Web Content Viewer
Actions
imageRUNNER ADVANCE C9075 PRO
Support Color Multifunction Copiers
Specifications
Model Name
Type
Color Digital Multifunction Imaging System Functions Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up to 4 Lines)Operation Panel 10.4 SVGA Full-Color TFT Upright Screen
Image Server Memory
Standard: 2GB RAM
Maximum: 2.5GB RAM Hard Disk Drive
Standard: 80GB
Maximum: 1TBMirroring Hard Disk Drive Optional (80GB, 1TB) Method: RAID1Network Interface Connection Standard: 10/100/1000Base-TX
Optional: Wireless LAN (IEEE 802.1x)Other Interface Standard: USB 2.0 (Host)x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host)x2], Serial Interface, Copy Control Interface
Max Mailboxes Supported
No. Supported: 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max. Pages Stored: 6,000Advanced Box
Available Disk Space: Approx. 10GB (Standard HDD)
664GB (1TB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 2000/XP/Windows Vista)
Max. Number of Concurrent Connections: SMB: 32
WebDAV: 12 (Active Sessions)
Advanced Box Features:Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
Memory Media Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive
Scanning Resolution
Up to 600 x 600 dpi Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility Color Network ScanGear
Letter
Up to 75/70 ppm
Legal/11 x 17: Up to 45/42 ppm
Up to 38/35 ppm
First Copy Time
B/W: 4.4 Seconds
Color: 6.0 Seconds
Multiple Copies
1 to 9,999Color Mode: Auto Color, Full Color, Black, Single Color, Two Colors
Copy Exposure Automatic or Manual (9 Levels)
Magnification
25% - 400% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%Copy Features
Basic Copy Features: Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying
Special Copy Features: Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox
Acceptable Originals
Sheet, Book, 3-Dimensional Objects (up to 4.4 lb.)
Maximum Original Size
Up to 11 x 17
Standard Paper Capacity
(20 lb. Bond): Dual 1,100-sheet Paper Drawers, Dual 550-sheet Cassettes, 100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck-A1, 3,500-POD Deck Lite-A1, or 6,000-sheet Multi-Drawer Paper Deck-A1
Maximum Paper Capacity
9,300 Sheets (with Multi-Drawer Paper Deck Option)*Output Paper Capacity (20 lb. Bond) 250 Sheets (with Copy Tray)
4,250 Sheets (with Staple Finisher or Booklet Finisher)
Output Sizes
Cassette
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size
Drawers: Letter
Bypass
Acceptable Paper Weights
Cassette
14 lb. Bond to 80 lb. Cover
Bypass
14 lb. Bond to 110 lb. Cover
Duplexing
Paper Size: Standard Automatic Trayless Duplexing (Up to 13 x 19)
Paper Weights: 14 lb. Bond to 80 lb. Cover
Special Media Support: Drawers: Transparency
Cassettes: Transparency, Tab
Bypass: Transparency, Tracing, Labels, Coated, Textured, Envelopes
Warm Up Time
From Power On: 6 Minutes
From Sleep Mode: 6 Minutes
From Energy Saver Mode: 90 Seconds
Power Requirements
208V AC, 60Hz, 15A
Power Consumption Maximum: 2,500 W or less; Sleep Mode: 1.5W
Plug NEMA 6-15P
Dimension
55-1/4** x 46-1/2*** x 36-3/4
Installation Space (W x D) 69-1/4 x 64 (When Copy Tray and Stack Bypass are extended)
Weight
Approx. 723.9 lb.ϑ
Toner
(Estimated Toner Yield @ 5% Coverage): Black: 72,000 Copies/Bottle
Color: 54,000 Copies/Bottle Security Specifications Standard: Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Address on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, Adobe® LiveCycle® Rights Management ES Integration
Optional: Removable HDD, HDD Erase, HDD Encryption/Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, IPSec, Secure Watermark Environmental Information ENERGY STAR® Qualified RoHS Compliant Ecomark WEEE Directive
Feeders
Paper Sizes: 11 x 17, Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weights: B/W Originals: 13 lb. Bond to 80 lb. Cover
Color Originals: 17 lb. Bond to 80 lb. Cover Scan Method Single-Pass Duplexing Automatic Document Feeder
Scanning Speed
(BW/Color; Letter): Simplex: 120/120 ipm (300 dpi)
120/70 ipm (600 dpi)
Duplex: 200/140 ipm (300 dpi)
Capacity
(20 lb. Bond): 300 Sheets
Paper Supply Options
Description
Paper Deck Unit-A1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched
Power Source
From Main Unit
Max. Power Consumption: 44W
Dimensions
22-1/2 x 12-3/4 x 23
Weight
Approx. 81.6 lb
Description
POD Deck Lite-A1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled Pre-punched, Transparency, Labels, Bond, Letterhead, Coated, Textured
Power Source
120-127V AC, 60Hz, 5A
Max. Power Consumption: 288 W
Plug: NEMA 5-15P
Dimensions
22-1/2 x 23-5/8 x 24-1/2
Weight
Approx. 110 lb.
