Web Content Viewer
Actions
imageRUNNER 3300i
Support - Multifunction
Features
The imageRUNNER 3300i features a 33 page-per-minute copy and print speed and a duty cycle of up to 120,000 impressions per month.
The imageRUNNER 3300i offers advanced scanning capabilities, embodied in Canon's Universal Send technology, as standard. Scanned documents can be sent quickly and easily to the user's PC or to others via e-mail, Internet-fax or by depositing the image into a mailbox, database or file server.
The 6.0GB Image Server and 192MB RAM deliver features such as Scan-Once-Print-Many, Job Build, Copy Reservation, Mailbox capabilities, and more.
The standard 50-sheet Automatic Document Feeder can handle mixed originals with different lengths and widths in one job.
The imageRUNNER 3300i features a generous paper supply with dual 500-sheet user-adjustable cassettes and a 50-sheet Stack Bypass, for a standard paper capacity of 1,050 sheets. With the addition of the optional paper deck, and another dual 500-sheet cassette feeding pedestal, the total paper capacity is 4,550 sheets.
With standard Automatic Trayless Duplexing, the imageRUNNER 3300i can duplex at the rated engine speed.
The imageRUNNER 3300i offers extensive document finishing capabilities with two optional finishers. An innovative internal finisher provides basic stapling and collating features without taking up any floor space. The optional saddle finisher delivers single and multiposition stapling capability, enabling users to staple in any corner of the document, or double staple in the margin of the document for a book staple. Saddle-stitch, V-folding and 2- or 3-hole punch functionality are also available.
Network printing capabilities are standard with support for PCL 5e, PCL 6, and PostScript 3 emulation printer languages.
The imageRUNNER 3300i ships standard with a full suite of Canon productivity-enhancing software, including a 10-user license for eCopy Desktop software, Canon's NetSpot Suite and device drivers.
Specifications
Model Name
imageRUNNER 3300i
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
RAPID Fusing System™
Duty Cycle
Up to 120,000 impressions/month
Image Server Memory
192MB Standard + 6.0GB Hard Disk Drive
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 600 dpi (Copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
Letter
33 cpm/ppm
Letter R
18 cpm/ppm
Legal
14 cpm/ppm
Ledger
16 cpm/ppm
Statement
18 cpm/ppm
First Copy Time
5.8 seconds (From Platen Glass)
6.6 seconds (From DADF)
Multiple Copies
1 to 999
Magnification
25% - 800%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%, 800%
Acceptable Originals
Sheets, Books, 3 Dimensional Items (Up to 4.4 lbs.)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 500 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
4,550 Sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
4 x 5-1/2 to 11-3/4 x 17
Acceptable Paper Weights
Cassette
17 - 20 lb. Bond
Bypass
17 - 32 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
10 Seconds or Less
Exposure Control
Automatic or Manual
Power Requirements
120V, 60Hz, 10A
Dimension
35-7/8 x 22-1/4 x 29
(910.5mm x 565mm x 762mm)
Weight
214 lbs.
Toner
GPR-6 Black Toner
Estimated Toner Yield
15,000 Copies/Bottle (Estimated yield at 6% Coverage)
Feeders
Description
Duplexing Automatic Document Feeder-H1 (Standard)
Statement to Ledger
Scanning Speed
33 opm (Letter)
Capacity
50 Sheets
Paper Weights
10 - 32 lb. Bond
Different Size Originals
Same Width/Different Width
Power Source
Directly from Main Unit
Dimensions
4-7/8 x 22-3/8 x 21-1/8
(122mm x 565mm x 535mm)
Weight
17.6 lbs.
Paper Supply Options
Description
Paper Deck-L1 (Optional)
Number Of Cassettes
1
Paper Capacity
2,500 Sheets
Paper Sizes
Letter
Paper Weights
17 - 20 lb. Bond
Power Source
Dimensions
17 x 12-7/8 x 23-1/4
(432mm x 324mm x 591mm)
Weight
66.1 lbs.
Description
Cassette Feeding Unit-W1 (Optional)
Number Of Cassettes
2
Paper Capacity
1,000 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
17 lb. - 20 lb. Bond
Power Source
Dimensions
22-3/8 x 26-3/4 x 9-3/4
(565mm x 678mm x 248mm)
Weight
67.1 lbs.
Output Options
Finishers Output Trays
Description
Finisher-J1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
1
Top Tray
300 Sheets (Letter)
Staple Capacity
30 Sheets (Letter)
15 Sheets (Ledger)
Staple Positions
1-Top Corner
Power Source
Dimensions
9-1/8 x 22-3/8 x 20-1/8
(232mm x 565mm x 509mm)
Weight
24.2 lbs.
Description
Inner 2-Way Tray-A1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
2
Top Tray
100 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Power Source
Dimensions
10 x 5-7/8 x 16-1/2
(254mm x 149mm x 420mm)
Weight
7.7 lbs.
Description
Saddle Finisher-G1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Statement to Ledger
Number Of Trays
4 Trays, including Saddle-Stitch Tray and Inner 2-Way Tray
Top Tray
1,000 Sheets (Letter)
Middle Tray
250 Sheets (Letter)
Lower Tray
250 Sheets (Letter)
Saddle Stitch Tray
100 Sheets
Staple Capacity
50 Sheets (Letter)
Staple Positions
Multiposition Stapling
1 - Top Corner
2 - Side Margin (Book Staple, Two Patterns)
3 - Saddle-Stitch
Paper Sizes
Letter-R , Ledger
Stapling Capacity
10 sheets
Fold Type
V-Fold Standard
Power Source
Dimensions
33-5/8 x 21 x 23-3/4
(855mm x 532mm x 603mm)
Weight
77.2 lbs.
Description
Puncher Unit-K1 (Optional)
Paper Weights
17 - 32 lb. Bond
Paper Size
Letter, Legal, Ledger
Hole Punch
2 Holes (Letter-R. Legal)
3 Holes (Letter, Ledger)
Power Source
Dimensions
6-3/4 x 3-1/2 x 22-1/8
(170mm x 90mm x 560mm)
Weight
5.3 lbs.
Fax Board
Description
Super G3 Fax Board-J1 (Optional)
Applicable Line
Public Switched Telephone Network
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
3 Seconds
Data Compression
MMR, MR, MH, JBIG
Memory
128MB
Maximum Memory
128MB
Print Board
Description
Network Multi-PDL Printer Kit-C1 (Standard)
Processor
250 MHz Canon Custom Processor
Standard Memory
192MB RAM
Maximum Memory
192MB RAM
Hard Disk
6.0 GB
Continuous Print Speed
33 ppm (Letter)
PDL Support
PCL 5e, PCL 6, PostScript­ 3™ Emulation
Postscript Fonts
136 (117 Adobe Type Fonts, 19 True Type)
PCL Fonts
80 Roman, 32 Barcode
Interface Connections
Ethernet (10/100BaseT)
IEEE 1284 (Parallel)
Token Ring (Optional)
Other Features
Access to Full Finishing Features
Internet Connectivity
NetSpot Supported
Spooling Supported
Awards
Line of the Year - Buyers Laboratory Inc.
Editor's Choice - Better Buys for Business
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 3300i that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
