Web Content Viewer
DISCLAIMER
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
imageRUNNER 1023N
The imageRUNNER 1023N is designed with small businesses and workgroups in mind. Operating at speeds of up to 23 pages-per-minute (LTR), the imageRUNNER 1023N model supports digital copying, network printing, automatic duplexing, and color scanning features, along with the added convenience of a 50-sheet Duplexing Automatic Document Feeder. The imageRUNNER 1023N provides a compact desktop design as well as all the functionality needed in a single multifunction solution. Plus, its expandable paper capacity helps maintain uptime for every user. Delivering durable performance with high-end capabilities, the imageRUNNER 1023N device is designed to redefine small office and workgroup efficiency.
Specifications
Model Name
imageRUNNER 1023N
Type
Monochrome Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Single Component Projection
Fixing System
RAPID Fusing System
Image Server Memory
128MB RAM
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
Enhanced 1200 x 600 dpi
Halftone
256 Levels
Letter
Up to 23 ppm (LTR)
First Copy Time
Less than 8 Seconds (From Platen Glass)
Less than 12 Seconds (From DADF)
Multiple Copies
1 to 99
Magnification
50% to 200% (In 1% Increments)
Preset Reductions
50%, 64%, 78%, 100%, 129%, 200%
Maximum Original Size
Legal
Standard Paper Capacity
1 x 500-Sheet Paper Cassette (21 lb. Bond)
Manual Bypass
1 x 100-Sheet Stack Bypass (21 lb. Bond)
Maximum Paper Capacity
1,100 Sheets
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond
Bypass
15 lb. to 34 lb. Bond
Duplexing
Standard
Warm Up Time
Less than 16 Seconds
1 Second (From Energy Star Mode)
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V AC, 60Hz, 5.1A
Dimension
17-7/8 x 20-1/2 x 18
(453mm x 520mm x 457mm)
Weight
(Including Drum Unit, Excluding Toner Cartridge): Approximately 53.1 lb. (24.1kg)
Estimated Toner Yield
Approximately 8,400 Images at 6% Coverage
Estimated Drum Yield
26,900 Copies
Feeders
Description
Duplexing Automatic Document Feeder-N1 (Standard)
Acceptable Originals
Statement to Legal
Capacity
50 Sheets (21 lb. Bond)
Paper Weights
13 lb. to 34 lb. Bond (One-Sided Scanning)
13 lb. to 28 lb. Bond (Two-Sided Scanning)
Paper Supply Options
Description
Cassette Feeding Module-N1 (Optional)
Paper Capacity
1 x 500 Sheet Paper Cassette (21 lb. Bond)
Paper Sizes
Legal, Letter
Paper Weights
Dimensions
6-1/4 x 20-1/2 x 17-3/8
(158mm x 520mm x 440mm)
Weight
Approximately 11.46 lb. (5.2kg)
Description
Cabinet-V1
Dimensions
20-5/8 x 20-1/2 x 19
(525mm x 520mm x 481mm)
Weight
27.9 lb.
Output Options
Print Board
Processor
Canon Custom Processor -- Shared
Standard Memory
Shared with Main Unit: 128MB RAM
PDL Support
UFR II LT (Standard), PCL 5e/6 (Optional with PCL Printer Kit-M1)
Interface Connections
USB 2.0 High Speed 10/100Base-TXNetwork OS: Windows® 98/Me/2000/XP/Server 2003/Macintosh® OS(10.2.8 to 10.4.6)t Utility Software: Remote UI/imageWARE Enterprise Management Console/iR Toolbox/Canon Font Manager Additional Supplies and Accessories:Barcode Printing Kit-B1^^^Basic Card Set Braille Label Kit-A1Card Reader Attachment-D2Card Reader-E1Cassette-AD1Copy Card SetsGPR-22 Black Toner PCL Printer Kit-M1Disclaimers:
* Warm-Up/First-Copy Time may differ depending on the condition and environment of the device.
^^Based on ITU-T Standard Mode.
^^^Check with your Authorized Canon Dealer for availability.
ENERGY STAR Qualified
Awards
Better Buys for Business Editor's Choice 2007
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 1023N that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
GPR-22 Toner
Color: Black
Item Code: 0386B003AA
Estimated Toner Yield: 8,400 Copies/Case (Estimated @ 6% Coverage)
Brochures
Loading...
Complementary Content
- ${title}${badge}
${loading}
