Web Content Viewer
Actions
imageRUNNER Pro 150+
Support - Black & White Multifunction
Features
The imageRUNNER Pro 150+ features a 150 page-per-minute print speed and a duty cycle of up to 3-5 million impressions per month (depending on customer job stream and number of shifts).
The imageRUNNER Pro 150+ comes complete with a six-drawer, 8,000-sheet paper supply, Interactive operator touch-screen interface, Sun Controller System, and a finisher, offering exceptional paper-handling and excellent 600 dpi resolution. With this set of features, you'll create more complex documents in less time, with less manual intervention.
Paper stock up to 110 lb. Index and 14" x 18" is supported.
Installation of a third party roll feed device and roll feed interface kit provides up to an additional 60,000 sheet capacity.
The optional Puncher allows you to produce ready-to-bind documents. The Puncher's unique rotating punch tool consistently delivers outstanding precision, even with mixed media. Aside from two- and three-hole punch tools, there are a variety of optional punch tools available, all of which are interchangeable by the key operator.
An optional 4,000-sheet post-process Inserter helps to eliminate manual collation of pre-printed color inserts, and the productivity gains are even higher.
Up to three optional stacker(s) can be configured with the device offering a generous 3 x 5,000-sheet capacity. Each stacker features a rolling, removable dolly for speedy off-loading and transport of finished documents.
Offering 65 page-per-minute, continuous-run operation, the optional imageSCANNER 65 Production Scanner scans at true 600 dpi resolution and produces precisely-registered images at full-rated speed.
The optional in-line Perfect Binder enables you to produce perfectly-bound books, on demand, automatically from 15 sheets up to 1.5" thick. Click here to watch a video demonstration of the Perfect Binder.
The optional booklet-maker creates saddle stitched booklets of up to 88 pages (22 sheets) in 5.5" x 8.5" or 8.5 "x 11" sizes. The optional booklet-maker also includes a trimmer and a tray capable of holding up to 42 booklets.
The optional SmartBoard Workflow Suite is based on industry standard PDF-based (Portable Document Format) workflow. It adds exceptional advantages to your pre-flighting for document assembly, viewing, editing and proofing. The easy-to-use visual interface has tremendous flexibility, from PDF normalization of input sources to scanning support to smooth assembly operations. SmartBoard expands the functionality of the imageRUNNER 110/Pro series products through the full integration of job tickets, page-level functionality, paper catalog updates, High Speed Direct printing, document importing and portable file format. The SmartBoard Workflow Suite is the perfect complement to your imageRUNNER Pro 150+.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER Pro 150+ that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
