Web Content Viewer
DISCLAIMER
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
imageRUNNER ADVANCE 6075
With outstanding speed and efficiency, the imageRUNNER ADVANCE 6075 model meets the needs of large corporate offices and workgroups that demand robust performance. Engineered for high-volume traffic, this digital monochrome model rapidly scans, prints, copy, fax and distribute documents with precision and ease. Advanced management tools and multiple in-line finishing options help produce professional documents with ease. The imageRUNNER ADVANCE 6075 model features a range of collaboration tools, streamlined one-step operations for complicated tasks, and the power to perform multiple jobs concurrently. The imageRUNNER ADVANCE 6075 model delivers output speeds of up to 75 ppm in black-and-white, single pass duplex scanning at speeds of up to 200 ipm (duplex, 300dpi, black-and-white). Offering standard Color Universal Send, UFR II Printing, and a range of paper handling and finishing options, with the imageRUNNER ADVANCE 6075 model, there's a dramatically better way to work.
Specifications
Model Name
Type
Digital Multifunction Imaging System Functions
Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up to 4 Lines)Operation Panel
Standard: 8.4 SVGA Full-Color, TFT Screen
Optional: 10.4 SVGA Full-Color, TFT Upright Screen
Image Server Memory
Standard: 1.5GB RAM
Maximum: 2GB RAM Hard Disk Drive
Standard: 80GB
Maximum: 250GBMirroring Hard Disk Drive
Mirroring Hard Disk Drive Optional (80GB, 250GB), Method: RAID1Network Interface Connection
Standard: 10/100/1000Base-TX
Optional: Wireless LAN (IEEE 802.1x)Other Interface
Standard: USB 2.0 (Host)x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host)x2], Serial Interface, Copy Control Interface
Standard: 80GB
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Maximum Pages Stored: 6,000Advanced Box
Available Disk Space: Approximately 10GB (Standard HDD), 113GB (250GB HDD)
Communication Protocol: SMB† or WebDAV
Supported Client PC: Windows (Windows 2000/XP/7 Windows Vista)
Maximum Number of Concurrent Connections: SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
Memory Media
Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive
Memory Media
Scanning Resolution
Up to 600 dpi x 600 dpi**Network TWAIN Scan Standard
Network Scan Utility Color Network ScanGear
Letter
Up to 75 ppm
Ledger
Up to 37 ppm
First Copy Time
3.1 Seconds or Less
Multiple Copies
1 to 9,999Copy Exposure Automatic or Manual (9 Levels)
Magnification
From Platen Glass: 25% - 400% (1% Increments)
From ADF: 25% - 200% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
(Glass) Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Maximum Original Size
Up to 11 x 17
Standard Paper Capacity
(20 lb. Bond) Dual 1,500-sheet Drawers
Dual 550-sheet Cassettes
100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck-A1 or 3,500-sheet Paper Deck-D1
Maximum Paper Capacity
7,700 Sheets (with optional Paper Deck)Output Paper Capacity (20 lb. Bond)
250 Sheets (with Copy Tray)
4,000 Sheets (with Staple Finisher or Booklet Finisher)
Output Sizes
Cassette
Output Sizes: 14 lb. Bond to 80 lb. Cover
Bypass
Output Sizes: 14 lb. Bond to 140 lb. Index
Acceptable Paper Weights
Cassette
Acceptable Paper Weights:11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size
Drawers: Letter
Drawers: Letter
Bypass
Duplexing
Paper Size: Standard Automatic Trayless Duplexing (Up to 11 x 17)
Paper Weight: 14 lb. Bond to 80 lb. Cover Special Media Support
Cassettes: Tab
Bypass: Transparency, Tracing, Labels
Cassettes: Tab
Warm Up Time
From Power On: 38 Seconds or Less
From Sleep Mode: 30 Seconds or Less
From Energy Saver Mode: Approximately 20 Seconds
Power Requirements
120-127V AC 60Hz, 16A
Plug: NEMA 5-20P
Power Consumption:
Maximum: 2.0kW or Less
Sleep Mode: 1W or Less
Energy Saver Mode: 158Wh or Less (-50% is selected)
Plug: NEMA 5-20P
Power Consumption:
Dimension
48 x 25-3/8 x 30-3/8
Installation Space (W x D): 53-5/8 x 30-3/8 (1362mm x 770mm) (When Booklet Finisher is attached, and Stack Bypass and Auxiliary Tray are extended)
Weight
Approximately 522.5 lb.
