
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Features
  • 10.1" intuitive touchscreen with smartphone-like usability.
  • A unique, customized experience tailored to individual preferences using My ADVANCE. Supports mobile solutions and integration with many popular cloud services like Google Drive.
  • Scan and convert documents to searchable digital files in a variety of file formats. Integration with Canon and various third-party software with embedded application platform.
  • Integration with Canon and various third-party software with embedded application platform.
  • Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
  • Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
  • Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.
  • Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
  • Control access to the device and specific features, using a host of flexible authentication methods PIN code, user name/password, or card access.
  • Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
  • Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
  • Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
  • imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
  • Designed for quick, easy deployment.
  • Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
  • Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
  • Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
  • Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
  • Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
  • Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
  • Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
  • A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
  • Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
  • ENERGY STAR® certified and rated EPEAT® Gold.
  • imageRUNNER ADVANCE DX C357iF
    MAIN UNIT
    TYPE Color Laser Multifunctional
    CORE FUNCTIONS Print, Copy, Scan, Send, Store, Fax
    PROCESSOR 1.75GHz Dual Core Processor
    CONTROL PANEL 10.1" TFT LCD WSVGA Color Touch-panel
    MEMORY 3.0 GB RAM
    HARD DISK DRIVE 320 GB (available disk space: 200 GB)
    INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
    Optional: NFC, Bluetooth Low Energy
    Others
    Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
    Optional: Serial Interface, Copy Control Interface
    PAPER CAPACITY (LETTER, 20 LB. BOND)
    Standard: 650 Sheets
    Maximum: 2,300 Sheets
    PAPER SOURCES (LETTER, 20 LB. BOND) Standard: 550-sheet Paper Cassette, 100-sheet Multi-Purpose Tray
    Optional: 550-sheet Paper Cassette (CASSETTE MODULE-AE1), 550-sheet Paper Cassette with cabinet (CASSETTE FEEDING UNITAJ1), Triple 550-sheet Paper Cassettes (CASSETTE FEEDING UNIT-AK1)
    PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) Standard: 250 Sheets
    Maximum: 500 Sheets (with STAPLE FINISHER-Z1)
    FINISHING CAPABILITIES Standard: Collate, Group
    With External Finisher: Collate, Group, Offset, Staple
    SUPPORTED MEDIA TYPES Multi-Purpose Tray: Thin, Plain, Heavy, Recycled, Color, Transparency, Pre-punched, Bond, Label, Envelope
    Paper Cassette: Thin, Plain, Heavy, Recycled, Color, Pre-punched, Bond, Envelope
    SUPPORTED MEDIA SIZES
    Standard Size: Legal, Letter, Executive, Statement Custom Size: 3-7/8" x 5-7/8" to 8-1/2" x 14" (98.0 x 148.0 mm to 216.0 x 355.6 mm)
    Envelopes: COM10 No.10, Monarch, DL, ISO-C5 Envelope
    Paper Cassette Standard size: Legal, Letter, Executive, Statement Custom Size : 3-7/8" x 7-1/2" to 8-1/2" x 14" (98.0 x 190.5 mm to 216.0 x 355.6 mm)
    SUPPORTED MEDIA WEIGHTS Cassettes: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
    Multi-Purpose Tray: 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2)
    Duplexing: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
    PRINT/COPY SPEED (BW AND COLOR) Up to 36 ppm (Letter); Up to 29 ppm (Legal)
    WARM-UP TIME From Power On: Approx. 10 Seconds1
    From Sleep Mode: Approx. 10 Seconds2
    Quick Startup Mode: Approx. 4 Seconds3
    DIMENSIONS (W x D x H) Standard (Desktop): 20-1/2" x 25-7/8" x 25-1/8" (519 mm x 658 mm x 638 mm)
    INSTALLATION SPACE (W x D x H) Basic: 33-1/2" x 35-3/4" (852 mm x 908 mm) (with Paper Cassette Open + Multi-Purpose Tray Extended)
