Web Content Viewer
Actions
imageRUNNER 2022
Support - Multifunction
Specifications
Model Name
imageRUNNER 1022
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Single-Component Projection
Fixing System
RAPID Fusing System
Image Server Memory
128MB/256MB RAM (Std./Max.)
Max Copy Reservation
Five Jobs
Scanning Resolution
Up to 600 x 600 dpi
Copy Resolution (Enhanced): Up to 1200 x 600 dpi
Printing Resolution
Up to 1200 x 1200 dpi**
Halftone
256 Levels
Letter
Up to 22 ppm (Letter)
First Copy Time
6.9 Seconds from Platen Glass
Multiple Copies
1 to 99
Magnification
20% to 200% (In 1% Increments)
Preset Reductions
50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%
Acceptable Originals
Sheets, Books, and 3-Dimensional Items (Up to 4-3/8 lb.)
Maximum Original Size
11 x 17
Maximum Copy Size: 11 x 17
Minimum Copy Size: 3-3/4 x 5/7-8
Standard Paper Capacity
2 x 250 + 80 Bypass (Total 580 Sheets)
Maximum Paper Capacity
4 x 250 + 80 Bypass (Total 1,080 Sheets)
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond
Bypass
17 lb. to 32 lb. Bond
Duplexing
Standard
Warm Up Time
One Second or Less from Sleep Mode*
14 Seconds or Less from Main Power Off *
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V AC, 60Hz, 4.6A
Power Consumption: 1.425kW (Max.)
Dimension
29-3/4 x 24-1/2 x 26-5/8
Weight
116 lb.
Estimated Toner Yield
8,300 at 6% Coverage
Feeders
Description
Duplexing Automatic Document Feeder-P2 (Opt.)
Statement to 11 x 17
Scanning Speed
20 Sheets/Minute (Letter, B/W)
Capacity
50 Sheets (Letter, Letter-R, Statement)
Paper Weights
10 lb. to 32 lb. Bond (One Sheet)
14 lb. to 28 lb. Bond (Multiple Sheets)
Dimensions
4-7/8 x 22-1/4 x 19-1/4
Description
Cassette Feeding Module-Q1 (Opt.)
11 x 17, Legal, Letter Letter-R, Statement
Capacity
2 x 250-Sheet Cassette
Paper Weights
Dimensions
8 x 22-7/8 x 22-3/8
Weight
Approx. 26.5 lb.
Description
Cassette Feeding Module-P1 (Opt.)
11 x 17 Legal, Letter, Letter-R, Statement
Capacity
1 x 250-Sheet Cassette
Paper Weights
Dimensions
4-5/8 x 22-7/8 x 22-3/8
Weight
Approx. 13 lb.
Output Options
Finishers Output Trays
Description
Inner 2-Way Tray-E2 (Opt.)
Paper Size
Number Of Trays
Two
Top Tray
100 Sheets (Letter)
50 Sheets (Other Sizes)
Lower Tray
250 Sheets (Letter)
100 Sheets (Other Sizes)
Dimensions
6 x 19-1/8 x 17-3/4
Weight
Approx. 33 lb.
Description
Finisher-U2 (Opt.)
Number Of Trays
One (Second Tray Optional)
Tray Capacity
Single Tray: 770 Sheets (Letter, Statement-R)
380 Sheets (Legal, Letter-R, 11 x 17)
With Additional Finisher Tray-C1: 200 Sheets Each Tray (Letter, Statement-R)
150 Sheets Each Tray (Legal, Letter-R, 11 x 17)
Staple Capacity
Up to 30 Sheets (All Sizes)
Staple Positions
Top Left Corner: 11 x 17 (Landscape), Legal (Landscape), Letter, Letter-R
Top Right Corner: 11 x 17 (Portrait), Legal (Portrait)
Dimensions
11-7/8 x 18-7/8 x 20-1/2
Weight
Approx. 22 lb.
Attachable Accessories: Optional Additional Finisher Tray-C1
Description
Add. Finisher Tray-C1 (Opt. for Finisher-U2)
Paper Size
200 Sheets (Letter, Statement-R)
150 Sheets (Legal, Letter-R, 11 x 17)
Dimensions
3-2/5 x 8-1/10 x 15-3/8
Weight
Approx. 4 lb.
Fax Board
Description
Super G3 Fax Board-AA1 (Opt.)
Applicable Line
Public Switched Telephone Network (PSTN) Facsimile Network
Connection Lines: One
Address Book: 500 Destinations
Sending Original Sizes: Statement to 11 x 17
Recording Printing Sizes: Statement to 11 x 17
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds/Page (33.6 Kbps)
GRMR Method: Approx. 13 Seconds/Page (33.6 Kbps)
GRMH Method: Approx. 13 Seconds/Page (33.6 Kbps)
JBIG: Approx. 2.6 Seconds/Page (33.6 Kbps)
Scan Line Density
Standard: 8 Pels/mm x 3.85 Lines/mm
Fine: 8 Pels/mm x 7.7 Lines/mm
Super Fine: 8 Pels/mm x 15.4 Lines/mm
Ultra Fine: 16 Pels/mm x 15.4 Lines/mm
Memory
Approx. 1,000 Pages
Print Board
Processor
Canon Customer Processor - Shared
Standard Memory
Shared with Main Unit: 128MB RAM
256MB RAM (Opt.)
PDL Support
UFR II LT (Std.)
PCL 5e/6 (Opt.)
Interface Connections
Novell NetWare v. 5.1, 6, 6.5
Windows 98/Me/2000/XP/Windows Server 2003/Windows Vista
Apple Macintosh OS X or Higher
Print Controller Technology
UFR II LT: Windows 98/Me/2000/XP
Windows Server 2003
Windows Vista
Citrix MetaFrame
Macintosh OS X (OS 10.2.8 or Later)
PCL 5e/6: Windows98/Me/2000/XP/Windows Server 2003/ Windows Vista
Citrix MetaFrame
Other Features
Standard Interfaces: 10/100Base-TX (RJ-45)
Hi-Speed USB 2.0Additional Supplies and Accessories Duplex Unit-B1Fax Panel-B1PCL Printer Kit-VI Platen Cover Type-J Basic Card Set Braille Label Lit-A1Cabinet-R1 (Large)Cabinet-S1 (Small)Card Reader Attachment-D1Card Reader-E1Copy Card Sets Document Tray-J1Power Supply Kit-Q1Barcode Printing Kit-B1FL Cassette-AF1Stamp Ink Cartridge-C1Staple Cartridge-J1GPR-18 Black Toner* At room temperature of 200C/680F.
** UFR II LT only. Requires 256MB RAM.
*** Approximately 3-second-per-page fax transmission time based on ITU-T No. 1 Chart (JBIG, Standard Mode) at 33.6 Kbps modem speed when transmitting to another v.34 machine. The Public Switched Telephone Network (PSTN) currently supports 28.8 Kbps modem speeds or lower, depending on telephone line conditions.
^ Available with PCL Printer Kit-VI.
^^ Option for imageRUNNER 2018 only.
^^^ Standard configuration of the imageRUNNER 2022i device shown; the imageRUNNER 2018i device ships standard with one paper cassette.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 2022 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER 2000 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
