Web Content Viewer
Actions
imageRUNNER C3100
Support Color Multifunction Copiers
Features
The imageRUNNER C3100 delivers output at 31 pages-per-minute (black and white) and 7 pages-per-minute (color), supporting the needs of busy office environments.
The imageRUNNER C3100 has been designed with an innovative dual processor supporting up to 768MB RAM, and a 40GB hard disk, thus eliminating bottlenecks and improving network efficiency.
With the ability to scan originals at 44 pages-per-minute (300 dpi) and 28 pages-per-minute (600 dpi) in both color and black-and-white, combined with 2400 x 600 dpi output resolution, the imageRUNNER C3100 will make every image sharp, every gradation smooth and every character crisp.
With Canon's optional Color Universal Send technology, users are able to scan and distribute documents to multiple destinations, eliminating the expense and administrative burden associated with conventional methods of printing, filing, and forwarding hard-copy documents.
Installed with an optional Super G3 Fax Board, the imageRUNNER C3100 can be transformed into an advanced, easy-to-use fax machine.
With a standard 1,100-sheet paper capacity that can be expanded to support up to 4,750 sheets, the imageRUNNER C3100 can meet the volume requirements of any workgroup. Additionally, users have the ability to print onto various types of media, including transparencies, envelopes, and irregular-size paper.
An optional 50-sheet capacity Automatic Document Feeder makes scanning multipage and different-size originals easy.
With the optional Finisher-P1, an innovative, internally mounted finishing option, the imageRUNNER C3100 offers basic stapling and collating with the main device footprint.
For those users requiring advanced document finishing needs, the optional Finisher-Q1 provides multiposition, stapled output. Also, the optional Saddle Finisher-Q2 for is equipped for outputting V-folded, saddle-stitched booklets.
Specifications
Model Name
imageRUNNER C3100
Imaging System
Laser Electrostatic Transfer System
Developing System
Dry Dual Component Developing System
Duty Cycle
Up to 110,000 impressions/month
Image Server Memory
Standard 512MB RAM/40GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
Up to 2400 dpi equivalent x 600 dpi (interpolated)
Halftone
256 Gradations
Letter
31 ppm (B/W)/ 7 ppm (Color)
Letter R
16 ppm (B/W)/ 3.5 ppm (Color)
Legal
Ledger
Statement
16 ppm (B/W)/ 7 ppm (Color)
First Copy Time
23.9 Seconds (Color)
8 Seconds (B/W)
Multiple Copies
1 to 9,999
Magnification
25% - 400%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Sheets, Books, and 3-Dimensional Objects (up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 550 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
4,750 Sheets
Output Sizes
Cassette
EXEC, STMT-R, LTR-R, LTR, LGL, 11 x 17, 12 x 18
Bypass
3-5/16 x 5-7/8 to 12-5/8 x 18
Acceptable Paper Weights
Cassette
17 lb. Bond to 90 lb. Index and Transparency
Bypass
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
6 minutes or less from Power On
30 seconds from Low Power mode
Exposure Control
Automatic or Manual (9 levels)
Power Requirements
120V, 12A, 60Hz
Dimension
29-3/4 x 22-1/4 x 29-3/4
(755mm x 565mm x 755mm)
Weight
190 lbs. (86.2 kg)
Toner
GPR-13 Toner
Estimated Toner Yield
Black Toner: 23,000 Copies/Bottle (Estimated @ 5% Coverage)
Color Toner: 8,500 Copies/Bottle (Estimated @ 5% Coverage)
Feeders
Description
Duplexing Automatic Document Feeder-L1 (Optional)
STMT-R, LTR, LTR-R, LGL, 11 x 17
Capacity
50 sheets (all sizes)
Paper Weights
13 lb. Bond to 32 lb. Bond
Different Size Originals
Same Width/Different Width
Power Source
Directly from Main Unit
Dimensions
4-4/5 x 22-1/4 x 21-1/5
(122mm x 565mm x 538mm)
Weight
18.7 lbs.
