Web Content Viewer
Actions
imageRUNNER 2535
Support - Multifunction
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
  • The imageRUNNER 2535 employs an updated version of the powerful imageCHIP LITE system architecture, consisting of a new CPU to speed up copy, print, fax, scan, and send functions. This architecture integrates the CPU and the image processing technologies onto a single chip, allowing for highly efficient processing of multiple functions simultaneously.
  • A compact MFP with a smart, comfortable design and innovative integrated accessories that enables the system to be placed in areas with limited space.
  • Using an advanced CCD scanning unit, the imageRUNNER 2535 delivers superior quality for copies and color scans. With a copy scanning resolution of 600x600 dpi and a native print resolution of 1200x1200 dpi, you benefit from the most faithful reproduction of text and images.
  • A standard 100-sheet Duplexing Automatic Document Feeder makes scanning multi-page and different-sized originals quick and easy.
  • With standard twin 550-sheet paper cassettes and a maximum paper capacity of 2,300 sheets, the imageRUNNER 2535 enables longer runs between paper fill ups, allowing offices to be more productive.
  • The imageRUNNER 2535 is ready to handle your office prints with UFR II LT printing and 10/100 Base-Tx Ethernet connectivity. Optional PCL 5e/6 and Postscript printing provides added flexibility to support your applications.
  • Standard duplexing capability provides users with the ability to copy/print their documents on either one or two sides of paper, saving paper, toner, and energy.
  • Documents up to 11" x 17" can be scanned in color or black and white at resolutions up to 600 x 600 dpi. These files then can be imported into TWAIN-compliant applications on the desktop through Canon's Color Network ScanGear software.
  • In addition to Color Scanning, the available Color Send technology gives users the ability to send their scanned documents directly to various destinations such as e-mail addresses, USB memory media, or even a particular folder on their network or computers. Includes support for PDF High Compression technology for efficient handling of color image data, and optional Searchable PDF technology to add OCR data to your scanned documents to make the most of documents.
  • LDAP address book support allows for browsing the corporate address book for easier scan-and-send operations, while also reducing address book maintenance.
  • The imageRUNNER 2535 gives IT managers control and helps drive cost out of operations with a variety of tools including the standard Remote User Interface, support for Canon's imageWARE Enterprise Management Console application, and Canon's Generic PCL6 driver to simplify driver deployment.
  • Designed with Canon's RAPID Fusing System to deliver exceptional image quality with less heat and energy to operate, while also allowing fast warm-up times.
  • On-the-fly toner replenishment keeps your office productive, so print and copy jobs keep running while the toner is replaced.
  • ID Card Copy mode provides a simple way to copy both sides of an ID card onto a single page.
  • An optional Super G3 fax board delivers the ability to transmit faxes at impressive speeds, without the need for a separate fax machine.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imageRUNNER 2535
Type
Monochrome Digital Multifunction Imaging System Functions Standard: Copy, Print (UFR II LT), Scan
Optional: Print (PCL, PostScript 3 Emulation), Send (Color Send, Searchable PDF), Fax (Up to one line)Operation Panel 5.7 QVGA Black-and-White LCD Touch-Screen
Image Server Memory
Standard: 512MB RAM
Maximum: 512MB RAM Network Interface Connection Ethernet 10/100Base-TXOther Interface Standard: USB 2.0 (Host)x1, USB 2.0 (Device)x1
Optional: USB 2.0 (Host)×3 (USB Application 3-Port Interface Kit-A1), Serial Interface, Copy Control Interface
Letter
Up to 35 ppm
Legal
Up to 25 ppm
Ledger
Up to 22 ppm
First Copy Time
3.9 Seconds
Multiple Copies
1 to 999Copy Exposure Automatic or Manual (9 Levels)
Magnification
