Web Content Viewer
Actions
Color imageRUNNER LBP5960
Support Color Multifunction Copiers
Features
The Canon imageRUNNER LBP Series is powered by a system architecture that is similar to the current imageRUNNER line, and provides unparalleled speed, power and functionality. Fast processing of large and complex documents is further enhanced through expandable onboard memory. Whether the needs of users are basic or more demanding, the imageRUNNER LBP Series offers a scalable solution to all environments.
The imageRUNNER LBP Series produces output of unparalleled quality, regardless of the document. Users can print remarkably sharp and impactful presentations, architectural renderings, engineering diagrams or general office documents at high speed. The Color imageRUNNER LBP5960 utilizes an innovative compact 4-in-1 laser beam unit that reaches true 1200 dpi output* in super fine mode for enhanced image clarity and gradients, or fine mode for precise output at 600 dpi.
The imageRUNNER LBP Series utilizes the same consistent printer driver that Canon developed for the imageRUNNER line. By standardizing the driver interface across the entire imageRUNNER series - from desktop to production devices - users need to only familiarize themselves with one universal set of print functions. Each intuitive tab in the printer driver provides graphical icons representing the device, as well as the page layout of the particular print job being submitted. Additionally, the Dynamic Configuration function of the printer driver always displays accurate information on the device&#39;s configuration options and installed paper to eliminate errors. The imageRUNNER printer driver is compatible with both Windows and Macintosh environments.<br/> <br/>
The Canon UFR II Print Controller is included in all three models in the Canon imageRUNNER LBP Series. This proprietary architecture has been consistently proven to deliver faster output than PCL or PS page description languages for complex documents that include images, graphics and text. The UFR II Controller achieves high-performance printing by automatically distributing data processing between the print driver on the user&#39;s desktop computer and the imageRUNNER LBP device. The intelligent architecture automatically determines the optimal balance of processing by analyzing the layout and graphic components of each page. This unique approach maintains exceptionally high print performance on office documents and PDF files. The print controller provides support for UFR II, PCL 5c (Color imageRUNNER LBP5960 and LBP5360), and PCL 5e/6 (imageRUNNER LBP3460).<br/> <br/>
The long wait for printed output is over since the Canon imageRUNNER Series requires no warm-up time from standby mode to produce documents fast. The power of the RAPID Fusing System is inside each model, which uses a special fixing film and ceramic heater unlike traditional roller-fixing devices. RAPID Fusing System provides exceptional image quality with zero warm-up time and reduces first print-out time, while requiring less heat and energy consumption.<br/> <br/>
The Color imageRUNNER LBP5960 uses the new QF (Quick Fixing) Color Toner. This new oil-less toner has special properties that enable it to melt fast at low temperature and pressure to maintain fast output with Color RAPID Fusing System.
The Color imageRUNNER LBP5960 requires less valuable desktop space, yet is able to produce larger format double-sided color documents with ease. The new 4-in-1 laser scanner in the Color imageRUNNER LBP5960 uses four individual lasers aimed at one polygon mirror from different angles to expose each beam to the drum. This remarkable design is responsible for the compact size of the device because it does not need a separate laser scanner for each image drum.<br/> <br/>
The Color imageRUNNER LBP5960 features a remarkably short vertical paper path, resulting in short first print-out times of 7.5 seconds (monochrome) and 9.0 seconds (color). The short path also contributes to the extremely compact size of the device.<br/> <br/>
All models in the Canon imageRUNNER LBP Series are remarkably compact and feature front-load access to consumables such as drum, toner, fuser and paper supply. This enables the devices to be conveniently placed either on top of or below a desk, in a corner, or in previously unusable space.<br/> <br/>
The Canon imageRUNNER LBP Series features a standard auto-duplexing function that can save paper costs by printing double-sided documents with nonstop productivity. Using a trayless duplexing design, the imageRUNNER LBP Series assures high reliability of paper feeding in a very compact size. In addition, each model offers options that provide extra paper capacity for even longer continuous operation. Up to three optional 550-sheet cassettes can be installed on the Color imageRUNNER LBP5960.
