Web Content Viewer
Actions
imageRUNNER C5068
Support Color Multifunction Copiers
Specifications
Model Name
imageRUNNER C5068
Type
Color Digital Multifunction Imaging System
Imaging System
Copying Method: Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent/Dual Component Developing System
Image Server Memory
1.5GB RAM
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max Copy Reservation
10 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
2400 dpi x 600 dpi Interpolated
Halftone
256 Gradations (Continuous-Tone)
Letter
(B/W, Color): Up to 68/16 ppm (Letter)
First Copy Time
5.3 Seconds (B/W)
12.2 Seconds (Color)
Multiple Copies
1 to 9,999
Magnification
25% - 400% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Statement to 11x 17
Sheet, Book, 3-dimensional Objects (up to 4.4 lb.)
Acceptable Paper Weight of Originals: Simplex: 13 lb. to 32 lb. Bond
Duplex: 17 lb. to 32 lb. Bond Scan Speed: Up to 70 ipm at 300 dpi (LTR in B/W and Color)
Up to 50 ipm at 600 dpi (LTR in B/W and Color)
Maximum Original Size
11 x 17Image Reader: Color Image Reader (Standard)
Standard Paper Capacity
Dual 1,500-sheet Paper Drawers
Dual 550-sheet Paper Cassettes
Optional: 3,500-sheet Paper Deck
Manual Bypass
100-sheet Stack Bypass
Maximum Paper Capacity
100 Sheets
Output Sizes
Cassette
Upper Drawers: Letter
Lower Cassettes: 13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
13 x 19, 12-5/8 x 17-11/16, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, Irregular size (3-15/16 x 5-7/8 to 13 x 19)
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index
Bypass
17 lb. Bond to 140 lb. Index
Duplexing
Standard Automatic Trayless Duplexing (STMT-R to 12 x 18)
Warm Up Time
8 Minutes and 50 Seconds after Powering On
Exposure Control
Automatic or Manual (9 Levels)Magnification
Color Mode: Auto Color, Full Color, Black, Single Color, Two Colors
Power Requirements
120V AC, 60Hz, 16A
Power Consumption: 1.75 kW
Plug: NEMA 5-20P
Dimension
46-7/8 x 26-3/4 x 33-1/2
Installation Space (W x D): 57-3/4 x 33-1/2 (When Stack Bypass is Extended)
Weight
Approx. 498 lb.
Estimated Toner Yield
Black: 40,000 Images at 6% Coverage
Color: 9,500 Images at 5% Coverage
Paper Supply Options
Description
Paper Deck-U1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter
Dimensions
22-3/8 x 12-7/8 x 23
Installation Space (W x D): 37-7/8 x 33-1/2
Weight
Approximately 101 lb.
Output Options
Finishers Output Trays
Description
Finisher-AC1/Saddle Finisher-AC2
Paper Weights
Paper Size
Standard: 13 x 19, 12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Non-standard Size: Irregular Size (3-15/16 x 5-7/8 to 13 x 19
Number Of Trays
3 Trays
Top Tray
1,300 Sheets (Letter, Statement-R, Executive)
650 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)
Lower Tray
2,450 Sheets (Letter)
Non-collating Tray: 250 Sheets (Letter, Statement-R, Executive)
125 Sheets (13 x 19, 12 x 18, 11 x 17, Legal, Letter-R)Paper Capacity of Staple Mode
Upper Tray: 1,300 Sheets/100 Sets (Letter, Executive)
Lower Tray: 650 Sheets /50 Sets (11 x 17, Legal, Letter-R)
Staple Capacity
Letter, Executive: 50 Sheets (17 lb. to 20 lb. Bond)
30 Sheets (20 lb. to 28 lb. Bond)
2 Sheets (28 lb. Bond to 140 lb. Index)
11 x 17, Legal, Letter-R: 30 Sheets (17 lb. to 20 lb. Bond)
20 Sheets (20 lb. to 28 lb. Bond)
Staple Positions
Corner: 11 x 17, Legal, Letter, Letter-R, Executive
Double: 11 x 17, Legal,†Letter Letter-R,†Executive
Paper Sizes
12 x 18,†11 x 17, Legal, Letter-R tt Saddle-stitch Capacity: 15 Sheets (17 lb. to 20 lb. Bond)
10 Sheets (20 lb. to 28 lb. Bond)Tray Capacity: 25 Sets (1 to 5 Sheets), 15 Sets (6 to 10 Sheets), 10 Sets (11 to 15 Sheets)
Fold Type
V-Fold
Dimensions
Finisher-AC1: 46-1/4 x 26-1/4 x 25-7/8
Saddle Finisher-AC2: 46-3/4 x 26-1/4 x 25-7/8Installation Space (W x D): 55-1/2 x 33-1/2 (When the Auxiliary Tray is Extended), 60-3/4 x 25-7/8 (When the Optional Puncher Unit-M1 is Attached and the Auxiliary Tray is Extended)
Weight
Finisher-AC1: Approximately 101 lb.
