Web Content Viewer
Actions
Color imageRUNNER LBP5970
Support Color Multifunction Copiers
Features
The Canon imageRUNNER LBP Series is powered by a system architecture that is similar to the current imageRUNNER line, and provides unparalleled speed, power and functionality. Fast processing of large and complex documents is further enhanced through expandable onboard memory. Whether the needs of users are basic or more demanding, the imageRUNNER LBP Series offers a scalable solution to all environments.
The imageRUNNER LBP Series produces output of unparalleled quality, regardless of the document. Users can print remarkably sharp and impactful presentations, architectural renderings, engineering diagrams or general office documents at high speed. The Color imageRUNNER LBP5970 utilizes an innovative compact 4-in-1 laser beam unit that reaches true 1200 dpi output* in super fine mode for enhanced image clarity and gradients, or fine mode for precise output at 600 dpi.&lt;br&gt;&lt;/br&gt;<br/> *Printing at 1200-dpi on Color imageRUNNER LBP5975/LBP5970 models may result in reduced engine speed.
The imageRUNNER LBP Series utilizes the same consistent printer driver that Canon developed for the imageRUNNER line. By standardizing the driver interface across the entire imageRUNNER series - from desktop to production devices - users need to only familiarize themselves with one universal set of print functions. Each intuitive tab in the printer driver provides graphical icons representing the device, as well as the page layout of the particular print job being submitted. Additionally, the Dynamic Configuration function of the printer driver always displays accurate information on the device&#39;s configuration options and installed paper to eliminate errors. The imageRUNNER printer driver is compatible with both Windows and Macintosh environments.
The Canon UFR II Print Controller is included in all three models in the Canon imageRUNNER LBP Series. This proprietary architecture has been consistently proven to deliver faster output than PCL or PS page description languages for complex documents that include images, graphics and text. The UFR II Controller achieves high-performance printing by automatically distributing data processing between the print driver on the user&#39;s desktop computer and the imageRUNNER LBP device. The intelligent architecture automatically determines the optimal balance of processing by analyzing the layout and graphic components of each page. This unique approach maintains exceptionally high print performance on office documents and PDF files. The print controller provides support for UFR II, PCL 5c (Color imageRUNNER LBP5975, LBP5970, LBP5960 and LBP5360), and PCL 5e/6 (imageRUNNER LBP3460).
The long wait for printed output is over since the Canon imageRUNNER Series requires no warm-up time from standby mode to produce documents fast. The power of the RAPID Fusing System&#153; is inside each model, which uses a special fixing film and ceramic heater unlike traditional roller-fixing devices. RAPID Fusing System&#153; provides exceptional image quality with zero warm-up time and reduces first print-out time, while requiring less heat and energy consumption.
The Color imageRUNNER LBP5970 uses the new QF (Quick Fixing) Color Toner. This new oil-less toner has special properties that enable it to melt fast at low temperature and pressure to maintain fast output with Color RAPID Fusing System.
The Color imageRUNNER LBP5970 requires less valuable desktop space, yet is able to produce larger format double-sided color documents with ease. The new 4-in-1 laser scanner in the Color imageRUNNER LBP5970 uses four individual lasers aimed at one polygon mirror from different angles to expose each beam to the drum. This remarkable design is responsible for the compact size of the device because it does not need a separate laser scanner for each image drum.
The Color imageRUNNER LBP5970 features a remarkably short vertical paper path, resulting in short first print-out times of 7.5 seconds (monochrome) and 9.0 seconds (color). The short path also contributes to the extremely compact size of the device.
All models in the Canon imageRUNNER LBP Series are remarkably compact and feature front-load access to consumables such as drum, toner, fuser and paper supply. This enables the devices to be conveniently placed either on top of or below a desk, in a corner, or in previously unusable space.
The Canon imageRUNNER LBP Series features a standard auto-duplexing function that can save paper costs by printing double-sided documents with nonstop productivity. Using a trayless duplexing design, the imageRUNNER LBP Series assures high reliability of paper feeding in a very compact size. In addition, each model offers options that provide extra paper capacity for even longer continuous operation. Up to three optional 550-sheet cassettes can be installed on the Color imageRUNNER LBP5970.
The Canon imageRUNNER LBP Series has been designed to optimize productivity through the minimization of downtime. This is achieved through the front-load access to all customer replaceable components. When replacements are required, each toner cartridge and image drum can be replaced individually to improve operating cost effectiveness.
Specifications
Model Name
Printing Process
Type: Desktop Color Laser Printer
Copying Method: Electrophoto method (Color RAPID Fusing System)
Developing System: Dry Dual Component Developing System
Letter
31/30 ppm
First Print Time
Black and White: 7.5 Sec.
Color: 9.0 Sec.