The Canon imageRUNNER LBP Series has been designed to optimize productivity through the minimization of downtime. This is achieved through the front-load access to all customer replaceable components. When replacements are required, each toner cartridge and image drum can be replaced individually to improve operating cost effectiveness.<br/> <br/>
Specifications
Model Name
Printing Process
Type: Desktop Color Laser Printer
Printing Method: Electrophoto Method (Color On-Demand Fusing)
Developing System: Dry Dual Component Developing System
Letter
30/30 ppm
First Print Time
7.5 Seconds (B/W)
9.0 Seconds (Color)
Warm-Up Time: 0 Seconds From Standby
30 Seconds or Less After Powering ON
Processor
PowerPC 750CXr (400 MHz **)
Memory
Standard 128 MB RAM
Maximum 384MB RAM*
Hard Disk Drive: Optional 20GB
Page Description Language
UFR II, PCL5c
Print Resolution
UFR II: 1200 dpi x 1200 dpi *** (Super Fine Mode)
2400 dpi equivalent x 600 dpi (Fine Mode)
PCL5c: 2400 dpi equivalent x 600 dpi
Engine Resolution: 1200 dpi x 1200 dpi
Printer Driver
UFR II: Windows® (Windows 2000/XP/Server 2003, Citrix MetaFrame), Macintosh® (OS 10.2.8 or later)
PCL5c:Windows (Windows 98/Me/2000/XP/Server 2003, Citrix MetaFrame)
Halftone: 256 Gradations (Continuous-Tone)
Interface
Connections: Parallel Connector (IEEE1284 Compatible)
10/100 Base-TX (RJ-45)
Other Interface: USB 2.0 High Speed / USB Full-Speed (USB 1.1 Equivalent)
User Interface: LCD 16 Characters x 1 Line
10 LED Indicators
8 Operation Keys
Paper Handling
Standard Input Upper Cassette
Paper Size
Ledger, Legal, Letter, Executive
Paper Weight
17 lb. Bond to 28 lb. Bond
Standard Input Multi Purpose Tray
Paper Size
Ledger, Legal, Statement, Letter, Executive, Custom Sizes (Width: 3-7/8 to 5-3/4 Length: 5-1/2 to 18), Long Size Paper (Width: 8-3/8 to 11-3/4 Length: 18 to 47-1/4) and Envelopes
Paper Weight
17 lb. Bond to 80 lb. Cover Paper Sources
Standard: 230-Sheet Paper Cassette (20 lb. Bond)
90-Sheet Multi Purpose Tray
Optional: 550-Sheet x Up To 3 Paper Cassettes
Maximum: 1,970 Sheets
Maximum Paper Size: 11x17 (305x457mm Paper Size)
Output Capacity: Approximately 250 Sheets (20 lb. Bond)
Paper Output: Face Down
Duplexing: Standard Automatic Trayless Duplexing (Executive to 11 x 17)
Dimensions
15 x 21-1/2 x 24
Installation Space (W x D): 21-1/2 x 35-7/8 (When the Multi Purpose Tray is extended)
Weight
Approximately 114.6 lb.****
Power Source
120V - 127V 60 Hz
Plug: NEMA 5-15P
Power Consumption
Standard
Operating: Approximately 585 W (Average)
Standby: Approximately 29 W (Average)
Power Saver Mode
Approximately 10 W (Average)
Estimated Toner Yield For Black and White
10,000 images@5% coverage *****
Estimated Toner Yield For Color
6,000 images@5% coverage ***** Optional Accessories
Paper Feeder Unit PF-98******
Paper Sizes: Ledger, Legal, Letter, Executive, Custom Sizes (Width: 8-3/8 to 11-3/4 Length: 8-3/8 to 17)
Paper Cassettes Capacity: 550 Sheets (20 lb. Bond)
Dimensions (H x W x D): 5-5/8 x 21-1/2 x 27-1/2
Weight: Approximately 24.3 lb. Other Optional Accessories Hard Disk KIT HD-98ABarcode Printing Kit A-98AWASTE TONER BOX WT-98CFUSER KIT UM-98FCabinet-W1Cabinet-X1EXPANSION RAM ER-128EXPANSION RAM ER-256
Footnotes:* One memory slot available for expanding memory
** The upper limit of the frequency range
*** If 1200 dpi print is selected, engine speed will slow down
**** Excluding the Toner Cartridges and Drum Cartridges
***** When printing Letter size paper at 5% page coverage with the default print density settings
****** Up to three additional paper cassette can be added.
Awards
BLI 2007 Reliability Seal
BERTL 4 Star Highly Recommended
BLI 2007 Recommended
Brochures
Loading...
 Return to Top
