Web Content Viewer
Actions
imageRUNNER 2025i
Support - Multifunction
Specifications
Model Name
imageRUNNER 2025i
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Single-Component Projection
Fixing System
RAPID Fusing System
Image Server Memory
256MB/256MB RAM
Max Copy Reservation
Five jobs
Scanning Resolution
Up to 600 x 600 dpi
Printing Resolution
Up to 1200 x 1200 dpi**
Halftone
256 Levels
Letter
Up to 25 ppm (Letter)
First Copy Time
6.9 Seconds from Platen Glass
Multiple Copies
1 to 99
Magnification
20% to 200% (In 1% Increments)
Preset Reductions
50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%
Acceptable Originals
Sheets, Books, and 3-Dimensional Items (Up to 4-3/8 lb.)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 250 + 80 Bypass (Total 580 Sheets)
Manual Bypass
80 Bypass
Maximum Paper Capacity
4 x 250 + 80 Bypass (Total 1,080 Sheets)
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond
Bypass
17 lb. to 32 lb. Bond
Duplexing
Standard
Warm Up Time
One Second or Less from Sleep Mode*
26 Seconds or Less from Main Power Off *
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120v AC, 60 Hz, 4.6A
Power Consumption 1.425 kW (MAX)
Dimension
29-3/4 x 24-1/2 x 26-5/8
Weight
116 lb.
Toner
GPR-18 Black Toner
Estimated Toner Yield
8,300 at 6% Coverage
Feeders
Description
Duplexing Automatic Document Feeder
Statement to 11 x 17
Capacity
50 Sheets (Letter, Letter-R, Statement)
Paper Weights
10 lb. to 32 lb. Bond (One Sheet)
14 lb. to 28 lb. Bond (Multi Sheets)
Document Scanning Speed: 20 Sheets/Minute (Letter, B/W)
Dimensions
4-7/8 x 22-1/4 x 19-1/4
Weight
Approx. 16 lb.
Description
Cassette Feeding Module-Q1 (Opt.)
11 x 17, Legal, Letter, Letter-R, Statement
Capacity
2 x 250-Sheet per Cassettes
Paper Weights
Dimensions
8 x 22-7/8 x 22-3/8
Weight
Approx. 26.5 lb. (12kg)
Paper Supply Options
Description
Inner 2-Way Tray-E2 (Opt.)
Number Of Cassettes
Two
Paper Capacity
Upper Output Tray: 100 Sheets (Letter)
50 Sheets (Other Sizes)
Lower Output Tray: 250 Sheets (Letter)
100 Sheets (Other Sizes)
Paper Sizes
Dimensions
(Inside Main Unit): 6 x 19-1/8 x 17-3/4
Weight
Approx. 33 lb. (1.5kg)
Output Options
Finishers Output Trays
Description
Finisher-U2
Number Of Trays
One (Second Tray Optional)Tray Capacity
Single Tray: 770 Sheets (Letter, Statement-R)
380 Sheets (Legal, Letter-R, 11 x 17)
With Additional Finisher
Tray-C1: 200 Sheets Each Tray (Letter, Statement-R)
150 Sheets Each Tray (Legal, Letter-R, 11 x 17)
Staple Capacity
Up to 30 Sheets (All Sizes)
Staple Positions
Top Left Corner: 11 x 17 (Landscape), Legal (Landscape), Letter, Letter-R
Top Right Corner: 11 x 17 (Portrait), Legal (Portrait)
Dimensions
(Inside Main Unit): 11-7/8 x 18-7/8 x 20-1/2
Weight
Approx. 22 lb. (10kg)
Attachable Accessories: Optional Additional Finisher Tray-C1
Description
Add. Finisher Tray-C1 (Opt. for Finisher-U2)
Top Tray
200 Sheets (Letter, Statement-R)
150 Sheets (Legal, Letter-R, 11 x 17)
Dimensions
(Inside Main Unit): 3-2/5 x 8-1/10 x 15-3/8
Weight
Approx. 4 lb. (1.8kg)
Fax Board
Description
Super G3 Fax Board-AA1
Applicable Line
Public Switched Telephone/Network (PSTN) Facsimile Network
Connection Lines: One
Address Book: 500 Destinations
Sending Original Sizes: Statement to 11 x 17
Recording Printing Sizes: Statement to 11 x 17
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds/Page (33.6 Kbps)
GRMR Method: Approx. 13 Seconds/Page (33.6 Kbps)
GRMH Method: Approx. 13 Seconds/Page (33.6 Kbps)
JBIG: Approx. 2.6 Seconds/Page (33.6 Kbps)
Scan Line Density Standard: 8 Pels/mm x 3.85 Lines/mm
Fine: 8 Pels/mm x 7.7 Lines/mm
Super Fine: 8 Pels/mm x 15.4 Lines/mm
Ultra Fine: 16 Pels/mm x 15.4 Lines/mm
Memory
Approx. 1,000 Pages
Print Board
Processor
Canon Customer Processor - Shared
Standard Memory
Shared with Main Unit - 256MB Std.
PDL Support
UFR II LT, PCL 5e/6 (Std.)
Interface Connections
10/100 Base-TX (RJ-45), Hi-Speed USB 2.0
Network Operating Systems Novell® NetWare® v. 5.1, 6, 6.5 Windows® 98/Me/2000/XP/Windows Server 2003/Windows Vista® Apple® Macintosh® OS X or Higher
Print Controller Technology
UFR II LT: Windows 98/Me/2000/XP/Windows Server 2003/Windows Vista/Citrix MetaFrame/Macintosh OS X (OS 10.2.8 or Later)
PCL 5e/6: Windows 98/Me/2000/XP/Windows Server 2003/Windows Vista/Citrix MetaFrame
Send Expansion Sets
Sending Method
E-mail, I-fax, Super G3 Fax (Opt.), File Server (FTP, SMB)
Address Book Capacity
500 Destinations
File Format
Black and White: TIFF, PDF
Color: JPEG, PDF, (Compact)
Sending Size
Statement to 11 x 17Additional Supplies and Accessories Basic Card Set Braille Label Lit-A1Cabinet-R1 (Large)Cabinet-S1 (Small)Card Reader Attachment-D1Card Reader-E1Copy Card Sets Document Tray-J1Power Supply Kit-Q1Barcode Printing Kit-B1FL Cassette-AF1Stamp Ink Cartridge-C1Staple Cartridge-J1* At room temperature of 200C/680F
** UFR II LT only.
*** Approximately 3-second-per-page fax transmission time based on ITU-T No. 1 Chart (JBIG, Standard Mode) at 33.6 Kbps modem speed when transmitting to another v. 34 machine. The Public Switched Telephone Network (PSTN) currently supports 28.8 Kbps modem speeds or lower depending on telephone line conditions.
Awards
BERTL 4 Star Highly Recommended
2011 BLI Performance Certified Seal
BLI 2008 Recommended
BLI 2008 Reliability Certified
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 2025i that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER 2000 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
