Web Content Viewer
Actions
imageRUNNER 2220i
Support - Multifunction
Features
Operating at 22 pages-per-minute, the imageRUNNER 2220i is equipped with a 10GB Hard Disk Drive and 256MB RAM, providing users with exceptional productivity and reliability.
With a scanning resolution of 600 x 600 dpi, copy resolution of 1200 x 600 dpi, and print resolution of 2400 x 600 dpi, the imageRUNNER 2220i delivers superior quality for the most faithful reproduction of text and images.
Incorporating Canon's MEAP™ (Multifunctional Embedded Application Platform) architecture, the imageRUNNER 2220i's applications can be customized to meet unique business needs. Using the MEAP platform, customized applications run from the imageRUNNER 2220i as if they are part of the device's system software, streamlining document workflows.
The full-color user interface panel and intuitively-designed device drivers provide user-friendly operation for both walk-up and desktop environments.
The imageRUNNER 2220i ships standard as a network printer, providing maximum flexibility and performance for busy workgroup environments.
Designed with Canon's RAPID Fusing Technology, energy consumption is dramatically reduced.
The imageRUNNER 2220i Ships standard with a 50-sheet capacity Duplexing Automatic Document Feeder, making quick work of scanning multi-page and different-size originals.
With a standard paper capacity of 1,050 sheets, which can be expanded to 4,550 sheets, the imageRUNNER 2220i has been designed to meet the volume requirements of any workgroup.
The Mailbox functions of the imageRUNNER 2220i serve as a centralized system for information-sharing, on-site document storage and print-on-demand applications.
With Remote UI, features and functions of the imageRUNNER 2220i are controlled and accessed right from a user's desktop.
When equipped with the optional Super G3 Fax, the imageRUNNER 2220i has the ability to transmit 3 seconds per page at 33.6 Kbps speed.
With its Universal Send™ technology, the imageRUNNER 2220i allows users to scan directly into the device for distribution to multiple destinations.
Specifications
Model Name
imageRUNNER 2220i
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
RAPID Fusing System™
Duty Cycle
75,000 Impressions per month
Image Server Memory
Standard 256MB RAM/10GB HVDD
(Max. Capacity: Approx. 3,700 Originals)
Max Mailboxes Supported
100
Max Copy Reservation
5 jobs
Interpolated Resolution
1200 dpi x 600 dpi (copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
Letter
22ppm
Letter R
18ppm
Legal
14ppm
Ledger
16ppm
First Copy Time
5.8 Seconds from Platen Glass
6.6 Seconds from Feeder
Multiple Copies
1 to 999
Magnification
25% to 800% - Platen (in 1% increments)
25% to 400% - Feeder (in 1% increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%, 800%
Acceptable Originals
Sheets, Books, 3 Dimensional Items (Up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
Dual 500-sheet Paper Cassettes (1,000 sheets)
Manual Bypass
50 Sheets
Maximum Paper Capacity
4,550 Sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
4 x 5-1/2 to 11-3/4 x 17
Acceptable Paper Weights
Cassette
17 - 20 lb. Bond
Bypass
17 - 32 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
10 Seconds or Less from Sleep Mode
40 Seconds or Less from Main Power Off
Exposure Control
Automatic or Manual
Power Requirements
120V AC, 60Hz, 10A
Dimension
35-7/8 x 22-1/4 x 29
(910.5mm x 565mm x 762mm)
Weight
214lb. (97.4kg)
Toner
GPR-6 Toner
Estimated Toner Yield
15,000 Copies/Bottle (Estimated yield at 6% Coverage)
Feeders
Description
Duplexing Automatic Document Feeder-H1 (Standard)
Statement to Ledger
Scanning Speed
22 opm
Capacity
50 Sheets
Paper Weights
10 lb. to 32 lb. Bond (Letter, One-Sided)
13 lb. to 32 lb. Bond (Letter, Two-Sided)
Different Size Originals
Same Width/Different Width
Power Source
From Main Unit
Dimensions
4-7/8 x 22-3/8 x 21-1/8
(122mm x 565mm x 535mm)
Weight
17.6 lbs.
