Web Content Viewer
Actions
imageRUNNER 3045
Support - Multifunction
Specifications
Model Name
imageRUNNER 3045
Type
Monochrome Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
RAPID Fusing System™
Image Server Memory
Standard: 512MB RAM + 20GB HDD (Shared)
Optional: 256MB RAM (768MB RAM Maximum)
Max Mailboxes Supported
100
Max Copy Reservation
10 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
600 x 600 dpi
Interpolated Resolution
1200 x 600 dpi (Copy)
2400 x 600 dpi (Print)
Halftone
256 Gradations of Gray (Continuous Tone)
Letter
Up to 45 ppm
First Copy Time
Approx. 3.9 Seconds (From Platen Glass)
Approx. 5.9 Seconds (From DADF)
Multiple Copies
1 - 9,999
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%Zoom Mode
Platen: 25% - 400% (in 1% Increments)
DADF: 25% - 200% (in 1% Increments)
Acceptable Originals
Sheets, Books, and 3-Dimensional Objects (up to 4.4 lb.)
Maximum Original Size
11 x 17
Minimum Original Size:3-7/8 x 5-7/8 (Stack Bypass)
Standard Paper Capacity
Dual 550-Sheet Paper Cassettes, plus a 50 sheet Stack Bypass
Optional: Dual 550-Sheet Paper Cassettes 2,700-Sheet Paper Deck
Manual Bypass
50-Sheet Stack Bypass
Maximum Paper Capacity
4,950 Sheets
Output Sizes
Cassette
Upper: Legal, Letter, Letter-R, Statement-R, Executive
Lower: 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, Free Size (3-7/8 x 5-7/8 to 11-5/8 x 17), and Envelopes
Acceptable Paper Weights
Cassette
17 lb. to 20 lb. Bond
Bypass
17 lb. to 32 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
Approx. 30 Seconds or Less From Main Power Off
Approx. 10 Seconds or Less From Sleep Mode
Power Requirements
120V AC, 60Hz, 10APower Consumption: 1.35kW (Max.)Plug: NEMA 5-15P
Dimension
34-3/4 x 22-1/4 x 27-5/8
(883mm x 565mm x 700mm)
Weight
183 lb. (83kg)
Estimated Toner Yield
24,000 Impressions at 6% Image Coverage
Feeders
Description
Duplexing Automatic Document Feeder (Std.)
Scanning Speed
Up to 45 ipm (LTR)
Capacity
50 Sheets (20 lb. Bond)
Paper Weights
One-Sided Scanning: 11 lb. to 32 lb. Bond
Two-Sided Scanning: 13 lb. to 32 lb. Bond
Dimensions
8-7/8 x 22-1/4 x 21-1/4
(122mm x 565mm x 538mm)
Weight
Approx. 18.7 lb. (8.5kg)Power Consumption: Approx. 30W
Description
Envelope Feeder Attachment-C2 (Opt.)
Envelopes: COM10, Monarch, DL, ISO-B5, ISO-C5, Yougata4Copy Speed: Up to 12 cpm
Capacity
50 Sheets or 30mm in Height
Dimensions
3-3/4 x 22-1/4 x 20-1/2
(95mm x 565mm x 521mm)
Weight
Approx. 6.6 lb. (3kg)
Description
Cassette Feeding Unit-Y3 (Opt.)
Capacity
Dual 550-Sheet Cassettes
(1,100 Sheets at 20 lb. Bond)
Paper Weights
Dimensions
9-7/8 x 22-1/4 x 27-5/8
(252mm x 565mm x 700mm)Power Consumption: Approx. 20W
Weight
Approx. 50.7 lb. (23kg)
Paper Supply Options
Description
Paper Deck-Q1 (Opt.)
Paper Capacity
2,700 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
Dimensions
18-5/8 x 14-5/8 x 23-1/4
(473mm x 372mm x 591mm)Installation Space (W X D): 36-7/8 x 27-5/8 (937mm x 700mm)
Weight
Approx. 65.3 lb. (29.6kg)
Output Options
Finishers Output Trays
Description
Inner 2-Way Tray-D1 (Opt.)
Paper Weights
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, Envelope, Freesize (3-7/8 x 5-7/8 to 11-3/4 x 17)
Number Of Trays
Two
Top Tray
100 Sheets (LTR), 50 Sheets (Other Sizes)
Lower Tray
250 Sheets (LTR), 100 Sheets (Other Sizes)
Dimensions
6 x 7 x 21-1/2 (151mm x 176mm x 546mm) 34 x 27-5/8 (862mm x 700mm)
(When Stack Bypass is Extended)Power Consumption: Approx. 16WAttachable Accessories: Copy Tray-J1
Description
Finisher-S1 (Opt.)
