Web Content Viewer
Actions
imageRUNNER ADVANCE 8105
Support - Black & White Multifunction
Specifications
Model Name
Type
Digital Multifunction Imaging System
Functions: Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PS® 3™)
Operation Panel: 10.4 SVGA Full-Color, TFT Upright Screen
Image Server Memory
Standard: 1.5GB RAM
Maximum: 2GB RAM
Hard Disk Drive Standard: 80GB
Maximum: 250GB
Mirroring Hard Disk Drive Optional (80GB, 250GB), Method: RAID1
Network Interface Connection
Standard: 10/100/1000Base-TX
Optional: Wireless LAN (IEEE 802.1x)
Other Interface
Standard: USB 2.0 (Host)x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host)x2], Serial Interface, Copy Control Interface
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Maximum Pages Stored: 6,000Advanced Box
Available Disk Space: Approximately 10GB (Standard HDD), 113GB (250GB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 2000/XP/7/Windows Vista)
Max. Number of Concurrent Connections: SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
Scanning Resolution
Up to 600 x 600 dpi†
Network TWAIN Scan Standard
Network Scan Utility Color Network ScanGear
Letter
Up to 105 ppm
Ledger
Up to 53 ppm
First Copy Time
(Letter): 2.7 Seconds or Less
Multiple Copies
1 to 9,999
Copy Exposure Automatic or Manual (9 Levels)
Magnification
From Platen Glass: 25% - 400% (1% Increments)
From ADF: 25% - 200% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%Basic Copy Features
Preset R/E Ratios by Area, Finishing, Two-Sided, Density/Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying Special Copy Features
Two-page Separation, Booklet, Job Build, N on 1, Add Cover, Sheet Insertion, Different Size Originals, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Block, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Favorites Setting, Previous Settings, Secure Watermark (Optional)
Acceptable Originals
(Glass): Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Maximum Original Size
Up to 11 x 17
Standard Paper Capacity
(20 lb. Bond): Dual 1,500-sheet Drawers
Dual 550-sheet Cassettes
100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck-C1 or 3,500-sheet POD Deck Lite-A1
Maximum Paper Capacity
7,700 Sheets (with optional Paper Deck)
Output Paper Capacity (20 lb. Bond) 4,250 Sheets (with Staple Finisher or Booklet Finisher)
Output Sizes
Cassette
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size
Drawers: Letter
Bypass
Acceptable Paper Weights
Cassette
14 lb. Bond to 80 lb. Cover
Bypass
14 lb. Bond to 140 lb. Index
Special Media Support Cassettes: Tab
Bypass: Transparency, Tracing, Labels
Duplexing
Paper Size: Standard Automatic Trayless Duplexing (Up to 13 x 19)
Paper Weight: 14 lb. Bond to 80 lb. Cover
Warm Up Time
From Power On: 1 Minute or Less
From Sleep Mode: 1 Minute or Less
From Energy Saver Mode: Approximately 20 Seconds
Power Requirements
120-127V AC, 60Hz, 16A
Plug NEMA 5-20P
Power Consumption Maximum: 2.0kW or Less
Sleep Mode: 1W or Less
From Energy Saver Mode: 171Wh or Less (-50% is selected)
Dimension
49-1/4* x 53-3/8** x 30-3/8
Installation Space (W x D) 93-3/4** x 30-3/8 (When Booklet Finisher is attached, and Stack Bypass and Auxiliary Tray are extended)
Weight
Approximately 534 lb.***
Estimated Toner Yield
70,000 Images @ 6% Coverage Memory Media Standard: USB Memory
Optional: SD, SDHC, Compact Flash, Memory Stick, Microdrive Security Features
Standard Department ID Management, Single Sign-On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, Adobe® LiveCycle® Rights Management ES Integration
Optional Removable HDD, HDD Erase, HDD Encryption/Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, IPSec, Secure Watermark Environmental Information ENERGY STAR® Qualified RoHS Compliant WEEE Directive Ecomark
Feeders
Description
Document Feeder
Paper Size: 11 x 17, Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weight: BW Originals: 13 lb. Bond to 80 lb. Cover
Color Originals: 17 lb. Bond to 80 lb. Cover
Scanning Speed
Simplex:120/85 ipm (300 dpi)
120/51 ipm (600 dpi)†
Duplex:200/100 ipm (300 dpi)
Scan Method Single-Pass Duplexing Automatic Document Feeder
Capacity
(20 lb. Bond): 300 Sheets
Paper Supply Options
Description
Paper Deck Unit-C1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched
Power Source
From Main Unit
Power Consumption Approximately 39W (Maximum)
Dimensions
22-1/2 x 12-3/4 x 23
Weight
Approximately 81.6 lb.