Description
Number Of Cassettes
3 (2,000 Sheets each)
Paper Capacity
6,000 Sheets
Paper Sizes
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Custom Size
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Labels, Tab, Bond, Letterhead, Coated, Textured
Power Source
120-127V 60Hz 4A
Max. Power Consumption: Approx. 753W
Plug: NEMA 5-15P
Dimensions
41 x 37-3/8 x 31-3/8
Output Options
Finishers Output Trays
Description
Copy Tray-P1
Paper Weights
Total Output Capacity: 250 Sheets (20 lb. Bond)
Paper Size
Dimensions
6-7/8 x 16-1/2 x 15
Weight
Approx. 2.9 lb.
Description
Staple Finisher-A1
Paper Weights
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, Coated, Textured, Envelopes
Paper Size
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size Total Output Capacity 4,250 Sheets (Letter, Statement-R, Executive)
Tray A: 1,500 Sheets (Letter, Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Tray B: 250 Sheets (Letter) 125 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R, Executive)
Tray C: 2,500 Sheets (Letter) 1,250 Sheets (Statement-R, Executive) 750 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Number Of Trays
3
Staple Capacity
(Max.): 100 Sheets (Letter, Executive)
50 Sheets (11 x 17, Legal, Letter-R)Paper Capacity of Staple Mode: Tray A/C: 1,500 Sheets/100 Sets (Letter, Statement-R, Executive), 750 Sheets/50 Sets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Type of Staple: Staple-G1 (5,000 x 3)
Staple Positions
Corner/Double Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Power Source
100-240V, 50/60Hz, 2.8A
Max. Power Consumption: 207 W
Plug: NEMA 5-15P
Dimensions
41 x 25-3/4 (30-3/4††) x 30-1/8
Weight
Approx. 134 lb.
Description
Booklet Finisher-A1
Paper Weights
Paper Size
13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size Total Output Capacity: 4,250 Sheets (Letter, Statement-R, Executive)
Number Of Trays
3
Staple Capacity
Staple Positions
Corner Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Saddle Stitch: 13 x 19, 12 x 18, 11 x 17, Legal, Letter-R
Staple-P1 (5,000 x 2)
Stapling Capacity
(Max.): 20 Sheets
Paper Capacity of Saddle-Stitch Mode: 1 to 5 Sheets/25 Sets, 6 to 10 Sheets/15 Sets, 11 to 16 Sheets/10 Sets, 17 to 20 Sheets/5 Sets
Power Source
100-240V 50/60Hz, 2.8A
Power Consumption: 255 W
Plug: NEMA 5-15P
Dimensions
41 x 30-1/4 (35-1/4††) x 30-1/8
Weight
Approx. 238 lb. Puncher Unit-BF1†††
Acceptable Punch Paper Weight: 14 lb. Bond to 140 lb. Index
Acceptable Punch Paper Type: Thin, Plain, Heavy, Color, Recycled, Tab, Bond, Letterhead, Coated, Textured
Acceptable Punch Paper Size: 11 x 17, Legal, Letter, Letter-R
Punch Type: 2 Holes (Legal, Letter-R)
3 Holes (11 x 17, Letter)
Distance Between Punch Holes:2 Holes: 2-3/4
3 Holes: 4-1/4
Punch Waste Tray Capacity: Approx. 5,000 Sheets (20 lb. Bond)
Power Requirement: From Finisher
Power Consumption: Approx. 56 W (When in operation)
Dimensions (H x W x D): Inside the Finisher 15-1/2 x 3-3/4 x 15-1/2
Weight: Approx. 8.2 lb. Inner Booklet Trimmer-A1▲
Trimming Method: Face Trim
Trim Thickness: 40 Sheets
Waste Tray Capacity: 1,500 Sheets of Trimmed Strips
Acceptable Paper Weight: 16 lb. Bond to 110 lb. Cover
Acceptable Paper Type: Thin, Plain, Heavy, Recycled, Color, Coated
Output Tray Capacity: 30 Booklets
Power Requirements: From Finisher
Max. Power Consumption: 51 W (when in operation)
Dimensions (H x W x D): Inside the Finisher 15-7/8 x 9-7/8 x 24-5/8
Weight: Approx. 70.5 lb. Professional Puncher-C1/Professional Puncher Integration Unit-B1▲▲
Acceptable Punch Paper Weight: Letter (3-hole, 5-hole, Velo Bind 11-hole, Plastic Comb 19-hole, Twin Loop 21-hole/32-hole, Color Coil 44-hole): 20lb. Bond to 80 lb. Cover, Letter (ProClick 32-hole): 20 lb. Bond to 65 lb. Cover
Acceptable Punch Paper Type: Plain, Heavy, Color, Recycled, Tab, Coated
Acceptable Punch Paper Size: Letter
Punch Pattern Die Sets (optional):Plastic Comb (19-hole)Twin Loop (21/32-hole)Color Coil (44-hole)Velo Bind (11-hole) Loose Leaf (3/5-hole)ProClick (32-hole)
Punch Waste Tray Capacity: Approx. 25,000 Sheets or more of 20 lb. Bond with 4 holes punched
Power Requirement: 120-127V/5.5A-60Hz
Max. Power Consumption:Professional Puncher-C1: 300W
Professional Puncher Integration Unit-B1: 130W Max.