Warm-Up Time: 0 Seconds from Standby, 30 Seconds or Less from Power On
Processor
R4000 Series (400 MHz***)
MIPS64 Series (533 MHz***)
Memory
Standard: 256MB RAM
Maximum: 768MB RAM*
Hard Disk Drive: Optional 30GB
Page Description Language
UFR II/PCL5c/6
Optional PDL Support: PostScript® 3™ Emulation (PS ROM 98B/98C)Print Resolution
Super Fine Mode: 1200 dpi x 1200 dpi
Fine Mode: 2400 dpi equivalent x 600 dpi
PCL5c/6: 2400 dpi equivalent x 600 dpi
PS3 (Optional): 1200 dpi x 1200 dpi (Text and Line Only)
Engine Resolution: 1200 dpi x 1200 dpi
Printer Driver
UFR II: Windows® (Windows 2000/XP/Vista®/ Server 2003), Citrix MetaFrame/Macintosh® (OS 10.3.3 or later)/Novell Netware® v3.20/4.1/4.11/4.20/5.0/5.1/6.0/6.5 (IPX/SPX)
PCL5c/6: Windows (Windows 2000/XP/Vista/Server 2003), Citrix MetaFrame
PS3 Emulation: Windows (Windows98/Me/2000/XP/Server 2003), Citrix MetaFrame/Macintosh (OS 10.3.3 or later)
Halftone: 256 Gradations (Continuous-Tone)
Interface
Network Interface Connections: 10/100Base-TX (RJ-45)
Wireless LAN (IEEE 802.11)**
Other Interface: USB 2.0 Hi-Speed/USB Full-Speed (USB 1.1 Equivalent)
User Interface: LCD 16 Characters x 1 Line
11 LED Indicators, 9 Operation Keys
Paper Handling
Standard Input Upper Cassette
Paper Size
Ledger, Legal, Letter, Executive
Paper Weight
17 lb. Bond to 28 lb. Bond
Standard Input Multi Purpose Tray
Paper Size
Ledger, Legal, Statement, Letter, Executive, Custom Sizes (Width: 3-7/8 to 5-3/4 Length: 5-1/2 to 18), Long Size Paper (Width: 8-3/8 to 11-3/4 Length: 18 to 47-1/4) and Envelopes
Paper Weight
17 lb. Bond to 80 lb. Cover
Paper Sources
Standard: 230-Sheet Paper Cassette (20 lb. Bond)
90-Sheet Multi Purpose Tray
Optional: 550-Sheet x Up to 3 Paper Cassettes
Maximum: 1,970 Sheets
Maximum Paper Size: 11 x 17 (305 x 457mm Paper Size)
Output Capacity: Approximately 250 Sheets (20 lb. Bond)
Paper Output: Face-Down
Duplexing: Standard Automatic Trayless Duplexing
Dimensions
15 x 21 x 25
Installation Space (W x D): 21 1/2 x 37 3/5 (When Multi-Purpose Tray is Extended)
Weight
Approximately 106.9 lb.
Power Source
120V - 127V 60Hz
Plug: NEMA 5-15P
Power Consumption
Standard
Operating: Approximately 653W (Average)
Standby: Approximately 34W (Average)
Power Saver Mode
Approximately 14W (Average)
Deep Sleep Mode: Approximately 1W (Average)
Estimated Toner Yield For Black and White
10,000 images @ 5% coverage††
Estimated Toner Yield For Color
6,000 images @ 5% coverage††OPTIONAL ACCESSORIES
Paper Feeder Unit-PF-98B†††
Paper Sizes: Ledger, Legal, Letter, Executive, Custom Sizes (Width 8-3/8 to 11-3/4; Length 8-3/8 to 17)
Paper Cassettes Capacity: 550 Sheets x 3 Cassettes (20 lb. Bond)
Dimensions (H x W x D): 5-5/8 x 21-1/2 x 27-1/2
Weight: Approximately 24.3 lb.
Other Optional Accessories PostScript 3 Emulation/Barcode Printing ROM A-98BPostScript 3 Emulation ROM A-98CWireless Network Interface Board NB-W2Hard Disk Kit HD-98BCabinet-W1 (Small)^Cabinet-X1 (Large)^^Expansion RAM ER-128A*Expansion RAM ER-256A*Expansion RAM ER-512A*
* One memory slot available for additional memory.
** Through optional Wireless LAN Kit.
*** The upper limit of the frequency range.
^ If 1200-dpi print is selected, engine speed will be reduced.
^^ Up to three additional paper feeder units can be installed when Cabinet-W1 is attached.
^^^ Up to one additional paper feeder unit can be installed when Cabinet-X1 is attached.
† Excluding the Toner Cartridges and Drum Cartridges.
†† When printing letter-sized paper at 5% page coverage with the default print density settings.
††† Up to three additional paper feeder units can be added.
PostScript 3 emulation/Barcode Printing ROM A-98B and PostScript 3 emulation ROM A-98C cannot be installed together.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER LBP5970 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