Saddle Finisher-AC2: Approximately 161 lb. Puncher Unit-M1ttt
Paper Size: 11 x 17, Legal, Letter, Letter-R
Max. Paper Weight: 17 lb. Bond to 140 lb. Index
Punch Type: 3 Holes (Letter, 11 x 17)
2 Holes (Legal, Letter-R)
Punch Waste Tray Capacity: When approximately 3,000 Sheets of Paper Have Been Punched
Dimensions (H x W x D): 32-3/4 x 4-1/4 x 24-1/2
Weight: Approximately 15.9 lb.
Fax Board
Description
Super G3 Fax Board-U1 (Opt.)
Applicable Line
Public Switched Telephone Network (PSTN)
Connection Lines: One-Line (Super G3 Fax Board-U1)Sending/Original Size: Statement to 11 x 17
Recording/Printing Size: Statement to 11 x 17
Print Board
Description
Color UFR II/PCL Printer Kit-Z1
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
1.5GB RAM (Std.) (Shared)
Hard Disk
80GB (Shared)
PDL Support
UFR II/PCL 5c/PCL 6
Optional PDL Support: PostScript 3 Emulation (PS Printer Kit-Z1)Print Resolution:
UFR II/PS 3: 2400 dpi Equivalent x 600 dpi
PCL 5c: 2400 dpi Equivalent x 600 dpi
PCL 6: 2400 dpi Equivalent x 600 dpi
Print Controller Technology
UFR II: Windows® (Windows 2000/XP/Server 2003/Windows Vista®), Citrix MetaFrame, Macintosh® (OS 10.2.8 or Later)
PCL 5c: Windows (Windows 2000/XP/Server 2003/Windows Vista) Citrix MetaFrame
PCL 6: Windows (Windows 2000/XP/Server 2003/Windows Vista) Citrix Metaframe
XPS:# Windows Vista
PS3 (Optional): Windows (Windows 2000/XP/Server 2003/Windows Vista), Citrix MetaFrame, Macintosh (OS 10.2.8 or Later)
Description
imagePASS-G1 v1.1
Processor
Celeron® M 1.2GHzSystem: System 7e
Standard Memory
256MB
Maximum Memory
512MB
Hard Disk
80GB
PDL Support
Adobe® Postscript® 3, PCL 5c
Print Resolution: 600 dpi x 600 dpi
Utility Software: Remote Scan/Command WorkStation® for Windows/Command WorkStation for Mac
Interface Connections
10/100/1000Base-T (RJ-45)
Other Features
Options: 256MB RAM, Secure Erase v1.0, Impose v2.6, X-Rite Eye-One
Send Expansion Sets
Description
Color Universal Send (Standard)
Address Book Capacity
Max. 1,800 Destinations (Includes 200 One-Touch Buttons), Max. 5 LDAP Servers
File Format
Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-mail/I-fax: SMTP, POP3, I-FAX (Simple, Full)
Data Format
File, E-mail: TIFF, JPEG, PDF, PDF (Compact),* PDF (Trace & Smooth),* PDF (OCR),* Encrypted PDF,** Digital Signature PDF (Device,** User***)
I-fax: B/W: TIFF (MH, MR, MMR) Color: TIFF (Profile-C)
Sending Size
E-Mail, I-FAX, SMB, File Server (FTP, IPX, WebDAV), User Inbox, Super G3 Fax (Opt.)Color Mode: Auto Color Select (Full Color, Grayscale)
Auto Color Select (Full Color, B/W)
Full Color, Grayscale, B/W Other Optional Accessories Encrypted Secured Print Software-C1^Barcode Printing Kit-A1Web Access Software Kit-E1^^Universal Send PDF Advanced Feature Set-A1Universal Send PDF Security Feature Set-A1Digital User Signature PDF Kit-A1Secure Watermark-A1Super G3 Fax Board-U1HDD Data Encryption Kit-B1HDD Data Erase Kit-A1Voice Guidance Kit-A2Remote Operator Software Kit-A2Document Tray-M1Copy Tray-K1Card Reader-C1Card Reader Attachment Kit-C1Key Switch Unit-A2Braille Label Kit-A1ADF Access Handle-A1Stamp Unit-B1eCopy Suite Access Management System Kit-A1Workflow Composer-B2Footnotes:
* Requires Universal Send PDF Advanced Feature Set-A1
** Requires Universal Send PDF Security Feature Set-A1
*** Requires Digital User Signature PDF Kit-A1
# Check with Authorized Canon Dealer for availability
t Not available on imagePASS-G1 v1.1
tt Available with Saddle Finisher-AC2 only
ttt Can only be installed with Finisher-AC1 or Saddle Finisher-AC2
^ Requires UFR II/PCL Printer Kit-Z1
^^ Requires UFR II/PCL Printer Kit-Z1 if printing Web pages; requires PS-Printer Kit-Z1 if printing PDF files
Voice Guidance Kit-A2 cannot be installed with Document Tray-M1
Cannot be installed if any optional finishers are installed
Requires Card Reader Attachment Kit-C1 for installation
Awards
BERTL 4 Star Highly Recommended
Better Buys for Business 2008 Editor's Choice
BLI 2008 4 Stars
BLI 2008 Recommended
BLI 2008 Reliability Certified
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER C5068 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER C5068 / C5058 Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