Plug: NEMA 5-15P
Dimensions (H x W x D):Professional Puncher-C1: 41 x 12 x 31-1/4
Professional Puncher Integration Unit-B1: 41 x 9-7/8 x 31-1/4
Weight:Professional Puncher-C1: Approx. 176 lb.
Professional Puncher Integration Unit-B1: Approx. 88.2 lb.
Document Inserters
Description
Document Insertion Unit-H1▲▲
Paper Weight
Acceptable Paper Type: Thin, Plain, Heavy, Color, Recycled Pre-punched, Tab, Bond, Letterhead, Coated, Textured
Paper Sizes
Number of Trays: 2
Acceptable Media: Covers and Inserts
Tray Capacity: Upper Tray: 200 Sheets
Lower Tray: 200 Sheets
Power Requirements: 100-240V/2.8A, 50/60Hz
Max. Power Consumption: 103 W
Plug: NEMA 5-15P
Dimensions (H x W x D): 55-3/8 x 29-3/8 x 31-1/4
Weight: Approx. 134 lb.
Paper Folding
Description
Paper Folding Unit-G1▲▲
Paper Weight
14 lb. Bond to 28 lb. Bond
Acceptable Paper Type: Thin, Plain, Color, Recycled, Bond
Paper Sizes
Accordion Z-Fold, C-Fold, Half-Fold: Letter-R
Z-Fold: 11 x 17, Legal, Letter-R
Fold Type
Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold
Folding Method: Roller Pressure Folding
Max. Power Consumption: 130 W
Dimensions (H x W x D): 46-7/8 x 13-1/4 x 31-1/4
Weight: Approx. 156.5 lb.
Fax Board
Applicable Line
4
Modem Speed
Super G3: 33.6 Kbps
G3: 14.4 Kbps
Data Compression
MH, MR, MMR, JBIG Resolution 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi Sending/Recording Size Statement to 11 x 17Fax Features Job Forwarding, Different-Size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax) Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type, Two-Sided Original, Book to Two pages
Print Board
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
2GB RAM
Maximum Memory
2.5GB RAM
Hard Disk
Standard: 80GB
Maximum: 1TB
Engine Resolution 1200 x 1200 dpi
PDL Support
Standard: UFR II
Optional: PCL 5c, PCL 6, Adobe PS 3
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/Server 2003/Server 2008/Windows Vista®), Citrix MetaFrame, Macintosh® (OS X 10.2.8 or Later)
PCL 5c/6:Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista), Citrix MetaFrame
Adobe PS 3:Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista), Citrix MetaFrame, Macintosh (OS X 10.2.8 or Later)
XPS: Windows VistaDirect Print Support Standard: TIFF, JPEG, EPS†
Optional: PDF, XPS† Print Features Suspend On Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Black-and-White Printing, Objective, Color/Black-and-White Auto Detect, Toner Reduction, Poster Printing
Description
imagePASS-A1▲▲▲
Processor
Intel® Core™ 2 Duo T2500 2.0GHz
Type: Embedded
System: System 8e Release 2
Standard Memory
512MB
Maximum Memory
1GB
Hard Disk
80GB
PDL Support
Adobe PS 3/PCL 5c/PCL 6
Print Resolution: 1200 x 1200 dpi
2400 dpi Equivalent x 600 dpi
Interface Connections
10/100/1000Base-T (RJ-45)
Adobe PS 3: Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista), Macintosh® (OS X 10.3.9 or later)
PCL 5c/6: Windows/2000/XP/Server 2003/ Windows Vista
Utility Software: Remote Scan 5.3, Command WorkStation® for Windows, Command WorkStation for Mac, WebTools
Other Features
(Std.): Auto Trapping, Hot Folders, Virtual Printers, Paper Catalog
EFI Options: Secure Erase V1.1, Impose v2.7, 512MB Optional Memory, X-Rite Eye-One
Description
ColorPASS-GX300▲▲▲
Processor
Intel Core2 Duo Xeon E8400
2 x 3.0GHz FSB 1333MHz
Type: External
System: System 8 Release 2
Standard Memory
2GB
Maximum Memory
2GB
Hard Disk
160GB
DVD-ROM Drive: Standard (DVD-RW)
PDL Support
Adobe PS 3
Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista), Macintosh (OS X 10.3.9 or later)
Utility Software: Remote Scan 5.3, Command WorkStation for Windows, Command WorkStation for Mac, WebTool
Other Features
(Std.): Auto Trapping, Paper Catalog, Hot Folders, Virtual Printers, Secure Erase
EFI Options: Integrated Interface and Stand, X-Rite Eye-One, Impose v2.7, Removable Hard Disk Drive Kit, Graphic Arts Feature Set, Premium v2.2, Compose v2.0
Dimensions (H x W x D): 19-1/8 x 8-1/2 x 19-1/8
Weight: Approx. 43.5 lb.
