Web Content Viewer
Actions
imageRUNNER ADVANCE DX C478iF
Multifunction Copiers
Solutions to help increase office efficiencies and productivity
Canon PRINT Business App
Features
  • 10.1" intuitive touchscreen with smartphone-like usability.
  • A unique, customized experience tailored to individual preferences using My ADVANCE.
  • Supports mobile solutions and integration with many popular cloud services like Google Drive.
  • Scan and convert documents to searchable digital files in a variety of file formats.
  • Integration with Canon and various third-party software with embedded application platform.
  • Hot Folders allow users to drag and drop a file into a hot folder, and automatically print with predefined settings such as number of copies and finishing requirements.
  • Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
  • Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
  • Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.
  • Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
  • Control aCess to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card aCess.
  • Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
  • Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
  • Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
  • imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
  • Designed for quick, easy deployment.
  • Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
  • Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
  • Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
  • Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
  • Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
  • Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
  • Upgrade to uniFLOW server or cloud-based solutions for full aCounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
  • A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
  • Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
  • ENERGY STAR® certified and rated EPEAT® Gold.
MAIN UNIT
TYPE Color Laser Multifunctional
CORE FUNCTIONS Print, Copy, Scan, Send, Store, Fax
PROCESSOR 1.75GHz Dual Core Processor
CONTROL PANEL 10.1" TFT LCD WSVGA Color Touch-panel
MEMORY 4.0 GB RAM
SOLID STATE DRIVE 256 GB
INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 (Host) x 2, USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND) Standard: 550-sheet Paper Cassette, 100-sheet Multi-Purpose Tray
Optional: 1,650-sheet Paper Cassette (Cassette Feeding Unit-AT1) 550-sheet Paper Cassette (Cassette Feeding Unit-AS-1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) Standard Model: 400 Sheets
Finisher Model: 900 Sheets (400 sheets: base tray, 400 sheets: upper tray, 100 sheets: lower tray)
FINISHING CAPABILITIES Standard: Collate, Group
Finisher: Collate, Group, Offset, Staple
SUPPORTED MEDIA TYPES Multi-Purpose Tray: Thin, Plain, Recycled, Heavy, Color, Bond, Envelope, Letterhead
Cassette: Thin, Plain, Recycled, Heavy, Color, Label, Bond, Letterhead
SUPPORTED MEDIA SIZES
Multi-Purpose Tray: Legal, Letter, Executive, Statement, Envelopes [No.10 (COM10), Monarch, DL, ISO-C5], Custom size: 3" x 5" to 8-1/2" x 14" (76.2 x 127.0 mm to 216.0 x 355.6 mm)
Cassette: Legal, Letter, Executive, Statement, Custom Size: 4" x 5-7/8" to 8-1/2" x 14" (101.6 x 148.0 mm to 216.0 x 355.6 mm)
SUPPORTED MEDIA WEIGHTS Cassettes: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2 )
Multi-Purpose Tray: 16 lb. Bond to 79 lb. Cover (60 to 216 g/m2 )
Duplex: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2 )
PRINT/COPY SPEED (BW AND COLOR) Up to 50 ppm (Letter), Up to 39 ppm (Legal)
WARM-UP TIME From Power On: Approx. 10 Seconds1
From Sleep Mode: Approx. 10 Seconds2
Quick Startup Mode: Approx. 4 Seconds3
DIMENSIONS (W x D x H) Standard Model: 20-1/2" x 25-1/4" x 26-3/8" (521 mm x 642 mm x 668 mm)
Finisher Model: 20-1/2" x 25-1/4" x 34" (521 mm x 642 mm x 864 mm)
INSTALLATION SPACE (W x D x H) 37-3/8" x 33-1/8" (950 mm x 840 mm)
(with Left Cartridge Door Open + Right Door Open + the Cassette Drawer Open)
WEIGHT4 Standard Model: Approx. 101.4 lb. (46 kg)
Finisher Model: Approx. 121.3 lb. (55 kg)
PRINT SPECIFICATIONS
PRINT RESOLUTION (dpi) 1200 x 600, 600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL6, Adobe® PostScript® 3™
DIRECT PRINT Available from USB, Advanced Box, Remote UI, and Web Access
