Web Content Viewer
Actions
imageRUNNER ADVANCE C5045
Support Color Multifunction Copiers
Features
New Advanced imageCHIP system architecture uses two processors to deliver outstanding multitasking performance. "Slide and Tilt" control panel allows users to adjust the UI to a comfortable and accessible position. Two menus streamline your workflow. The Main Menu gives you instant access to system functions, while the Quick Menu powers productivity by allowing you to combine and access routine tasks at the touch of a button. A universal design that's not only appealing to the eye but also easy and comfortable to operate. Compact footprint, soft curves and natural soothing color palette create harmony between innovation and your work environment.
Rapidly convert paper documents to digital files with the 150-sheet capacity, ultra-fast single-pass duplex document feeder at speeds of up to 100 ipm (duplex 300 dpi). A choice of modular in-line accessories makes professionally finished documents simple, including an optional inner finisher with 50-sheet multi-position stapling. Advanced Box, Canon's new built-in document sharing solution enhances the ability of multiple users to collaborate. Files can be stored in Advanced Box shared folders and accessed from multiple locations including a PC or other networked imageRUNNER ADVANCE systems. Whether from the imageRUNNER ADVANCE model or at your own desk, you can have direct access to the functions that make your work easier with the imageRUNNER ADVANCE Desktop utility. The Workflow Composer utility reduces multi-step and frequently performed operations to the touch of one button that can be placed on the Quick Menu. Universal Send provides an expanded range of file formats including High Compression PDF/XPS, Adobe PDF Reader Extensions, Searchable PDF, OOXML, PDF (Optimize for Web), PDF (Apply Policy), PDF/A-1b and Encrypted PDF. Canon's UFR II print technology is standard with this model, optional Adobe PostScript 3 and PCL 5c/6 are also supported. Scan to or print from a USB thumb drive or optional memory media. Enter data more comfortably with the optional USB keyboard.
Canon offers a number of security features for document security, data security, mail server security, logging/auditing security and authentication. Access Management System allows you to limit device access by user, group or role and you can even limit access for only specific functions such as Send. The Trusted Platform Module allows you to safeguard vulnerable settings such as passwords with a new security chip featuring tamper-resistant hardware. With Document Scan Lock and Tracking you can embed hidden tracking information in a document to restrict unauthorized copying or scanning and to track the origin. Disguise information before it's written to the hard drive, and permanently remove it by overwriting when the job is complete with data encryption and erase options. The Remote User Interface gives you centralized control for any individual device right from your desktop, so that you can check supply levels, monitor jobs and stay completely informed. The imageWARE Enterprise Management Console offers one central point of control for all systems across your organization. This web-based utility makes it easy to install and manage multiple Canon and third-party networked devices. Adobe LiveCycle Rights Management ES Integration protects access to documents throughout their duration. After documents are scanned, specify security policies and select authorized recipients. The imageRUNNER ADVANCE Series makes it easier to track, manage and influence user behavior. From analyzing color output by employee or client to encouraging double sided printing, you can ensure that resources are employed optimally and costs are allocated accurately.
Reduce costs, increase performance with the ability to streamline workflow. Outstanding image quality for striking results. Retrieve information from other imageRUNNER ADVANCE models on the network to help eliminate extra hardware or to easily collaborate. Reduce downtime with the ability to replace toner on the fly. If incorrect paper size or stack for a job is unavailable, the system can begin the next job without delay. New level of connector and link support through Canon's innovative MEAP platform. With 1200 x 1200 dpi print resolution, text is sharp with smooth corners, and images have subtle gradient transitions. Innovative technologies, including Canon's fine-grained pQ toner, produce rich, clear, vivid images with a smooth, high quality finish.
Canon's life cycle assessment system helps to reduce C02 emissions by more than 30% over previous models. Compact with less packaging for efficient transportation. Designed with 100% recycled plastic and bio-based plastic for certain components. Meets Energy Star standards. New pQ toner and Advanced RAPID fusing system helps to reduce overall energy consumption by minimizing heat and power requirements. Power consumption for sleep mode is 1w or less Meets and exceeds ROHS directive.
