Web Content Viewer
Actions
imageRUNNER ADVANCE DX C5850i
Multifunction Copiers
Solutions to help increase office efficiencies and productivity
Canon PRINT Business App
Features
10.1" intuitive touchscreen with smartphone-like usability. A unique, customized experience tailored to individual preferences using My ADVANCE. Supports mobile solutions and integration with many popular cloud services like Google Drive. Scan and convert documents to searchable digital files in a variety of file formats. Integration with Canon and various third-party software with embedded application platform. Hot Folders allow users to drag and drop a file into a hot folder, and automatically print with predefined settings such as number of copies and finishing requirements.
Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance. Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers. Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications. Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices. Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources. Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile. Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement. imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
Designed for quick, easy deployment. Remote diagnostics and parts life management for proactive maintenance and rapid fixes. Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies. Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects. Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency. Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity. Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption. Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy. ENERGY STAR® certified and rated EPEAT® Gold.
MAIN UNIT
TYPE Color Laser Multifunctional
CORE FUNCTIONS Standard: Print, Copy, Scan, Send, Store
Optional: Fax
CONTROL PANEL 10.1" TFT LCD WSVGA Color Flat-panel
MEMORY 5.0 GB RAM
SOLID STATE DRIVE Standard: (SSD) 256 GB
Optional: (SSD) 256 GB, 1 TB
INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 (Host) x1, USB 3.0 (Host) x1, USB 2.0 (Device) x1
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 1,200 Sheets
Maximum: 6,350 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND) Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: Dual 550-Sheet Paper Cassettes (Cassette Feeding Unit-AM1), 2,450-Sheet High Capacity Paper Cassette (High Capacity Cassette Feeding Unit-C1), 2,700-Sheet Paper Deck (Paper Deck Unit-F1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) Standard: 250 Sheets Maximum: 3,450 Sheets (with Staple Finisher-AB1 or Booklet Finisher-AB1 and 3rd Copy Tray Kit-A1)
FINISHING CAPABILITIES Standard: Collate, Group With Options: Collate, Group, Offset, Staple, Saddle-Stitch, Hole Punch, Eco Staple, Staple On Demand
SUPPORTED MEDIA TYPES Multi-Purpose Tray: Thin, Plain, Recycled, Color, Heavy, Coated, Tracing, Bond, Transparency, Label, Pre-punched, Letterhead, Tab, Envelope
Paper Cassettes: Thin, Plain, Recycled, Color, Heavy, Bond, Transparency, Pre-punched, Letterhead, Envelope
SUPPORTED MEDIA SIZES
Upper Cassette: Letter, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 8-1/2")
Lower Cassette: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 12" x 18")
Multi-Purpose Tray: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 3-1/2" to 12-5/8" x 18"), Custom Size/ Free Size (3-7/8" x 5-1/2" to 12-5/8" x 18")
SUPPORTED MEDIA WEIGHTS Cassettes: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2 )
Stack Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2 )
Duplexing: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2 )
PRINT/COPY SPEED (BW AND COLOR) Up to 50 ppm (Letter); Up to 30 ppm (Letter-R); Up to 29 ppm (Legal); Up to 27 ppm (11" x 17")
WARM-UP TIME From Power On: Approx. 6 Seconds1
From Sleep Mode: Approx. 7 Seconds2
Quick Startup Mode: Approx. 4 Seconds3
DIMENSIONS (W x D x H) 24-3/8" x 28-1/2" x 36-7/8" (620 x 722 x 937 mm)4
INSTALLATION SPACE (W x D x H) Basic: 44-7/8" x 45-3/4" (1,138 x 1,162 mm) (Right Cover Open with Multi-purpose tray extended + Cassette Drawers Open)
Fully Configured: 73-1/2" x 45-3/4" (1,866 x 1,162 mm ) (Staple Finisher-AB1 or Booklet Finisher-AB1 with the extension tray extended + Paper Deck Unit-F1 + Cassette Drawers open)
WEIGHT5 Approx. 231.5 lb. (108 kg)
PRINT SPECIFICATIONS
PRINT RESOLUTION (dpi) 1200 x 1200
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL6, Adobe PS 3
SUPPORTED FILES PDF, TIFF, JPEG, EPS6, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft®, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
FONTS PCL: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),7 Barcode Fonts8
PS: 136 Roman
OPERATING SYSTEM 9 UFRII/PS: Windows® 7/8.1/10/Server2008/ Server2008 R2/Server2012/Server2012 R2/Server2016/Server2019, Mac OS X (10.11 or later)
PCL: Windows® 7/8.1/10/Server2008/ Server2008 R2/Server2012/Server2012 R2/Server2016/Server2019 PPD: Windows® 7/8.1/10, Mac OS X(10.10 or later)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME As fast as 3.3 seconds (BW)/ 4.9 seconds (Color)
COPY RESOLUTION (dpi) 600 x 600
MULTIPLE COPIES Up to 999
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTION / ENLARGEMENT 25%, 50%, 64%, 73%, 78%, 100% (1:1), 121%, 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE Single-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Up to 200 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom Size: 2-3/4" x 5-1/2" to 12" x 17"
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single-Sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 gsm) (BW, CL)
Double-Sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 gsm) (BW, CL)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects
PULL SCAN Color Network ScanGear for both Twain and WIA
Supported OS: Windows® 7/8.1/10/Server 2008/ Server 2008 R2/Server 2012/ Server 2012 R2/Server 2016
SCAN RESOLUTION (dpi) Scan for Copy: 600 x 600
Scan for Send: (Push) 600 x 600 (SMB/FTP/WebDAV/ IFAX), (Pull) 600 x 600
Scan for Fax: 600 x 600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to compatible mobile devices and certain cloud-based services depending on your requirements.