Description
POD Deck Lite-A1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-punched, Transparency, Labels, Bond, Letterhead
Power Source
120-127V AC, 60Hz, 5A
Power Consumption Approximately 288W (Maximum)
Plug Approximately 288W (Maximum)
Dimensions
22-1/2 x 23-5/8 x 24-1/2
Weight
Approximately 110 lb.
Output Options
Finishers Output Trays
Description
Staple Finisher-D1
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated†††
Paper Size
Number Of Trays
3
Total Output Capacity: 4,250 Sheets (Letter, Statement-R, Executive)
Top Tray
1,500 Sheets (Letter, Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Middle Tray
250 Sheets (Letter, Statement-R, Executive) 125 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Lower Tray
2,500 Sheets (Letter), 1,250 Sheets (Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Staple Capacity
(Maximum): 100 Sheets (Letter, Executive)
50 Sheets 50 Sheets
Staple Positions
Corner/Double Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Paper Capacity of Staple Mode: Tray A/C: 1,500 Sheets/100 Sets (Letter, Executive)750 Sheets/50 Sets (11 x 17, Legal, Letter-R)
Type of Staple:Staple-G1 (5,000 x 3) for 100 Sheets Staple
Staple-H1 (5,000 x 3) for 50
Sheets Staple
Power Source
100-240V, 50/60Hz, 2.8A
Power Consumption: Approximately 185W (Maximum)
Plug: NEMA 5-15P
Dimensions
41 x 25-3/4 (30-3/4Δ) x 30-1/8
Weight
Approximately 134 lb.
Description
Booklet Finisher-D1
Paper Weights
Paper Size
Number Of Trays
3
Top Tray
Middle Tray
Lower Tray
2,500 Sheets (Letter, Statement-R, Executive), 1,250 Sheets (Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Staple Capacity
50 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Saddle-Stitch: 13 x 19, 12 x 18, 11 x 17, Legal, Letter-R, Custom Size
Maximum Saddle-Stitch Capacity: 20 Sheets (20 lb. Bond including one cover page up to 140 lb. Index)
Paper Capacity of Staple Mode: Tray A/C: 1,500 Sheets/100 Sets (Letter, Executive) 750 Sheets/50 Sets (11 x 17, Legal, Letter-R)
Paper Capacity of Saddle-Stitch Mode: 1 to 5 Sheets/25 Sets, 6 to 10 Sheets/15 Sets, 11 to 16 Sheets/10 Sets, 17 to 20 Sheets/5 Sets
Type of Staple: Staple-G1 (5,000 x 3) for 100 Sheets Staple
Staple-H1 (5,000 x 3) for 50 Sheets Staple
Staple-P1 (5,000 x 2) for Saddle-Stitch Booklet
Power Source
Power Consumption: Approximately 224W (Maximum)
Plug: NEMA 5-15P
Dimensions
41 x 30-1/4 (35-1/4Δ) x 30-1/8
Weight
Approximately 238 lb. Puncher Unit-BF1&Delta'Δ
Acceptable Punch Paper Weight: 14 lb. Bond to 140 lb. Index
Acceptable Punch Paper Type: Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated†††
Acceptable Punch Paper Size: 11 x 17, Legal, Letter, Letter-R
Punch Type: 2 Holes: (Legal, Letter-R)
3 Holes: (11 x 17, Letter)
Distance Between Punch Holes: 2 Holes: 2-3/4 (70mm)
3 Holes: 4-1/4 (108mm)
Punch Waste Tray Capacity: Approximately 5,000 Sheets (20 lb. Bond)
Power Source: From Finisher
Power Consumption: Approximately 56W (Maximum)
Dimensions (H x W x D): Inside the Finisher (15-1/2 x 3-3/4 x 15-1/2)
Weight: Approximately 8.2 lb.
