Web Content Viewer
Actions
Color imageRUNNER C2880
Support Color Multifunction Copiers
Specifications
Model Name
Imaging System
Color Digital Multifunction Imaging System
Developing System
Dry Dual Component Developing System
Image Server Memory
Standard 1GB RAM
Maximum 1.5GB RAM Hard Disk Drive: 80GB
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max Copy Reservation
10 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Halftone
256 Gradations (Continuous-Tone)
Letter
28/26 ppm (Letter)
First Copy Time
8.9 Seconds (Color)
5.9 Seconds (B/W)
Multiple Copies
1 to 999
Magnification
25% - 400% (1% increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Statement to 11x 17
Maximum Original Size
11 x 17
Standard Paper Capacity
Dual 550-Sheet x 2 Paper Cassettes Optional: Dual 550-Sheet x 2 Paper Cassettes
2,700-Sheet Paper Deck
Manual Bypass
50-Sheet Stack Bypass (Std)
Maximum Paper Capacity
4,950 Sheets
Output Sizes
Cassette
12x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Irregular size (3-7/8x 5-9/16 to 12-5/8 x 18) and Envelopes
Acceptable Paper Weights
Cassette
17 lb. Bond to 90 lb. Index
Bypass
17 lb. Bond to 110 lb. Index
Duplexing
Standard Automatic Trayless Duplexing (Executive to 12x18)
Warm Up Time
38 Seconds After Powering On
Exposure Control
Color Exposure Automatic or Manual (9 Levels)Color Mode: Auto Color, Full Color, Black, Single Color, Two Colors
Power Requirements
120V AC, 60Hz, 15A
Dimension
31-1/8 x 22-1/4 x 29-3/4 (Main Unit)
36 x 22-1/4 x 29-3/4 (with DADF)Installation Space: 34 x 29-3/4 (when the Stack Bypass is extended)
Weight
Approximately 256 lb. (116kg Main Unit)
Estimated Toner Yield
Black: 26,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: 14,000 Copies/Bottle (Estimated @ 5% Coverage)
Feeders
Description
Cassette Feeding Unit-Y3
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Capacity
550 Sheets x 2 Cassettes [20 lb. Bond (80 g/m2)]
Dimensions
9-7/8 x 22-1/4 x 27-5/8
Weight
Approximately 50.7 lb. (23kg)
Paper Supply Options
Description
Paper Deck-Z1
Paper Capacity
2,700 Sheets [20 lb. Bond (80 g/m2 )]
Paper Sizes
Letter
Dimensions
18-5/8 x 14-5/8 x 23-1/4
Installation Space (W x D): 36-7/8 x 29-3/4
Weight
Approximately 65.3 lb. (29.6kg)
Output Options
Finishers Output Trays
Description
Finisher-Z1
Paper Weights
17 lb. Bond to 80 lb. Cover Paper Capacity Per Tray: 500 Sheets (Letter, Statement,Statement-R) or 2-3/4 in Height
250 Sheets (11 x 17, Legal,Letter-R) or 1-3/8 in Height
Paper Size
Standard: 12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Envelopes (COM10 No. 10, Monarch, DL, ISO-B5, ISO-C5, Yougata 4, Catalog Glove No.8)Non-Standard Size: 3-7/8 x 5-9/16 to 12-5/8 x 18
Number Of Trays
1 Tray Paper Capacity of Staple Mode: 500 Sheets/30 Sets (Letter)or 2-3/4 in Height
250 Sheets/30 Sets (11 x 17,Legal, Letter-R) or 1-3/8 in Height
500 Sheets/30 Sets (Staple Mode with Different Paper Sizes) or 2-3/4 in Height
Staple Capacity
Letter: 50 Sheets (17 lb. to 20 lb. Bond), 30 Sheets (20 lb. to 28 lb. Bond), 2 Sheets (32 lb. Bond to 90 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond), 20 Sheets (20 lb. to 28 lb. Bond), 2 Sheets (32 lb. Bond to 90 lb. Index)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R), Double (11 x 17, Letter)
