Web Content Viewer
Actions
Color imageRUNNER C5185i
Support Color Multifunction Copiers
Specifications
Model Name
Type
Color Digital Multifunction Imaging System
Developing System
Dry Dual Component Developing System
Image Server Memory
Standard 1GB RAM
Maximum 1.5GB RAM Hard Disk Drive: 80GB
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max Copy Reservation
10 Jobs Color Mode: Auto Color, Full Color, Black, Single Color, Two Colors
Copy Exposure: Automatic or Manual (9 Levels)
Scanning Resolution
600 dpi x 600 dpi Copy Resolution: 600 dpi x 600 dpi Engine Resolution: 1200 dpi x 1200 dpi
Halftone
256 Gradations (Continuous-Tone)
Letter
Up to 51/51 ppm (Letter) (BW, Color)
First Copy Time
8.0 Seconds (Color)
6.2 Seconds (B/W)
Multiple Copies
1 to 999
Magnification
25% - 400% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Statement to 11x 17
Paper Weights:
Simplex: 70 ipm (300 dpi)/51 ipm (600 dpi)
Duplex: 100 ipm (300 dpi)/51 ipm (600 dpi)
Maximum Original Size
11 x 17Document Feeding Method: Single Pass Duplexing Automatic Document Feeder (Std.)
Standard Paper Capacity
Dual 550-Sheet Paper Cassettes
100-Sheet Stack Bypass
Manual Bypass
100-Sheet Stack Bypass Optional: Dual 550-Sheet Paper Cassettes
2,700-Sheet Paper Deck
Maximum Paper Capacity
100 Sheets
Output Sizes
Cassette
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, 12-5/8 x 17-11/16, Irregular size (3-15/16 x 5-7/8 to 12-7/8 x 18) and Envelopes
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index
Bypass
17 lb. Bond to 140 lb. Index
Duplexing
Standard Automatic Trayless Duplexing (Executive to 12 x 18)Image Reader: Duplex Color Image Reader-G1 (Standard)
Acceptable Originals: Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Max. Original Size: 11 x 17 Scan Feature
Network TWAIN Scan: Standard
Network Scan Utility: Color Network ScanGear
Warm Up Time
4 Minutes After Powering On
Power Requirements
120V AC, 60Hz, 20A
Power Consumption: 2,100W
Plug: NEMA 5-20P
Dimension
35-5/8 x 24-3/8 x 33-1/2
Installation Space (W x D): 35-1/2 x 33-1/2 (When Stack Bypass is Extended)
Weight
Approximately 309 lb. (140.2kg)
Toner
Black/Color
Estimated Toner Yield
27,000 Copies/Bottle (Estimated @ 5% Coverage), 36,000 Copies/Bottle (Estimated @ 5% Coverage)
Feeders
Description
Cassette Feeding Unit-Z2^^^
Capacity
550 Sheets x 2 Cassettes
Dimensions
12-1/4 x 24-3/8 x 27-3/4
Weight
Approximately 66.1 lb. (30kg)
Paper Supply Options
Description
Paper Deck-Y1
Paper Capacity
2,700 Sheets (20 lb. Bond)
Paper Sizes
Letter
Dimensions
17 x 12-3/4 x 23-1/4
Installation Space (W x D): 37-1/8 x 33-1/2
Weight
Output Options
Finishers Output Trays
Description
Finisher-X1
Paper Weights
Paper Size
Standard: 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Non-Standard Size: (3-15/16 x 5-7/8 to 12-7/8 x 18)
Number Of Trays
1 Tray
Paper Capacity Per Tray: 1,000 Sheets (Letter, Statement-R, Executive)
500 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Paper Capacity of Staple Mode: 1,000 Sheets/30 Sets (Letter, Executive) 500 Sheets/30 Sets (11 x 17, Legal, Letter-R)