25% - 400% (1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Standard Paper Capacity
(20 lb. Bond): Standard: Dual 550-sheet Paper Cassettes
100-sheet Stack Bypass
Optional: Dual 550-sheet Paper Cassettes
Maximum Paper Capacity
2,300 Sheets Output Paper Capacity (20 lb. Bond) Standard: 250 Sheets (Inner Tray)
Maximum: 1,100 Sheets (w/Inner Finisher-B1 and Inner Finisher Additional Tray-B1)
Output Sizes
Cassette
Cassette 1/3/4: 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Cassette 2: 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, Envelopes
Bypass
Acceptable Paper Weights
Cassette
17 lb. Bond to 24 lb. Bond
Bypass
17 lb. Bond to 34 lb. Bond
Duplexing
Paper Size: Standard Automatic Trayless Duplexing (Executive to 11 x 17)
Paper Weight: 17 lb. Bond to 24 lb. Bond Special Media Support Cassette 2: Envelopes
Bypass: Transparencies, Labels, Envelopes
Warm Up Time
From Power On: 30 Seconds or Less
From Sleep Mode: 1 Second or Less
Power Requirements
120V AC, 60Hz, 9.3A
Plug NEMA 5-15P
Power Consumption Maximum: 1,690W; Sleep Mode: 1W
Dimension
35-3/4 x 22-1/4 x 27-1/8
Installation Space (W x D) 42-1/2 x 56-3/4 (with no optional equipment attached)
53-4/5 x 56-3/4 (with optional Inner Finisher-B1 attached)
Weight
Approximately 174 lb.**
Estimated Toner Yield
19,400 Copies/Bottle (Estimated @ 6% Coverage) Basic Copy Features
Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection Special Copy Features
ID Card Copy, Two-page Separation, Image Combination, Frame Erase, Different Size Original, Sharpness, Mode Memory, Booklet Print Features
Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing, Generic PCL 6 Driver Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility Color Network Scan Gear Security Specifications Department ID Management, User ID Management, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book, Address Book Password, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast), SNMPv1, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP Environmental Information EPEAT Silver ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Angel WEEE Directive
Feeders
Description
Document Feeder
Acceptable Originals
11 x 17, Legal, Letter, Letter-R, or Statement
Scanning Speed
Copy: 35 ipm (600 dpi)
Scan: 45/34 ipm (300 dpi)Scan Method Duplexing Automatic Document Feeder
Capacity
100 Sheets
Paper Weights
BW Originals: 13 lb. Bond to 34 lb. Bond
Color Originals: 17 lb. Bond to 34 lb. Bond
Paper Supply Options
Description
Cassette Feeding Unit-AE1†
Paper Capacity
550 Sheets x 2 Cassettes (20 lb. Bond)
Paper Sizes
Paper Weights
17 lb. Bond to 24 lb. Bond Acceptable Paper Type: Plain, Recycled, Color Pre-Punched
Power Source
From the Main Unit/Approximately 13.3W (Maximum)
Dimensions
9-3/4 x 22-1/4 x 26-3/4
Weight
Approximately 52.9 lb.
Description
Envelope Feeder Attachment-D1††
Paper Capacity
50 Sheets (or 30mm in height)
Paper Sizes
(Envelope Size:) COM10 No.10, Monarch, DL, ISO-B5, ISO-C5Print Speed: Up to 12 ppm
Output Options
Finishers Output Trays
Description
Inner Finisher-B1†††
Paper Weights
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive Acceptable Paper Type Plain, Recycled, Color (17 lb. Bond to 21 lb. Bond), Pre-Punched, Heavy Paper 1 (22 lb. Bond to 24 lb. Bond), Heavy Paper 2 (24 lb. Bond to 28 lb. Bond), Heavy Paper 3 (28 lb. Bond to 34 lb. Bond)
Number Of Trays
Up to 2 Trays (w/Inner Finisher Additional Tray-B1)Total Output Capacity:Without Inner Finisher Additional Tray-B1: 1,000 Sheets
With Inner Finisher Additional Tray-A1: Upper Tray: 100 Sheets (Letter)
Lower Tray: 1,000 Sheets (Letter)
Staple Capacity
(Max.): 50 Sheets (Letter)
30 Sheets (11 x 17, Legal, Letter-R) (17 lb. Bond to 21 lb. Bond)Paper Capacity of Staple Mode: Top Tray: 15 Sets (or 3/8 in height)
Lower Tray: 30 Sets (or 4-7/8 in height)Type of Staple Staple-J1 (5,000 x 3)
Staple Positions
Corner Stapling: 11 x 17, Legal, Letter, Letter-R
Double Stapling: 11 x 17, Legal, Letter, Letter-R
Power Source
From the main unit/Approximately 43.9W (Maximum)
Dimensions
11-3/5 x 27-3/4 x 21-7/8 (When the auxiliary tray is extended)
Weight
Approximately 27.6 lb.
