Web Content Viewer
Actions
imageRUNNER 1370F
Support - Multifunction
Features
The imageRUNNER 1370F features a 13 page-per-minute copy and print speed and a duty cycle of up to 20,000 impressions per month.
The standard 16MB of memory supports a host of important features, including Scan-Once-Print-Many, Copy Reservation and Electronic Collating.
The imageRUNNER 1370F offers a 600-sheet paper capacity standard through a 500-sheet user-adjustable paper cassette that supports letter and legal-sized paper, and a 100-sheet Stack Bypass for copying and printing onto various types of media.
The imageRUNNER 1370F comes standard with fax capabilities at Super G3 speed, speeding the completion of fax jobs while contributing to lower telephone line charges.
The imageRUNNER 1370F offers a standard 30-sheet Automatic Document Feeder (ADF), designed to increase productivity when scanning multi-page originals. The ADF accepts statement, letter and legal-sized paper.
The separated Toner Cartridge and Drum Unit keeps parts and supply costs at a minimum.
The imageRUNNER 1370F features a compact design, allowing the unit to fit comfortably in environments with little room for additional hardware. An optional cabinet is available for those who wish to raise the height of the main unit to make it comfortable for walk-up users.
The imageRUNNER 1370F comes standard with Canon's Advanced Printing Technology (CAPT), which makes printing solutions more affordable without sacrificing speed, functionality, or image quality. Direct printing is available via built-in parallel and USB ports. By adding the optional AXIS 1610 Print Server, the imageRUNNER 1330 can be transformed into a shared network printer to serve the needs of multiple network-connected users in a workgroup.
A user-friendly interface panel allows even the most casual user to perform every function with ease.
Specifications
Model Name
imageRUNNER 1370F
Type
Digital, Multifunction Imaging System
Imaging System
Indirect Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
Canon's Rapid Fusing System
Duty Cycle
Up to 20,000 impressions/month
Image Server Memory
16MB Standard/Max
Max Copy Reservation
No Limit (Up to memory capacity)
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 600 dpi (Copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
Letter
13 cpm/ppm
First Copy Time
13 Seconds
Multiple Copies
1-99
Magnification
50%-200%, in 1% increments
Preset Reductions
50%, 64%, 78%
Preset Enlargements
129%, 200%
Acceptable Originals
Sheets, Books, 3 Dimensional Items (up to 4.4 lbs.)
Maximum Original Size
8-1/2x14
Standard Paper Capacity
1 x 500 Sheets
Manual Bypass
100 Sheets
Maximum Paper Capacity
600 Sheets
Acceptable Paper Weights
Cassette
17-20 lb. Bond
Bypass
15-32 lb.
Warm Up Time
4.5 Seconds (from power plug-in)
1 Second (from Energy Saver Mode)
Power Requirements
120V, 60Hz, 3.8A
Dimension
15-1/8 x 18-3/4 x 17-3/8
Weight
52.9
Toner
GPR-10 Black Toner
Estimated Toner Yield
5,300 Images
Drum
GPR-10 Drum Unit
Estimated Drum Yield
24,000 Impressions
Feeders
Description
Statement to Legal
Capacity
30 Sheets
Paper Weights
14-32 lb. Bond
Power Source
Directly from Main Unit
Output Options
Fax Board
Description
Super G3 Fax Board (Standard)
Applicable Line
Public Switched Telephone Network
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
3 Seconds/Page
Data Compression
MH, MR, MMR, JBIG
Memory
4.5MB
Print Board
Description
Canon Advanced Print Technology (Standard)
Standard Memory
2MB
Continuous Print Speed
13 ppm (Letter)
Interface Connections
IEEE 1284 (Bi-directional Parallel)
USB 2.0 Full Speed (12Mbps)
Description
Processor
32-bit 100MHz RISC Controller
Standard Memory
2MB DRAM/1MB (Flash)
IEEE 802.2
IEEE 802.3
SNAP
Ethernet II
Awards
Line of the Year - Buyers Laboratory Inc.
Recommended - BERTL Digital Test Lab
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 1370F that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