Booklet Trimmers
Description
Inner Booklet Trimmer-A1ΔΔΔ
Sheet Capacity
30 Booklets
Trimming Method: Face Trim Trim Thickness: 40 Sheets (2mm to 20mm Trimming Width)
Waste Tray Capacity: 1,500 Sheets of Trimmed Strips
Acceptable Paper Weight: 16 lb. Bond to 140 lb. Index
Acceptable Paper Type: Thin, Plain, Heavy, Recycled, Color, Coated†††
Power Consumption: Approximately 51W (Maximum) (When in operation)
Dimensions (H x W x D): Inside the Finisher (15-7/8 x 9-7/8 x 24-5/8)
Weight: Approximately 70.5 lb. Professional Puncher-C1 (with Integration Unit⟩)
Acceptable Punch Paper Weight: Letter (3-hole, 5-hole, Velo Bind 11-hole, Plastic Comb 19-hole, Twin Loop 21-hole/32-hole, Color Coil 44-hole): 20 lb. Bond to 80 lb. Cover, Letter (ProClick 32-hole): 20 lb. Bond to 65 lb. Cover
Acceptable Punch Paper Type: Plain, Heavy, Color, Recycled, Tab, Coated†††
Acceptable Punch Paper Size: Letter
Punch Pattern Die Sets (Optional): Plastic Comb (19-hole), Twin Loop (21/32-hole), Color Coil (44-hole), Velo Bind (11-hole), Loose Leaf (3/5-hole),ProClick (32-hole)
Punch Waste Tray Capacity: Approximately 25,000 Sheets or more of 20 lb. Bond with 4 holes punched
Power Requirement: 120-127V/5.5A-60Hz (Maximum)
Power Consumption: Professional Puncher-C1: Approximately 300W (Maximum)
Integration Unit: Approximately 130W (Maximum)
Plug: NEMA 5-15P
Dimensions (H x W x D): Professional Puncher-C1: 41 x 12 x 31-1/4
Integration Unit: 41 x 9-7/8 x 31-1/4
Weight: Professional Puncher-C1: Approximately 176 lb.
Integration Unit: Approximately 88.2 lb.
Document Inserters
Description
Document Insertion Unit-K1⟩
Paper Weight
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-punched, Tab, Bond, Letterhead, Coated†††
Paper Sizes
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Custom Size
Feeder Capacity
Upper Tray: 200 Sheets
Lower Tray: 200 Sheets
Number of Trays: 2
Acceptable Media: Covers and Inserts
Power Requirements: 100-240V/1A, 50/60Hz
Plug: NEMA 5-15P
Power Consumption: 104W (Maximum)
Dimensions (H x W x D): 55-3/8 x 29-3/8 x 31-1/4
Weight: Approximately 134 lb.
Paper Folding
Description
Paper Folding Unit-H1⟩
Paper Weight
14 lb. Bond to 28 lb. Bond
Acceptable Paper Type: Thin, Plain, Color, Recycled, Bond, Coated†††
Folding Method: Roller Pressure Folding
Paper Sizes
Accordion Z-Fold, C-Fold, Half-Fold: Letter-R
Z-Fold: 11 x 17, Legal, Letter-R
Fold Type
Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold
Power Requirements: From Finisher
Power Consumption: 140W (Maximum)
Dimensions (H x W x D): 46-7/8 x 13-1/4 x 31-1/4
Weight: Approximately 157 lb.
Print Board
Description
Canon Dual Custom Processor (Shared)
Standard Memory
1.5GB RAM
Maximum Memory
2GB RAM
Hard Disk
Standard: 80GB
Maximum: 250GB
Engine Resolution 1200 x 1200 dpi
PDL Support
Standard: UFR II
Optional: PCL 5e, PCL 6, Adobe PostScript 3
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista®), Citrix MetaFrame, Macintosh® (OS X 10.3.9 or Later, Including 10.6.1)
PCL 5e/6: Windows (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista), Citrix MetaFrame
Adobe PS 3: Windows (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista), Citrix MetaFrame, Macintosh (OS X 10.3.9 or Later, Including 10.6.1)
XPS: Windows Vista
Direct Print Support Standard: TIFF, JPEG, EPS††
Optional: PDF, XPS††
Other Features
Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Save, Poster Printing
Description
imagePASS-U1
Processor
Intel® Core™ Duo T2500 2.0GHz
System: System 8 Release 2
Standard Memory
2GB
Maximum Memory
2GB
Hard Disk
80GB
Media Type: DVD-RW Drive
PDL Support
Adobe PS 3/PCL 5e/PCL 6
Print Resolution: 1200 x 1200 dpi
2400 dpi Equivalent x 600 dpi
Interface Connections
10/100/1000Base-T (RJ-45)