Description
Inner 2-Way Tray-G1†††
Paper Weights
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement-R, Executive Acceptable Paper Type: Plain, Recycled, Color (17 lb. Bond to 21 lb. Bond), Pre-Punched, Heavy Paper 1 (22 lb. Bond to 24 lb. Bond), Heavy Paper 2 (24 lb. Bond to 28 lb. Bond), Heavy Paper 3 (28 lb. Bond to 34 lb. Bond)
Number Of Trays
2
Top Tray
100 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Dimensions
4-1/4 x 16-3/4 x 16-1/4
Weight
Approximately 1.3 lb.
Print Board
Processor
Canon Custom Processor (Shared)
Standard Memory
512MB RAM
Maximum Memory
512MB RAM Engine Resolution 1200 dpi x 1200 dpi (Maximum)
PDL Support
Standard: UFR II LT
Optional: PCL 5e/6, PostScript 3 Emulation (Standard on i Models)
Print Controller Technology
UFR II LT, PostScript 3 Emulation: Windows® (Windows 2000/XP/Vista®/Windows 7/Server 2003/Server 2008), Citrix Presentation Server 4.0/4.5, Citrix XenApp 5.0, XenDesktop 2.0/2.1/3.0, Macintosh® (OS X 10.6.1), SAP (PS3 Only)PCL 5e/6: Windows (Windows 2000/XP/Vista/Windows 7/Server 2003/Server 2008), Citrix Presentation Server 4.0/4.5, Citrix XenApp 5.0, XenDesktop 2.0/2.1/3.0, SAP
Send Expansion Sets
Description
Color Send Specifications (Std. on i Models)
Sending Method
E-Mail, I-Fax, File Server (FTP, SMB), Super G3 Fax Color Mode Color, BW Scan Resolution (dpi)600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
Address Book Capacity
Max. 500 Destinations (Includes 200 One-Touch Buttons)Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP)
E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple)
File Format
TIFF, JPEG, PDF, PDF (Compact), PDF (OCR)***I-Fax Data Format TIFF (MH)Number of Connection Lines 1 (Maximum)Modem Speed
Super G3: 33.6 Kbps
G3: 14.4 Kbps Compression Method MH, MR, MMR, JBIG Resolution (dpi) 400 x 400, 200 x 400, 200 x 200, 200 x 100Sending/Recording Size Statement-R to 11 x 17Fax Features Job Forwarding, Different Size Originals, Sharpness, Delayed Send, Finished Stamp, Two-sided Original Other Optional Accessories Cabinet Type-C† Inner Finisher Additional Tray-B1Document Tray-J1PCL Printer Kit-AF1ΔPS Printer Kit-AF1ΔBarcode Printing Kit-B1ΔΔColor Send Kit-Y1Searchable PDF Kit-C1ΔΔΔSuper G3 Fax Board-AG1Card Reader-E1⟩♦Card Reader Attachment-D3ADF Access Handle-A1Braille Label Kit-F1USB Application 3-Port Interface Kit-A1USB Keyboard (Cherry)Serial Interface Kit-J2 ⟩⟩Copy Control Interface Kit-A1 ⟩⟩♦* The optional Envelope Feeder Attachment-D1 is required.
** Includes consumables.
*** The optional Searchable PDF Kit-C1 is required for Base models.
† The Cassette Feeding Unit-AE1 and Cabinet Type-C cannot be installed at the same time.
†† Installs on the second paper cassette.
††† The Inner Finisher-B1 and Inner 2-Way Tray cannot be installed at the same time.
Δ Optional for Base models; standard on i models.
ΔΔ Requires PCL Printer Kit-AF1.