Send Expansion Sets
Description
Universal Send Specifications
Sending Method
E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), User Inbox, Super G3 Fax (Optional)Color Mode Auto Color Select (Full Color, Grayscale), Auto Color Select (Full Color, B/W), Full Color, Grayscale, B/W Scan Resolution 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
Address Book Capacity
Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)Communication Protocol File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
File Format
Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/A-1b, XPS, XPS (Compact)
Optional: PDF (Trace & Smooth), PDF/XPS (OCR), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions), Office Open XMLI-Fax Data Format B/W: TIFF (MH, MR, MMR)
Color: TIFF (Profile-C)Other Optional Options Utility Tray-A1■USB Keyboard Key Switch Unit-B1Card Reader-C1■■Copy Card Reader Attachment Kit-A1Braille Label Kit ADF Access Handle-A1Serial Interface Kit-K1Copy Control Interface Kit-A1PCL Printer Kit-AD1PS Printer Kit-AD1▲▲▲Direct Print Kit (for PDF/XPS)-H1▲▲▲Encrypted Secure Print-D1Barcode Printing Kit-D1■■■Web Access Software-H1●imageRUNNER ADVANCE Essentials Universal Send Advanced Feature Set-D1Universal Send Security Feature Set-D1Universal Send Digital User Signature Kit-C1Super G3 Fax Board-AD1Super G3 2nd Line Fax Board-AD1●●Super G3 3rd/4th Line Fax Board-AE1●●●Remote Fax Kit-A1♦Secure Watermark-B1Wireless LAN Board-B1♦♦USB Device Port-A1Multimedia Reader/Writer-A1♦♦♦Additional Memory Type B (512MB)Document Scan Lock Kit-A1Data Erase Kit-C1HDD Data Encryption and Mirroring Kit-C1Removable HDD Kit-AB13.5-inch/80GB HDD-A13.5-inch/1TB HDD-B1IPSec Board-B2♦♦Expansion Bus-F1Voice Guidance Kit-F1GVoice Operation Kit-C1GRemote Operator's Software Kit-B1eCopy Suite imageWARE Suite* Stack Bypass is not available when Multi-Drawer Paper Deck is installed.
** Up to top of Upright Control Panel in standard position.
*** Up to edge of Upright Control Panel in right side position.
ϑ Includes ADF and consumables.
† EPS and XPS cannot be printed directly from Memory Media or Advanced Box.
†† When the Auxiliary Tray is extended.
††† Puncher Unit-BF1 installs internally with either Staple Finisher-A1 or Booklet Finisher-A1.
▲ Option for Booklet Finisher-A1.
▲▲ Requires Staple Finisher-A1 or Booklet Finisher-A1.
▲▲▲ Requires Additional Memory Type B (512MB).
■ Cannot be installed if Multi-Drawer Paper Deck-A1 is installed.
■■ Requires the Copy Card Reader Attachment Kit-A1.
■■■ Requires PCL Printer Kit-AD1.
● Requires PS Printer Kit-AD1 or Direct Print Kit (for PDF/XPS)-H1 when printing PDF files.
●● Requires Super G3 Fax Board-AD1.
●●● Requires Super G3 Fax Board-AD1 and Super G3 2nd Line Fax Board-AD1.
♦ Cannot be installed with Super G3 Fax Board-AD1.
♦♦ Requires Expansion Bus-F1.
♦♦♦ Requires USB Device Port-A1.
☼ Voice Guidance Kit-F1 and Voice Operation Kit-C1 cannot be installed at the same time.
Awards
BLI 2009 Pick of the Year Award - Outstanding Achievement in Scanning
2010 BLI Performance Certified Seal
Better Buys for Business 2011 Editor's Choice
2011 BERTL's Best Award
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER ADVANCE C9075 PRO that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER ADVANCE 9000S Series Configurator.
This is to make Misc appear on the page when needed.
Product Walkthroughs
imageRUNNER ADVANCE - Access Stored Files Walkthrough
imageRUNNER ADVANCE - Scan and Send Walkthrough
Brochures
Loading...
 Return to Top
