Web Content Viewer
Actions
imageRUNNER 1600
Support - Multifunction
Features
The imageRUNNER 1600 features a 16 page-per-minute copy and print speed and a duty cycle of up to 50,000 impressions per month.
The standard 16MB Image Server supports a host of important features, including Scan-Once-Print-Many, Copy Reservation, and more. To further enhance copying productivity, an additional 32MB of memory capacity may be added for a total of 48MB of memory.
The imageRUNNER 1600 offers a 350-sheet paper capacity as standard through a 250-sheet universal paper cassette and a 100-sheet Stack Bypass. Through optional paper supply accessories, the maximum paper capacity can be increased to 1,100 sheets, for virtually uninterrupted productivity of long-run length jobs.
The imageRUNNER 1600 features a compact design, which means that this unit can fit comfortably in environments with little room for additional hardware. When installed as a multifunction copier/printer solution, users will realize significant space savings as compared to using several standalone devices.
An easy-to-use control panel at the device provides users with quick programming for each feature and function. With dual accessibility, the imageRUNNER 1600 is designed to minimize job batting (contention) allowing users to access multiple product functions simultaneously.
When configured with optional accessories, the imageRUNNER 1600 can be transformed into a dedicated or shared network printer. When connected to a network, this model is also capable of being managed by users and administrators remotely via Canon's innovative Remote UI function and NetSpot Suite Utilities.
The imageRUNNER 1600 offers finishing capabilities and modes typically not available to Segment 1 prospects. Multiple output options are available, from simply separating copy/print output to full sorting, stapling and collating.
Specifications
Model Name
imageRUNNER 1600
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
Heat Roller Fusing
Duty Cycle
Up to 50,000 impressions/month
Image Server Memory
16MB Standard
Upgradeable to 48MB Maximum
Max Copy Reservation
No Limit (up to Memory Capacity)
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 600 dpi (Copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
Letter
16 cpm/ppm
Letter R
12 cpm/ppm
Legal
10 cpm/ppm
Ledger
9 cpm/ppm
Statement
16 cpm/ppm
First Copy Time
8.2 Seconds (From Platen Glass)
Multiple Copies
1 to 99
Magnification
50% - 200%, in 1% increments
Preset Reductions
50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%
Acceptable Originals
Sheets, Books, 3 Dimensional Items (Up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
1 x 250 Sheets
Manual Bypass
100 Sheets
Maximum Paper Capacity
1,100 Sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
4 x 5-3/4 to 11-5/8 x 17
Acceptable Paper Weights
Cassette
16 - 24 lb. Bond
Bypass
16 - 32 lb. Bond
Warm Up Time
30 Seconds or Less
Exposure Control
Automatic or Manual
Power Requirements
120V, 60Hz, 10A
Dimension
22 x 24-1/4 x 24-3/4
(560mm x 615mm x 631mm)
Weight
84 lbs.
Toner
GPR-8 Black Toner
Estimated Toner Yield
7,850 Images (6% Coverage)
Drum
GPR-8 Drum Unit
Estimated Drum Yield
21,000 Impressions
Feeders
Description
Automatic Document Feeder-J1 (Optional)
Statement to Ledger
Scanning Speed
16 opm
Capacity
50 Sheets
Paper Weights
14 - 28 lb. Bond
Power Source
Directly from Main Unit
Dimensions
4-3/4 x 23-1/4 x 19
(122mm x 592mm x 484mm)
Weight
16 lbs.
Paper Supply Options
Description
Cassette Feeding Module-F1 (Optional)
Number Of Cassettes
1
Paper Capacity
250 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
16 - 24 lb. Bond
Power Source
Description
Cassette Feeding Module-H1 (Optional)
Number Of Cassettes
3
Paper Capacity
750 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
16 - 24 lb. Bond
Power Source
Output Options
Finishers Output Trays
Description
Inner 2-Way Tray-B1 (Optional)
Paper Size
Statement to Ledger
Number Of Trays
2
Top Tray
100 Sheets (Letter)
Middle Tray
250 Sheets (Letter)
Power Source
Dimensions
4-1/2 x 5-1/8 x 18-1/2
(114.2mm x 127.6mm x 468.4mm)
Weight
8 lbs.
Description
Finisher-L1 (Optional)
Paper Weights
13 - 28 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
1
Top Tray
300 Sheets (Letter)
Staple Capacity
15 Sheets
Staple Positions
1 - Top Left Corner
Power Source
Dimensions
9-5/8 x 19-1/4 x 19-1/4
(245mm x 491mm x 491mm)
Weight
20 lbs.
Print Board
Description
Printer Board-N1 (Optional)
Processor
Power PC405 200MHz RISC Processor
Standard Memory
8MB
Maximum Memory
72MB
Hard Disk
Optional 10.0 GB HDD
Continuous Print Speed
16 ppm (Letter)
PDL Support
PCL 5e, PCL 6
PCL Fonts
80 Roman, 32 Barcode
Interface Connections
Ethernet (10/100BaseT) (Optional)
IEEE 1284 (Parallel)
Token Ring (Optional)
Other Features
Access to Full Finishing Features
Remote UI Supported
NetSpot Supported
Spooling Supported
Ethernet Network Interface Adaptors
Description
Ethernet Network Interface Adaptor iN-E5 (Optional)
Cpu
ETRAX 100LX (32 bit RISC CPU 100 MHz)
Memory Ram
4MB
Storage Rom
2MB (Flash™)
SDRam
128 Kbytes
Network Interface
10Base-T, 100Base-TX (RJ-45)
Printer Interface
EPS10 v. 1.00
Network OS
Novell® NetWare® v.3.2,4.1,4.2,4.11,
5.0,5.1 (IPX/SX™)
Windows® 95/98/Me(TCP/IP)
Windows NT® 4.0, 2000, Windows XP (TCP/IP)Solaris 1.1x,2.5 or later (TCP/IP)
Protocol Stacks
IPX/SPX: 802.2, 802.3, Ethernet II, 802.2 SNAP
(Ethernet SNAP)
TCP/IP: Ethernet II
NetBEUI (NetBIOS): 802.2
Awards
Line of the Year - Buyers Laboratory Inc.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 1600 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
