Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
imageRUNNER 2018i
Operating at speeds of up to 18 pages per minute (letter) the imageRUNNER 2018i is a powerful multifunction device that allows small businesses and workgroups to take advantage of their network infrastructure and speed their business communications. While already offering standard duplexing copying and printing capabilities, the ability to scan two-sided documents could not be easier as the imageRUNNER 2018i comes equipped with a standard 50-sheet Duplexing Automatic Document Feeder. Also, by utilizing the device's Color Send technology, users can send their scanned color documents to various destinations, providing them with the ability to distribute/share documents in a more convenient way. With all of its advanced features and capabilities, the imageRUNNER 2018i is the ideal solution to meet the daily challenges faced in increasingly sophisticated communications environments.
Specifications
Model Name
Type
Imaging System
Developing System
Fixing System
Image Server Memory
Max Copy Reservation
Scanning Resolution
Copy Resolution (Enhanced): Up to 1200 x 600 dpi
Printing Resolution
Halftone
Letter
First Copy Time
Multiple Copies
Magnification
Preset Reductions
Preset Enlargements
Acceptable Originals
Maximum Original Size
Maximum Copy Size: 11 x 17
Minimum Copy Size: 3-3/4 x 5/7-8
Standard Paper Capacity
Maximum Paper Capacity
Acceptable Paper Weights
Cassette
Bypass
Duplexing
Warm Up Time
26 Seconds or Less from Main Power Off *
Exposure Control
Power Requirements
Power Consumption: 1.425kW (Max.)
Dimension
Weight
Estimated Toner Yield
Feeders
Description
Scanning Speed
Capacity
Paper Weights
14 lb. to 28 lb. Bond (Multiple Sheets)
Dimensions
Weight
Description
Capacity
Paper Weights
Dimensions
Weight
Description
Capacity
Paper Weights
Dimensions
Weight
Output Options
Finishers Output Trays
Description
Paper Size
Number Of Trays
Top Tray
50 Sheets (Other Sizes)
Lower Tray
100 Sheets (Other Sizes)
Dimensions
Weight
Description
Number Of Trays
Tray Capacity
Single Tray: 770 Sheets (Letter, Statement-R)
380 Sheets (Legal, Letter-R, 11 x 17)
With Additional Finisher Tray-C1: 200 Sheets Each Tray (Letter, Statement-R)
150 Sheets Each Tray (Legal, Letter-R, 11 x 17)
Staple Capacity
Staple Positions
Top Right Corner: 11 x 17 (Portrait), Legal (Portrait)
Dimensions
Weight
Attachable Accessories: Optional Additional Finisher Tray-C1
Description
Paper Size
150 Sheets (Legal, Letter-R, 11 x 17)
Dimensions
Weight
Fax Board
Description
Applicable Line
Connection Lines: One
Address Book: 500 Destinations
Sending Original Sizes: Statement to 11 x 17
Recording Printing Sizes: Statement to 11 x 17
Transmission Speed
GRMR Method: Approx. 13 Seconds/Page (33.6 Kbps)
GRMH Method: Approx. 13 Seconds/Page (33.6 Kbps)
JBIG: Approx. 2.6 Seconds/Page (33.6 Kbps)
Scan Line Density
Standard: 8 Pels/mm x 3.85 Lines/mm
Fine: 8 Pels/mm x 7.7 Lines/mm
Super Fine: 8 Pels/mm x 15.4 Lines/mm
Memory
Print Board
Processor
Standard Memory
PDL Support
Interface Connections
Hi-Speed USB 2.0
Print Controller Technology
Windows Server 2003
Windows Vista
Citrix MetaFrame
Macintosh OS X (OS 10.2.8 or Later)
PCL 5e/6: Windows 98/Me/2000/XP
Windows Server 2003
Windows Vista
Citrix MetaFrame
Other Features
Windows 98/Me/2000/XP/Windows Server 2003/Windows Vista
Apple Macintosh OS X or Higher
Send Expansion Sets
Sending Method
Address Book Capacity
File Format
Color: JPEG, PDF, (Compact)
Sending Size
* At room temperature of 200C/680F.
** UFR II LT only.
*** Approximately 3-second-per-page fax transmission time based on ITU-T No. 1 Chart (JBIG, Standard Mode) at 33.6 Kbps modem speed when transmitting to another v.34 machine. The Public Switched Telephone Network (PSTN) currently supports 28.8 Kbps modem speeds or lower, depending on telephone line conditions.
^ Option for imageRUNNER 2018i only.
^^ Standard configuration of the imageRUNNER 2022i device shown; the imageRUNNER 2018i device ships standard with one paper cassette.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 2018i that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
GPR-18 Toner
Color: Black
Item Code: 0384B003AA
Estimated Toner Yield: 8,300 Copies/Case (Estimated @ 6% Coverage)
Brochures
- ${title}${badge}
