Web Content Viewer
Actions
Color imageRUNNER LBP5460
Support Color Multifunction Copiers
Specifications
Model Name
Printing Process
Electrophoto Method (Color RAPID Fusing System)
Developing System: Dry Dual Component Developing System
Type: Desktop Color Laser Printer
Memory
(RAM): Standard 256 MB, Maximum 768 MB*
Hard Disk Drive: Optional 60GB
CPU: R4000 Series (400 MHz)**
MIPS64 Series (533 MHz)**
Printer Driver
UFR II/PCL 5c/PCL6/PostScript 3 Emulation (Std)UFR II/PS3: Windows 2000/XP/Windows Vista/Server 2003/Server 2008
Citrix MetaFrame
Macintosh (OS 10.4 or Later)
Novell NetWare v3.20/4.1/4.11/4.20/5.0/5.1/5.5 (IPX/SPX)
Novell NetWare v6.0/6.5 (TCP/IP)PCL 5c/6: Windows 2000/XP/Windows Vista/Server 2003/Server 2008
Citrix MetaFrame
Interface
Connections: 10/100Base-TX (RJ-45)
Wireless LAN (IEEE 802.11)***
Other Interface: USB 2.0 Hi-Speed
USB Full-Speed (USB 1.1 Equivalent)
User Interface: LCD 22 Characters x 5 Lines, 9 LED Indicators, 10 Operation Keys
Paper Handling
Standard Input Upper Cassette
Paper Size
250-Sheet Paper Cassette (20 lb. Bond
100-Sheet Multi-Purpose Tray (Std)
Maximum: 850 Sheets
Letter, Executive, Custom Sizes
(Width: 5-7/8 to 8-1/2; Length: 8-1/4 to 11-5/8)
Maximum Size: Legal (216mm x 355.6mm)
Paper Weight
Standard Cassette: 16 lb. Bond to 60 lb. Cover
Multi-Purpose Tray: 16 lb. Bond to 8- lb. Cover
Optional Cassette: 16 lb. Bond to 65 lb. cover
Standard Input Multi Purpose Tray
Paper Size
Legal, Letter, Executive, Statement, Custom Sizes
(Width: 3-7/8 to 8-1/2; Length: 5-3/4 to 14), and Envelopes
Paper Weight
16 lb. Bond to 80 lb. Cover
Optional Input
500-Sheet Paper Cassette
Legal, Letter, Executive, Custom Sizes
(Width: 5-7/8 to 8-1/2; Length: 8-1/4 to 14)
16 lb. Bond to 65 lb. Cover
Standard Output
Approx. 250 Sheets (20 lb. Bond)
Paper Output: Face-Down
Duplexing: Standard Automatic Trayless Duplexing (Executive to Legal)
Dimensions
14-5/8 x 20-1/4 x 20-3/4
Installation Space (W x D): 29-1/8 x 32-1/4 (When Multi-Purpose Tray is Extended)
Weight
Approx. 68.3 lb. (31.0 kg)††
Power Source
120V 60Hz
Plug: NEMA 5-15P
Power Consumption
Average Printing
573W (Approx., Average)
Standby: 47W (Approx., Average)
Power Saver Mode
18W (Approx., Average)
Deep Sleep Mode: 1.8W (Approx., Average)
Copy Speed (copies per minute)
Letter
(B/W, Color): Up to 31/31 ppm
Resolution
Print: 2400-dpi equivalent x 600 dpi
Engine: 600 x 600 dpi
Halftone: 256 Gradations (Continuous-Tone)
Warm Up Time
7 Seconds from Standby
60 Seconds or Less from Power On
First Copy Time
10.2 Seconds (B/W)
10.4 Seconds (Color)Optional Accessories
PAPER FEEDER UNIT PF-723♦
Paper Sizes: Legal, Letter, Executive, Custom Sizes (Width: 5-7/8 to 8-1/2; Length: 8-1/4 to 14)
Paper Capacity: 500 Sheets (20 lb. Bond)
Dimensions (H x W x D): 6-3/8 x 20-1/4 x 20-3/4
Weight: Approx. 17.2 lb. OTHER Barcode Printing ROM A-723AWireless Network Interface Board NB-W2Hard Disk Kit HD-723Expansion RAM ER-128A, ER-256A, ER-512A** One memory slot available for expanding memory.
** The upper limit of the frequency range.
*** Through optional Wireless LAN Kit.
† Excluding the toner cartridges.
†† Toner cartridge yield in accordance with ISO/IEC 19798.
Δ Main unit ships with starter cartridges: Average Black (GPR-29) Starter Cartridge: 3,000 standard pages; Average Composite Cyan/Magenta/Yellow (GPR-29) Starter Cartridge: 4,100 standard pages.
♦ One Paper Feeder Unit can be added.
Toner
GPR-29
Estimated Toner Yield For Black and White
10,000 Standard Pages††Δ
Estimated Toner Yield For Color
8,500 Standard Pages††Δ
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER LBP5460 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
