Web Content Viewer
Actions
Color imageRUNNER C2050
Support Color Multifunction Copiers
Features
Works Beautifully on Budgets... and spreadsheets, reports, manuals...anything a busy workgroup puts out. Say you have to scrap all your color flyers due to a price change. With the Color imageRUNNER C2050, you're able to print only as many as you need, only when you need them. And no matter how many last-minute revisions, client changes, custom covers, or eleventh-hour deadlines are required, Canon's Color imageRUNNER delivers the job-without the additional "rush" charges you'd incur elsewhere.
Bring Out Your Best Ideas on One of Ours. About the only thing the Canon Color imageRUNNER C2050 can't contain is your imagination New concepts are easily understood Ideas get communicated faster Recommendations are more persuasive The image you project is stronger Client recall is longer All those "gray" areas disappear And your bottom line looks better all the time
The Shortest Distance from Inspiration to Implementation Fast turnaround is the norm at 21 color/black-and-white pages per minute. Advanced digital technology provides crisp, clean black-and-white text and color images at 600 x 1200 dpi, with 256 gradations for outstanding printing. Automatic Document Feeding through the optional 50-sheet DADF-G1 and trayless Automatic Duplexing mean uninterrupted production of long copy or print jobs.
Not Fussy About What You Feed It Canon's Color imageRUNNER C2050 offers versatile media-handling and multiple paper-feeding options. You can print on a variety of papers, including cover stock up to 80lb., and transparencies. You'll even be able to create reports with color covers on heavy stock, giving you black-and-white pages combined with text and graphics throughout. Auto-duplexing makes it easy to produce brochures and flyers. And with the optional two-drawer Cassette Feeding Unit and optional Paper Deck, you'll have a total paper capacity of up to 5,550 sheets, which means less-frequent reloading and longer production runs.
Less Waiting, More Creating No more standing in line to input the next job. Whether you use the Color imageRUNNER as a walk-up copier or networked printing device, you get true multifunction convenience. When the printer is busy outputting one job, another can be processing at the same time. And by the time the first job is complete, the next in the queue is ready to print, resulting in optimum productivity and efficiency. So now, you can be working on one job while the Color imageRUNNER finishes another
Specifications
Model Name
C2050
MSRP
$19,275
Type
Electrophotostatic
Imaging System
Color Digital Multifunctional Imaging System
Monthly Duty Cycle
40,000
Letter Color
21
Letter B&W
21
Ledger Color
10.5
Ledger B&W
10.5
Letter-R Color
15
Letter-R B&W
15
Legal Color
10.5
Legal B&W
10.5
Toner Colors:
c,m,y,k
Acceptable Originals
Sheets,books,& solid objects
Maximum Output Size
12x18
Letter
Two Front-loading Paper Drawers plus Stack Bypass
Transparency
Via Stack Bypass Only
Letter
3,500
Statement to 12" x 18"
17 lb. to 80 lb. cover
Cassette
8 1/2 to 11 x 17
Bypass
3.9 x 5.8 to 12 x 18
Cassette
17 lb-28 lb bond
Bypass
up to 80 lb cover
Paper Deck
17 lb-28 lb bond
Duplexing
Automatic
Magnification
25%-400% in 1% increments
Standard Mode
100%
Preset Reductions
25%,50%,64%,73%,78%
Preset Enlargements
121%,129%,200%,400%
Zoom Mode
First Copy Time
10.9 sec.
Warm-up Time
Within 4 min. (68° F/ 20° C)
Exposure Control
(Copy) Automatic Exposure, 9/17 Gradations (Switchable)
Multiple Copies
(copy/prints) 1 to 999
Power Requirements
120V, 60Hz, 15A
Dimensions (H x W x D)
23.27 x 33.07 x 29.37 (591mm x 840mm x 746mm)
Weight
361.34 lb. (163.9kg)
Supplies
CMYK Cyan, Magenta: 20,000; Yellow, Black: 18,000
Toner:
CMYK
Estimated Toner Yield:
Feeders
Description
DADF-G1
Statement to 11 x 17
Capacity
50 Sheets/Letter, Letter-R, Statement (20 lb. Bond)
Paper Weights
15 lb. - 28 lb.
Power Source
DC 24V directly from unit
Power Consumption
170W or less
5.90 x 25.39 x 20.51 (150mm x 645mm x 521mm)
Weight
32.18 lb. (14.6kg)
Output Options
Description
Stapler Sorter-N1
Sort Mode
30 Sheets (Letter, Letter-R); 25 Sheets (Legal, 11 x 17)
Staple Sort Mode
Non-Sort Mode
200 Sheets (Statement-R to 12 to 18)
Staple Sizes
Letter, Letter-R, Legal, 11 x 17
Staple Positions
Upper Left, Upper and Lower Left, Saddle-Stitching
Paper Sizes
Statement-R to 12 x 18
Stapling Capacity
Non-Staple Mode: Bin 1: 300 Sheets (Letter); Bin 2: 1,000 Sheets (Letter); Bin 3: 200 Sheets (Letter) Staple Mode: Bin 1: Up to 30 Sets; Bin 2: Up to 30 Sets; Bin 3: N/A
22.4 x 12.7 x 23.0 (570mm x 323mm x583mm)
Weight
Finisher-H1: 72.7 lb (33kg); Saddle Finisher-H2: 99.2 lb. (45 kg)
Paper Supply Options
Description
Paper Deck-F1
Paper Capacity
3,500 Sheets
Paper Sizes
Letter (8 1/2 x 11)
Paper Weights
17 lb. - 28 lb.
22.4 x 12.7 x 23.0 (570mm x 323mm x 583mm)
Weight
90.4 lb. (22.1kg)
Editor
Description
Editor-G1
Features
Image adjustment from hard-copy originals.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C2050 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