SUPPORTED FILES PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft® , Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
FONTS PCL: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),5 Barcode Fonts6
PS: 136 Roman
OPERATING SYSTEM 7 UFRII/PS: Windows® 8.1/10/Server 2012/Server 2012 R2/Server 2016/Server 2019, Mac OS X(10.11 or later)
PCL: Windows® 8.1/10/Server 2012/Server 2012 R2/Server 2016/Server 2019
PPD: Windows® 8.1/10, Mac OS X(10.10 or later)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME Approx. 5.1/5.8 seconds or less
COPY RESOLUTION (dpi) 600 x 600
MULTIPLE COPIES Up to 9,999
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTION / ENLARGEMENT 25%, 50%, 64%, 78%, 100% (1:1), 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE Single-Pass Duplexing Automatic Document Feeder8
DOCUMENT FEEDER PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES Legal, Letter, Statement, Custom Size: 1-7/8" x 5" to 8-1/2" x 14" (48.0 mm x 128.0 mm to 216.0 mm x 355.6 mm), Business Card: 1-7/8" x 3-3/8" to 2-1/8" x 3-5/8" (48.0 mm x 85.0 mm to 55.0 mm x 91.0 mm)
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single-Sided Scanning: 13.3 to 34 lb. Bond (50 to 128 gsm) (BW); 17 to 34 lb. Bond (64 to 128 gsm) (CL)
Double-Sided Scanning: 13.3 to 34 lb. Bond (50 to 128 gsm) (BW); 17 to 34 lb. Bond (64 to 128 gsm) (CL)
Business Card: 21.3 lb. Bond to 80 lb. Cover (80 to 220 gsm)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book
PULL SCAN Color Network ScanGear2 for both Twain and WIA Supported OS: Windows® 8.1/10/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION (dpi) Scan for Copy: 600 x 600
Scan for Send: (Push) 600 x 600 (SMB/FTP/WebDAV/ IFAX), (Pull) 600 x 600
Scan for Fax: 600 x 600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to compatible mobile devices and certain cloud-based services depending on your requirements.
SCAN SPEED (LETTER) Send: Automatic Color Select "OFF" (300 x 300 dpi): Single-Sided Scanning: 100 ipm Double-Sided Scanning: 200 ipm Automatic Color Select "ON" (300 x 300 dpi): Single-Sided Scanning: 50 ipm Double-Sided Scanning:100 ipm
Copy: Scan Speed Priority (300 x 600 dpi): Single-Sided Scanning: 50 ipm Double-Sided Scanning: 100 ipm Image Quality Priority (600 x 600 dpi): Single-Sided Scanning: 30 ipm Double-Sided Scanning: 50 ipm
SEND SPECIFICATIONS
DESTINATION Standard: Email/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax
Optional: IP Fax
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION Push: Up to 600 x 600
Pull: Up to 600 x 600
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB v3.0, WebDAV
Email: SMTP, POP3
FILE FORMAT TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
FAX SPECIFICATIONS
MAXIMUM NUMBER OF CONNECTION LINES 1
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 (Ultra Fine), 200 x 400 (Super Fine), 200 x 200 (Fine), 200 x 100 (Normal)
SENDING / RECORDING SIZE Statement to Legal
FAX MEMORY Up to 30,000 Pages (2,000 jobs
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCAST Max. 256 Addresses
MEMORY BACKUP Yes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, Maximum 10,000 Pages (2,000 jobs) Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV
Supported Client PC:
Windows 8.1/10
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard: Universal Login Manager (Device and Function Level Log-in), uniFLOW Online Express,9 User Authentication, Department ID Authentication, Access Management System
Optional: uniFLOW
DATA Standard: Trusted Platform Module (TPM), SDD Password Lock, SDD Initialize, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control
Optional: Data Loss Prevention (Requires uniFLOW)
NETWORK Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT Standard: Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signatures, Secure Watermark
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86 ºF
Humidity: 20 to 80 % RH (Relative Humidity)
POWER REQUIREMENTS 110 V-127 V, 60 Hz, 8.4 A
PLUG NEMA 5-15P
POWER CONSUMPTION Maximum: Approx. 1,500 W
Standby: Approx. 49 W10
Sleep Mode: Approx. 1.0 W11
Typical Electricity Consumption (TEC) Rating:12 0.54 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold
CONSUMABLES
TONER CARTRIDGE
TONER T04 BK/C/M/Y13
TONER YIELD (ESTIMATED @ 5% COVERAGE)