Dimensions
8-1/2 x 27-3/8 x 21-5/8
Installation Space (W x D): 42 x 29-3/4 (when the Auxiliary Tray is extended)
Weight
Approximately 26.5 lb. (12kg)
Description
Finisher-Y1/Saddle Finisher-Y2
Paper Weights
Paper Size
Standard: 12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive
Number Of Trays
2 Trays, Paper Capacity Per Tray
Upper/Lower Tray: 1,000 Sheets (Letter, Statement, Statement-R, Executive), 500 Sheets (11 x 17, Legal,Letter-R)Paper Capacity of Staple Mode
Upper/Lower Tray: 1,000 Sheets/30 Sets (Letter, Executive), 500 Sheets/30 Sets (11 x 17, Legal, Letter-R), 500 Sheets/30 Sets (Staple Mode with Different Paper Sizes)
Staple Capacity
Letter, Executive: 50 Sheets (17 lb. to 20 lb. Bond), 30 Sheets (20 lb. to 28 lb. Bond), 2 Sheets (32 lb. Bond to 80 lb. Cover)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond), 20 Sheets (20 lb. to 28 lb. Bond), 2 Sheets (32 lb. Bond to 80 lb. Cover)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R, Executive)
Double (11 x 17, Legal, Letter,Letter-R, Executive)
Paper Sizes
12x18,11x17, Legal, Letter-R Saddle Stitch Capacity: 15 Sheets (17 lb. to 20 lb. Bond), 10 Sheets (20 lb. to 28 lb. Bond)Tray Capacity: 25 Sets (1 to 5 Sheets), 15 Sets (6 to 10 Sheets), 10 Sets (11 to 15 Sheets)
Dimensions
Finisher-Y1: 42-1/4 x 26-1/8 x 25-7/8
Saddle Finisher-Y2: 42-1/4 x 29-3/8 x 25-7/8Installation Space (W x D):
Finisher-Y1: 59-3/8 x 29-3/4 (when the Auxiliary Tray is extended)
Saddle Finsher-Y2: 63-1/4 x 29-3/4 (when the Auxiliary Tray is extended)
Weight
Finisher-Y1: Approximately 96.1 lb. (43.6kg)
Saddle Finisher-Y2: Approximately 162 lb. (73.6kg)
Description
Inner 2 Way Tray-D1
Paper Weights
Paper Size
Non-Standard: 3-7/8 x 5-9/16 to 12-5/8 x 18
Top Tray
100 Sheets (Letter), 50 Sheets (Other Sizes)
Lower Tray
250 Sheets (Letter), 100 Sheets (Other Sizes)
Hole Punch
Puncher Unit-M1^^Paper Size 11 x 17, Legal, Letter, Letter-R, Executive
Max. Paper Weight: 17 lb. Bond to 80 lb. Cover
Punch Type: 3 Holes (Letter, 11 x 17), 2 Holes (Legal, Letter-R, Executive)
Punch Waste Tray Capacity: When Approximately3,000 Sheets of Paper Have Been Punched
Dimensions (H x W x D): 37-1/8 x 4-1/4 x 24-1/2
Weight: Approximately 15.9 lb. (7.2kg)
Dimensions
6 x 7 x 21-1/2
Installation Space (W x D): 34 x 29-3/4
Weight
Approximately 8.6 lb. (3.9kg)
Fax Board
Description
Super G3 Fax Board-W1/Multi-Line Fax Board-J2
Applicable Line
Public Switched Telephone Network (PSTN)Connection Lines: One-Line (Super G3 Fax BoardW1), Two-Lines (Super G3 Multi-Line Fax Board-J2)
Print Board
Description
PCL Printer Kit-Q2 (Standard for i Models) tt
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
1GB RAM (Standard)
Maximum Memory
1.5GB RAM (Maximum) (Shared)
Hard Disk
80GB (Shared)
PDL Support
PCL 5c, PCL 6
Optional PDL Support: PostScript 3 Emulation (PS Printer Kit-Q2ttt )Print Resolution
PCL 5c: 2400 dpi equivalent x 600 dpi
PCL 6: 1200 dpi x 1200 dpi*, 2400 equivalent x 600 dpi
PS3 (Optional ): 1200 dpi x 1200 dpi*, 2400 dpi equivalent x 600 dpi
Print Controller Technology