    Fully Configured: 55-3/8" x 35-3/4" (1407 mm x 908 mm) (with Staple Finisher-Z1 + Paper Cassette Open + Multi-Purpose Tray Extended)
    WEIGHT4 Standard (Desktop): Approx. 108 lb. (49 kg)
    PRINT SPECIFICATIONS
    PRINT RESOLUTION 1200 x 600
    STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
    SUPPORTED FILES PDF, TIFF, JPEG, EPS, XPS
    PRINTING FROM MOBILE AND CLOUD-BASED SERVICES A range of standard and optional software and MEAP- based solutions (including AirPrint, Mopria, Google Cloud Print, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internetconnected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
    FONTS PCL: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),5 Barcode Fonts6
    PS: 136 Roman
    OPERATING SYSTEM 7 UFRII/PS: Windows® 7/8.1/10/Server 2008/ Server 2008 R2/Server 2012/ Server 2012 R2 /Server 2016 / Server 2019, Mac OS X (10.10 or later)
    PCL: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016 /Server 2019
    PPD: Windows® 7/8.1/10, Mac OS X (10.9 or later)
    COPY SPECIFICATIONS
    FIRST-COPY-OUT-TIME As fast as 5.1 seconds (BW)/ 6.9 seconds (Color)
    COPY RESOLUTION (dpi) With Platen: 600 x 600
    With DADF: 300 x 600
    MULTIPLE COPIES Up to 999
    MAGNIFICATION 25%-400% (1% Increments)
    PRESET REDUCTION / ENLARGEMENT 25%, 50%, 64%, 78%, 100% (1:1), 129%, 200%, 400%
    SCAN SPECIFICATIONS
    TYPE Single-pass Duplexing Automatic Document Feeder8
    DOCUMENT FEEDER PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
    DOCUMENT FEEDER SUPPORTED MEDIA SIZES Legal, Letter, Statement Custom Size: 1-7/8" x 5" to 8-1/2" x 14" (48.0 mm x 128.0 mm to 216.0 mm x 355.6 mm)
    Business Card: 1-7/8" x 3-3/8" to 2-1/8" x 3-5/8" (48.0 mm x 85.0 mm to 55.0 mm x 91.0 mm)
    DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
    One-Sided Scanning: 13.3 to 34 lb. Bond (50 to 128 gsm) (BW), 17 to 34 lb. Bond (64 to 128 gsm) (CL)
    Two-Sided Scanning: 13.3 to 34 lb. Bond (50 to 128 gsm) (BW), 17 to 34 lb. Bond (64 to 128 gsm) (CL)
    Note: Business Card: 21.3 lb bond to 80 lb cover (80 to 220 gsm)
    PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects
    PULL SCAN Color Network ScanGear2 for both Twain and WIA Supported OS: Windows® 7/8.1/10/Server 2008/ Server 2008 R2/Server 2012/ Server 2012 R2/Server 2016
    SCAN RESOLUTION (dpi) Scan for Copy: 600 x 600
    Scan for Send: (Push) 600 x 600 (SMB/FTP/WebDAV/IFAX), (Pull) 600 x 600
    Scan for Fax: 600 x 600
    SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to compatible mobile devices and certain cloud-based services depending on your requirements.
    SCAN SPEED (LETTER) Send: Automatic Color Select "OFF" (300 x 300 dpi): Single-Sided Scanning: 100 ipm Double-Sided Scanning: 200 ipm Automatic Color Select "ON" (300 x 300 dpi): Single-Sided Scanning: 50 ipm Double-Sided Scanning: 100 ipm
    Copy: Scan Speed priority (300 x 600 dpi): Single-Sided Scanning: 50 ipm Double-Sided Scanning: 100 ipm Image Quality priority (600 x 600 dpi): Single-Sided Scanning: 30 ipm Double-Sided Scanning: 50 ipm
    SEND SPECIFICATIONS
    DESTINATION Email/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax, IP Fax (Optional)
    ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed Dial (200)
    SEND RESOLUTION Push: Up to 600 x 600
    Pull: Up to 600 x 600
    COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB v3.0, WebDAV
    Email: SMTP, POP3
    FILE FORMAT TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
    FAX SPECIFICATIONS
    MAXIMUM NUMBER OF CONNECTION LINES 2
    MODEM SPEED Super G3: 33.6 Kbps
    G3: 14.4 Kbps
    COMPRESSION METHOD MH, MR, MMR, JBIG
    RESOLUTION 400x400 (Ultra Fine), 200x400 (Super Fine), 200x200 (Fine), 200x100 (Normal)
    SENDING / RECORDING SIZE Statement to Legal
    FAX MEMORY Up to 30,000 Pages (2,000 jobs)
    SPEED DIALS Max. 200
    GROUP DIALS / DESTINATIONS Max. 199 Dials
    SEQUENTIAL BROADCAST Max. 256 Addresses
    MEMORY BACKUP Yes
    STORE SPECIFICATIONS
    MAIL BOX SIMPLE (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX Inbox, 50 Confidential Fax In-boxes, Maximum 10,000 Pages (2,000 jobs) Stored
    ADVANCED BOX Communication Protocol: SMB or WebDAV
    Supported Client PC: Windows (Windows 8.1/10)
    Concurrent Connections (Max.)
