Web Content Viewer
Actions
imageRUNNER ADVANCE C5051
Support Color Multifunction Copiers
Features
New Advanced imageCHIP system architecture uses two processors to deliver outstanding multitasking performance. "Slide and Tilt" control panel allows users to adjust the UI to a comfortable and accessible position. Two menus streamline your workflow. The Main Menu gives you instant access to system functions, while the Quick Menu powers productivity by allowing you to combine and access routine tasks at the touch of a button. A universal design that's not only appealing to the eye, but also easy and comfortable to operate. Compact footprint, soft curves and natural soothing color palette create harmony between innovation and your work environment.
Rapidly convert paper documents to digital files with the 150-sheet capacity, ultra-fast single-pass duplex document feeder at speeds of up to 100 ipm (duplex 300 dpi). A choice of modular in-line accessories makes professionally finished documents simple, including an optional inner finisher with 50-sheet multi-position stapling. Advanced Box, Canon's new built-in document sharing solution enhances the ability of multiple users to collaborate. Files can be stored in Advanced Box shared folders and accessed from multiple locations including a PC or other networked imageRUNNER ADVANCE systems. Whether from the imageRUNNER ADVANCE model or at your own desk, you can have direct access to the functions that make your work easier with the imageRUNNER ADVANCE Desktop utility. The Workflow Composer utility reduces multi-step and frequently performed operations to the touch of one button that can be placed on the Quick Menu Universal Send provides an expanded range of file formats including High Compression PDF/XPS, Adobe PDF Reader Extensions, Searchable PDF, OOXML, PDF (Optimize for Web), PDF (Apply Policy), PDF/A-1b and Encrypted PDF. Canon's UFR II print technology is standard with this model, optional Adobe PostScript 3 and PCL 5c/6 are also supported. Scan to or print from a USB thumb drive or optional memory media. Enter data more comfortably with the optional USB keyboard.
Canon offers a number of security features for document security, data security, mail server security, logging/auditing security and authentication. Access Management System allows you to limit device access by user, group or role and you can even limit access for only specific functions such as Send. The Trusted Platform Module allows you to safeguard vulnerable settings such as passwords with a new security chip featuring tamper-resistant hardware. With Document Scan Lock and Tracking you can embed hidden tracking information in a document to restrict unauthorized copying or scanning and to track the origin. Disguise information before it's written to the hard drive, and permanently remove it by overwriting when the job is complete with data encryption and erase options. The Remote User Interface gives you centralized control for any individual device right from your desktop, so that you can check supply levels, monitor jobs and stay completely informed. The imageWARE Enterprise Management Console offers one central point of control for all systems across your organization. This web-based utility makes it easy to install and manage multiple Canon and third-party networked devices. Adobe LiveCycle Rights Management ES Integration protects access to documents throughout their duration. After documents are scanned, specify security policies and select authorized recipients. The imageRUNNER ADVANCE Series makes it easier to track, manage and influence user behavior. From analyzing color output by employee or client to encouraging double sided printing, you can ensure that resources are employed optimally and costs are allocated accurately.
Reduce costs, increase performance with the ability to streamline workflow. Outstanding image quality for striking results. Retrieve information from other imageRUNNER ADVANCE models on the network to help eliminate extra hardware or to easily collaborate. Reduce downtime with the ability to replace toner on the fly. If incorrect paper size or stack for a job is unavailable, the system can begin the next job without delay. New level of connector and link support through Canon's innovative MEAP platform. With 1200 x 1200 dpi print resolution, text is sharp with smooth corners, and images have subtle gradient transitions. Innovative technologies, including Canon's fine-grained pQ toner, produce rich, clear, vivid images with a smooth, high quality finish.
Canon's life cycle assessment system helps to reduce C02 emissions by more than 30% over previous models. Compact with less packaging for efficient transportation. Designed with 100% recycled plastic and bio-based plastic for certain components. Meets Energy Star standards. New pQ toner and Advanced RAPID fusing system helps to reduce overall energy consumption by minimizing heat and power requirements. Power consumption for sleep mode is 1w or less. Meets and exceeds ROHS directive.
Awards
2010 BLI 5 Star Environmental Award
BLI 2009 Pick of the Year Award - Outstanding Achievement in Scanning
BLI 2010 Highly Recommended Seal
BLI 2010 Reliability Seal
2010 BLI Performance Certified Seal
Better Buys for Business 2011 Editor's Choice
2011 BERTL's Best Award
BLI 2011 Pick of the Year Award
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER ADVANCE C5051 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER ADVANCE C5051 / C5045 / C5035 / C5030 Series Configurator.
This is to make Misc appear on the page when needed.
Supplies
GPR-30 Toner
Color: Black
Item Code: 2789B03BA
Yield: 44,000 Copies/Bottle
Color: Cyan
Item Code: 2793B003AC
Yield: 38,000 Copies/Bottle
Color: Magenta
Item Code: 2797B003AC
Color: Yellow
Item Code: 2801B003AC
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AD1
  • Paper Deck Unit-B1
  • Envelope Feeder Attachment-D1
  • Copy Tray-J1
  • Inner 2-Way Tray-F1
  • Inner Finisher-A1
  • Staple Finisher-C1
  • Booklet Finisher-C1
  • External 2/3-Hole Puncher-B1
  • Cabinet Type-B Inner Finisher
  • Additional Tray-A1
  • Tab Feeding Attachment Kit-B1
  • Utility Tray-A1
  • USB Keyboard
System Connectivity Accessories
  • imagePASS-B1
  • ColorPASS-GX300
  • Key Switch Unit-A2
  • Card Reader-C1
  • Copy Card Reader Attachment Kit-B1
  • Braille Label Kit
  • ADF Access Handle-A1
  • Stamp Ink CRG-C1
  • Stamp Unit-B1
  • imageRUNNER ADVANCE Essentials
  • Universal Send Advanced Feature Set-D1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 Fax Board-AE1
  • Super G3 2nd Line Fax Board-AE1
  • Super G3 3rd/4th Line Fax Board-AE1
  • Remote Fax Kit-A1
  • PS Printer Kit-AE1
  • PCL Printer Kit-AE1
  • Direct Print Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Secure Watermark-B1
  • Wireless LAN Board-B1
  • USB Device Port-B1
  • Multimedia Reader/Writer-A1
  • Additional Memory Type B (512MB)
  • Document Scan Lock Kit-A1
  • Data Erase Kit-C1
  • HDD Data Encryption and Mirroring Kit-C1
  • Removable HDD Kit-AC1
  • 2.5-inch/80GB HDD-C1
  • 2.5-inch/250GB HDD-D1
  • IPSec Board-B2
  • Expansion Bus-F1
  • Voice Guidance Kit-F1
  • Voice Operation Kit-C1
  • Remote Operator's Software Kit-B1
  • Copy Control Interface Kit-A1
  • eCopy Suite
  • imageWARE Suite
  • iR-ADV Security Kit-A1 for IEEE2600.1 Common Criteria Certification*
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
* Please see the Product Advisory for the latest status on this item.
Brochures
Loading...
 Return to Top