Estimated Toner Yield
56,000 Images @ 6% Coverage Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-Sided, Density/Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying Special Copy Features Two-page Separation, Booklet, Job Build, N on 1, Add Cover, Sheet Insertion, Different Size Originals, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Block, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Favorites Setting, Previous Settings, Secure Watermark (Optional)Security Features
Standard
Department ID Management, Single Sign-On-H,Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, Adobe® LiveCycle® Rights Management ES Integration
Optional
Removable HDD, HDD Erase, HDD Encryption/Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, IPSec, Secure Watermark
Environmental Information ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Angel WEEE Directive
Standard
Optional
Feeders
Description
Document Feeder
Paper Size: 11 x 17, Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weight: Originals: 13 lb. Bond to 80 lb. Cover
Color Originals: 17 lb. Bond to 80 lb. Cover
Scanning Speed
(BW/Color; Letter): Simplex: 120/85 ipm (300 dpi), 120/51 ipm (600 dpi)**
Duplex: 200/100 ipm (300 dpi), 120/51 ipm (600 dpi)**
Scan Method Single-Pass Duplexing Automatic Document Feeder
Capacity
300 Sheets
Paper Supply Options
Description
Paper Deck Unit-A1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched
Power Source
From Main Unit
Power Consumption Approximately 39W (Maximum)
Dimensions
22-1/2 x 12-3/4 x 23
Weight
Approximately 81.6 lb.
Description
Paper Deck Unit-D1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-punched
Power Source
From Main Unit
Dimensions
22-1/2 x 23-5/8 x 24-1/2
Weight
Approximately 125.7 lb.
Description
Copy Tray-Q1
Paper Capacity
250 Sheets (20 lb. Bond)
Paper Sizes
11x17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size
Paper Weights
Dimensions
6-7/8 x 16-1/2 x 15
Weight
Approximately 2.4 lb.
Output Options
Finishers Output Trays
Description
Staple Finisher-E1
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated††
Paper Size
Number Of Trays
3
Total Output Capacity 4,000 Sheets (Letter, Statement-R, Executive)
Top Tray
250 Sheets (Letter, Statement-R, Executive)
125 Sheets (11 x 17, Legal, Letter-R)
Middle Tray
1,300 Sheets (Letter, Statement-R, Executive)
650 Sheets (11 x 17, Legal, Letter-R)
Lower Tray
2,450 Sheets (Letter)
1,700 Sheets (Statement-R, Executive)
Staple Capacity
(Maximum): 50 Sheets (Letter, Executive)
30 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Corner/Double Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Paper Capacity of Staple Mode:
Tray B/C: 1,300 Sheets/100 Sets (Letter, Executive)
650 Sheets/50 Sets (11 x 17, Legal, Letter-R)
Type of Staple: Staple-J1 (5,000 x 3)
Power Source
From Main Unit
Power Consumption: Approximately 108W (Maximum)
Dimensions
44-1/8 x 25-5/8
Weight
Approximately 106 lb.
Description
Booklet Finisher-E1
Paper Weights
Paper Size
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing,Labels, Tab, Bond, Letterhead, Coated††
Number Of Trays
3
Total Output Capacity: 4,000 Sheets (Letter, Statement-R, Executive)
Top Tray
Middle Tray
Lower Tray
Staple Capacity
30 Sheets 11 x 17, Legal, Letter-R
Staple Positions
Saddle-stitch: 11 x 17, Legal, Letter-R
Maximum Saddle-Stitch Capacity: 16 Sheets
Paper Capacity of Staple Mode: Tray B/C: 1,300 Sheets/100 Sets (Letter, Executive)
Paper Capacity of Saddle-Stitch Mode:1 to 5 Sheets/25 Sets
6 to 10 Sheets/15 Sets
11 to 16 Sheets/10 Sets
Type of Staple:Staple-J1 (5,000 x 3)
Staple Cartridge-D1 (2,000 x 3)
Power Source
From Main Unit
Power Consumption Approximately 112W (Maximum)
Dimensions
44-1/8 x 25-5/8x 25-7/8
Weight
Approximately 155 lb. External 2/3-Hole Puncher-A1Δ
Acceptable Punch Paper Weight: 14 lb. Bond to 140 lb. Index
Acceptable Punch Paper Type: Thin, Plain, Heavy, Color, Recycled, Tab, Coated††
Acceptable Punch Paper Size: 11 x 17, Legal, Letter, Letter-R
Punch Type: 2 Holes: Legal, Letter-R
3 Holes: 11 x 17, Letter
Distance Between Punch Holes: 2 Holes: 2-3/4 (70mm)
3 Holes: 4-1/4 (108mm)
Punch Waste Tray Capacity: Approximately 10,000 Sheets (20 lb. Bond)
Power Source: From Finisher
Power Consumption: Approximately 25W (Maximum)
Dimensions (H x W x D): 32-7/8 x 4-1/4 x 24-1/4
Weight: Approximately 17 lb.