Specifications
Model Name
Type
Color Digital Multifunction Imaging System Functions
Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up to 4 Lines)Operation Panel
8.4 SVGA Full-Color, TFT Screen
Image Server Memory
Standard: 2GB RAM
Maximum: 2.5GB RAM Hard Disk Drive
Standard: 80GB
Maximum: 250GBMirroring Hard Disk Drive
Optional (80GB, 250GB) Method: RAID1Network Interface Connection
Standard: 10/100/1000Base-TX
Optional: Wireless LAN (IEEE 802.1x)Other Interface
Standard: USB 2.0 (Host)x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host)x2], Serial Interface, Copy Control Interface
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max. Pages Stored: 6,000Advanced Box
Available Disk Space: Approx. 10GB (Standard HDD)
113GB (250GB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 2000/XP/Windows Vista)
Max. Number of Concurrent Connection: SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support Memory Media
Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive
Scanning Resolution
Up to 600 x 600 dpi
Network TWAIN Scan Standard
Network Scan Utility Color Network ScanGear
Letter
Up to 45/45 ppm
Legal
Up to 26/26 ppm
Ledger
Up to 26/26 ppm
First Copy Time
(Letter) B/W: 4.0 Seconds
Color: 6.5 Seconds
Multiple Copies
1 to 999Color Mode:
Auto Color, Full Color, Black, Single Color, Two Colors Copy Exposure
Automatic or Manual (9 Levels)
Magnification
25% - 400% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%Basic Copy Features
Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying Special Copy Features
Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox
Acceptable Originals
Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2kg)]
Maximum Original Size
Up to 11 x 17
Standard Paper Capacity
Dual 550-sheet Cassettes
100-sheet Stack Bypass
Optional: Dual 550-sheet Cassettes
2,700-sheet Paper Deck
Maximum Paper Capacity
5,000 Sheets Output Paper Capacity (20 lb. Bond)
Standard: 250 Sheets (Inner Tray)
Maximum: 3,250 Sheets (w/Staple Finisher or Booklet Finisher)
Output Sizes
Cassette
12 x 18,* 11 x 17,* Legal, Letter, Letter-R, Statement-R, Executive, Custom Size [5-1/2 x 7-1/8 to 12 x 18
Bypass
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8 x 5-1/2 to 12-5/8 x 18Paper Deck:
Letter Other Options:
Envelope Feeder Attachment** (COM10 No.10, Monarch, DL, ISO-B5, ISO-C5) Tab Feeding Attachment Kit**
Acceptable Paper Weights
Cassette
14 lb. Bond to 110 lb. Index
Bypass
14 lb. Bond to 140 lb. Index
Duplexing
Paper Size: Standard Automatic Trayless Duplexing (Executive to 12 x 18)
Paper Weights: 14 lb. Bond to 110 lb. Index Special Media Support
Tracing, Labels, Transparency, Tab, and Envelopes
Warm Up Time
38 Seconds from Power On
18 Seconds from Sleep Mode
Power Requirements
120V AC, 60Hz, 20A/NEMA 5-20PPower Consumption
Maximum: 1,800W; Sleep Mode: 1W
Dimension
38-5/8 x 24-3/8 x 29-7/8Installation Space (W x D) 42-1/8 x 52
Weight
Approx. 379 lb. (172kg)***Security Specifications
Standard Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Address on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, Adobe® LiveCycle® Rights Management ES Integration
Optional
Removable HDD, HDD Erase, HDD Encryption/Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, IPSec, Secure Watermark Environmental Information
ENERGY STAR® Qualified, RoHS Compliant, Ecomark, Blue Angel, WEEE Directive
Estimated Toner Yield
Black: 44,000 Images
Color (C,M,Y): 38,000 Images
Feeders
Description
Single-Pass Duplexing Automatic Document Feeder
Paper Sizes: 11 x 17, Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weights: One-sided Scanning: 11 lb. Bond to 32 lb. Bond
Two-sided Scanning: 13 lb. Bond to 32 lb. Bond
Scanning Speed
Simplex: 70/70 ipm (300 dpi)
70/51 ipm (600 dpi)
Duplex: Up to 100/100 ipm (300 dpi)
Up to 70/51 ipm (600 dpi)
Paper Weights
150 Sheets
Paper Supply Options
Description
Cassette Feeding Unit-AD1
Paper Capacity
550 Sheets x 2 Cassettes (20 lb. Bond)
Paper Sizes
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2 x 7-3/16 to 12 x 18
Paper Weights
Power Source
From Main Unit/Approx. 30W
Maximum Power Consumption: Approx. 30W
Dimensions
9-7/8 x 24-3/8 x 27-5/8
Weight
Approx. 60.6 lb.
