Web Content Viewer
DISCLAIMER
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
imageRUNNER 2800
The imageRUNNER 2800 digital multifunction workgroup solution delivers new generation capabilities designed to meet every need, application and budget of small to medium-sized enterprises. The imageRUNNER 2800 ships as a standalone digital copier, supporting many advanced copying features, as well as the local scanning of documents into an internal image server Mailbox system. As a truly modular system, customers can easily add network printing, Super G3 Fax capabilities, and network scanning if and when they dictate. The imageRUNNER 2800 offers a maximum paper capacity of 4,550 sheets and a choice of finishers that offer stapled output, saddle-stitched booklets, and two- or three-hole punching. Plus, with features like Scan-Once-Print-Many, standard Automatic Trayless Duplexing, and 2400 x 600 dpi interpolated printing resolution, the imageRUNNER 2800 truly stands apart from competitive offerings in its class.
Features
The imageRUNNER 2800 features a 28 page-per-minute copy and print speed and a duty cycle of up to 100,000 impressions per month.
A 5.1GB Image Server and 128MB of RAM support a number of key applications including Scan-Once-Print-Many, Confidential Mailboxes, Automatic Page Impositioning, Copy Reservation, and Job Build. These functions can be easily accessed through a large Touchscreen LCD panel at the device.
An extensive on-line paper supply minimizes paper reloading chores for maximum productivity. The standard 1,050-sheet paper capacity can be increased to a maximum of 4,550-sheets through optional accessories. In addition, an Envelope Feeder Attachment is available for high-volume envelope printing environments.
Canon's patented RAPID Fusing System™ dramatically reduces energy consumption costs while virtually eliminating long warm-up periods typically associated with conventional solutions.
A compact engine design makes the imageRUNNER 2800 a perfect fit even in environments with limited space.
With an optional print controller capable of handling 10/100 Ethernet or Token ring connections, and support for PostScript® 3 Emulation and PCL® 6 print languages, the imageRUNNER 2800 meets the needs of even the most demanding workgroup environments.
Super G3 fax capabilities are available through an optional fax board that provides fax transmission at 33.6 Kbps.
Network scanning capabilities are available through the implementation of Canon's Network ScanGear TWAIN-compliant scanner software. For advanced scanning and file management functionality, the imageRUNNER 2800 supports eCopy Suite, including eCopy ScanStation, eCopy ShareScan and eCopy Desktop.
An optional 50-sheet Duplexing Automatic Document Feeder accepts double-sided originals in sizes up to 11"x 17" and even handles different sized leading edges with ease.
The imageRUNNER 2800 offers finishing capabilities previously available only through outsourcing or through Central Reproduction Departments. With multiple output options, the imageRUNNER 2800 can perform simple sorting and collating or advanced multiposition stapling, saddle-stitching, V-folding and 2- or 3-hole punched output.
Specifications
Model Name
imageRUNNER 2800
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
RAPID Fusing System
Duty Cycle
Up to 100,000 impressions/month
Image Server Memory
128MB Standard + 5.1GB Hard Disk Drive
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 600 dpi (Copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
Letter
28 cpm/ppm
Letter R
18 cpm/ppm
Legal
14 cpm/ppm
Ledger
16 cpm/ppm
Statement
18 cpm/ppm
First Copy Time
5.8 seconds (From Platen Glass)
6.6 seconds (From DADF)
Multiple Copies
1 to 999
Magnification
25% - 800%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%, 800%
Acceptable Originals
Sheets, Books, 3 Dimensional Items (Up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 500 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
4,550 Sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
4 x 5-1/2 to 11-3/4 x 17
Acceptable Paper Weights
Cassette
17 - 20 lb. Bond
Bypass
17 - 32 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
10 Seconds or Less
Exposure Control
Automatic or Manual
Power Requirements
120V, 60Hz, 15A
Dimension
40-1/8 x 22-1/4 x 26-3/4
(1020mm x 565mm x 678mm)
Weight
176.3 lbs.
Toner
GPR-6 Black Toner
Estimated Toner Yield
15,000 Copies/Bottle (Estimated yield at 6% Coverage)
Feeders
Description
Duplexing Automatic Document Feeder-H1 (Optional)
Statement to Ledger
Scanning Speed
28 opm (Letter)
Capacity
50 Sheets
Paper Weights
10 - 32 lb. Bond
Different Size Originals
Same Width/Different Width
Power Source
Directly from Main Unit
Dimensions
4-7/8 x 22-3/8 x 21-1/8
(122mm x 565mm x 535mm)
Weight
17.6 lbs.
