Web Content Viewer
Actions
imageRUNNER C3170U
Support Color Multifunction Copiers
Specifications
Model Name
imageRUNNER C3170U
Imaging System
Laser Electrostatic Transfer System
Developing System
Dry Dual Component Developing System
Image Server Memory
Standard 1GB RAM/80GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
Up to 2400 dpi equivalent x 600 dpi (interpolated)
Halftone
256 Gradations
Letter
31 ppm (B/W)/ 7 ppm (Color)
Letter R
16 ppm (B/W)/ 3.5 ppm (Color)
Legal
Ledger
Statement
16 ppm (B/W)/ 7 ppm (Color)
First Copy Time
23.9 Seconds (Color)
8 Seconds (B/W)
Multiple Copies
1 to 9,999
Magnification
25% - 400%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Sheets, Books, and 3-Dimensional Objects (up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 550 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
4,750 Sheets
Output Sizes
Cassette
EXEC, STMT-R, LTR-R, LTR, LGL, 11 x 17, 12 x 18
Bypass
3-5/16 x 5-7/8 to 12-5/8 x 18
Acceptable Paper Weights
Cassette
17 lb. Bond to 90 lb. Index and Transparency
Bypass
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
6 minutes or less from Power On
30 seconds from Low Power mode
Exposure Control
Automatic or Manual (9 levels)
Power Requirements
120V, 12A, 60Hz
Dimension
29-3/4 x 22-1/4 x 29-3/4
(755mm x 565mm x 755mm)
Weight
190 lbs. (86.2 kg)
Toner
GPR-13 Toner
Estimated Toner Yield
Black Toner: 23,000 Copies/Bottle (Estimated @ 5% Coverage)
Color Toner: 8,500 Copies/Bottle (Estimated @ 5% Coverage)
Feeders
Description
Duplexing Automatic Document Feeder-L1 (Optional)
STMT-R, LTR, LTR-R, LGL, 11 x 17
Capacity
50 sheets (all sizes)
Paper Weights
13 lb. Bond to 32 lb. Bond
Different Size Originals
Same Width/Different Width
Power Source
Directly from Main Unit
Dimensions
4-4/5 x 22-1/4 x 21-1/5
(122mm x 565mm x 538mm)
Weight
18.7 lbs.
Paper Supply Options
Description
Cassette Feeding Unit-Y1 (Optional)
Number Of Cassettes
2
Paper Capacity
2 x 550 Sheets (1,100 Sheets Total)
Paper Sizes
STMT to 11 x 17
Paper Weights
Dimensions
9-7/8 x 22-1/4 x 27-5/8
(251mm x 565mm x 700mm)
Weight
50.7 lbs.
Description
Paper Deck-Q1 (Optional)
Number Of Cassettes
1
Paper Capacity
2,500 Sheets
Paper Sizes
LTR
Paper Weights
17 lb. Bond to 28 lb. Index
Power Source
Dimensions
18-5/8 x 14-5/8 x 23-1/4
(473mm x 372mm x 591mm)
Weight
65.3 lbs.
Output Options
Finishers Output Trays
Description
Finisher-P1 (Optional)
Paper Weights
Paper Size
STMT-R to 12 x 18
Number Of Trays
1 Internal Tray + optional Copy Tray-J1 installed on right side
Top Tray
500 Sheets (LTR, STMT-R)
250 Sheets (LGL, 11 x 17)
Staple Capacity
50 Sheets (LTR)
30 Sheets (LTR-R, LGL, 11 x 17)
Staple Positions
1-Top corner (Any corner of page)
2-Side Margin (Book Staple)
Power Source
Dimensions
7-7/8 x 16-1/8 x 21-1/4
(201mm x 409mm x 534mm)
Weight
25.3 lbs.
Description
Finisher-Q1/Q3 (Optional)
Paper Weights
Paper Size
STMT to 11 x 17
Number Of Trays
2 + optional Additional Finisher Tray-A1
Top Tray
1,000 Sheets (LTR, STMT-R)
500 Sheets (LGL, 11 x 17)
Lower Tray
Staple Capacity
50 Sheets (LTR)
Staple Positions
Power Source
Directly from main unit
Dimensions
40-3/4 x 21-1/8 x 25-7/8
(1036mm x 536mm x 657mm)
Weight
87.3 lbs.
Description
Saddle Finisher-Q2/Q4 (Optional)
Paper Weights
Paper Size
STMT-R to 12 x 18
Number Of Trays
3 + optional Additional Finisher Tray-A1
Top Tray
Lower Tray
Saddle Stitch Tray
11-15 Sheets/10 Sets
6-10 sheets/15 Sets
1 to 5 Sheets/25 Sets
Staple Positions
3-Saddle-stitch mode (Center Stapling)
Paper Sizes
LTR-R, LGL, 11 x 17
Stapling Capacity
15 Sheets
Fold Type
V-Folding
Power Source
Dimensions
40-3/4 x 25-1/5 x 25-7/8
(1036mm x 648mm x 657mm)
Weight
149 lbs.
Fax Board
Description
Super G3 Fax Board-N1/Multi-Line Fax Board-F1
Applicable Line
Public Switched Telephone Network(PSTN)Super G3 Fax Board-S1: One line
Super G3 Multi-Line Fax Board-F1: Two lines Sending/Original Size: Stmt to 11 x 17 (from DADF-L1)
Recording/Printing Size: Stmt. to 11 x 17
Description
Canon Color PCL/PS Printer Kit-D1 (standard w/ iR C3170i)
Processor
Dual Canon Custom Processor (250MHz - shared)
Standard Memory
1GB (shared)
Maximum Memory
1GB (shared)
Hard Disk
Shared 80GB HDD
Continuous Print Speed
31-ppm (LTR)
PDL Support
UFR II, PCL5c, PostScript 3 emulation
Postscript Fonts
136
PCL Fonts
80 Roman, 32 Barcode
Interface Connections
RJ45 (10/100BaseT)
USB Interface (optional)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER C3170U that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
