Web Content Viewer
Actions
imageRUNNER 8070
Support - Multifunction
Features
Operating at 80 pages-per-minute, the imageRUNNER 8070 is equipped with a 20GB Hard Disk Drive and 512MB RAM, providing users with exceptional productivity and reliability
With a scanning resolution of 600 x 600 dpi, enhanced copy resolution of 1200 x 600 dpi, and enhanced print resolution of 2400 x 600 dpi, the imageRUNNER 8070 delivers superior quality for the most faithful reproduction of text and images.
Incorporating Canon's MEAP™ (Multifunctional Embedded Application Platform) architecture, the imageRUNNER 8070 can be customized to meet unique business needs. Customized applications can run from the imageRUNNER 8070 control panel, streamlining document workflows.
The color user interface panel, including a new Express Copy screen, and intuitively designed device drivers provide user-friendly operation for both walk-up and desktop environments.
With its standard Duplexing Automatic Document Feeder (DADF), the imageRUNNER 8070 makes quick work of multi-paged, double-sided and mixed-size originals. It can handle up to 100 originals and can accept paper weights from 10lb. to 32lb. Bond. The DADF is equipped with a Semi Automatic Document Feeder (SADF), which is ideal for making copies of heavy or light-weight originals that should not be subject to bending.
The imageRUNNER 8070 device's extensive finishing capabilities are designed to handle the most common high-volume copying and printing applications, such as booklets, training manuals, etc. Three optional finishers are available, all of which deliver single and multiposition stapling. Support for saddle-stitching, Z-folding, booklet trimming, 2- or 3-hole punching and post-process document insertion is also available.
Provides greater security measures for online information sharing and storage needs.
The imageRUNNER 8070 provides users with unmatched flexibility with respect to paper capacity, paper stocks, and drawer selection. Two 1,500-sheet paper trays and two 550-sheet user adjustable cassettes capable of handling from statement-sized paper up to 11" x 17" come standard. Additionally, a 50-sheet Stack Bypass brings the standard paper capacity to 4,150 sheets. An optional 3,500-sheet user-adjustable paper deck designed to accommodate 11" x 17", Legal, Letter or Letter-R-sized paper can be added to the device. All paper sources support paper weights from 17lb. Bond to 110lb. Index.
The Mail Box functions of the imageRUNNER 8070 serve as a centralized system for information-sharing, on-site document storage and print-on-demand applications.
Users can choose between two print controller options, the Canon Multi-PDL Printer Kit-F1 or the imagePASS-M3. The Canon controller delivers printing capabilities with support for PCL 5e/6, PostScript® 3™ emulation, and Canon's UFR II (Ultra Fast Rendering) technology. For those users with higher bandwidth requirements, the imagePASS-M3 features its own hardware dedicated to printing applications, and supports genuine Adobe® PostScript 3 and PCL 5e/6.
With its Universal Send™ technology, the imageRUNNER 8070 allows users to scan directly into the device for distribution to multiple destinations. Advanced Send options such as searchable PDF (OCR) and Encrypted PDF can be added for an even more sophisticated solution.
With Remote UI, features and functions of the imageRUNNER 8070 are controlled and accessed right from a user's desktop.
The imageRUNNER 105 delivers both copies and prints at a quick 105 pages-per-minute and a duty cycle of up to 600,000 impressions per month.
The imageRUNNER 105 ships standard with a 100-sheet Automatic Document Feeder (ADF) that accepts sizes up to 11" x 17" and weights up to 110 lb. Index. The ADF supports mixed-size originals with the same leading edge width, and comes equipped with a Semi Automatic Document Feeder (SADF), which is ideal for making copies of heavy- or light-weight originals that should not be subject to the bending that occurs inside the ADF.
A generous 7,650-sheet paper supply from six sources minimizes paper re-loading and maximizes flexibility in paper choice for output. Two 550-sheet front-loading user-adjustable cassettes, two 1,500-sheet paper trays, and a 50-sheet Stack Bypass come standard. An optional 3,500-sheet user-adjustable paper deck designed to accommodate ledger, legal, letter or letter-R can be added to the device. All paper sources handle paper from 17 lb. Bond to 110 lb. Index Stock.
The imageRUNNER 105 offers a 10GB internal Image Server as standard. The Hard Disk supports a host of applications for production level output including support for up to 100 User Mailboxes, Job Build, Automatic Page Impositioning for saddle-stitch booklet-making, and more!
With standard Automatic Trayless Duplexing, the imageRUNNER 105 can duplex on all supported paper sizes and paper stocks, including 11" x 17" paper and 110 lb. Index Stock.
The imageRUNNER 105 offers a choice of three finishers with the ability to perform multiposition and saddle-stitched stapling, booklet trimming, 2- or 3-hole punching, Z-folding, and post-process document insertion.