Paper Supply Options
Description
Cassette Feeding Unit-W1 (Optional)
Number Of Cassettes
2
Paper Capacity
1,000 Sheets
Paper Sizes
Statement-R to Ledger
Paper Weights
17 - 20 lb. Bond
Power Source
Dimensions
22-3/8 x 26-3/4 x 9-3/4
(565mm x 678mm x 248mm)
Weight
67.1 lbs.
Description
Paper Deck-L1 (Optional)
Number Of Cassettes
1
Paper Capacity
2,500 Sheets
Paper Sizes
Letter
Paper Weights
17 - 20 lb. Bond
Power Source
Dimensions
17 x 12-7/8 x 23-1/4
(432mm x 324mm x 591mm)
Weight
66.1 lbs.
Output Options
Finishers Output Trays
Description
Finisher-J1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
1
Top Tray
300 Sheets
Staple Capacity
30 Sheets (Letter)15 Sheets (Ledger)
Staple Positions
1-Top Corner
Power Source
Dimensions
9-1/8 x 22-3/8 x 20-1/8
(232mm x 565mm x 509mm)
Weight
24.2 lbs.
Description
Inner 2-Way Tray-A1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
2
Top Tray
100 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Power Source
Dimensions
10 x 5-7/8 x 16-1/2
(254mm x 149mm x 420mm)
Weight
7.7 lbs.
Description
Saddle Finisher-G1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
4 Trays, including Saddle-Stitch Tray and Inner 2-Way Tray
Top Tray
1,000 Sheets (Letter)
Middle Tray
250 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Saddle Stitch Tray
100 Sheets
Staple Capacity
50 Sheets (Letter)
Staple Positions
Multiposition Stapling
1 - Top Corner
2 - Side Margin (Book Staple, Two Patterns)
3 - Saddle-Stitch
1 - Top Corner
3 - Saddle-Stitch
Paper Sizes
Letter-R , Ledger
Stapling Capacity
10 Sheets
Fold Type
V-Fold Standard
Power Source
Dimensions
33-5/8 x 21 x 23-3/4
(855mm x 532mm x 603mm)
Weight
77.2 lbs.
Description
Puncher Unit-K1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Letter, Legal, Ledger
Hole Punch
2 Holes (Letter-R. Legal)
3 Holes (Letter, Ledger)
Power Source
Dimensions
6-3/4 x 3-1/2 x 22-1/8
(170mm x 90mm x 560mm)
Weight
5.3 lbs.
Fax Board
Description
Super G3 Fax Board-J1 (Optional)
Applicable Line
Public Switched Telephone Network
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
3 Seconds
Data Compression
MMR, MR, MH, JBIG
Memory
128MB
Maximum Memory
128MB
Print Board
Description
Network Multi-PDL Printer Kit-C1 (Optional)
Processor
250 MHz Canon Custom Processor
Standard Memory
128MB RAM
Maximum Memory
128MB RAM
Hard Disk
5.1 GB
Continuous Print Speed
28 ppm (Letter)
PDL Support
PCL 5e, PCL 6, PostScript 3 Emulation
Postscript Fonts
136 (117 Adobe Type Fonts, 19 True Type)
PCL Fonts
80 Roman, 32 Barcode
Interface Connections
Ethernet (10/100BaseT)
IEEE 1284 (Parallel)
Token Ring (Optional)
Other Features
Access to Full Finishing Features
Internet Connectivity
NetSpot Supported
Spooling Supported
NetSpot Supported
Spooling Supported
Awards
Line of the Year - Buyers Laboratory Inc.
Editor's Choice - Better Buys for Business
IEA-DSM Award of Excellence
BERTL "Best of the Best" 2002 Digital Office Award
Highly Recommended - BERTL Digital Test Lab
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 2800 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
GPR-6 Toner
Color: Black
Item Code: 6647A003AA
Estimated Toner Yield: 15,000 Copies/Case (Estimated @ 6% Coverage)
Brochures
Loading...
Complementary Content
- ${title}${badge}
${loading}
