Web Content Viewer
Actions
imageRUNNER 2016i
Support - Multifunction
Features
Delivers output at up to 16 pages-per-minute (LTR) to keep pace with the needs of small businesses and workgroups.
Cutting edge image processing technology enables high-speed image data processing and the simultaneous processing of multiple functions. The imageRUNNER 2016i ships standard with 256MB RAM for reliable, high-speed image processing.
With a scanning resolution of 600 x 600 dpi, enhanced copy resolution of 1200 x 600 dpi, and print resolution of 1200 x 1200 dpi (with Canon UFR II LT), the imageRUNNER 2016i delivers superior quality for the most faithful reproduction of text and images.
Color-enabled document distribution allows users to communicate information more effectively; Includes standard support for PDF High Compression technology for efficient handling of color image data.
Compact MFP with a smart design and innovative integrated accessories that enables the system to be placed in areas with limited space.
The imageRUNNER 2016i offer standard duplexing capabilities, expandable paper capacities, and a choice of integrated output options.
Designed with Canon's RAPID Fusing Technology to significantly reduce energy consumption and improve productivity.
A standard 50-sheet capacity Duplexing Automatic Document Feeder makes scanning multi-page and different-size originals quick and easy.
With a maximum paper capacity of 1,080 sheets, the imageRUNNER 2016i has been designed to meet the volume requirements of any small business or workgroup.
Standard UFR II LT and PCL 5e/6 network printing to provide maximum flexibility and performance for busy workgroups and businesses.
The imageRUNNER 2016i can be equipped with an optional Super G3 fax board for the ability to transmit faxes at impressive speeds.
With Remote UI, features and functions of the imageRUNNER 2016i are easily accessed and controlled via a Web browser.
Specifications
Model Name
imageRUNNER 2016i
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Single-Component Projection
Fixing System
RAPID Fusing System™
Image Server Memory
256MB RAM
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
1200 x 1200 dpi (Std. UFR II Only)
Halftone
256 Levels
Letter
Up to 16 ppm (Letter)
First Copy Time
7.9 Seconds from Platen Glass; 13.5 Seconds from Feeder
Multiple Copies
1 to 99
Magnification
50% to 200% (In 1% Increments)
Preset Reductions
50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%
Acceptable Originals
Sheets, Books, and 3-Dimensional Items (Up to 4-3/8 lb.)
Maximum Original Size
11 x 17
Standard Paper Capacity
1 x 250+80 Bypass (Total 330 Sheets)
Manual Bypass
80 sheets
Maximum Paper Capacity
4 x 250+80 Bypass (Total 1,080 Sheets)
Output Sizes
Cassette
Statement to 11 x 17
Bypass
3 3/4 x 5 7/8 to 11 3/4 x 17
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond
Bypass
17 lb. to 32 lb. Bond
Duplexing
Standard
Warm Up Time
1 Second or Less from Sleep Mode; 25 Seconds or Less from Main Power Off
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V AC, 60Hz, 4.6A
Dimension
26-1/2 x 24-1/2 x 26-3/8 (672mm x 622mm x 668mm)
Weight
Approx. 102 lb. (46.2 kg)
Estimated Toner Yield
8,300 @ 6% Coverage
Drum
Organic Photo Conductor (OPC)
Estimated Drum Yield
55,000 Impressions
Feeders
Description
Duplexing Automatic Document Feeder-P1 (Standard)
Scanning Speed
20 Sheets/Minute (Letter, B/W)
Capacity
50 Sheets (Letter, Letter-R, Statement)
Paper Weights
10 lb. to 32 lb. Bond (One Sheet)
14 lb. to 28 lb. Bond (Multiple Sheets)
Dimensions
4-7/8 x 22-1/4 x 19-1/4
(122mm x 565mm x 489.4mm)
Weight
Approx. 16 lb. (7kg)
Paper Supply Options
Description
Cassette Feeding Module-J1 (Optional)
Number Of Cassettes