Adobe PS 3: Windows (Windows 2000/XP/7/Server 2003/Server 2008/Windows Vista), Macintosh® (OS X 10.3.9 or later)
PCL 5e/6: Windows (2000/XP/7/ Server 2003/Windows Vista)
Utility Software: Remote Scan 5.3, Command Workstation® for Windows, Command Workstation for Mac, WebTools
Other Features
(Standard): Hot Folders, Virtual Printers
EFI Options:SeeQuence Suite SeeQuence Impose SeeQuence Compose Removable Hard Disk Drive Integrated Interface and Stand
Send Expansion Sets
Description
Universal Send Specifications
Sending Method
E-Mail, I-Fax, SMB, File Server (FTP, SMB, WebDAV), Mail Box
Color Mode Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
Scan Resolution (dpi)†† 600 x 600 , 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
Address Book Capacity
Max. 1,800 Destinations (Including 200 One-Touch Buttons)
Communication Protocol File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
File Format
Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/A-1b, XPS, XPS (Compact)
Optional: PDF (Trace & Smooth), PDF/XPS (OCR), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions)
I-Fax Data Format BW: TIFF (MH, MR, MMR)
Color: TIFF (Profile-C)
Universal Send Features
Two-sided Original, Different Size Originals, Original Type Selection, Book to Two Pages, Density/Exposure Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority Other Optional Accessories Utility Tray-A1USB Keyboard Card Reader-C1⟩⟩Copy Card Reader Attachment Kit-A1Braille Label Kit-F1ADF Access Handle-A1Copy Control Interface Kit-A1Convenience Stapler-B1PCL Printer Kit-AH1PS Printer Kit-AH1Direct Print Kit (for PDF/XPS)-H1Encrypted Secure Print-D1Barcode Printing Kit-D1⟩⟩⟩Web Access Software-H1♦imageRUNNER ADVANCE Essentials Universal Send Advanced Feature Set-E1Universal Send Security Feature Set-D1Universal Send Digital User Signature Kit-C1Authorized Send♦♦Secure Watermark-B1Wireless LAN Board-B1♦♦♦USB Device Port-A1Multimedia Reader/Writer-A1Additional Memory Type B (512MB)Document Scan Lock Kit-A2Data Erase Kit-C1HDD Data Encryption and Mirroring Kit-C2Removable HDD Kit-AD12.5-inch/80GB HDD-C12.5-inch/250GB HDD-D1IP Sec Board-B2♦♦♦Expansion Bus-F1Voice Guidance Kit-F1Remote Operator's Software Kit-B1eCopy Suite imageWARE Suite* To the top of the Upright Control Panel in the standard position.
** To the right edge of the Upright Control Panel in the extended position.
*** Includes ADF and consumables.
† Standard color scan support is up to 300 dpi. Up to 600-dpi scanning requires Additional Memory Type B (512MB).
†† EPS and XPS cannot be printed directly from the Memory Media or Advanced Box.
††† Coated paper can only be loaded through the Document Insertion Unit-K1.
∂ Browsing Advanced Box using SMB is not supported when imagePASS-U1 is attached.
Δ When the Auxiliary Tray is extended.
ΔΔ Puncher Unit-BF1 installs internally within either Staple Finisher-D1 or Booklet Finisher-D1.
ΔΔΔ Option for Booklet Finisher-D1.
⟩ Requires Staple Finisher-D1 or Booklet Finisher-D1.
⟩⟩ Requires the Copy Card Reader Attachment Kit-A2.
⟩⟩⟩ Requires PCL Printer Kit-AH1.
♦ Requires PS Printer Kit-AH1 or Direct Print Kit (for PDF/XPS)-H1 when printing PDF files.
♦♦ Check with your Authorized Canon Dealer for availability.
♦♦♦ Requires Expansion Bus-F1.
◊ Requires USB Device Port-A1.
◊◊ Required for 600-dpi color scanning.
Awards
2011 BLI Performance Certified Seal
BLI 2011 Reliability Seal
BLI 2011 Recommended Seal
#1 Ease of Use Monochrome MFP Customer Survey
#1 Best Monochrome MFP's Customer Survey
Product Configurator
Click here for the imageRUNNER ADVANCE 8000 and 6000 Series Configurator.
This is to make Misc appear on the page when needed.
Product Walkthroughs
imageRUNNER ADVANCE - Access Stored Files Walkthrough
imageRUNNER ADVANCE - Scan and Send Walkthrough
Brochures
Loading...
 Return to Top