Paper Supply Options
Description
Cassette Feeding Unit-W1 (Optional)
Number Of Cassettes
2
Paper Capacity
1,000 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
17 lb. - 20 lb. Bond
Power Source
Directly from Main Unit
Dimensions
9-3/4 x 22-1/4 x 26-3/4
(248mm x 565mm x 678mm)
Weight
61.7 lbs.
Description
Paper Deck-L1 (Optional)
Number Of Cassettes
1
Paper Capacity
2,500 Sheets
Paper Sizes
Letter
Paper Weights
17 - 20 lb. Bond
Power Source
Dimensions
17 x 12-3/4 x 23-1/4
(432mm x 324mm x 591mm)
Weight
66.1 lbs.
Description
Envelope Feeder Atachment-B1 (Optional)
Paper Capacity
Approx. 50 Envelopes
Dimensions
2-1/2 x 7-7/8 x 11-3/8
(62mm x 199mm x 288mm)
Weight
1.85lb. (840g)
Output Options
Finishers Output Trays
Description
Finisher-J1 (Optional)
Paper Weights
17 lb. to 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
1
Top Tray
300 Sheets (Letter)
Staple Capacity
30 Sheets (Letter)
15 Sheets (Ledger)
Staple Positions
1-Top Corner
Paper Sizes
Letter-R, Ledger
Stapling Capacity
10 sheets
Fold Type
V-Fold Standard
Power Source
Dimensions
9-1/8 x 22-1/4 x 20
(232mm x 565mm x 509mm)
Weight
24.3 lbs.
Description
Saddle Finisher-G1 (Optional)
Paper Weights
17 - 20 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
4 Trays, including Saddle-Stitch Tray and Inner 2-Way Tray
Top Tray
1,000 Sheets (Letter)
Middle Tray
100 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Saddle Stitch Tray
100 Sheets
Staple Capacity
50 Sheets (Letter)
Staple Positions
Multiposition Stapling
1 - Any Corner
2 - Side Margin
2 - Saddle-Stitch
Paper Sizes
Letter-R , Ledger
Stapling Capacity
10 sheets
Fold Type
V-Fold Standard
Power Source
Dimensions
33-5/8 x 21 x 23-3/4
(855mm x 532mm x 603mm)
Weight
77.2 lbs.
Description
Inner 2-Way Tray-A1 with Copy Tray-F1 (Optional)
Paper Weights
17 lb. to 20 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
2
Top Tray
100 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Power Source
From Main Unit
Dimensions
Inner 2-Way Tray: 10 x 5-7/8 x 16-1/2
(254mm x 149mm x 420mm)
Copy Tray-F1: 9 x 12-3/4 x 11-7/8
(227mm x 322mm x 300mm)
Weight
Inner 2-Way Tray: 7.7 lbs. (3.5kg)
Copy Tray-F1: 15.3 oz. (435g)
Description
Puncher Unit-K1 (Optional)
Paper Weights
17 - 20 lb. Bond
Paper Size
Letter, Legal, Ledger
Hole Punch
2 Holes (Letter-R. Legal)
3 Holes (Letter, Ledger)
Power Source
Dimensions
6-3/4 x 3-1/2 x 22-1/8
(170mm x 90mm x 560mm)
Weight
5.3 lbs.
Fax Board
Description
Super G3 Fax Board-J1 (Optional)
Applicable Line
Public Switched Telephone Network
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
3 Seconds
Data Compression
MMR, MR, MH, JBIG
Memory
256MB
Maximum Memory
256MB
Print Board
Description
Network Multi-PDL Printer Kit-C1 (Standard)
Processor
250 MHz Canon Custom Processor
Standard Memory
256MB RAM
Maximum Memory
256MB RAM
Hard Disk
10.0 GB
Continuous Print Speed
22 ppm (Letter)
PDL Support
PCL 5e, PCL 6, PostScript-3™ Emulation
Postscript Fonts
136 (117 Adobe Type Fonts, 19 True Type)
PCL Fonts
80 Roman, 32 Barcode
Interface Connections
Ethernet (10/100BaseT)
IEEE 1284 (Parallel)
Token Ring (Optional)
Other Features
Access to Full Finishing Features
Internet Connectivity
NetSpot Supported
Spooling Supported
Automatic Job Recovery
Canon Network ScanGear
Print and Fax Drivers
Brochures
Loading...
 Return to Top