Description
Paper Deck Unit-B1††
Paper Capacity
2,700 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
14 lb. Bond to 28 lb. Bond
Power Source
From Main Unit/Approx. 45W
Dimensions
18-5/8 x 14-5/8 x 23-3/4
Weight
Approx. 81.6 lb.
Description
Envelope Feeder Attachment-D1**
Paper Capacity
50 Sheets (or 30mm in height)
Acceptable Envelope Sizes: COM10 No.10, Monarch, DL, ISO-B5, ISO-C5
Feeding Speed: 10 cpm
Dimensions
3-1/4 x 17-1/4 x 12-1/8
Weight
Approx. 2.6 lb.
Description
Copy Tray-J1†††
Paper Capacity
100 Sheets (20 lb. Bond)
Paper Sizes
11 x 17, Legal, Letter, Letter-R, Statement-R and Executive
Paper Weights
Dimensions
5-5/8 x 14-3/8 x 14-3/4
Weight
Approx. 1 lb.
Staplers and Sorters
Description
Inner 2-Way Tray-F1Δ
Paper Weights
Paper Size
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8 x 5-1/2 to 12-5/8 x 18 and Envelopes
Number Of Bins
2Total Output Capacity: Top Tray: 250 Sheets (20 lb. Bond)
Lower Tray: 100 Sheets (20 lb. Bond)
Dimensions
3 x 16-3/4 x 16
Weight
Approx. 1.3 lb.
Output Options
Finishers Output Trays
Description
Inner Finisher-A1
Paper Weights
Paper Size
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size and Envelopes
Number Of Trays
Up to 2 Trays (with Inner Finisher Additional Tray-A1)Total Output Capacity: Without Inner Finisher Additional Tray-A1: 500 Sheets
Top Tray
With Inner Finisher Additional Tray-A1: 100 Sheets (Letter)
Lower Tray
With Inner Finisher Additional Tray-A1: 200 Sheets (Letter)
Staple Capacity
Letter: 50 Sheets (14 lb. Bond - 21 lb. Bond)
30 Sheets (22 lb. Bond - 28 lb. Bond)
2 Sheets (29 lb. Bond - 140 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (14 lb. Bond - 21 lb. Bond)
20 Sheets (22 lb. Bond - 28 lb. Bond)
2 Sheets (29 lb. Bond - 140 lb. Index)Paper Capacity of Staple Mode: Top Tray: 3/8 in Height
Lower Tray: 30 Sets (or 2-1/2 in Height)
Staple Positions
Corner Stapling: 11 x 17, Legal, Letter, Letter-R
Double Stapling: 11 x 17, Legal, Letter, Letter-R Type of Staple: Staple-J1 (5,000 x 3)
Power Source
From Main Unit/Approx. 50W
Dimensions
9-1/4 x 34-1/8 x 21-1/4
Weight
Approx. 28.7 lb.
