Web Content Viewer
Actions
Color imageRUNNER C3480
Support Color Multifunction Copiers
Specifications
Model Name
Type
Color Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Dual Component Developing System
Image Server Memory
Standard 1GB RAM
Maximum 1.5GB RAM Hard Disk Drive: 80GB
Max Mailboxes Supported
100 User Inboxes, One Memory RX
Inbox, 50 Confidential Fax Inboxes Scan Features
Network TWAIN Scan: Standard
Network Scan Utility: Color Network ScanGear
Max Copy Reservation
10 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Halftone
256 Gradations (Continuous-Tone)
Letter
(B/W, Color): 34/30 ppm
First Copy Time
8.9 Seconds (Color)
5.9 Seconds (B/W)
Multiple Copies
1 to 999
Magnification
25% - 400% (1% increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Statement to 11 x 17
Maximum Original Size
11 x 17
Standard Paper Capacity
Dual 550-Sheet x 2 Paper Cassettes Optional: Dual 550-Sheet x 2 Paper Cassettes
2,700-Sheet Paper Deck
Manual Bypass
50-Sheet Stack Bypass
Maximum Paper Capacity
4,950 Sheets
Output Sizes
Cassette
12x18^, 11 x 17^, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Irregular size (3-7/8x 5-9/16 to 12-5/8 x 18) and Envelopes
Acceptable Paper Weights
Cassette
17 lb. Bond to 90 lb. Index
Bypass
17 lb. Bond to 110 lb. Index
Duplexing
Standard Automatic Trayless Duplexing (Executive to 12 x 18)
Warm Up Time
38-Seconds After Powering On
Exposure Control
Automatic or Manual (9 Levels)
Color Mode: Auto Color, Full Color, Black, Single Color, Two Colors
Power Requirements
120V AC, 60Hz, 15A
Power Consumption: 1,500W
Plug: NEMA 5-15P
Dimension
31-1/8 x 22-1/4 x 29-3/4 (Main Unit)
36 x 22-1/4 x 29-3/4 (with DADF)
Installation Space (W x D): 34 x 29-3/4 (when the Stack Bypass is extended)
Weight
Approximately 256 lb. (Main Unit)
Approximately 275 lb. (with DADF)
Estimated Toner Yield
Black: 26,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: 14,000 Copies/Bottle (Estimated @ 5% Coverage)
Feeders
Description
Cassette Feeding Unit-Y3
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Capacity
550-Sheet x 2 Cassettes (20 lb. Bond)
Dimensions
9-7/8 x 22-1/4 x 27-5/8
Weight
Approximately 50.7 lb.
Paper Supply Options
Description
Paper Deck-Z1
Paper Capacity
2,700 Sheets (20 lb. Bond)
Paper Sizes
Letter
Dimensions
18-5/8 x 14-5/8 x 23-1/4
Installation Space (W x D): 36-7/8 x 29-3/4
Weight
Approximately 65.3 lb.
Description
Inner 2-Way Tray-D1
Paper Capacity
Upper Output Tray: 100 Sheets (Letter)
50 Sheets (Other Sizes)
Lower Output Tray: 250 Sheets (Letter)
100 Sheets (Other Sizes)
Paper Sizes
Standard: 12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive
Non-Standard: 3-7/8 x 5-9/16 to 12-5/8 x 18
Paper Weights
17 lb. Bond to 80 lb. Cover
Dimensions
6 x 7 x 21-1/2
Weight
Approximately 8.6 lb. Puncher Unit-M1◊ ◊
Paper Size
Standard: 11 x 17, Legal, Letter, Letter-R, Executive
Max. Paper Weight: 17 lb. Bond to 80 lb. Cover
Punch Type: 3 Holes (Letter, 11 x 17)
2 Holes (Legal, Letter-R, Executive)
Punch Waste Tray Capacity: When Approximately 3,000 Sheets of Paper Have Been Punched
Dimensions (H x W x D): 37-1/8 x 4-1/4 x 24-1/2
Weight: Approximately 15.9 lb.