Staple Capacity
Letter, Executive: 50 Sheets (17 lb. to 20 lb. Bond)
30 Sheets (20 lb. to 28 lb. Bond)
2 Sheets (28 lb. Bond to 140 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond)
20 Sheets (20 lb. to 28 lb. Bond)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R, Executive)
Dimensions
28-5/8 x 16-1/4 x 24
Installation Space (W x D): 46-1/2 x 33-1/2 (when the auxiliary tray is extended)
Weight
Approximately 35.3 lb. (16kg)
Description
Finisher-W1/Saddle Finisher-W2
Paper Weights
Paper Size
Number Of Trays
3 Trays Paper Capacity Per Tray
Non-Collating Tray: 250 Sheets (Letter, Statement-R, Executive)
125 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Upper Tray: 1,300 Sheets (Letter, Statement-R, Executive)
650 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Lower Tray: 2,450 Sheets (Letter), 1,700 Sheets (Statement-R, Executive), 650 Sheets (12 x 18, 11 x 17, Legal, Letter-R)
Staple Capacity
Upper/Lower Tray: 1,300 Sheets/100 Sets (Letter, Executive), 650 Sheets/50 Sets (11 x 17, Legal, Letter-R, Staple with Different Paper Sizes)Max. Stapling Capacity
Letter, Executive: 50 Sheets (17 lb. to 20 lb. Bond), 30 Sheets (20 lb. to 28 lb. Bond), 2 Sheets (28 lb. Bond to 140 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond), 20 Sheets (20 lb. to 28 lb. Bond), 2 Sheets (28 lb. Bond to 140 lb. Index)
Staple Positions
Corner (11 x 17, Legal, Letter, Letter-R, Executive), Double (11 x 17, Legal, Letter, Letter-R, Executive)
Paper Sizes
12 x 18, 11 x 17, Legal, Letter-R Saddle Stitch Capacity: 15 Sheets (17 lb. to 20 lb. Bond)
10 Sheets (20 lb. to 28 lb. Bond)Tray Capacity: 25 Sets (1 t o 5 Sheets), 15 Sets (6 to 10 Sheets), 10 Sets (11 to 15 Sheets)
Fold Type
V-Fold
Dimensions
46-1/4 x 26-3/4 x 25-7/8
Installation Space (W x D): 55-1/2 x 33-1/2 (when the auxiliary tray is extended), 59-5/8 x 33-1/2 (when the optional Puncher Unit-AH1 is attached and the auxiliary tray is extended)
Weight
Approximately 101 lb. (50kg)Puncher Unit-AH1**
Paper Size: 11 x 17, Legal, Letter, Letter-R
Max. Paper Weight: 17 lb. Bond to 140 lb. Index
Punch Type: 3 Holes (Letter, 11 x 17)
2 Holes (Legal, Letter-R)
Punch Waste Tray Capacity: When approximately 3,000 Sheets of paper have been punched
Dimensions (H x W x D): 32-3/4 x 4-1/4 x 24-1/2
Weight: Approximately 15.9 lb. (7.2kg)
Fax Board
Description
Super G3 Fax Boad-V2/G3 Multi-Line Fax Board-H2
Applicable Line
Public Switched Telephone Network (PSTN)
Connection Lines: One-Line (Super G3 Fax Board-V2), Two-Lines (Super G3 Multi-Line Fax Board-H2)Sending/Original Size: Statement to 11 x 17
Recording/Printing Size: Statement to 11 x 17
Print Board
Description
Color UFR II/PCL Printer Kit-N2 (Std. on C5185i)
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
1GB RAM
Maximum Memory
1.5GB RAM
Hard Disk
80GB (Shared)
PDL Support
UFR II/PCL 5c/PCL 6
Optional PDL Support: PostScript 3 Emulation (PS Printer Kit-N2^)Print Resolution:
UFR II/PS3: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi
PCL 5c: 2400 Equivalent dpi x 600 dpi
PCL 6: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi Printer Drivers