Description
Staple Finisher-C1
Paper Weights
Paper Size
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, ΔΔ Statement-R, Executive, and Envelopes
Number Of Trays
2Total Output Capacity: 3,000 Sheets (Letter, Statement-R, Executive)
Top Tray
1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (11 x 17, Legal, Letter-R)
Lower Tray
1,700 Sheets (Letter, Statement-R, Executive) 650 Sheets (11 x 17, Legal, Letter-R)
Staple Capacity
Letter, Executive: 50 Sheets (14 lb. Bond to 21 lb. Bond)
30 Sheets (22 lb. Bond to 28 lb. Bond)
2 Sheets (29 lb. Bond to 140 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (14 lb. Bond to 21 lb. Bond)
20 Sheets (22 lb. Bond to 28 lb. Bond)
2 Sheets (29 lb. Bond to 140 lb. Index)Paper Capacity of Staple Mode: Top Tray: 1,300 Sheets/30 Sets (Letter, Executive) 650 Sheets/30 Sets (11 x 17, Legal, Letter-R)
Lower Tray: 1,700 Sheets/30 Sets (Letter, Executive) 650 Sheets/30 Sets (11 x 17, Legal, Letter-R)
Staple Positions
Corner Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Double Stapling: 11x 17, Legal, Letter, Letter-R, Executive Type of Staple: Staple-J1 (5,000 x 3)
Power Source
From Main Unit/Approx. 117W
Dimensions
43-1/4 x 26-5/8 x 25-1/2
Weight
Approx. 101 lb.
Description
Booklet Finisher-C1
Paper Weights
Paper Size
Number Of Trays
2Total Output Capacity: (Letter, Statement-R, Executive)
Top Tray
Lower Tray
Saddle Stitch Tray
16 Sheets (14 lb. Bond to 20 lb. Bond) (12 x 18, 11 x 17, Legal, Letter-R)
10 Sheets (22 lb. Bond to 28 lb. Bond) (12 x 18, 11 x 17, Legal, Letter-R)Paper Capacity of Saddle-Stitch Mode: 25 Booklets (5-sheet Booklets)
Staple Capacity
11 x 17, Legal, Letter: 30 Sheets (14 lb. Bond to 21 lb. Bond)
Staple Positions
Double Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Saddle-Stitch: 12 x 18, 11 x 17, Legal, Letter-R Type of Staple: Staple Cartridge-D2 (2,000 x 3)
Power Source
Dimensions
43-1/4 x 31-1/8 x 25-1/2
Weight
Approx. 165 lb. External 2/3-Hole Puncher-B1ΔΔΔ
Acceptable Punch Paper Weight: 14 lb. Bond to 140 lb. Index Acceptable Punch Paper Size:11 x 17, Legal, Letter, Letter-R Punch Type: 2 Holes (Legal, Letter-R)
3 Holes (Letter, 11 x 17)Distance between Punch Holes: 2 Holes: 2-3/4
3 Holes: 4-1/4Tray Capacity: Approx. 2,500 Sheets (20 lb. Bond)Power Source: From Main Unit Dimensions (H x W x D): 35-3/4 x 4-1/4 x 24-1/2Weight: Approx. 15.9 lb.
Fax Board
Applicable Line
4
Modem Speed
Super G3: 33.6 Kbps
G3: 14.4 Kbps
Data Compression
MH, MR, MMR, JBIG Resolution 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi Sending/Recording Size Statement to 11 x 17Fax Features Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type, Two-Sided Original, Book to Two pages
Print Board
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
2GB RAM
Maximum Memory
2.5GB RAM
Hard Disk
Standard: 80GB
Maximum: 250GB
Maximum Engine Resolution 1200 x 1200 dpi
PDL Support
Standard: UFR II
Optional: PCL 5c, PCL 6, Adobe PS 3
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/Server 2003/Server 2008/Windows Vista®, Windows 7), Citrix MetaFrame, Macintosh® (OS X 10.2.8 or Later)
PCL 5c/6: Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista, Windows 7), Citrix MetaFrame
Adobe PS 3: Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista, Windows 7), Citrix MetaFrame, Macintosh (OS X 10.2.8 or Later)
XPS: Windows Vista Direct Print Support Standard: TIFF, JPEG, EPS†
Optional: PDF, XPS†
Other Features