Output Options
Finishers Output Trays
Description
Finisher-Z1
Paper Weights
Paper Size
Standard: 12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Envelopes (COM10 No. 10, Monarch, DL, ISO-B5, ISO-C5, Yougata 4, Catalog Glove No.8)
Non-Standard Size: 3-7/8 x 5-9/16 to 12-5/8 x 18
Number Of Trays
One Tray
Top Tray
500 Sheets (Letter, Statement, Statement-R) or 2-3/4 in Height
250 Sheets (11 x 17, Legal, Letter-R) or 1-3/8 in Height Paper Capacity of Staple Mode: 500 Sheets/30 Sets (Letter) or 2-3/4 in Height
250 Sheets/30 Sets (11 x 17, Legal, Letter-R) or 1-3/8 in Height
500 Sheets/30 Sets (Staple Mode with Different Paper Sizes) or 2-3/4 in Height
Staple Capacity
Letter: 50 Sheets (17 lb. to 20 lb. Bond)
30 Sheets (20 lb. to 28 lb. Bond)
2 Sheets (32 lb. Bond to 90 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond)
20 Sheets (20 lb. to 28 lb. Bond)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R)
Dimensions
8-1/2 x 27-3/8 x 21-5/8
Installation Space (W x D): 42 x 29-3/4 (when the Auxiliary Tray is extended)
Weight
Approximately 26.5 lb.
Description
Finisher-Y1/Saddle Finisher-Y2
Paper Weights
Paper Size
Number Of Trays
Two Trays
Top Tray
1,000 Sheets (Letter, Statement, Statement-R, Executive)
500 Sheets (11 x 17, Legal, Letter-R)
Lower Tray
Saddle Stitch Tray
25 Sets (1 to 5 Sheets)
15 Sets (6 to 10 Sheets)
10 Sets (11 to 15 Sheets)
Staple Capacity
Letter, Executive: 50 Sheets (17 lb. to 20 lb. Bond)
2 Sheets (32 lb. Bond to 80 lb. Cover)
2 Sheets (32 lb. Bond to 80 lb. Cover)Paper Capacity of Staple Mode:
Upper/Lower Tray: 1,000 Sheets/30 Sets (Letter, Executive)
500 Sheets/30 Sets (11 x 17, Legal, Letter-R)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R, Executive)
Double (11 x 17, Legal, Letter, Letter-R, Executive)
Paper Sizes
Saddle-Stitching◊
12x18, 11x17, Legal, Letter-R
Stapling Capacity
15 Sheets (17 lb. to 20 lb. Bond)
10 Sheets (20 lb. to 28 lb. Bond)
Dimensions
Finisher-Y1: 42-1/4 x 26-1/8 x 25-7/8
Saddle Finisher-Y2: 42-1/4 x 29-3/8 x 25-7/8
Installation Space (W x D): Finisher-Y1: 59-3/8 x 29-3/4 (when the Auxiliary Tray is extended)
Saddle Finsher-Y2: 63-1/4 x 29-3/4 (when the Auxiliary Tray is extended)
Weight
Finisher-Y1: Approximately 96.1 lb.
Saddle Finisher-Y2: Approximately 162 lb
Fax Board
Description
Super G3 Fax Board-W2/Multi-Line Fax Board-J2
Applicable Line
Public Switched Telephone Network (PSTN)Connection Lines: One-Line (Super G3 Fax BoardW2), Two-Lines (Super G3 Multi-Line Fax Board-J2)Sending/Original Size: Statement to 11 x 17
Recording/Printing Size: Statement to 11 x 17
Print Board
Description
Print Features
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
1GB RAM
Maximum Memory
1.5GB RAM (Shared)
Hard Disk
80GB (Shared)Print Resolution
UFR II: 1200 dpi x 1200 dpi^^
2400 dpi equivalent x 600 dpi
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/Server 2003/Windows Vista®), Citrix MetaFrame, Macintosh® (OS 10.2.8 or later)
XPS:* Windows Vista
Description
PCL Printer Kit-Q3 (Opt.)+ +
Processor
Standard Memory
1GB RAM
Maximum Memory
1.5GB RAM (Shared)
Hard Disk
80GB (Shared)
PDL Support
PCL 5c/6
Optional PDL Support: PostScript 3 Emulation (PS Printer Kit-Q3+ + +)Print Resolution
PCL 5c: 2400 dpi equivalent x 600 dpi
PCL 6: 1200 dpi x 1200 dpi^^
PS3 (Optional): 1200 dpi x 1200 dpi+ +
