Web Content Viewer
Actions
Color imageRUNNER C1022i
Support Color Multifunction Copiers
Specifications
Model Name
Type
Color Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Image Server Memory
Standard: 768MB RAM
Max Copy Reservation
10 Jobs
Scanning Resolution
600 dpi x 600 dpi
Copy Resolution: 600 dpi x 600 dpi
Printing Resolution
2400 dpi equivalent x 600 dpi
Halftone
256 Gradations (Continuous-Tone)
Letter
(B/W, Color) 22/22 ppm
First Copy Time
12.5 Seconds (Color)
12.5 Seconds (B/W)
Multiple Copies
1 to 99
Magnification
50%- 200%(1%increments)
Preset Reductions
50%, 64%, 78%
Preset Enlargements
129%, 200%
Acceptable Originals
Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Maximum Original Size
Statement to Legal
Standard Paper Capacity
250-Sheet Paper Cassette
Optional: 500-Sheet Paper Cassette Feeder
Manual Bypass
100-Sheet Stack Bypass
Maximum Paper Capacity
50 Sheets (LTR)/30 Sheets (LGL)
Output Sizes
Cassette
Legal, Letter, Executive
Bypass
Legal, Letter, Statement, Executive, Custom size (3 x 5 to 8-1/2 x 14) and Envelopes
Acceptable Paper Weights
Cassette
16 lb. Bond to 32 lb. Bond
Bypass
16 lb. Bond to 65 lb. Cover
Duplexing
Standard Automatic Trayless Duplexing (Letter and Legal)
Image Reader: Standard
Warm Up Time
Less than 60 seconds after Powering On
Exposure Control
Automatic or Manual (9 levels)
Color Mode: Auto Color, Full Color, Black
Power Requirements
120V-127V AC, 50/60Hz, 15A
Power Consumption: Less than 1,300W(Main Unit)Less than 1,350W (with Optional Cassette)
Plug: NEMA 5-15P
Dimension
24-7/8 x 21-1/2 x 20-3/4 (Main Unit)
36-7/8 x 21-1/2 x 21-3/8 (with Optional Cassette)
Installation Space (Wx D): 21-1/2 x 44-7/8 (with drawer pulled out and with rear cover open)
Weight
Approximately 96 lb.
Estimated Toner Yield
Black: 6,000 images at 5% coverage
Full Color: 6,000 images at 5% coverage
Feeders
Description
Cassette Feeding Unit-AB1
Capacity
500 Sheets x 1 Cassette (20 lb. Bond)
Different Size Originals
Dimensions
12 x 17-3/8 x 21-3/8
Weight
28.7 lb.
Output Options
Fax Board
Description
Super G3 Fax Board-AB1 (Standard on C1022i)
Applicable Line
Public Switched Telephone Network (PSTN)
Connection Lines: One-Line
Sending/Original Size: Statement to Legal
Recording/Printing Size: Statement to Legal
Print Board
Description
Printing Features
Processor
Canon Custom Processor (Shared)
Standard Memory
768MB RAM
Maximum Memory
768MB RAM
Hard Disk
N/A Print Resolution
UFR II LT: 2400 dpi equivalent x 600 dpi
PCL 5c/6: 2400 dpi equivalent x 600 dpi
Print Controller Technology
UFR II LT: Windows® (Windows 2000/XP/Server 2003/Server 2008/Vista®), Citrix Meta Frame, Macintosh® (OS 10.2.8 or later)
PCL 5c/6: Windows (Windows 2000/XP/Server 2003/Server 2008/Vista®), Citrix MetaFrame
Other Features
Direct Print Supported Media: USB Memory, SD Secure Digital Memory Card, SDHC Memory Card, Compact Flash (CF) Card: Type I/II (3.3 V), Microdrive, Memory Stick, Memory Stick PRO, mini SD Card,* micro SD Card,*Memory Stick Duo,*Memory Stick PRO Duo*Data Format: TIFF, JPEG
Description
PCL Printer Kit-Y1 (Standard on C1022i)
Processor
PDL Support
PCL 5c/PCL 6Print Resolution
PCL 5c/6: 2400 dpi equivalent x 600 dpi Scan Features
Network TWAIN Scan: Standard
Network Scan Utility: Color Network ScanGear, Scan to USB
Data Format: TIFF, JPEG, PDF, PDF (Compact), PDF (OCR)**Document Distribution Technology
Color Mode: Full Color, B/W
Address Book Capacity: Max. 300 Destinations (Includes 200 One- Touch Buttons)
Sending Methods: E-mail, I-fax, SMB, File Server (FTP), Super G3 Fax (Standard on C1022i, Optional for C1022)
Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP)
E-mail/I-fax: SMTP, POP3, I-fax (Simple)
Data Format
File, E-mail: TIFF, JPEG, PDF, PDF (Compact), PDF (OCR)
I-fax: TIFF (MH,MR,MMR)
PCL 5c/6: Windows (Windows 2000/XP/Server 2003/Server2008/Vista®), Citrix Meta Frame OTHER OPTIONAL ACCESSORIES Barcode Printing Kit-C1Ο ΔColor Send Kit-W1† ΔHandset-J1♦System Upgrade RAM-A1†Cabinet Type-A♦ ♦Card Reader-E1ϑ ϑ ϑCard Reader Attachment Kit-F1Braille Label Kit-E1Footnotes:
* Memory cards that can be inserted into the slot using an adapter.
** Requires Color Send Kit-W1 when configured on C1022 model.
Δ Requires System Upgrade RAM-A1 when configured on C1022 model.
Ο Requires PCL Printer Kit-Y1 when configured on C1022 model.
† Standard on C1022i model.
♦ Requires fax capability for use.
♦ ♦ Cassette Feeding Unit-AB1 and Cabinet Type-A cannot be installed at the same time.
ϑ ϑ ϑ Requires Card Reader Attachment Kit-F1 for installation.
Awards
BLI 2009 Pick of the Year Award
BLI 2009 Highly Recommended Seal
BERTL 4 Star Highly Recommended
BLI 2009 Reliability Seal
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C1022i that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
