Web Content Viewer
Actions
imageRUNNER C5870U
Support Color Multifunction Copiers
Features
The imageRUNNER C5870U device offers black-and-white output speeds of up to 58 pages-per-minute with the ability to handle occasional color requirements at 16 ppm. The device also supports fast scanning speeds of up to 70-ipm (ltr, 300 dpi).
The imageRUNNER C5870U has been designed with an innovative dual processor supporting up to 1GB RAM and a 80GB hard disk drive, thus eliminating bottlenecks and improving network efficiency.
With Canon's standard Color Universal Send technology, users are able to scan and distribute documents to multiple destinations, eliminating expense and administrative burden associated with conventional methods of printing, filing, and forwarding of hard-copy documents. In addition, users may add the optional PDF High-Compression Kit-A1 to send complex and detailed color pages efficiently over network lines and the Universal Send PDF Enhancement Kit-C1 offering Searchable PDF and Encrypted functionality.
Installed with an optional Super G3 Fax Board-U1, the imageRUNNER C5870U can be transformed into an advanced, easy-to-use fax machine.
With reliable consumables and supplies, the imageRUNNER C5870U device offers easy-to-replace and high yielding toners. And, a durable Amorphous Silicon Drum, which delivers high reliability over millions of impressions for both black-and-white and color output.
Incorporating Canon MEAP™ (Multifunctional Embedded Application Platform) architecture, the imageRUNNER C5870U is customized to meet unique business needs. Customized applications can run from the device's control panel, streamlining document workflows.
Users can choose to add the Canon Color UFR II/PCL/PS Printer Kit-L1, which delivers printing capabilities with support for PCL 5e/6, PostScript® 3™ emulation, and Canon's UFR II (Ultra Fast Rendering) technology.
The generous paper supply of 4,200 sheets can be boosted to a bountiful capacity of 7,700 sheets for virtual uninterrupted productivity. The imageRUNNER C5870U supports large paper sizes of up to 13" x 19" and heavy weights of up to 140lb. Index, and can accommodate tab paper and transparencies.
Users can choose to add the optional Finisher-R1 or Saddle Finisher-R2 for advanced document finishing capabilities. The Saddle Finisher allows users to create folded booklets for paper sizes including Letter, 11" x 17", and Legal-sized paper. Each finisher can be configured with a hole-punch unit for professional-looking documents.
Supports a host of Internet-ready capabilities, including the optional Web Access Software that allows users to call up Internet or intranet data right on the user-interface, and print Web Pages and downloadable PDF files when configured with the Canon print controller.
Specifications
Model Name
imageRUNNER C5870U
Type
Color Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent/Dual Component Developing System (B/W, Color)
Image Server Memory
Standard 1GB RAM + 80GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi (256 Gradations) 8 Bit x 3 Colors
Printing Resolution
2400 dpi x 600 dpi Interpolated
Halftone
256 Gradations (Continuous-Tone)
Letter
58, 16 ppm (B/W, Color)
Letter R
42, 7.8 ppm (B/W, Color)
Legal
34, 7.8 ppm (B/W, Color)
Ledger
25, 5.2 ppm (B/W, Color)
Statement
First Copy Time
5.3 Seconds (B/W); 12.2 Seconds (Color)
Multiple Copies
1 to 9,999
Magnification
25% to 400% (in 1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%, 121%, 129%, 200%, 400%
Acceptable Originals
Sheets, Books, 3-Dimensional Items (Up to 4.4 lb.)
Maximum Original Size
11 x 17
Standard Paper Capacity
Dual Front-Loading Trays (1,500 Sheets Each); Dual Front-Loading Cassettes (550 Sheets Each); Optional: 3,500-Sheet Paper Deck
Manual Bypass
100-Sheet Stack Bypass
Maximum Paper Capacity
7,700 Sheets
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index (Trays, Cassettes, Optional Paper Deck)
Bypass
17 lb. Bond to 140 lb. Index (Manual Bypass Tray)
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
9 Minutes or Less
Power Requirements
120V, 60Hz, 16A
Dimension
46-7/8 x 26-3/4 x 33-1/2 (1191mm x 679mm x 852mm)
Weight
498 lb. (226kg)
Toner
Black: Magnetic Negative Toner; Colors: Non-Magnetic Negative Toners
Estimated Toner Yield
Black: Estimated Yield: 40,000 Images (at 6% Coverage); Colors: Estimated Yield: 9,500 Images (at 5% Coverage)
Drum
Amorphous Silicon
Estimated Drum Yield
Estimated
Feeders
Description
Automatic Document Feeder (Standard)
Statement to 11 x 17
Capacity
100 Sheets (Letter/20 lb.)
Paper Weights
13 lb. to 32 lb. Bond (Simplex); 17 lb. to 32 lb. Bond (Duplex)
Power Source
From Main Unit
Weight
Approximately 32.4 lb. (14.7kg)
Paper Supply Options
Description
Side Paper Deck-U1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
Power Source
From Main Unit
Dimensions
22-3/8 x 12-7/8 x 23 (569.5mm x 326mm x 583mm)
Weight
Approximately 101 lb. (46kg)
Output Options
Finishers Output Trays
Description
Finisher-R1/Saddle Finisher-R2
Paper Weights
Paper Size
Non-Collate, Collate, and Group Mode: 1,000 Sheets (Letter, Statement, Statement-R, Executive); 500 Sheets (Legal, Letter-R, 11 x 17, 12 x 18, 13 x 19); Staple Mode: 1,000 Sheets/30 Sets (Letter, Executive); 500 Sheets/30 Sets (Legal, Letter-R, 11 x 17); Max. Stapling Capacity Corner, Double: 50 Sheets (Letter), 30 Sheets (Letter-R, Legal, 11 x 17; 17 lb. to 20 lb. Bond)
Number Of Trays
2 Trays
Saddle Stitch Tray
Yes
Staple Capacity
15 Sheets
Hole Punch
Puncher Unit-M1
Paper Sizes
Stapling Capacity
1 to 5 Sheets/25 Sets; 6 to 10 Sheets/15 Sets; 11 to 15 Sheets/10 Sets
Fold Type
V-Fold
Description
Additional Finisher Tray-A1
Top Tray
100 Sheets (Top Finisher Tray 1,000-Sheet Max. Decrease to 500)
Fax Board
Description
Applicable Line
Public Switched Telephone Network (PSTN)
Print Board
Description
Color UFR II/PCL/PS Printer Kit-LI
Processor
Canon Custom Processor -- Shared
Standard Memory
1GB
Maximum Memory
1GB
Hard Disk
80GB -- Shared
PDL Support
PCL 5c, PostScript® 3TM Emulation, UFR II
Interface Connections
10/100Base-T (RJ-45), USB 2.0
Print Controller Technology
Printer Drivers: UFR II; PCL 5c; PS 3 Emulation
Description
imagePASS-G1: External Piggy-Back Controller
Processor
Intel® Celeron® M 1.2GHz
Standard Memory
256MB
Maximum Memory
512MB
Hard Disk
80GB
PDL Support
Adobe PostScript 3, PCL 5c
PCL Fonts
PS: 136 Fonts (117 Adobe® Type and 19 TrueType®); PCL 5c: 113 Roman
10/100/1000Base-T (RJ-45)
Other Features
Color Network ScanGear
ENERGY STAR Qualified
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER C5870U that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