Document Inserters
Description
Document Insertion Unit-L1Δ
Paper Weight
16 lb. Bond to 140 lb. Index
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated††
Paper Sizes
Feeder Capacity
100 Sheets
Number of Trays: 1
Acceptable Media: Covers and Inserts
Requirements: 100-240V/5.0A 50/60Hz
Power Consumption: Approximately 84W (Maximum)
Plug: NEMA 5-15P
Dimensions (H x W x D): 48-7/8 x 26-1/8 x 26-3/4
Weight: Approximately 88.2 lb.
Number of Trays: 1
Plug: NEMA 5-15P
Description
Document Insertion/Folding Unit-H1ΔΔ
Paper Weight
Insertion: 16 lb. Bond to 140 lb. Index
Folding: 16 lb. Bond to 28 lb. Bond
Acceptable Paper Type: Insertion: Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated††
Folding: Thin, Plain, Color, Recycled
Paper Sizes
Z-Fold: 11 x 17, Legal, Letter-R
C-Fold: Letter-R
Insertion: 11 x 17, Legal, Letter, Letter-R, Executive
Folding Method: Roller Pressure Folding
Folding Type: Z-Fold, C-Fold
Power Requirements: 100-240V AC/5.0A, 50/60Hz
Power Consumption: Approximately 139W (Maximum)
Weight: Approximately 168 lb.
C-Fold: Letter-R
Fax Board
Description
Fax Specifications
Applicable Line
4
Modem Speed
Super G3: 33.6 Kbps
G3: 14.4 Kbps
G3: 14.4 Kbps
Data Compression
MH, MR, MMR, JBIG
Resolution (dpi) 400 x 400, 200 x 400, 200 x 200, 200 x 100
Sending/Recording Size Statement to 11 x 17
Fax Features Job Forwarding, Different-Size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-Sided Original, Book to Two pages
Print Board
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
1.5GB RAM
Maximum Memory
2GB RAM
Hard Disk
Standard: 80GB
Maximum: 250GBEngine Resolution 1200 x 1200 dpi
PDL Support
Standard: UFR II
Optional: PCL 5e, PCL 6, Adobe PostScript 3
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista®), Citrix MetaFrame, Macintosh® (OS X 10.3.9 or Later, Including 10.6.1)
PCL 5e/6: Windows (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista), Citrix MetaFrame
Adobe PS 3: Windows (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista), Citrix MetaFrame, Macintosh (OS X 10.3.9 or Later, Including 10.6.1)
XPS: Windows Vista Direct Print Support
Standard: TIFF, JPEG, EPS***
Optional: PDF, XPS***Print Features Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Save, Poster Printing
Description
imagePASS-U1
Processor
Intel® Core™ Duo T2500 2.0GHz
Type: External
System: System 8 Release 2
Type: External
Standard Memory
2GB
Maximum Memory
2GB
Hard Disk
80GB
Media Type: DVD-RW Drive
PDL Support
Adobe PostScript 3/PCL 5e/6
Interface Connections
10/100/1000Base-T (RJ-45)
Print Resolution: 1200 x 1200 dpi
2400 dpi Equivalent x 600 dpi
Adobe PS 3: Windows (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista), Macintosh (OS X 10.3.9 or later)
PCL 5e/6: Windows (Windows 2000/XP/7/Server 2003/Windows Vista)
Utility Software: Remote Scan 5.3, Command WorkStation® for Windows, Command WorkStation for Mac, WebTools
Other Features
(Standard): Hot Folders, Virtual Printers
EFI Options:SeeQuence Suite SeeQuence Impose SeeQuence Compose Removable Hard Disk Drive Integrated Interface and Stand (19 display, keyboard, mouse, and furniture stand)
Send Expansion Sets
Description
Universal Send Specifications
Sending Method