PCL 5c/6: Windows (Windows 2000/XP/Server 2003/Windows Vista) Citrix MetaFrame
PS3 (Optional): Windows (Windows 2000/XP/Server 2003/Windows Vista) Citrix MetaFrame Macintosh (OS 10.2.8 or later)
Description
imagePASS-J1
Processor
Celeron M 1.2GHZ
Standard Memory
256MB
Maximum Memory
512MB
Hard Disk
80GB
PDL Support
Adobe® PostScript® 3, PCL 5cPrint Resolution: 1200 dpi x 1200 dpi+ +
Interface Connections
10/100/1000Base-T (RJ-45)Utility Software: Remote Scan, Command WorkStation for Windows, Command WorkStation for Mac EFI Options: 256MB RAM, Secure Erase v1.0, Hot Folders v2.0, Impose v2.6
Send Expansion Sets
Description
Color Universal Send Features
Sending Method
E-mail, I-fax, SMB, File Server (FTP, IPX, WebDAV), User Inbox, Super G3 Fax (Optional)Color Mode: Auto Color Select (Full Color/Grayscale)
Auto Color Select (Full Color, B/W)
Full Color, Grayscale, B/W
Address Book Capacity
Max. 1,800 Destinations (Includes 200 One-Touch Buttons) Max. 5 LDAP Servers
File Format
File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-mail/I-fax: SMTP, POP3, I-fax (Simple, Full)Data Format
File, E-mail: TIFF, JPEG, PDF, PDF (Compact),** PDF (Trace & Smooth),** PDF (OCR),** Encrypted PDF,*** Digital Signature PDF (Device,*** User+)
I-fax: B/W: TIFF (MH, MR, MMR) Color: TIFF (Profile-C)OTHER OPTIONAL ACCESSORIES Encrypted Secured Print Software-C1ϑBarcode Printing Kit-A1ϑWeb Access Software-E1♦Universal Send PDF Advanced Feature Set-A1♦ ♦Universal Send PDF Security Feature Set-A1♦ ♦Digital User Signature PDF Kit-A1Secure Watermark-A1+++Super G3 Fax Board-W2Super G3 Multiline Fax Board-J2iR 512MB Expansion RAM-C1HDD Data Erase Kit-A1HDD Data Encryption Kit-B1Voice Guidance Kit-B1ºVoice Operation Kit-A1ºRemote Operator's Software Kit-A2Platen Cover Type H Copy Tray-J1Envelope Feeder Attachment-C2FL Cassette-Y1FL Cassette-Z1Document Tray-J1Card Reader-C1Card Reader Kit-B1Key Switch Unit-A2Braille Label Kit-A1ADF Access Handle-A1Stamp Unit-A1eCopy Suite imageWARE Suite Access Management System Kit-A1Workflow Composer-B3Wireless Network Interface Adapter NB-W1ΔΔFootnotes:
^ Not available in top cassette.
^^ If 1200-dpi print is selected, engine speed will slow down.
* Check with your Authorized Canon Dealer for availability.
** When configured on C3480/C3080 models, requires Universal Send PDF Advanced Feature Set-A1.
*** When configured on the C3480/C3080 models, requires Universal Send PDF Security Feature Set-A1.
+ Requires Digital User Signature Kit-A1.
+>+ Color UFR II Printing is standard on C3480/C3080 Series models.
+++ Requires imageRUNNER 512MB Expansion RAM-C1.
◊ Available with Saddle Finisher-Y2 only.
◊◊ Puncher Unit-M1 can only be installed with either the Finisher-Y1 or Saddle Finisher-Y2.
ϑ When Configured on the C3480/C3080 models, requires PCL Printer Kit-Q3.
♦ Requires PS Printer Kit-Q3 if printing PDF files.
♦♦ Standard on C3480i/C3080i models.
º Voice Guidance Kit-1 and Voice Operation Kit-A1 cannot be installed together.
Δ Option on C3480/C3080 models.
ΔΔ Not supported with imagePASS-J1.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C3480 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the Color imageRUNNER C3480 / C3080 / C2550 Series Configurator
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
