Web Content Viewer
Actions
Color imageRUNNER C1030
Support Color Multifunction Copiers
Features
The Color imageRUNNER C1030 models pack a powerful architecture based on the latest imageCHIP LITE platform that provides proven performance for handling concurrent print, copy, scan, fax, and send jobs. Each model has ample RAM, built-in Ethernet, dual USB 2.0 ports and a host of advanced functionality to enhance productivity. The systems also include Canon's Color RAPID Fusing System, which delivers short wait times between jobs, fast warm-up and first-copy-out times, and low energy consumption.
The Color imageRUNNER C1030 models are remarkably compact and versatile, easily fitting on a desktop or in a centralized area with optional paper cassette or cabinet for walk-up convenience. Regardless of the placement, usability is simple with the stunning 3.5" color LCD display. The control panel also features an innovative scroll wheel for easy navigation and entry of alphanumeric characters, which is adjustable for optimal viewing angle.
Support for Canon's innovative UFR II LT print language is standard on each model. UFR II LT is optimized to produce high-speed output by automatically sharing processing tasks between the desktop computer and the device.<br/> Color imageRUNNER C1030 supports optional PCL 5c/6 and for more advanced workflows, PostScript 3 Emulation is also available as an option on both systems. PostScript 3 Emulation support delivers accurate rasterization of PS3 print data, particularly useful for design, publishing, education, and healthcare businesses.<br/> In addition, Canon's print driver interface is consistent throughout the entire imageRUNNER line, simplifying output and ensuring a familiar user experience across devices.<br/>
Produce high-quality color output and accurate gradients through Canon's oil-free S Toners, which have been specifically engineered for uniformity in size and shape with a gloss-free look for superb results. And unlike other printers, the Color imageRUNNER C1030 models feature Pure Black technology to produce black text and lines on the page with greater clarity using the black toner instead of mixing CMYK colors.
Increase your productivity with color sending capabilities that come standard, which enable you to electronically distribute documents to e-mail, fax, i-fax, SMB, FTP destinations, or save them to removable media. The systems support popular formats including TIFF, JPEG, PDF, PDF High Compression, and Searchable PDF.
For the ultimate in document portability, scanned pages can be saved as TIFF, JPEG, PDF Compact, or PDF OCR files using the Scan-to-USB Memory function. You can output documents when needed - even when you don't have access to a computer - with the Direct Print feature. This allows the reading of TIFF or JPEG files stored on a USB memory device or SD/MMC/CompactFlash media card.
Enhanced authentication and security settings for user access is now available as standard for easy access management, cost control, device security, secure print and send restrictions. Additionally, Copy Card and Proximity card is supported for easy authentication.<br/>
The Color imageRUNNER C1030 models have been designed with front-load access to all consumables, providing quick replenishment with minimal downtime. The devices also use distinctive all-in-one cartridges to minimize the number of replacement parts needed to maintain uptime. Device setup, maintenance, and error recovery are facilitated through on-screen guides and tutorials on the control panel to get up and running quickly.<br/>
IT managers can easily manage multiple Canon devices and helps drive cost out of operations with a variety of tools including the standard Remote User Interface, support for Canon's imageWARE Enterprise Management Console application, and Canon's Generic PCL6 driver to simplify driver deployment and so much more.
Color imageRUNNER C1030 is ready for your fleet business with an array of management tools.
Awards
Better Buys for Business 2011 Editor's Choice
2011 BERTL's Best Award
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C1030 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Yes, networking and security is standard on the Color imageRUNNER C1030.
Yes, LDAP Address Book lookup feature is standard on the device.
Yes, there is a standard send restriction feature called User Authentication at Send Operation, which restricts or prevents access to send features.
Optional for high security environments, the Color imageRUNNER C1030 does not come with an internal hard disk drive (HDD), thus eliminating concerns over confidential data retained on the MFP. (No HDD = no latent images.)
Yes, the Color imageRUNNER C1030 is Energy Star qualified and has low energy usage of less than 1,3000W maximum and only 1W during Sleep Mode.
Brochures
Loading...
 Return to Top