Paper Weights
Paper Size
Number Of Trays
One (Second Tray Optional)Paper Capacity Per Tray
Non-collate, Collate, Group Mode: 1,000 Sheets (Letter, Statement-R) 500 Sheets (11 x 17, Legal, Letter-R)
Staple Mode: 1,000 Sheets/30 Sets (Letter) 500 Sheets/30 Sets (11 x 17, Legal, Letter-R)Paper Capacity Per Tray (with Additional Finisher Tray-B1)
Non-collate, Collate, Group Mode: 300 Sheets Per Tray (Letter, Statement-R) 150 Sheets Per Tray (11 x 17, Legal, Letter-R)
Staple Mode: 300 Sheets/30 Sets Per Tray (Letter) 150 Sheets/30 Sets Per Tray (11 x 17, Legal, Letter-R)
Staple Capacity
50 Sheets (Letter)
30 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Top Left Corner: 11 x 17 (Landscape), Legal (Landscape), Letter, Letter-R
Top Right Corner: 11 x 17 (Portrait), Legal (Portrait)
Hole Punch
Puncher Unit-R1 (Option for Finisher-S1)Acceptable Paper Sizes: 11 x 17, Legal, Letter, Letter-R
Acceptable Paper Weight: 17 lb. to 32 lb. Bond
Punch Type
Two Holes: Legal, Letter-R
Three Holes: 11 x 17'', Letter
Punch Waste Capacity
Two Holes: Approx. 2,500 Sheets
Three Holes: Approx. 1,500 Sheets
Dimensions (H x W x D): 6-7/8 x 19-7/8 x 5-1/8
(175mm x 505mm x 130mm)
Weight: Approx. 8.6 lb. (3.9kg)
Dimensions
12-3/8 x 23-1/2 x 21-3/4
(315mm x 598mm x 552mm)Installation Space: 41-1/8 x 27-5/8 (1044mm x 700mm)Power Consumption: Approx. 45W (When Additional Finisher Tray-B1 is Attached)Attachable Accessories: Additional Finisher Tray-B1
Puncher Unit-R1
Copy Tray-J1Additional Finisher Tray-B1 (Opt.)
Tray Capacity: See Finisher-S1 Specifications
Dimensions (H x W x D): 3-1/8 x 7-7/8 x 15-5/8
(80mm x 200mm x 395mm)
Weight: Approx. 3.7 lb. (1.7kg)
Description
Finisher-AE1/Saddle Finisher-AE2 (Opt.)
Paper Weights
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Envelope, Freesize (3-7/8 x 5-7/8 to 11-3/4 x 17)
Number Of Trays
2 Trays Paper Capacity Per Tray
Non-collate, Collate, Group Mode: 1,000 Sheets (Letter, Statement-R, Executive)
Staple Mode: 1,000 Sheets/30 Sets (Letter, Executive)
Staple Capacity
50 Sheets (Letter, Executive)
Staple Positions
Corner Staple, Double-Staple
Hole Punch
Puncher Unit-M1 (Option for Finisher-AE1/Saddle Finisher-AE2)
Punch Type
Three Holes: 11 x 17, Letter
Punch Waste Capacity: Approx. 3,000 Sheets
Dimensions (H x W x D): 37-1/8 x 4-1/4 x 24-1/4
(941mm x 107mm x 615mm)
Weight: Approx. 15.9 lb. (7.2kg)
Paper Sizes
Stapling Capacity
15 Sheets (60 Page Booklets)
Tray Capacity: 25 Sets (1 to 5 Sheets)
15 Sets (6 to 10 Sheets)
10 Sets (11 to 15 Sheets)
Fold Type
V-Folding Saddle Stitch specifications apply to the Saddle Finisher-AE2 only.