Paper Capacity
1 x 250-Sheet Paper Cassette
Paper Sizes
11 x 17, Legal, Letter, Letter-R, Statement
Paper Weights
Dimensions
4-5/8 22-7/8 x 22-3/8
(116mm x 580.3mm x 569.3mm)
Weight
Approx. 13 lb. (6kg)
Description
Cassette Feeding Module-K1 (Optional)
Number Of Cassettes
Paper Capacity
2 x 250-Sheet Paper Cassettes
Paper Sizes
Paper Weights
Dimensions
8 x 22-7/8 x 22-3/8
(201.8mm x 580.3mm x 569.3mm)
Weight
Approx. 26 lb. (12kg)
Output Options
Finishers Output Trays
Description
Inner 2-Way Tray-E1 (Optional)
Paper Size
Statement-R to 11 x 17
Number Of Trays
Two
Top Tray
100 Sheets (Letter); 50 Sheets (Other Sizes)
Lower Tray
250 Sheets (Letter); 100 Sheets (Other Sizes)
Dimensions
(Inside Main Unit): 6 x 19-1/8 x 17-3/4
(151.2mm x 485.5mm x 451mm)
Weight
Approx. 3 lb. (1.5kg)
Description
Finisher-U1 (Optional)
Paper Weights
17 lb bond to 32 lb bond
Paper Size
Number Of Trays
One (Second Tray Optional)
Top Tray
Single Tray: 770 Sheets (Letter, Statement, Statement-R); 380 Sheets (Legal, Letter-R, 11 x 17)
With Additional Finisher Tray-C1: 200 Sheets Each Tray (Letter, Statement, Statement-R); 150 Sheets Each Tray (Legal, Letter-R, 11 x 17)
Staple Capacity
Up to 50 Sheets (Letter); Up to 30 Sheets (Letter-R, Legal, 11 x 17)
Staple Positions
Corner Stapling (Letter, Letter-R, Legal, 11 x 17)
Dimensions
(Inside Main Unit): 11-7/8 x 18-1/8 x 20-1/2
(300mm x 480mm x 520mm)
Weight
Approx. 22 lb. (10kg)
Description
Add. Finisher Tray-C1 (Opt. for Finisher-U1)
Top Tray
200 Sheets (Letter, Statement, Statement-R) 150 Sheets (Legal, Letter-R, 11 x 17)
Lower Tray
Dimensions
(Inside Main Unit): 3-2/5 x 8-1/10 x 15-3/8
(86mm x 204mm x 390mm)
Weight
Approx. 4 lb. (1.8kg)
Fax Board
Description
Super G3 Fax Board-T1 (Optional)
Applicable Line
Public Switched Telephone Network (PSTN), Facsimile Network
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds/Page (33.6 Kbps)
G3MR Method: Approx. 13 Seconds/Page (33.6 Kbps)
G3MH Method: Approx. 13 Seconds/Page (33.6 Kbps)
JBIG: Approx. 2.6 Seconds/Page (33.6 Kbps)
Data Compression
MMR, MR, MH, JBIG
Memory
Approx. 1,000 Pages
Maximum Memory
Uses the imageRUNNER shared image server. Holds approx. 1,000 pages
One Touch Speed Dialing Locations
500 Destinations
Print Board
Description
Standard Printing Specifications
Processor
Canon Custom Processor -- Shared
Standard Memory
Shared with Main Unit -- 256MB Std.
PDL Support
UFR II LT, PCL 5e/6 (Std.)
Interface Connections
Standard Interfaces: 10/100Base-TX (RJ-45), USB 2.0 High Speed
Print Controller Technology
UFR II LT: Windows 98/Me/2000/XP
Windows Server 2003
Citrix Meta Frame
Macintosh OS X (OS 10.2.8 or later)PCL 5e/6: Windows 98/Me/2000/XP
Windows NT 4.0/Server 2003
Citrix Meta Frame Utility Software: Remote UI
NetSpot Device Installer
NetSpot Console
USB Class Driver, Fax Driver
Canon LPR 2
Canon Font Manager
Address Book Conversion Utility Network OS
Novell® NetWare® v. 5.1, 6, 6.5 (with Axis 1650 Print Server)
Windows® 98/Me
Windows NT® 4.0/2000/XP/Server 2003 (TCP/IP)
Apple® Macintosh® OS X or Higher Additional Supplies and Accessories Additional Finisher Tray C1AXIS 1650 Print Server Basic Card Set Braille Label Kit-A1Cabinet-R1 (Large)Cabinet-S1 (Small)Card Reader Attachment-D1Card Reader-E1Copy Card Sets Document Tray-J1Stamp Ink Cartridge-B1Staple Cartridge-J1
Send Expansion Sets
Description
Send Capabilities
Sending Method
Standard: E-Mail, I-Fax, Super G3 Fax (Opt.), File Server (FTP, SMB)
Address Book Capacity
500 Destinations
File Format
Black and White: TIFF, PDF Color: JPEG, PDF (Compact)
Sending Size
ENERGY STAR Qualified
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 2016i that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
