Web Content Viewer
Actions
imageRUNNER 1023
Support - Multifunction
Specifications
Model Name
imageRUNNER 1023
Type
Monochrome Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Single Component Projection
Fixing System
RAPID Fusing System™
Image Server Memory
128MB RAM
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
Enhanced 1200 x 600 dpi
Halftone
256 Levels
Letter
Up to 23 ppm (LTR)
First Copy Time
Less than 8 Seconds (From Platen Glass)
Less than 12 Seconds (From DADF)
Multiple Copies
1 to 99
Magnification
50% to 200% (In 1% Increments)
Preset Reductions
50%, 64%, 78%, 100%, 129%, 200%
Maximum Original Size
Legal
Standard Paper Capacity
1 x 500-Sheet Paper Cassette (21 lb. Bond)
Manual Bypass
1 x 100-Sheet Stack Bypass (21 lb. Bond)
Maximum Paper Capacity
1,100 Sheets
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond
Bypass
15 lb. to 34 lb. Bond
Duplexing
Standard
Warm Up Time
Less than 13.5 Seconds 1 Second (From Energy Saver Mode)
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V AC, 60Hz, 5.1A
Dimension
14-7/8 x 20-1/2 x 18
(378mm x 520mm x 457mm)
Weight
(Including Drum Unit, Excluding Toner Cartridge): Approximately 48.5 lb. (22kg)
Estimated Toner Yield
Approximately 8,400 Images at 6% Coverage
Estimated Drum Yield
26,900 Copies
Paper Supply Options
Description
Cassette Feeding Module-N1 (Optional)
Paper Capacity
1 x 500 Sheet Paper Cassette (21 lb. Bond)
Paper Sizes
Legal, Letter
Paper Weights
Dimensions
6-1/4 x 20-1/2 x 17-3/8
(158mm x 520mm x 440mm)
Weight
Approximately 11.46 lb. (5.2kg)
Description
Cabinet-V1
Dimensions
20-5/8 x 20-1/2 x 19
(525mm x 520mm x 481mm)
Weight
27.9 lb.
Output Options
Print Board
Processor
Canon Custom Processor -- Shared
Standard Memory
Shared with Main Unit: 128MB RAM
PDL Support
UFR II LT (Standard),** PCL 5e/6** (Optional with PCL Printer Kit-M1)
Interface Connections
USB 2.0 High Speed 10/100Base-TX***Network OS: Windows® 98/Me/2000/XP/Server 2003/Macintosh® OS(10.2.8 to 10.4.6)t Utility Software: Remote UI/imageWARE Enterprise Management Console/iR Toolbox/Canon Font Manager Additional Supplies and Accessories:Barcode Printing Kit-B1^^^Basic Card Set Braille Label Kit-A1Card Reader Attachment-D2Card Reader-E1Cassette-AD1 (Replacement Cassette)Copy Card SetsGPR-22 Black Toner PCL Printer Kit-M1Network Interface Adapter-IN-E11**Disclaimers:
* Warm-Up/First-Copy Time may differ depending on the condition and environment of the device.
** Network printing requires the optional Network Interface Adapter-IN-E11.
*** Optional for imageRUNNER 1023 model.
t Only available for UFR II LT.
^^Based on ITU-T Standard Mode.
^^^Check with your Authorized Canon Dealer for availability.
Send Expansion Sets
Sending Size
Statement to Legal
ENERGY STAR Qualified
Awards
Better Buys for Business Editor's Choice 2007
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 1023 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER 1023 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