Suspend Job Timeout, Feature, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Black-and-White Printing, Objective, Color/Black-and-White Auto Detect, Toner Reduction, Poster Printing
Description
imagePASS-B1⟩
Processor
Intel® Celeron® M440 1.88GHzSystem: System 8e Release2Type: Embedded
Standard Memory
512MB
Maximum Memory
1GB
Hard Disk
80GB
PDL Support
Adobe PS 3/PCL 5c/PCL 6Print Resolution: 1200 x 1200 dpi
2400 dpi Equivalent x 600 dpi
Interface Connections
10/100/1000Base-T (RJ-45)
Adobe PS 3: Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista), Macintosh (OS X 10.3.9 or Later)
PCL 5c/6: Windows (Windows 2000/XP/Server 2003/Windows Vista)Utility Software: Remote Scan 5.3, Command WorkStation® for Windows, Command WorkStation for Mac, Web Tools
Other Features
(Std.) Auto Trapping, Paper Catalog EFI Options: Hot Folder v2.0, Secure Erase V1.1, Impose v2.7, 512MB Optional Memory, X-Rite Eye-One
Send Expansion Sets
Description
Universal Send Specifications
Sending Method
E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), User Inbox, Super G3 Fax (Optional)Color Mode Auto Color Select (Full Color, Grayscale), Auto Color Select (Full Color, B/W), Full Color, Grayscale, B/W Scan Resolution 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
Address Book Capacity
Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)Communication Protocol File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
File Format
Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/A-1b, XPS, XPS (Compact)
Optional: PDF (Trace & Smooth), PDF/XPS (OCR), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions), Office Open XML (OCR)I-Fax Data Format B/W: TIFF (MH, MR, MMR)
Color: TIFF (Profile-C)Other Optional Accessories
Cabinet Type-B⟩⟩
Tab Feeding Attachment Kit-B1**
Utility Tray-A1
USB Keyboard
Key Switch Unit-A2
Card Reader-C1⟩⟩⟩
Copy Card Reader Attachment Kit-B1
Braille Label Kit
ADF Access Handle-A1
Stamp Ink CRG-C1
Stamp Unit-B1
imageRUNNER ADVANCE Essentials
Universal Send Advanced Feature Set-D1
Universal Send Security Feature Set-D1
Universal Send Digital User Signature Kit-C1
Super G3 Fax Board-AE1
Super G3 2nd Line Fax Board-AE1•
Super G3 3rd/4th Line Fax Board-AE1••
Remote Fax Kit-A1•••
PS Printer Kit-AE1⟩
PCL Printer Kit-AE1
Direct Print Kit (for PDF/XPS)-H1⟩
Encrypted Secure Print-D1
Barcode Printing Kit-D1♦
Web Access Software-H1♦♦
Secure Watermark-B1
Wireless LAN Board-B1♦♦♦
USB Device Port-B1
Multimedia Reader/Writer-A1◊
Additional Memory Type B (512MB)
Document Scan Lock Kit-A1
Data Erase Kit-C1
HDD Data Encryption and Mirroring Kit-C1
Removable HDD Kit-AC1
2.5-inch/80GB HDD-C1◊◊
2.5-inch/250GB HDD-D1
IPSec Board-B2♦♦♦
Expansion Bus-F1
Voice Guidance Kit-F1◊◊◊
Voice Operation Kit-C1◊◊◊
Remote Operator's Software Kit-B1
Serial Interface Kit-K1
Copy Control Interface Kit-A1º
eCopy Suite
imageWARE Suite
Canon iR-ADV Security Kit-A1 for IEEE 2600.1 Common Criteria Certificationºº
*Not available in top cassette.
**Installs on Cassette 2. Cannot install Envelope Feeder Attachment and Tab Feeding Attachment Kit at same time.
***Includes consumables.
† EPS and XPS cannot be printed directly from Memory Media or Advanced Box.
†† Cannot be installed with Cabinet Type-B.
††† Cannot be installed with Booklet Finisher-C1 or Staple Finisher-C1.
Δ Cannot be installed with Booklet Finisher-C1, Staple Finisher-C1, or Inner Finisher-A1.
ΔΔ Statement cannot be used when the External 2/3-Hole Puncher-B1 is attached.
ΔΔΔ External 2/3-Hole Puncher-B1 can only be installed with either the Staple Finisher-C1 or Booklet Finisher-C1.