SCAN SPEED (LETTER) Single-sided Scanning: 135/135 (300 dpi), 80/80 (600 dpi)
Double-sided Scanning: 270/270 (300 dpi), 160/90 (600 dpi)
SEND SPECIFICATIONS
DESTINATION Standard: E-mail/Internet FAX (SMTP), SMB3.0, FTP, WebDAV, Mail Box
Optional: Super G3 FAX, IP Fax
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION Push: Up to 600 x 600
Pull: Up to 600 x 600
COMMUICATION PROTOCOL File: FTP(TCP/IP), SMB3.0 (TCP/IP), WebDAV
Email: SMTP, POP3
FILE FORMAT Standard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, User Signature, PDF A/1-b, Limited Color, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
FAX SPECIFICATIONS
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 Pages (2,000 jobs)
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCAST Max. 256 Addresses
MEMORY BACKUP Yes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, Maximum 10,000 Pages (2,000 jobs) Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB (Standard HDD)
Approx. 480 GB (With Optional 1 TB HDD)
SECURITY SPECIFICATIONS
AUTHENTICATION AND ACCESS CONTROL User Authentication (Picture Login, Picture and PIN Login, Card Login, Username and Password Login, Function Level Login, Mobile Login), Department ID Authentication (Department ID and PIN Login, Function Level Login), uniFLOW Online Express10 (PIN Login, Picture Login, Picture and PIN Login, Card Login, Card and PIN Login, Username and Password Login, Department ID and PIN Login, Function Level Login), Access Management System (Access Control)
DOCUMENT SECURITY Print Security (Secure Print, Encrypted Secure Print, Forced Hold Printing, uniFLOW Secure Print11), Receive Data Security (Confidential Fax Inbox Forwarding Received Documents Automatically), Scan Security (Encrypted PDF, Device Signature PDF/XPS, User Signature PDF/XPS, Adobe LiveCycle® Rights Management ES2.5 Integration), BOX Security (Mail Box Password Protected, Advanced Box Access Control), Send Data Security (Setting for requesting password input per transmission, Restricted E-mail/File send functions, Confirming FAX number, Allow/ Restrict Fax Driver Transmissions, Allow/Restrict Sending from History, S/MIME Support), Document Tracking (Secure Watermark)
NETWORK SECURITY TLS 1.3, IPSec, IEEE802.1X authentication, SNMP V3.0, Firewall Functionality (IP/MAC Address Filtering), Dual Network Support (Wired LAN/Wireless LAN, Wired LAN/ Wired LAN), Disabling Unused Functions (Enabling/ Disabling Protocols/Applications, Enabling/Disabling Remote UI, Enabling/Disabling USB Interface), G3 FAX separation from LAN, USB Port separation from LAN, Prohibit the execution of files stored in Advanced Box in the MFP, Scan and Send-Virus Concerns for E-mail Reception
DEVICE SECURITY Protecting SSD Data [SSD Data Encryption (FIPS140-2 Validated), SSD Lock], Standard SSD Initialize, Trusted Platform Module (TPM), Job Log Conceal Function, Protecting MFD Software Integrity, Checking MFD Software Integrity (Verify System at Startup, Runtime Intrusion Detection)
DEVICE MANAGEMENT AND AUDITING Administrator Password, Digital Certificate and Key Management, Audit Log, Cooperating with External Security Audit System (Security Information and Event Management), Image Data Logging, Security Policy Setting
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86º F
Humidity: 20 to 80% RH (Relative Humidity)
POWER REQUIREMENTS 110-127V, 60Hz, 12A
POWER CONSUMPTION Maximum: Approx. 1,800 W
Standby: Approx. 56.1 W12
Sleep Mode: Approx. 0.8 W13
Typical Electricity Consumption (TEC) Rating:14 0.57 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold
CONSUMABLES
TONER15
GPR-61 Toner BK/C/M/Y
GPR-61L Toner C/M/Y
TONER YIELD (ESTIMATED @ 5% COVERAGE)
GPR-61 Toner BK: 71,000 Pages
GPR-61 Toner C/M/Y: 60,000 Pages
GPR-61L Toner C/M/Y: 26,000 Pages
FOOTNOTES
  1. Time from device power-on, until copy ready (not print reservation).
  2. Time from exiting Sleep mode to when printing is operational.
  3. Time from device power-on to when the copy icon appears and is enabled to operate on the touch panel display.
  4. Includes main unit and either Cassette Feeding Unit-AQ1, High Capacity Cassette Feeding Unit-C1, or Cabinet Type-V.
  5. Includes main unit, consumables, and Cassette Feeding Unit-AQ1.
  6. EPS can be printed directly only from the Remote User Interface.
  7. Requires the optional PCL International Font Set-A1.
  8. Requires the optional Barcode Printer Kit-D1.
  9. Other operating systems and environments, including AS/400, UNIX, Linux, and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  10. No charge for this solution; however, activation is required.