Dimensions
Finisher-AE1: 40-7/8 x 25-3/8 x 25-7/8
(1037mm x 643mm x 657mm)
Saddle Finisher-AE2: 40-7/8 x 29-3/8 x 25-7/8
(1037mm x 747mm x 657mm)Installation Space (W X D):
Finisher-AE1: 59-3/8 x 27-5/8 (1058mm x 700mm) (When Stack Bypass and Auxiliary Tray are Extended)
Saddle Finisher-AE2: 63-1/4 x 27-5/8 (1607mm x 700mm) (When Stack Bypass and Auxiliary Tray are Extended)
Weight
Finisher-AE1: Approx. 95.2 lb. (43.2kg)
Saddle Finisher-AE2: Approx. 161 lb. (73.2kg)Attachable Accessories: Puncher Unit-M1
Fax Board
Description
Super G3 Fax Board-Q1/Multi-Line Fax Board-D1
Applicable Line
Public Switched Telephone Network (PSTN)
Connection Lines: One-Line (Super G3 Fax Board-Q1)
Two-Lines (Super G3 Multi-Line Fax Board-D1)
Sending/Original Size: Statement to 11 x 17
Receiving/Printing Size: Statement to 11 x 17
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds/Page
G3MR/G3MH: Approx. 13 Seconds/Page
JBIG: Approx. 2.6 Seconds/Page
Auto Dial Function: Address Book 1,800 Destinations (Including Destinations Stored in One-Touch Buttons)
Print Board
Description
UFR II/PCL Printer Kit-S1
Processor
Canon Custom Processor
Standard Memory
512MB
Maximum Memory
768MB (Shared)
Hard Disk
20GB (Shared)
PDL Support
UFR II, PCL 5e, PCL 6
Interface Connections
10/100Base-TX (RJ-45), USB 2.0 High Speed
Maximum Print Resolution: 2,400 x 600 dpi (Interpolated)
Print Controller Technology
UFR II: Windows® 2000/XP; Windows Server 2000, Citrix MetaFrame, Macintosh® OS X (OS 10.1.5 or Later)
PCL 5e/6: Windows 98/Me/2000/XP Windows NT 4.0/Server 2003 Citrix Meta Frame Internal Fonts: 80 Scalable Fonts, 30 Barcode,10 Bitmap, 2 OCR Fonts Interface Connections: 10/100 Base-TX (RJ-45), USB 2.0 High Speed Network Operating Systems:Novell® NetWare® v.3.2, 4.1, 4.11, 4.2, 5, 5.1, 6.5 (IPX/SPX) Windows 98, Me, 2000, XP, Server 2003 (TCP/IP) Apple® Macintosh OS 8.0 or Higher (DDP) Solaris™ 1.5x, 2.5x, or Later (TCP/IP)Accessory: PS Printer Kit-S1
Description
PS Printer Kit-S1 (Opt. for UFR II/PCL Printer)
Standard Memory
512MB
Maximum Memory
768MB (Shared)
Hard Disk
20GB (Standard) (Shared)
PDL Support
PostScript 3 Emulation
Maximum Print Resolution: 2400 x 600 dpi (Interpolated)
Windows 98/Me/2000/XP, Windows NT 4.0/Server 2003, Citrix MetaFrame, Macintosh OS X (OS 10.2 or Later)Internal Fonts: 136 Scalable Fonts Network Operating Systems: Windows 98, Me, 2000, XP, Server 2003, Apple Macintosh OS X (10.2.8 or Later)
Send Expansion Sets
Description
Universal Send Kit-G1
Sending Method
E-mail, I-Fax, File Server (FTP, SMB, IPX, WebDAV), User Inbox, Super G3 (Optional)
Communication Protocol File: FTP (TCP/IP), SMB (TCP/IP), NCP, (IPX), WebDAV
E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
Data Format
File/E-Mail: TIFF, PDF, PDF (OCR),** Encrypted PDF,*** Digital Device Signature PDF,*** Digital User Signature PDF^
I-Fax: TIFF (MH, MR, MMR)
Address Book Capacity
Max. 1,800 Destinations
Max. 5 LDAP Servers OTHER OPTIONAL ACCESSORIES
Cabinet-P1FL Cassette-Y1 (Replacement)FL Cassette-Z1 (Replacement)Envelope Feeder Attachment-C2Copy Tray-J1Document Tray-J1Card Reader-C1Card Reader Kit-B1Braille Label Kit-A1ADF Access Handle-A1Workflow Composer-A1Encrypted Secure Print Software-C1^^Barcode Printing Kit-A1^^Web Access Software-F1tDigital User Signature PDF Kit-A1tttUniversal Send PDF Security Feature Set-A1tttUniversal Send Searchable PDF Kit-A1tttimageRUNNER 256MB Expansion RAM-B1Secure Watermark-A1HDD Data Encryption Kit-B4HDD Data Erase Kit-A1Expansion Bus-B1USB Application Interface Board-G1Remote Operator's Software Kit-A2Voice Operation Kit-A1tteCopy Suite imageWARE™ Suite* Available with Saddle Finisher-AE2 only.
** Requires Universal Send Searchable PDF Kit-A1.
*** Requires Universal Send PDF Security Feature Set-A1.
^ Requires Digital User Signature PDF Kit-A1.
^^ Requires the UFR II/PCL Printer Kit-S1.
t Requires the imageRUNNER 256MB Expansion RAM to display Web Flash content. Requires the UFR II/PCL Printer Kit-S1 for printing functions. Add the PS Printer Kit-S1 if printing PDF files.
tt Requires imageRUNNER 256MB Expansion RAM-B1.
ttt Requires Universal Send Kit-G1
Awards
2007 BLI Highly Recommended
Better Buys for Business Innovative Product of the Year 2007
BLI 2007 Reliability Seal
BERTL 4 Star Highly Recommended
Better Buys for Business Editor's Choice 2007
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 3045 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER 3000 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
