Web Content Viewer
Actions
Color imageRUNNER C5180i
Support Color Multifunction Copiers
Specifications
Model Name
Color imageRUNNER® C5180i
Type
Color Digital Multifunction Color Digital Multifunction
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Dual Component Developing System
Image Server Memory
Standard 1GB RAM
Maximum 1.5GB RAM
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max Copy Reservation
10 Jobs
Scanning Resolution
600 dpi x 600 dpi
Halftone
256 Gradations (Continuous-Tone)
Letter
(B/W, Color): 51/51 ppm
First Copy Time
8.0 Seconds (Color)
6.2 Seconds (B/W)
Multiple Copies
1 to 999
Magnification
25% - 400% (1% increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Image Reader: Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Document Feeding Method: Statement to 11x 17
Maximum Original Size
11 x 17
Standard Paper Capacity
Dual 550-Sheet Paper Cassettes
Optional: Dual 550-Sheet Paper Cassettes 2,700-Sheet Paper Deck
Manual Bypass
100-Sheet Stack Bypass
Output Sizes
Cassette
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, 12-5/8 x 17-11/16, Irregular size (3-15/16 x 5-7/8 to 12-7/8 x 18) and Envelopes
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index
Bypass
17 lb. Bond to 140 lb. Index
Duplexing
Standard Automatic Trayless Duplexing (Executive to 12 x 18)
Warm Up Time
4 Minutes after Powering On
Exposure Control
Copy Exposure: Automatic or Manual (9 levels)Color Mode: Auto Color, Full Color, Black, Single Color, Two Colors
Power Requirements
120V AC, 60Hz, 20A
Dimension
35 x 24-3/8 x 33-1/2
Weight
Approximately 295 lb. (134kg)
Estimated Toner Yield
Black: 27,000 Images @ 5% Coverage
Color: 36,000 Images @ 5% Coverage
Feeders
Description
Cassette Feeding Unit-Z1
Capacity
550 Sheets x2 Cassettes
Paper Weights
20 lb. Bond (80g/m2)
Dimensions
12-1/4 x 24-3/8 x 27-3/4
Weight
Approximately 66.1 lb. (30kg)
Paper Supply Options
Description
Paper Deck-Y1
Paper Capacity
2,700 Sheets
Paper Sizes
Letter
Paper Weights
(20 lb. Bond 80g/m2)
Dimensions
17 x 12-3/4 x 23-1/4
Installation Space (W x D): 37-1/8 x 33-1/2
Weight
Output Options
Finishers Output Trays
Description
Finisher-X1
Paper Weights
Paper Size
Standard: 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Non-Standard Size: (3-15/16 x 5-7/8 to 12-7/8 x 18)
Number Of Trays
1 Tray
Top Tray
1,000 Sheets (Letter, Statement-R, Executive) 500 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Staple Capacity
Letter, Executive: 50 Sheets (17 lb. to 20 lb. Bond) 30 Sheets (20 lb. to 28 lb. Bond) 2 Sheets (28 lb. Bond to 140 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond) 20 Sheets (20 lb. to 28 lb. Bond) 2 Sheets (28 lb. Bond to 140 lb. Index)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R, Executive)
Dimensions
28-5/8 x 16-1/4 x 24
Installation Space (W x D): 46-1/2 x 33-1/2 (when the auxiliary tray is extended)
Weight
Approximately 35.3 lb. (16kg)
Description
Finisher-W1/Saddle Finisher-W2+
Paper Weights
Paper Size
Standard: 12 x 18, 11 x 17, Legal,Letter, Letter-R, Statement-R, Executive
Number Of Trays
3 Trays
Top Tray
Upper Tray: 1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (12 x 18, 11 x 17, Legal, Letter-R)Non-Collating Tray: 250 Sheets (Letter, Statement-R, Executive) 125 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Lower Tray
2,450 Sheets (Letter)1,700 Sheets (Statement-R, Executive) 650 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Saddle Stitch Tray
15 Sheets (17 lb. to 20 lb. Bond) 10 Sheets (20 lb. to 28 lb. Bond)
Staple Capacity
2 Sheets (28 lb. Bond to 140 lb. Index)11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond)
Staple Positions
Double (11 x 17, Legal, Letter, Letter-R, Executive)
Hole Punch
Puncher Unit-AH1++
Paper Size: 11 x 17, Legal, Letter, Letter-R
Max. Paper Weight: 17 lb. Bond to 140 lb. Index
Punch Type: 3 Holes (Letter, 11 x 17) 2 Holes (Legal, Letter-R)
Punch Waste Tray Capacity: When approximately 3,000 Sheets of paper have been punched
Dimensions (H x W x D): 32-3/4 x 4-1/4 x 24-1/2
Weight: Approximately 15.9 lb. (7.2kg)