  11. Requires uniFLOW Online/uniFLOW.
  12. Reference Value (measured one unit).
  13. 0.8 W Sleep mode not available in all circumstances due to certain settings.
  14. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
  15. GPR-61L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 26,000 images.
This is to make Misc appear on the page when needed.
Supplies
GPR-61 Toner
Color: Black
Item Code: 3763C003AA
Estimated Toner Yield: 71,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 3764C003AA
Estimated Toner Yield: 60,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 3765C003AA
Color: Yellow
Item Code: 3766C003AA
GPR-61L Toner
Color: Cyan
Item Code: 3767C003AA
Estimated Toner Yield: 26,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 3768C003AA
Color: Yellow
Item Code: 3769C003AA
Accessories
Hardware Accessories
  • High Capacity Cassette Feeding Unit-C1
  • Cassette Feeding Unit-AQ1
  • Cabinet Type-V
  • Paper Deck Unit-F1
  • Inner 2way Tray-M1
  • Inner Finisher-L1 (not supported with C5870i)
  • Inner 2/3 Hole Puncher-D1 (not supported with C5870i)
  • Staple Finisher-AB1
  • Booklet Finisher-AB1
  • Buffer Pass Unit-P1
  • 2/3 Hole Puncher Unit-A1
  • Tab Feeding Attachment-F1
  • Inner Tray (1st Copy Tray Kit-A1)
  • 3rd Copy Tray Kit-A1
  • Utility Tray-B1
  • Platen Cover-Y3
  • USB Keyboard (Cherry)
  • Copy Card Reader Attachment-B7
  • Copy Card Reader-F1
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-A1 (White)
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
  • Attachment Kit for Reader
  • imageRUNNER ADVANCE DX Series Control Panel Protective Film (10 pack)
  • imageRUNNER ADVANCE DX Series Control Panel Protective Film (100 pack)
System Connectivity Accessories
  • PCL International Font Set-A1
  • Barcode Printing Kit-D1
  • MEAP Web Connection Kit V5.7
  • Super G3 FAX Board-AX1
  • Super G3 2nd Line Fax Board-AX1
  • Super G3 3rd/4th Line Fax Board-AX1
  • IP FAX Expansion Kit-B1
  • Remote FAX Kit-A1
  • Memory Mirroring Kit
  • HDD Data Erase Scheduler V3.1.3
  • HDD Data Erase Scheduler V3.1.3 NFR
  • 250GB SSD-A1
  • 1TB SSD-A1
  • Numeric Keypad-A2
  • IC Card Reader Box for Numeric Keypad-A1
  • Voice Guidance Kit-G1
  • Voice Operation Kit-D1
  • Connection Kit-A3 for Bluetooth LE
  • NFC Kit-E2
System Connectivity Accessories - imagePASS
  • imagePASS-R1
  • Hot Folders License
  • Fiery with Adobe PDF Print Engine KIT
  • Fiery Compose
  • Fiery Impose
  • Fiery Impose and Compose
  • X-Rite i1 (for imagePASS-P2)
  • i1 Publish (i1 Profiler) Software
  • Fiery Color Profiler Suite
  • Fiery Color Profiler Suite Annual Maintenance
  • Fiery ColorRight Package 1year term license
  • Fiery ColorRight Package 3year term license
  • Fiery ColorRight Package 5year term license
  • Fiery Automation Package 1year term license
  • Fiery Automation Package 3year term license
  • Fiery Automation Package 5year term license
Click here to learn more about the imageRUNNER ADVANCE product line.
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Workflow Solutions
Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE DX C5850i model is equipped to support the needs of mobile users based on varying company policies, types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE DX C5850i model offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This series is designed with Document Capture and Distribution in mind.
The Output Management Solutions available for the Canon imageRUNNER ADVANCE DX C5850i model provide various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE DX C5850i model is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE DX C5850i model, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The imageRUNNER ADVANCE DX C5850i model can be a key business solution for information management and easier workflow.
Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class imageRUNNER ADVANCE DX C5850i model offers solid, fleet-based management tools to establish an integrated solution that can help reduce costs and minimize IT resources. These models are designed to help companies realize increased productivity and focus on day-to-day IT activities.
Videos
imageRUNNER ADVANCE DX Teaser Video
imageRUNNER ADVANCE DX Features Video
Advance Scanning with Cloud Filing Assist and imageRUNNER ADVANCE DX
imageRUNNER ADVANCE Control Video
Simplify, Control, and Evolve with imageRUNNER ADVANCE
 Return to Top
