Web Content Viewer
Actions
imageRUNNER 3300EN
Support - Multifunction
Specifications
Model Name
imageRUNNER 3300EN
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
RAPID Fusing System
Image Server Memory
Standard 128MB RAM; 5.1GB HDD
Max Mailboxes Supported
100 (100 items per box, 4,000 pages max.)
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Interpolated Resolution
1200 x 600 dpi (Copy)
2400 x 600 dpi (Print)
Halftone
256 Level
Letter
Up to 33 ppm
First Copy Time
5.8 Seconds (from Platen Glass)
6.6 Seconds (from DADF)
Multiple Copies
1 - 999
Magnification
From Glass: 25% - 800% (In 1% Increments)
From Feeder: 25% - 200% (In 1% Increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%, 800%
Acceptable Originals
Sheets, Books, 3-Dimensional Items (Up to 4.4 lb.)
Maximum Original Size
11 x 17 (Ledger)
Maximum Copy Size: 11 x 17 (Only lower cassettes will hold 11 x 17)
Minimum Copy Size: 4 x 5-1/2
Standard Paper Capacity
Dual 500-Sheet Paper Cassettes (1,000 Sheets)
Stack Bypass (50 Sheets)
Optional: Dual 500-Sheet Paper Cassettes (1,000 Sheets)
Manual Bypass
50 Sheets
Acceptable Paper Weights
Cassette
17 lb. - 20 lb. Bond
Bypass
17 lb. - 32 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
10 Seconds or Less (Sleep Mode)
29 Seconds or Less (Main Power Off)
Exposure Control
AE or Manual (Text, Photo, or Text & Photo)
Power Requirements
120V/60Hz, 15A
Power Consumption: 1.35kW Max.
Plug: NEMA 5-15P
Dimension
(When DADF is not attached): 30-1/4 x 22-1/4 x 26-3/4 (769mm x 565mm x 678mm)
Installation Space (W x D): 32-3/4 x 26-3/4 (830mm x 768mm)
Weight
176.3 lb. (80kg)
Estimated Toner Yield
15,000 Images at 6% Coverage
Feeders
Description
Duplexing Automatic Document Feeder (Std.)
11 x 17, Legal, Letter, Letter-R, Statement
Feeding Speed: Up to 33 Sheets/Minute
Capacity
50 Sheets (All Sizes)
Paper Weights
13 lb. to 32 lb. Bond (Two-sided)
10 lb. to 32 lb. Bond (One-sided)
Different Size Originals
Same Width/Different Width
Dimensions
4-7/8 x 22-1/4 x 21-1/4 (122mm x 565mm x 538mm)
Weight
18.7 lb. (8.5kg)
Description
Cassette Feeding Unit-W1 E (Opt.)
Capacity
2 x 500-Sheet Cassettes (20 lb. Bond)
Paper Size: First Cassette (Statement-R to Legal)
Second Cassette (Statement-R to 11 x 17)
Paper Weights
Dimensions
22-3/8 x 26-3/4 x 9-3/4
Weight
67.1 lb. (28kg)
Output Options
Finishers Output Trays
Description
Internal Finisher (Std.)
Paper Weights
Paper Size
Statement to 11 x 17
Number Of Trays
One Tray
Top Tray
300 Sheets (Letter)/150 Sheets
(Letter-R, Legal, 11 x 17)
Staple Capacity
30 Sheets (Letter)/15 Sheets (11 x 17)
Staple Positions
1-Top Left Corner
Staple Type: Staple-L1 (Included)
Power Source
Directly From Main Unit
Dimensions
9-1/8 x 22-1/4 x 20
Weight
24.3 lb. (11kg)
Fax Board
Description
Super G3 Fax**
Applicable Line
Public Switched Telephone Network (PSTN)
Connection Lines: One
Sending Sizes: Statement to Ledger
Address Book: 200 Destinations
Image Memory: Approx. 3,700 Pages
Print Board
Processor
Canon Custom Processor-Shared
Standard Memory
Shared with Main Unit - 128MB RAM Standard
Continuous Print Speed
Up to 33 ppm (Letter)
PCL Fonts
PCL 5e/6, PostScript® 3™ Emulation
Interface Connections
RJ-45 (10/100Base-TX), IEEE 1284 (Compatibility: Nibble, Byte, and ECP Mode)
Print Controller Technology
PCL 5e/6: Windows® (Windows 2000/XP/Server 2003/Windows Vista®) Citrix MetaFrame
PS3: Windows (Windows 2000/XP/Server 2003/Windows Vista) Citrix MetaFrame, Macintosh® (OS 10.2.8 or Later)* NOTE: FACTORY CERTIFIED MODEL -- This FACTORY CERTIFIED MODEL has been thoroughly inspected and cleaned. It has had a prescribed number of parts replaced so as to ensure operation and quality to Canon standards. This model has been assigned a new model name and serial number, may incorporate new features and/or functions, and has had its meter reset to zero. This model contains new, refurbished, and/or recovered parts and fully meets the original equipment manufacturer's quality and operational standards for this FACTORY CERTIFIED machine.
** Standard on some configurations.
Brochures
Loading...
 Return to Top