Two network printing options are available, both of which are compatible with most Windows and Macintosh network environments. One is best suited for text-intensive, every day printing needs and light graphics, and the other meets the needs of customers printing true Adobe PostScript 3 files, complex graphics, variable data output and other larger, more complex files.
Network scanning capabilities are available through Canon's Network ScanGear TWAIN-compliant software. Using a ScanGear enabled imageRUNNER 105, users can scan documents from the imageRUNNER 105's platen glass or feeder for transmission over the network to a ScanStation, their desktop or a file server. In addition, eCopy's ShareScan and Desktop product offerings can operate with a ScanGear-equipped imageRUNNER 105 for enhanced scanning and file management capabilities.
Operating at 105 pages-per-minute, the imageRUNNER 105+ is equipped with a 20GB Hard Disk Drive and 512MB RAM, providing users with exceptional productivity and reliability
With a scanning resolution of 600 x 600 dpi, enhanced copy resolution of 1200 x 600 dpi, and enhanced print resolution of 2400 x 600 dpi, the imageRUNNER 105+ delivers superior quality for the most faithful reproduction of text and images.
Incorporating Canon's MEAP™ (Multifunctional Embedded Application Platform) architecture, the imageRUNNER 105+ can be customized to meet unique business needs. Customized applications can run from the imageRUNNER 105+ control panel, streamlining document workflows.
With its standard Duplexing Automatic Document Feeder (DADF), the imageRUNNER 105+ makes quick work of multi-paged, double-sided and mixed-size originals. It can handle up to 100 originals and can accept paper weights from 13lb. Bond to 110lb. Index. The DADF is equipped with a Semi Automatic Document Feeder (SADF), which is ideal for making copies of heavy- or light-weight originals that should not be subject to bending.
The imageRUNNER 105+ device's extensive finishing capabilities are designed to handle the most common high-volume copying and printing applications, such as booklets, training manuals, etc. Three optional finishers are available, all of which deliver single and multiposition stapling. Support for saddle-stitching, Z-folding, booklet trimming, 2- or 3-hole punching and post-process document insertion is also available.
The imageRUNNER 105+ provides users with unmatched flexibility with respect to paper capacity, paper stocks, and drawer selection. Two 1,500-sheet paper trays and two 550-sheet user adjustable cassettes capable of handling from statement-sized paper up to 11" x 17" come standard. Additionally, a 50-sheet Stack Bypass brings the standard paper capacity to 4,150 sheets. An optional 3,500-sheet user-adjustable paper deck designed to accommodate 11" x 17", Legal, Letter or Letter-R-sized paper can be added to the device. All paper sources support paper weights from 17lb. Bond to 110lb. Index.
The Mail Box functions of the imageRUNNER 105+ serve as a centralized system for information-sharing, on-site document storage and print-on-demand applications.
With its Universal Send™ technology, the imageRUNNER 105+ allows users to scan directly into the device for distribution to multiple destinations. Advanced Send options such as searchable PDF (OCR) and Encrypted PDF can be added for an even more sophisticated solution.
With Remote UI, features and functions of the imageRUNNER 105+ are controlled and accessed right from a user's desktop.
Specifications
Model Name
imageRUNNER 105+
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Duty Cycle
600,000 Impressions per Month
Image Server Memory
Standard 512MB RAM + 20GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Printing Resolution
2400 x 600 dpi interpolated
Interpolated Resolution
1200 dpi x 600 dpi Interpolated
Halftone
256 Gradations of Gray
Letter
105 cpm
Ledger
49 cpm
First Copy Time
2.8 Seconds from Platen Glass
4.1 Seconds from ADF
Multiple Copies
1 to 9,999
Magnification
25% to 400% in 1% Increments
Maximum Original Size
11 x 17 (Ledger)
Standard Paper Capacity
Dual Front-loading Trays-1,500 Sheets Each
Dual Front-loading Cassettes-550 Sheets Each
Manual Bypass
Maximum Paper Capacity
7,650 Sheets
Acceptable Paper Weights
Cassette
Duplexing
Standard Automatic Trayless
Warm Up Time
6 Minutes or Less
Power Requirements
208V, 60Hz, 12A
Dimension
54-7/8 x 40-3/4 x 31-3/8
(1395mm x 1035mm x 795mm)
Weight
617 lb. (280kg)
Toner
Magnetic Negative Toner
Estimated Toner Yield
36,600 Images
Drum
Amorphous Silicon
Estimated Drum Yield
5,000,000 Impressions
Feeders
Description
Acceptable Originals
Statement to Ledger
Scanning Speed
80 ppm (Letter)