Paper Supply Options
Description
Cassette Feeding Unit-Y1 (Optional)
Number Of Cassettes
2
Paper Capacity
2 x 550 Sheets (1,100 Sheets Total)
Paper Sizes
STMT to 11 x 17
Paper Weights
Dimensions
9-7/8 x 22-1/4 x 27-5/8
(251mm x 565mm x 700mm)
Weight
50.7 lbs.
Description
Paper Deck-Q1 (Optional)
Number Of Cassettes
1
Paper Capacity
2,500 Sheets
Paper Sizes
LTR
Paper Weights
17 lb. Bond to 28 lb. Index
Power Source
Dimensions
18-5/8 x 14-5/8 x 23-1/4
(473mm x 372mm x 591mm)
Weight
65.3 lbs.
Output Options
Finishers Output Trays
Description
Finisher-P1 (Optional)
Paper Weights
Paper Size
STMT-R to 12 x 18
Number Of Trays
1 Internal Tray + optional Copy Tray-J1 installed on right side
Top Tray
500 Sheets (LTR, STMT-R)
250 Sheets (LGL, 11 x 17)
Staple Capacity
50 Sheets (LTR)
30 Sheets (LTR-R, LGL, 11 x 17)
Staple Positions
1-Top corner (Any corner of page)
2-Side Margin (Book Staple)
Power Source
Dimensions
7-7/8 x 16-1/8 x 21-1/4
(201mm x 409mm x 534mm)
Weight
25.3 lbs.
Description
Finisher-Q1 (Optional)
Paper Weights
Paper Size
STMT to 11 x 17
Number Of Trays
2 + optional Additional Finisher Tray-A1
Top Tray
1,000 Sheets (LTR, STMT-R)
500 Sheets (LGL, 11 x 17)
Lower Tray
Staple Capacity
50 Sheets (LTR)
Staple Positions
Power Source
Directly from main unit
Dimensions
40-3/4 x 21-1/8 x 25-7/8
(1036mm x 536mm x 657mm)
Weight
87.3 lbs.
Description
Saddle Finisher-Q2 (Optional)
Paper Weights
Paper Size
STMT-R to 12 x 18
Number Of Trays
3 + optional Additional Finisher Tray-A1
Top Tray
Lower Tray
Saddle Stitch Tray
11-15 Sheets/10 Sets
6-10 sheets/15 Sets
1 to 5 Sheets/25 Sets
Staple Positions
3-Saddle-stitch mode (Center Stapling)
Paper Sizes
LTR-R, LGL, 11 x 17
Stapling Capacity
15 Sheets
Fold Type
V-Folding
Power Source
Dimensions
40-3/4 x 25-1/5 x 25-7/8
(1036mm x 648mm x 657mm)
Weight
149 lbs.
Fax Board
Description
Super G3 Fax Board-N1
Applicable Line
Public Switched Telephone Network
Modem Speed
Super G3 33.6 Kbps, G3: 14.4 Kbps with automatic fallback
Transmission Speed
Approx. 3 seconds/page @ 33,600 bps
Data Compression
MMR, MR, MH, JBIG
Memory
Approx. 3,700 pages
(uses main unit shared image server 512MB RAM, and 40GB HDD memory)
Print Board
Description
imagePASS-E1 (Optional)
Processor
External (Back-mount Print Controller)
Intel Mobile Pentium III 850MHz
Standard Memory
128MB
Maximum Memory
256MB
Hard Disk
20GB
Continuous Print Speed
31-ppm (LTR)
PDL Support
PCL 5c, Adobe PostScript 3
Description
Color Network Multi-PDL Printer Kit-B1 (Optional)
Processor
Dual Canon Custom Processor (250MHz - shared)
Standard Memory
512 MB RAM
Maximum Memory
512 MB RAM
Hard Disk
Shared 40.0GB HDD
31-ppm (LTR)
PDL Support
UFR, PCL5c, PostScript 3 emulation
Postscript Fonts
136
PCL Fonts
80 Roman, 32 Barcode
Interface Connections
RJ45 (10/100BaseT)
Token Ring (4M/16M Optional Card)
USB Interface (optional)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER C3100 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