⟩ Requires Additional Memory Type B (512MB).
⟩⟩ Cannot be installed when Cassette Feeding Unit-AD1 is installed.
⟩⟩⟩ Requires Copy Card Reader Attachment Kit-B1.
• Requires Super G3 Fax Board-AE1.
•• Requires Super G3 Fax Board-AE1 and Super G3 2nd Line Fax Board-AE1.
••• Cannot be installed with Super G3 Fax Board-AE1.
♦ Requires PCL Printer Kit-AE1.
♦♦ Requires PS Printer Kit-AE1 or Direct Printer Kit (for PDF/XPS)-H1 for printing PDF files.
♦♦♦ Requires Expansion Bus-F1.
◊ Requires Device Port-B1.
◊◊ 80GB HDD for Mirroring functionality only, cannot be used to increase storage.
◊◊◊ Voice Operation Kit-C1 and Voice Guidance Kit-F1 cannot be installed together.
º Cannot be installed with Serial Interface Kit-K1 or Card Reader-C1.
ºº Please see the Product Advisory for the latest status on this item.
Awards
BLI 2009 Pick of the Year Award - Outstanding Achievement in Scanning
Better Buys for Business 2011 Editor's Choice
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER ADVANCE C5045 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER ADVANCE C5051 / C5045 / C5035 / C5030 Series Configurator.
This is to make Misc appear on the page when needed.
Supplies
GPR-30 Toner
Color: Black
Item Code: 2789B03BA
Yield: 44,000 Copies/Bottle
Color: Cyan
Item Code: 2793B003AC
Yield: 38,000 Copies/Bottle
Color: Magenta
Item Code: 2797B003AC
Color: Yellow
Item Code: 2801B003AC
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AD1
  • Paper Deck Unit-B1
  • Envelope Feeder Attachment-D1
  • Copy Tray-J1
  • Inner 2-Way Tray-F1
  • Inner Finisher-A1
  • Staple Finisher-C1
  • Booklet Finisher-C1
  • External 2/3-Hole Puncher-B1
  • Cabinet Type-B Inner Finisher
  • Additional Tray-A1
  • Tab Feeding Attachment Kit-B1
  • Utility Tray-A1
  • USB Keyboard
System Connectivity Accessories
  • imagePASS-B1
  • ColorPASS-GX300
  • Key Switch Unit-A2
  • Card Reader-C1
  • Copy Card Reader Attachment Kit-B1
  • Braille Label Kit
  • ADF Access Handle-A1
  • Stamp Ink CRG-C1
  • Stamp Unit-B1
  • imageRUNNER ADVANCE Essentials
  • Universal Send Advanced Feature Set-D1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 Fax Board-AE1
  • Super G3 2nd Line Fax Board-AE1
  • Super G3 3rd/4th Line Fax Board-AE1
  • Remote Fax Kit-A1
  • PS Printer Kit-AE1
  • PCL Printer Kit-AE1
  • Direct Print Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Secure Watermark-B1
  • Wireless LAN Board-B1
  • USB Device Port-B1
  • Multimedia Reader/Writer-A1
  • Additional Memory Type B (512MB)
  • Document Scan Lock Kit-A1
  • Data Erase Kit-C1
  • HDD Data Encryption and Mirroring Kit-C1
  • Removable HDD Kit-AC1
  • 2.5-inch/80GB HDD-C1
  • 2.5-inch/250GB HDD-D1
  • IPSec Board-B2
  • Expansion Bus-F1
  • Voice Guidance Kit-F1
  • Voice Operation Kit-C1
  • Remote Operator's Software Kit-B1
  • Copy Control Interface Kit-A1
  • eCopy Suite
  • imageWARE Suite
  • iR-ADV Security Kit-A1 for IEEE2600.1 Common Criteria Certification*
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
* Please see the Product Advisory for the latest status on this item.
Product Walkthroughs
imageRUNNER ADVANCE - Access Stored Files Walkthrough
imageRUNNER ADVANCE - Scan and Send Walkthrough
Brochures
Loading...
 Return to Top