TONER T04 BK: 33,000 Pages14
TONER T04 C/M/Y: 27,500 Pages14
FOOTNOTES
  1. Time from device power-on until copy ready (not print reservation).
  2. Time from exiting Sleep mode to when printing is operational.
  3. Time from device power-on to when copy jobs can be programmed.
  4. Includes consumables.
  5. Requires the optional PCL International Font Set-A1.
  6. Requires the optional Barcode Printer Kit-D1.
  7. Other operating systems and environments, including AS/400, UNIX, Linux, and Citrix, may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  8. Multi-Sheet Feed Detector Supported.
  9. No charge for this solution; however, activation is required.
  10. Reference value (measured one unit).
  11.  1.0 W Sleep mode not available in all circumstances due to certain settings.
  12. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
  13. Toner T04L also available for BK and Color (C, M, Y). Yield is BK 11,000 images and Color 9,000 images.
  14. Toner Cartridge yield in accordance with ISO/IEC 19798.
This is to make Misc appear on the page when needed.
Supplies
TONER T04
Color: Black
Item Code: 2980C001AA
Estimated Toner Yield: 33,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 2979C001AA
Estimated Toner Yield: 27,500 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 2978C001AA
Color: Yellow
Item Code: 2977C001AA
TONER T04L
Color: Black
Item Code: 4616C001AA
Color: Cyan
Item Code: 4615C001AA
Estimated Toner Yield: 9,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 4614C001AA
Color: Yellow
Item Code: 4613C001AA
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AS1
  • Cassette Feeding Unit-AT1
  • Cassette Module-AJ1
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-B5
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • USB Key Board (Cherry)
  • Convenience Stapler-A1
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
  • imageRUNNER ADVANCE DX Series Control Panel Protective Film (10 pack)
  • imageRUNNER ADVANCE DX Series Control Panel Protective Film (100 pack)
System Connectivity Accessories
  • IP FAX Expansion Kit-B1
  • MEAP Web Connection Kit V5.7
  • PCL International Font Set-A1
  • Barcode Printing Kit-D1
  • Connection Kit-A3 for Bluetooth LE
  • NFC Kit-E2
Click here to learn more about the imageRUNNER ADVANCE product line.
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Workflow Solutions
Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE DX C478iF is equipped to support the needs of mobile users based on varying company policies, types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE DX C478iF offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This model is designed with Document Capture and Distribution in mind.
The Output Management Solutions available for the Canon imageRUNNER ADVANCE DX C478iF provides various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE DX C478iF is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE DX C478iF, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The imageRUNNER ADVANCE DX C478iFZ can be a key business solution for information management and easier workflow.
Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class imageRUNNER ADVANCE DX C478iF offers solid, fleet-based management tools to establish an integrated solution that can help reduce costs and minimize IT resources. This model is designed to help companies realize increased productivity and focus on day-to-day IT activities.
Videos
imageRUNNER ADVANCE DX Teaser Video
imageRUNNER ADVANCE DX Features Video
Advance Scanning with Cloud Filing Assist and imageRUNNER ADVANCE DX
imageRUNNER ADVANCE Control Video
Simplify, Control, and Evolve with imageRUNNER ADVANCE
What’s New with uniFLOW Online 2021.2?
 Return to Top
