Web Content Viewer
Actions
imageRUNNER 210S
Support - Multifunction
Features
The imageRUNNER 210S features a 21 page-per-minute copy and print speed and a duty cycle of up to 75,000 impressions per month.
With standard Automatic Duplexing, the imageRUNNER 210S is ideal for users who demand the image quality and editing capabilities that digital technology offers.
With standard support for 1,050 sheets of paper ranging from Statement to Ledger, the imageRUNNER 210S offers support for workgroup office volume. For paper intensive environments, two paper supply options are available, which can increase the paper capacity to a maximum of 3,050 sheets.
The imageRUNNER 210S offers digital copying support of 1200 x 600 dpi resolution and 256 grayscale.
The imageRUNNER 210S is upgradeable, offering optional 10/100 Ethernet connection for network printing, optional Super G3 faxing and optional scanning.
Canon's network printer option ships standard with graphical printer driver software, which makes it simple to access the imageRUNNER 210S' functions right from the user's desktop.
The optional Recirculating Document Feeder lets you stack up to 50 originals, from Statement to Ledger size, and is capable of handling different sized originals.
The imageRUNNER 210S offers four sorter options. You can select your finishing accessories to suit the needs of your workplace.
Specifications
Model Name
imageRUNNER 210S
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
RAPID Fusing System™
Duty Cycle
Up to 75,000 impressions per month
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1,200 dpi x 600 dpi
Halftone
256 Gradations of Gray
Letter
21 cpm/ppm
Legal
13 cpm/ppm
Ledger
11 cpm/ppm
First Copy Time
9.2 Seconds (AE Off, Letter, Upper Cassette)
Multiple Copies
1 to 100
Magnification
25% to 800%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%, 800%
Acceptable Originals
Sheets, Books, and 3 Dimensional Items (Up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 500 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
3,050 sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
4-1/8 x 5-7/8 to Ledger
Acceptable Paper Weights
Cassette
17 - 22 lb.
Bypass
17 - 32 lb.
Duplexing
Standard 20 Sheets (Letter)
Warm Up Time
8.6 Seconds (from Power OFF)
Exposure Control
Automatic or Manual (Text or Photo)
Power Requirements
115V, 60Hz
Dimension
23 x 23-5/8 x 27-5/8
(585mm x 599mm x 700mm)
Weight
155 lbs.
Toner
imageRUNNER 210 Black Toner
Estimated Toner Yield
9,600 Images (6% Coverage)
Drum
imageRUNNER 210 Drum
Estimated Drum Yield
50,000 Impressions
Feeders
Description
Recirculating Document Feeder-G1 (Optional)
Statement to Ledger
Scanning Speed
21 opm
Capacity
50 Sheets (Letter)
Paper Weights
13 - 28 lb.
Different Size Originals
Standard
Power Source
Directly from Main Unit
Dimensions
5-7/8 x 24-1/4 x 20-1/4
(149mm x 616mm x 513mm)
Weight
31 lbs.
Paper Supply Options
Description
Cassette Feeding Unit-M1 (Optional)
Number Of Cassettes
2
Paper Capacity
1,000 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
17 - 22 lb. Bond
Power Source
Dimensions
17-7/8 x 23 x 24-3/8
(453mm x 585mm x 619mm)
Weight
93 lbs.
Description
Cassette Feeding Unit-L1 (Optional)
Number Of Cassettes
4
Paper Capacity
2,000 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
17 - 22 lb. Bond
Power Source
Dimensions
Weight
93 lbs.
Sorters Stapler Sorters
Description
Stapler Sorter-M1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Bins
10
Sort Mode
30 Sheets (Letter, Letter-R, Statement, Statement-R)
25 Sheets (Legal)
15 Sheets (Ledger)
Staple Sort Mode
30 Sheets (Letter, Letter-R)
25 Sheets (Legal)
15 Sheets (Ledger)
Group Mode
20 Sheets (Letter, Letter-R, Statement, Statement-R)
15 Sheets (Ledger, Legal)
Staple Capacity
Up to 30 Sheets
Staple Positions
1
Power Source
Dimensions
15-3/8 x 15-3/8 x 21-7/8
(390mm x 390mm x 555mm)
Weight
26.4 lbs.
Description
Multi Output Tray-B2/B3 (Optional)
Paper Weights
17 - 22 lb. Bond
Paper Size
Statement to Ledger
Number Of Bins
12 (10 Stapler Sorter; 2 Output Trays)
Sort Mode
10 Sheets (Ledger)
Staple Sort Mode
20 Sheets (Letter, Letter-R)
10 Sheets (Ledger)
Group Mode
15 Sheets (Ledger)
Non Sort Mode
100 Sheets/Top Bin
Staple Capacity
Up to 20 Sheets
Power Source
Dimensions
27-1/4 x 17-1/8 x 22-1/2
(691mm x 434mm x 571mm)
Weight
55.1 lbs.
Output Options
Finishers Output Trays
Description
Multi Output Tray-C1 (Optional)
Paper Weights
15 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
3 (Top Tray and Two Shift Trays)
Top Tray
100 Sheets - Copy Output
Middle Tray
100 Sheets - Fax Output
Lower Tray
100 Sheets - Print Output
Power Source
Dimensions
10-3/8 x 7-3/4 x 19-1/8
(262mm x 195mm x 485mm)
Weight
13.4 lbs.
Fax Board
Description
Super G3 Fax Board-D1 (Optional)
Applicable Line
Public Switched Telephone Network
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
2.8 Seconds
Data Compression
MMR, MR, MH
Memory
4MB
Maximum Memory
10MB
One Touch Speed Dialing Locations
60
Coded Speed Dialing Locations
140
Print Board
Description
Network Multi-PDL Board-D1 (Optional)
Processor
MIPS R4700 133MHz RISC
Standard Memory
32MB
Maximum Memory
64MB
Hard Disk
3.2GB
Continuous Print Speed
20 ppm
PDL Support
Adobe PostScript 3; PCL 5e
Postscript Fonts
139 Type 1 and 3
PCL Fonts
45 True Type
Interface Connections
Ethernet (10/100BaseT)
IEEE 1284 (Parallel)
Token Ring (Optional)
Print Controller Technology
Compression and Decompression
PostScript Font Management
Resolution Enhancement Technology
Direct EPS File Printing
RIP-While-Print®
Font and Forms Downloading
Continuous Print™
Other Features
Access to Full Finishing Features
Internet Connectivity
NetSpot Supported
Spooling Support
Automatic Job Recovery
Awards
Line of the Year - Buyers Laboratory Inc.
Pick of the Year - Buyers Laboratory Inc.
Brochures
Loading...
 Return to Top
