Web Content Viewer
Actions
Color imageRUNNER C2058
Support Color Multifunction Copiers
Specifications
Model Name
MSRP
Copier ($14,540)Printer($15,380)Copier/Printer($19,185)
Type
LED
Imaging System
Color Digital Multifunctional Imaging System
Developing System
Toner (C,M,Y,K)
Monthly Duty Cycle
40,000
Letter Color
21 cpm (Full color)
Letter B&W
28 cpm (B/W)
Ledger Color
10.5 cpm (Full color)
Ledger B&W
14 cpm (B/W)
Letter-R Color
15 cpm (Full color)
Letter-R B&W
20 cpm (B/W)
Legal Color
Legal B&W
14 cpm (B/W)
Toner Colors:
c,m,y,k
Acceptable Originals
Sheets,booklets,and solid objects (up to 2kg)
Maximum Output Size
12 x 18
Letter
8 1/2 x 11
Ledger
11 x 17
Legal
8 1/2 x 14
Letter-R
11 x 8 1/2
Statement-R
8 1/2 x 5 1/2
Transparency
8 1/2 x 11
Letter
8 1/2 x 11
Ledger
N/A
OverSized
N/A
Transparency
N/A
Statement to 12" x 18"
3.9 x 5.8 to 12 x 18
Transparency
NA
Bypass
Cassette
17 lb. 28 lb. bond
Bypass
17 lb. bond-80 lb. cover
Paper Deck
17 lb. bond-28 lb. bond
Duplexing
automatic (trayless)
Standard Mode
100%
Preset Reductions
25%,50%,64%,73%,78%
Preset Enlargements
121%,129%,200%,400%
Zoom Mode
25%-400% (in 1% increments
First Copy Time
10.6 seconds
Warm-up Time
within 4 minutes (68 degrees F/20 degrees C)
Exposure Control
Automatic Exposure,9/17 Gradations (Switchable)
Multiple Copies
1-999
Power Requirements
120V,60Hz,15A
Dimensions (H x W x D)
23.27 x 33.07 x 29.37 (591mm x 840mm x 746 mm)
Weight
362.44 lb (164.4 kg)
Supplies
Spherical Toner Cyan (20,000) Magenta (20,000) Yellow (18,000) Black (18,000)
Toner:
Spherical Toner
Estimated Toner Yield:
Feeders
Description
DADF-G1
Statement to 11 x 17
Capacity
50 sheets/Letter,Letter-R,Statement(20 lb bond)
Paper Weights
15 lb.-28 lb.
Different Size Originals
Power Source
DC 24V directly from the unit
Power Consumption
170W or less
5.90 x 25.39 x 20.51 (150mm x 645mm x 521mm)
Weight
32.18 lb (14.6kg)
Output Options
Description
Stapler-Sorter-N1(StaplerSorter-N1 Kit required), Finisher-H1 / Saddle Finisher-H2 (Power Supply Unit-M1 required for both Finisher-H1 and H2)
Sort Mode
Stapler-Sorter-N1 (30 sheets:Letter, Letter-R) 25 sheets (Legal, 11x 17)
Staple Sort Mode
Stapler Sorter-N1 (30 sheets:Letter, Letter-R) 25 sheets (Legal, 11x 17)
Non-Sort Mode
Stapler Sorter-N1 (200 sheets, Statement-R to 12 x 18)
Hole Punch
NA
Power Source
Stapler-Sorter-N1(DC 24v directly from the unit)
Stapler Sorter-N1 (42.32 x 23.39 x 18.27) Finisher-H1 / Saddle Finisher-H2 (41.2 x 26.3 x 22.9)
Weight
Stapler Sorter-N1(70.55 lb.), Finisher-H1 (72.7 lb.) Saddle Finisher-H2 (99.2 lb.)
Paper Supply Options
Description
Cassette Feeding Unit-U2, Paper Deck-F2 (Power Supply Unit-M1 required)
Number of Cassettes
2 Standard Front-Loading Adjustable Drawers + 2 optional Front-Loading Adjustable Drawers + Optional Paper Deck-F2
Paper Capacity
1,000 standard Cassette-Feeding Unit-U2, 1,000 sheet optional Cassette feeding Unit-U2, 3,500 sheet optional Paper Deck-F2, 50 sheet Stack Bypass for maximum of 5,550 sheet
Paper Sizes
Cassette Feeding Unit-U2 (Statement to 11 x 17) Paper Deck-F2 (Letter 8 1/2 x 11)
Paper Weights
Cassette Feeding Unit-U2 (17 lb.-28 lb.) Paper Deck-F2 (17 lb.-28 lb. bond)
Cassette Feeding Unit-U2 (10.2x26.8x27.8) Paper Deck-F2 (22.4 x 12.7 x 23.0)
Weight
Cassette Feeding Unit-U2 (72.5 lb.) Paper Deck-F2 (90.4 lb.)
Editor
Description
Optional Editor-G1
Features
Framing,Blanking,Area of Designation
Film Projector
Description
N/A
Acceptable Film Types
N/A
Focusing
N/A
Power Requirements
N/A
Power Consumption
N/A
Weight
N/A
Rotary Changer
N/A
Acceptable Film Trays
N/A
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C2058 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