UFR II: Windows® (Windows 2000/XP/Server 2003/Windows Vista™)Citrix MetaFrame Macintosh®(OS 10.2.8 or Later)
PCL 5c: Windows (Windows 98/Me/2000/XP/Server 2003/Windows Vista) Citrix MetaFrame
PCL 6: Windows (Windows 98/Me/2000/XP/Server 2003/Windows Vista) Citrix MetaFrame
XPS:^^ Windows Vista
PS3 (Optional): Windows (Windows 98/Me/2000/XP/Server 2003/Windows Vista) Citrix MetaFrame Macintosh (OS 10.2.8 or Later)
Description
imagePASS-H1
Processor
Celeron® M 1.5GHz
System: System 8e
Connectable Device: Color imageRUNNER C5185
Standard Memory
256MB
Maximum Memory
512MB
Hard Disk
80GB
PDL Support
Adobe® PostScript™ 3, PCL 5cPrint Resolution: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi Utility Software: Remote Scan 5.3, Command WorkStation for Windows, Command WorkStation for Mac
Options: 256MB RAM, Secure Erase v1.0, Hot Folders v2.0, Impose v2.6
Interface Connections
10/100/1000Base-T (RJ-45)
Description
ColorPASS-GX100
Processor
Intel™ Pentium™ 4, 3.2GHz
System: System 8Connectable Device: Color imageRUNNER C5185
Standard Memory
1GB
Maximum Memory
2GB
Hard Disk
160GBDVD-ROM: Standard
PDL Support
Adobe PostScript 3Print Resolution: 1200 dpi x 1200 dpi, 2400 dpi Equivalent x 600 dpi
Options: 1GB RAM, GA Package, GA Premium, Production Printing Package, Impose v2.6, ACI Kit, Removable HDD
Send Expansion Sets
Description
Color Universal Send Feature (Standard)
Sending Method
E-Mail, I-FAX, SMB, File Server (FTP, IPX, WebDAV), User Inbox, Super G3 Fax (Optional)Color Mode: Auto Color Select (Full Color/Gray Scale) Auto Color Select (Full Color, B/W) Full Color, Grayscale, B/W
Address Book Capacity
Max. 1,800 Destinations (Includes 200 One-Touch Buttons)
File Format
Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-Mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full)
Data Format
File, E-Mail: TIFF, JPEG, PDF, PDF (Compact),*PDF (Trace & Smooth),* PDF (OCR),*Encrypted PDF,** Digital Signature PDF (Device,** User***)
I-Fax: B/W: TIFF (MH, MR, MMR) Color: TIFF (Profile-C)OTHER OPTIONAL ACCESSORIES Encrypted Secured Print Barcode Printing Kit-A1 Web Access Software-E1 Universal Send PDF Advanced Feature Set-A1 Universal Send PDF Security Feature Set-A1 Digital User Signature PDF Kit-A1 Secure Watermark-A1 Super G3 Fax Board-V2 Super G3 Multi-Line Fax Board-H2 imageRUNNER 512MB Expansion RAM-C1 HDD Encryption Kit-B1 HDD Erase Kit-A1 Voice Guidance Kit-A2 Voice Operation Kit-A1 Remote Operator's Software Kit-A2 Plain Pedestal-E2 Document Tray-J1 Copy Tray-M1 Copy Tray-N1 Stack Bypass Alignment Tray-B1 Card Reader-D1 Key Switch Unit-A2 Braille Label Kit-A1 ADF Access Handle-A1 Stamp Unit-A1e Copy Suiteimage WARE® Suite Access Management System Kit-A1 Workflow Composer-B1
Awards
BLI 2008 Pick of the Year Award
BLI 2008 Highly Recommended
Better Buys for Business 2008 Editor's Choice
BLI 2008 Reliability Certified
2010 BLI Performance Certified Seal
Product Configurator
Click here for the Color imageRUNNER C5185 / C4580 / C4080 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