PCL 5c/PCL 6: Windows (Windows 98/Me/ 2000/ XP/ Server 2003/Windows Vista, Citrix MetaFrame)
PS3 (Optional): Windows (Windows 98/Me/ 2000/XP/ Server 2003, Citrix MetaFrame), Macintosh (OS 10.2.8 or later)
Description
imagePASS-J1
Processor
Celeron M 1.2GHZ
System: System 8e
Standard Memory
256MB
Maximum Memory
512MB
Hard Disk
80GB
PDL Support
Adobe® PostScript® 3, PCL 5c
Interface Connections
10/100/1000 Base-T (RJ-45)
Other Features
Utility Software: Remote Scan, Command WorkStation for Windows, Command WorkStation for Mac EFI Options: 256MB RAM, Secure Erase v1.0, Hot Folders v2.0, Impose v2.6
Send Expansion Sets
Description
Color Universal Send Features
Sending Method
E-Mail, I-FAX, SMB, File Server (FTP, IPX, WebDAV), User Inbox, Super G3 Fax (Optional)
Address Book Capacity
Max. 1,800 Destinations (Includes 200 One-Touch Buttons) Max. 5 LDAP Servers
File Format
Communication Protocol:
File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-Mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full)Data Format
File, E-Mail: TIFF, JPEG, PDF, PDF (Compact),** PDF (Trace & Smooth),** PDF (OCR),** Encrypted PDF,*** Digital Signature PDF (Device,*** User t)
I-Fax: B/W: TIFF (MH, MR, MMR) Color: TIFF (Profile-C)
Scan Density
Network TWAIN Scan: Standard
Network Scan Utility: Color Network Scan Gear OTHER OPTIONAL ACCESSORIES: Encrypted Secured Print Software-C1 IBarcode Printing Kit-A1 Web Access Software-E1 III Universal Send PDF Advanced Feature Set-A1 Universal Send PDF Security Feature Set-A1 Digital User Signature PDF Kit-A1Secure Watermark-A1(Requires 512 RAM)Super G3 Fax Board-W1Super G3 Multiline Fax Board-J2imageRUNNER 512MB Expansion RAM-C1HDD Data Erase Kit-A1HDD Data Encryption Kit-B1Voice Guidance Kit-B1 Voice Operation Kit-A1 Remote Operator's Software Kit-A2Platen Cover Type VCabinet-P1Copy Tray-J1Envelope Feeder Attachment-C2FL Cassette-Y1FL Cassette-Z1Document Tray-J1Card Reader-C1Card Reader Kit-B1Key Switch Unit-A2Braille Label Kit-A1ADF Access Handle-A1Stamp Unit-A1eCopy SuiteimageWARE#&153; Suite Access Management System Kit-A1Workflow Composer-B1Footnotes:
* If 1200 dpi print is selected, engine speed will slow down
** When configured on C3380/C2880 models, requires Universal Send PDF Advanced Feature Set-A1
*** When configured on the C3380/C2880 models, requires Universal Send PDF Security Feature Set-A1
t Requires Digital User Signature Kit-A1
tt Color UFR II Printing is standard on C3380/C2880 models
ttt Requires imageRUNNER 512MB Expansion RAM-C1
^Available with Saddle Finisher-Y2 Only
^^Puncher Unit-M1 can only be installed with either the Finisher-Y1 or Saddle Finisher-Y2
I Requires PCL Printer Kit-Q2
II When Configured on the C3380/C2880 models, requires PCL Printer Kit-Q2
III Requires PS Printer Kit-Q2 if printing PDF files
IV Standard on C3380i/C2880i models
V Option on C3380/C2880 models
ENERGY STAR Qualified
VI Voice Guidance Kit-B1 and Voice Operation Kit-A1 can not be installed together.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C2880 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the Color imageRUNNER C3380 / C2880 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