E-Mail, I-Fax, SMB, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional)
Color Mode Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
Scan Resolution (dpi)** 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
Address Book Capacity
Maximum 1,800 Destinations (Including 200 One-Touch Buttons)
Communication Protocol File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
File Format
Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/A-1b, XPS, XPS (Compact)
Optional: PDF (Trace & Smooth), PDF/XPS (OCR), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions)
I-Fax Data Format
BW: TIFF (MH, MR, MMR)
Color: TIFF (Profile-C)
Universal Send Features
Two-sided Original, Different Size Originals, Original Type Selection, Book to Two Pages, Density/Exposure Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority Other Optional Accessories Utility Tray-A1 Upright Control Panel-B1 USB Keyboard Card Reader-C1ΔΔ Copy Card Reader Attachment Kit-A2 Braille Label Kit-F1 ADF Access Handle-A1 Copy Control Interface Kit-A1 Convenience Stapler-B1 PCL Printer Kit-AJ1 PS Printer Kit-AJ1 Direct Print Kit (for PDF/XPS)-H1 Encrypted Secure Print-D1 Barcode Printing Kit-D1ΔΔΔ Web Access Software-H1∂ imageRUNNER ADVANCE Essentials Universal Send Advanced Feature Set-E1 Universal Send Security Feature Set-D1 Universal Send Digital User Signature Kit-C1 Authorized Send∂∂ Super G3 Fax Board-AF1 Super G3 2nd Line Fax Board-AF1∂∂∂ Super G3 3rd/4th Line Fax Board-AE1〉 Remote Fax Kit-A1♦ Secure Watermark-B1 Wireless LAN Board-B1♦ USB Device Port-A1 Multimedia Reader/Writer-A1♦♦♦ Additional Memory Type B (512MB)◊ Document Scan Lock Kit-A2 Data Erase Kit-C1 HDD Data Encryption and Mirroring Kit-C2 Removable HDD Kit-AD1 2.5-inch/80GB HDD-C1 2.5-inch/250GB HDD-D1 IP Sec Board-B2♦♦ Expansion Bus-F1 Voice Guidance Kit-F1 Remote Operator's Software Kit-B1 eCopy Suite imageWARE Suite * Includes ADF and consumables.
** Standard color scan support is up to 300 dpi. Up to 600-dpi scanning requires Additional Memory Type B (512MB).
*** EPS and XPS cannot be printed directly from the Memory Media or Advanced Box.
† Browsing Advanced Box using SMB is not supported when imagePASS-U1 is attached.
†† Coated paper can only be loaded through the Document Insertion Unit-L1 or Document Insertion/Folding Unit-H1.
††† When the Auxiliary Tray is extended.
Δ Requires Staple Finisher-E1 or Booklet Finisher-E1.
ΔΔ Requires the Copy Card Reader Attachment Kit-A1.
ΔΔΔ Requires PCL Printer Kit-AJ1.
∂ Requires PS Printer Kit-AJ1 or Direct Print Kit (for PDF/XPS)-H1 when printing PDF files.
∂∂ Check with your Authorized Canon Dealer for availability.
∂∂∂ Requires Super G3 Fax Board-AF1.
〉 Requires Super G3 Fax Board-AF1 and Super G3 2nd Line Fax Board-AF1.
♦ Cannot be installed with Super G3 Fax Board-AF1.
♦♦ Requires Expansion Bus-F1.
♦♦♦ Requires USB Device Port-A1.
◊ Required for 600-dpi color scanning.
I-Fax Data Format
Awards
2011 BLI Performance Certified Seal
BLI 2011 Highly Recommended
BLI 2011 Reliability Seal
BLI 2011 Pick of the Year Award
#1 Ease of Use Monochrome MFP Customer Survey
#1 Best Monochrome MFP's Customer Survey
Brochures
Loading...
Complementary Content
- ${title}${badge}
${loading}