    SMB: 64
    WebDAV: 3 (Active Sessions)
    ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB
    SECURITY SPECIFICATIONS
    AUTHENTICATION Standard: Universal Login Manager, uniFLOW Online Express,9 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in
    Optional: uniFLOW
    DATA Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control
    Optional: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
    NETWORK Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
    DOCUMENT Standard: Secure Watermarks, Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature
    Optional: User Signatures
    ENVIRONMENTAL SPECIFICATIONS
    OPERATING ENVIRONMENT Temperature: 50 to 86 ºF
    Humidity: 20 to 80% RH (Relative Humidity)
    POWER REQUIREMENTS 110-127V AC 60 Hz, 6.9 A
    PLUG (MAIN UNIT) NEMA 5-15P
    POWER CONSUMPTION Maximum: Approx. 1,500 W
    Standby: Approx. 38.9 W10
    Sleep Mode: Approx. 0.8 W or Less11
    Typical Electricity Consumption (TEC) Rating12 0.36 kWh
    STANDARDS ENERGY STAR® Certified
    Rated EPEAT® Gold
    CONSUMABLES
    TONER
    GPR-58 Toner
    TONER YIELD (ESTIMATED @ 5% COVERAGE)
    Black: 23,000 Images
    Color (C,M,Y): 18,000 Images
    FOOTNOTES
    1. Time from device power-on until copy ready (not print reservation).
    2. Time from exiting Sleep Mode to when printing is operational.
    3. Time from device power ON to when the copy icon appears and is enabled to operate on the touch panel display.
    4. Includes consumables.
    5. Requires the optional PCL International Font Set-A1.
    6. Requires the optional Barcode Printer Kit-D1.
    7. Other operating systems and environments, including AS/400, UNIX, Linux, and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your authorized sales representative.
    8. Multi-Sheet Feed Detector Supported.
    9. No charge for this solution; however, activation is required.
    10. Reference value (measured one unit).
    11. 0.8 W Sleep Mode not available in all circumstances due to certain settings.
    12. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
    This is to make Misc appear on the page when needed.
    Supplies
    GPR-58 Toner
    Color: Black
    Item Code: 2182C003AA
    Estimated Toner Yield: 23,000 Copies/Bottle (Estimated @ 5% Coverage)
    Color: Cyan
    Item Code: 2183C003AA
    Estimated Toner Yield: 18,000 Copies/Bottle (Estimated @ 5% Coverage)
    Color: Magenta
    Item Code: 2184C003AA
    Color: Yellow
    Item Code: 2185C003AA
    Accessories
    Hardware Accessories
    • Cassette Module-AE1
    • Cassette Feeding Unit-AJ1
    • Cassette Feeding Unit-AK1
    • Staple Finisher-Z1
    • Copy Card Reader-F1
    • Copy Card Reader Attachment-B5
    • Canon Card Set-A1 (1-30)
    • Canon Card Set-A2 (31-100)
    • Canon Card Set-A3 (101-200)
    • Canon Card Set-A4 (201-300)
    • Canon Card Set-A5 (301-500)
    • Canon Card Set-A6 (501-1000)
    • ADF Access Handle-A1
    • Copy Control Interface Kit-A1
    • Braille Label Kit-F1
    • USB Keyboard (Cherry)
    • Universal Keyboard Stand-A1
    • Card Reader Assembly for Universal Keyboard Stand
    • Convenience Stapler-A1 (White)
    System Connectivity Accessories
    • PCL International Font Set-A1
    • Barcode Printing Kit-D1
    • MEAP Web Connection Kit V5.6
    • Super G3 2nd Line Fax Board-AT1
    • IP FAX Expansion Kit-B1
    • HDD Data Erase Scheduler V3.1.3
    • HDD Data Erase Scheduler V3.1.3 NFR
    • iR-ADV Security Kit-AQ1 for IEEE 2600 Common Criteria Certification
    • Connection Kit-A2 for Bluetooth LE
    • NFC Kit-E1
    Click here to learn more about the imageRUNNER ADVANCE product line.
    Note: For additional details and descriptions for each accessory, please access the product configurator.
    Brochures
    Loading...
    Workflow Solutions
    Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE DX C357iF model is equipped to support the needs of mobile users based on varying company policies, types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
    Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE DX C357iF model offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This model is designed with Document Capture and Distribution in mind.
    The Output Management Solutions available for the Canon imageRUNNER ADVANCE DX C357iF model provide various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE DX C357iF Model is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
    Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE DX C357iF model, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The imageRUNNER ADVANCE DX C357iF Model can be a key business solution for information management and easier workflow.
    Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class Canon imageRUNNER ADVANCE DX C357iF model offers solid, fleet-based management tools to establish an integrated solution that can help reduce costs and minimize IT resources. These models are designed to help companies realize increased productivity and focus on day-to-day IT activities.
    Videos
    imageRUNNER ADVANCE DX Teaser Video
    imageRUNNER ADVANCE DX Features Video
    imageRUNNER ADVANCE Control Video
    Simplify, Control, and Evolve with imageRUNNER ADVANCE
     Return to Top