ΔΔΔ Requires Color Send Kit-Y1.
⟩ Requires the Card Reader Attachment-D3 for installation.
⟩⟩ Serial Interface Kit-J2 and Copy Control Interface Kit-A1 cannot be installed at same time.
♦ Card Reader-E1 and Copy Control Interface Kit-A1 cannot be installed at the same time.
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 2535 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Supplies
GPR-34 Toner
Color: Black
Item Code: 2786B003AB
Estimated Toner Yield: 19,400 Copies/Bottle  (Estimated @ 6% Coverage)
The imageRUNNER 2500 Series models employs the imagechip (Concurrent Hyper Intelligent Platform) Lite system architecture. Imagechip Lite architecture provides concurrent processing technology (dynamic concurrent multi-functional processing), which enables faster image processing and color scanning abilities. All imageRUNNER 2500 models are equipped with the imagechip Lite controller with 512MB of available memory (RAM) as standard.
Yes, color scanning capability is standard, via the Color Network Scan Gear tool. Color Sending is also available.
Yes, the imageRUNNER 2500 Series models feature a Compact E(Excellent)-Drum. E-Drum technology has been incorporated into the imageRUNNER ADVANCE models for professional color printing and this technology is being introduced in the black-and-white office devices for the first time. The E-Drum employs an additional layer on the surface of an OPC drum, which resists scratching and wear. E-Drum technology delivers significant improvements in durability and reliability compared to standard OPC drum, while maintaining high image quality.
QF (Quick Fixing) toner is employed, which fuses quickly at low temperatures and achieves high quality output. The QF toner maximizes the performance of the RAPID Fusing Technology, which utilizes ceramic heater to instantaneously heat the rubber coated fixing film for high energy efficiency. Both enable an energy saving design of a 1.0 W energy consumption in the Sleep mode, and a Sleep mode recovery time of 1 second or less.
Yes, imageRUNNER 2500 Series models are Energy Star qualified. Canon has incorporated a range of energy saving technologies into its products, such as QF Toner with low melting point and RAPID Fusing Technology to help save energy while improving performance. Canon's technologies achieve a low 1W of electrical use when in sleep mode, while maintaining a fast 1 second or less warm-up time.
Yes, envelopes are supported with the optional envelope attachment, holding up to 50 envelopes. Supported envelope types are COM10 No.10, Monarch, DL, ISO-B5, ISO-C5.Envelopes can also be fed through the Stack Bypass, one at a time.
FCOT is reduced to less than 3.9 seconds on imageRUNNER 2545/2535 Series and 5.4 seconds on the imageRUNNER 2530/2525 models, after warm-up.
The imageRUNNER 2500 Series come standard with UFR II LT. Optional PCL 5e/6 and PostScript 3 emulation printing options are also available. PCL and PS are standard on "i" models.
The Generic PCL6 Print Driver (the official name for Canon's universal print driver) will be available and will support imageRUNNER 2500 Series models as well as imageRUNNER ADVANCE and certain legacy models. The Generic PCL6 Print Driver reduces IT burden by allowing deployment of a single driver to support multiple device models. The PCL print option is required to use this driver.
Ideal for Healthcare, ID Card Copy is a new Copy feature that allows users to copy the front and back of an ID card onto a single page. There is a dedicated option to guide users through the simple process.
The imageRUNNER 2500 Series models support sending to USB memory Media, email, I-fax, fax*, SMB, and FTP.
Note: Color Send Kit-Y1 is required for send capability. It is standard on "i" models and optional on base models.
Yes, all the devices come standard with USB 2.0 ports, one for Device and one for Host. The optional USB Application 3-Port Interface Kit-A1 can be added to expand the number of USB Host ports on the device from one (standard) to three, providing support for concurrent usage of USB Memory Media and USB Keyboard.
Yes, users can scan and store files directly into a USB memory media. This feature is standard on "i" models. Base models must install the optional Color Send Kit-Y1.
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video.
Awards
#1 Ease of Use Monochrome MFP Customer Survey
#1 Best Monochrome MFP's Customer Survey
 Return to Top