Paper Sizes
Fold Type
V-Fold
Dimensions
46-1/4 x 26-3/4 x 25-7/8 Installation Space (W x D): 55-1/2 x 33-1/2 (when the auxiliary tray is extended) 59-5/8 x 33-1/2 (when the optional Puncher Unit-AH1 is attached and the auxiliary tray is extended)
Weight
Approximately 101 lb. (50kg)
Fax Board
Description
Super G3 Fax Board-V1/Multi-Line Fax Board-H1
Applicable Line
Public Switched Telephone Network (PSTN) Connection Lines: One-Line (Super G3 Fax Board-V1), Two-Lines (Super G3 Multi-Line Fax Board-H1)
Print Board
Description
Color UFR II/PCL Printer Kit-N1(Std. for C5180i)
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
1GB RAM
Maximum Memory
1.5GB RAM
Hard Disk
80GB (Shared)
PDL Support
UFR II/PCL 5c
Optional PDL Support: PostScript 3 Emulation (PS Printer Kit-N1^)
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/ Server 2003, Citrix MetaFrame) Macintosh® (OS 10.2.8 or later)
PCL5c: Windows (Windows 98/Me/2000/XP/Server 2003, Citrix MetaFrame)
PS3 (Optional): Windows (Windows 98/Me/2000/XP/Server 2003, Citrix MetaFrame) Macintosh (OS 10.2.8 or later)Print Resolution:
UFR II/PS3: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi (Text and Line only for 1200 dpi)
PCL 5c:2400 Equivalent dpi x 600 dpi
Description
imagePASS-H1
Processor
Celeron M 1.5GHz
Standard Memory
256MB
Maximum Memory
512MB
Hard Disk
80GB
PDL Support
Adobe® Postscript® 3, PCL 5c
Interface Connections
10/100/1000Base-T (RJ-45)
Utility Software: Remote Scan 5.3 Command WorkStation for Windows; Command WorkStation for Mac Print Resolution: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi (Text only for 1200dpi)Options: 256MB RAM, Secure Erase v1.0, Hot Folders v2.0, Impose v2.6
Description
ColorPASS-GX100
Processor
Intel® Pentium® 4, 3.2GHzSystem: System 8
Standard Memory
1GB
Maximum Memory
2GB
Hard Disk
160GB
PDL Support
Adobe PostScript 3
Print Resolution: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi (Text only for 1200 dpi)Options: 1GB RAM, GA Package, GA Premium, Production Printing Package, Impose v2.6, ACI Kit, Removable HDDOTHER OPTIONAL ACCESSORIES Encrypted Secured Print Software-C1+++Barcode Printing Kit-A1***Web Access Software-E1^Universal Send Advanced Feature Set-A1^^Universal Send PDF Security Feature Set-A1^^Digital User Signature PDF Kit-A1Secure Watermark-A1Super G3 Fax Board-V1Super G3 Multi-Line Fax board-H1imageRUNNER 512MB Expansion RAM-C1imageRUNNER Security Kit-A2^^^Security Expansion Board-E1Voice Guidance Kit-A2Remote Operator's Software Kit-A2Plain Pedestal-E1Document Tray-J1Copy Tray-M1Copy Tray-N1Card Reader-D1Key Switch Unit-A2Braille Label Kit-A1ADF Access Handle-A1Stamp Unit-A1eCopy Suite imageWARE Suite
Send Expansion Sets
Description
Color Universal Send Feature (Standard)
Sending Method
E-Mail, I-FAX, SMB, File Server (FTP, IPX, WebDAV), User Inbox, Super G3 Fax (Optional)
Address Book Capacity
Max. 1,800 Destinations (Includes 200 One-Touch Buttons)
File Format
File, E-Mail: TIFF, JPEG, PDF, PDF (Compact)*,PDF (Trace & Smooth)*, PDF (OCR)*,Encrypted PDF**, Digital Signature PDF (Device**, User***)
I-Fax: B/W: TIFF (MH,MR, MMR) Color: TIFF (Profile-C)
Scan Density
70 ipm (300 dpi)
51 ipm (600 dpi)Network TWAIN Scan: Standard
Network Scan Utility: Color Network Scan Gear Footnotes:
* When configured on C5180, requires Universal Send PDF Advanced Feature Set-A1
** When configured on the C5180, requires Universal Send PDF Security Feature Set-A1
*** Requires Digital User Signature Kit-A1
^When configured on the C5180, requires UFR II/PCL Printer Kit-N1 if printing web pages; requires PS Printer Kit-N1 on C5180/C5180i if printing PDF files
^^Standard on C5180i
^^^Requires Security Expansion Board-E1
*^Requires iR 512MB Expansion RAM-C1
+ Available with Saddle Finisher-W2 only
++ Puncher Unit-AH1 can only be installed with either the Finisher-W1 or Saddle Finisher-W2
+++ Requires UFR II/PCL Printer Kit-N1
ENERGY STAR Qualified
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C5180i that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
 Return to Top
