Web Content Viewer
Actions
CLC 1180
Support CLC Series
Features
Through Tag Bit Support, the CLC 1180 can produce two different screen resolutions on the same page - one for text, the other for background, a great way to impose text over graphics.
Canon's Automatic Image Refinement boosts the image resolution of the CLC 1180 to the equivalent of 800 x 400 dpi, delivering superior text and finer detail.
Canon's Finer, Brighter Toner enables the CLC 1180 to yield a wide range of colors and maintain proper toner density, producing every color accurately and consistently.
The CLC 1180's Single-Step Direct transfer System transfers toner directly from the photosensitive drum to the paper, four times for each color, dramatically reducing the effects of environmental conditions on image quality.
Real Time Calibration uses sensors to measure gradation levels every few pages, allowing necessary adjustments to be made in "real time" for precise color, page to page and job to job.
By simulating the non-linear curve density of printing presses, the CLC 1180 is able to provide the closest possible match to offset output.
Special effects and color adjustments are easily accessible by using the LCD Touch panel control on the CLC 1180. Features include Color Copy Original, One-touch Color, Complexion Adjustment, Hue and Image Repeat.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you CLC 1180 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