Capacity
100 Sheets (All Sizes/20 lb.)
Paper Weights
13 lb. Bond to 110 lb. Index
Paper Supply Options
Description
Paper Deck-N1(Optional)
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
Power Source
Directly From Main Unit
Dimensions
22-1/2 x 12-3/4 x 23
(570mm x 323mm x 583mm)
Weight
Approximately 90.3 lb. (41kg)
Description
Paper Deck-S1(Optional)
Paper Capacity
3,500 Sheets
Paper Sizes
Letter-R, Letter, Legal, 11 x 17
Paper Weights
Power Source
Dimensions
22-5/8 x 23-3/8 x 24-1/2
575mm x 593mm x 621mm)
Weight
Approximately 101 lb. (46kg)
Output Options
Finishers Output Trays
Description
Finisher-K1N (Optional)
Number Of Trays
2 Trays
Top Tray
1,000 Sheets (All Sizes)
Offset Stacking
Lower Tray
2,000 Sheets (Letter)
1,000 Sheets (11 x 17, Legal)
Offset Stacking
Staple Capacity
100 Sheets (Letter/Statement)
50 Sheets (Letter-R/Legal/11 x 17)
Staple Positions
1 - Any Corner
2 - Side Margin
Power Source
Dimensions
39-1/4 x 26-1/4 x 29-1/8
(995mm x 667mm x 738mm)
Weight
Approximately 141 lb. (64kg)
Description
Finisher-K2N (Optional)
Number Of Trays
2
Top Tray
Offset Stacking
Lower Tray
Offset Stacking
Staple Capacity
Staple Positions
1 - Any Corner
2 - Side Margin
Hole Punch
3 Holes (11 x 17, Letter)
2 Holes (Legal, Letter-R)
Power Source
Dimensions
Weight
145 lb. (66kg)
Description
Saddle Finisher-K3N (Optional)
Number Of Trays
3 Trays
Top Tray
Offset Stacking
Lower Tray
Offset Stacking
Saddle Stitch Tray
30 Sets
Staple Capacity
Staple Positions
1 - Any Corner
2 - Side Margin
Hole Punch
Paper Sizes
11 x 17, Letter
Stapling Capacity
15 Sheets (60 Pages)
Fold Type
V-folding Standard
Booklet Trimmers
Description
Booklet Trimmer-A1 (Optional)
Sheet Capacity
30 Sheets (60 Pages)
Stack Capacity
2,000 Pages
Dust Capacity
2,000 Pages
Document Inserters
Description
Document Insertion Unit-B1(Optional)
Paper Weight
Paper Sizes
Letter-R to 11 x 17
Feeder Capacity
Legal, 11 x 17: 50 Sheets
Letter, Letter-R: 100 sheets
Paper Folding
Description
Paper Folding Unit-C1 (Optional)
Paper Weight
17 lb. Bond to 22 lb. Bond
Paper Sizes
11 x 17 Only
Fold Type
Z-fold
Print Board
Description
Network Multi-PDL Printer Kit-F1 (Optional)
Processor
Canon-Custom Processor Shared
Standard Memory
512 MB - Shared
Storage: 20GB - Shared
PDL Support
PCL 5e, PCL 6, UFR II, PostScript 3 Emulation
Interface Connections
Standard: 10/100Base-T (RJ-45), USB 2.0 High Speed
Description
Canon imagePASS-M3 Print Controller (Optional)
Processor
Intel® Celeron® 2.5GHZ
Standard Memory
256MB
Hard Disk
40GB HDD
PDL Support
Adobe PostScript 3,PCL 5e, PCL 6
Standard: 10/100/1000 Base-T (RJ-45)
Optional: Parallel Interface Adapter (IEEE 1284)
Send Expansion Sets
Description
Universal Send Kit-C1
Sending Method
E-mail, I-fax, File Server, (IPX, FTP, SMB), User Inbox
Address Book Capacity
Maximum 1,800 destinations
File Format
Standard:TIFF, PDF
Optional: PDF (OCR)
Sending Size
Statement to Ledger
Scan Density
200 dpi, 300 dpi, 400 dpi, 600 dpi Other Accessories and Supplies:
Tab Feeding Attachment-A1
FL Cassette-P4
Card Reader-D1
GPR-7 Toner
Staple-G1
Staple-H1
Staple-D2
Basic Card Set, Copy Card Sets 1 (1-30), 2 (31-100), and 3 (101-200)
USB Application Interface Board-D1
Expansion Bus-A1
imageRUNNER Security Kit-A2
Universal Send PDF Enhancement Kit-B1
Awards
Line of the Year - Buyers Laboratory Inc.
Pick of the Year - Buyers Laboratory Inc.
Exceptional - BERTL Digital Test Lab
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 8070 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
