Web Content Viewer
Actions
imageRUNNER 330S
Support - Multifunction
Features
The imageRUNNER 330S features a 33 page-per-minute copy and print speed and a duty cycle of up to 120,000 impressions per month
The imageRUNNER 330S is a stand-alone digital copier that can be easily modified to incorporate Super G3 faxing, network printing and document scanning by adding the appropriate expansion board.
The imageRUNNER 330S comes with 32MB of Image Server memory, upgradeable to 96MB. The Image Server supports a host of functions including Scan-Once-Print-Many, Auto Image Orientation, Booklet Making and Confidential User Mailboxes.
The imageRUNNER 330S ships standard with trayless duplexing support. Using this design, the imageRUNNER 330S is not required to stack duplexed pages in a separate cassette, and as a result, can deliver two-sided output at the rated speed of the print engine.
The imageRUNNER 330S comes with a standard paper capacity of 1,050 sheets, which can be upgraded to a maximum of 5,550 sheets to accommodate paper-intensive operations by adding the available paper supply options.
Both optional network printer boards integrate seamlessly into 10/100 Ethernet or Token Ring environments, and ship standard with 32MB of industry-standard memory and a 4.2GB hard disk drive used for spooling jobs, storing ripped images and handling fonts. One offers support for Adobe PostScript 3 and PCL 5e printing, while the other offers support for PCL 5e only.
There are two document feeder options. The feeders are capable of holding up to 50 (DADF-A1) and 30 (DADF-B1) originals respectively, and will support paper sizes from Statement to 11" x 17". With their ability to handle mixed sized originals, the Automatic Document Feeders will provide you with significant document feeding flexibility.
With three optional finishers that provide capabilities ranging from basic collated and stapled output to multipage, saddle-stitched brochures, the imageRUNNER 330S provides the greatest flexibility and quality available in producing finished sets of documents.
Specifications
Model Name
imageRUNNER 330S
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Duty Cycle
Up to 120,000 impressions/month
Image Server Memory
32MB Standard
Upgradeable to 96MB Total (DIMMs)
Max Mailboxes Supported
100
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1,200 dpi x 600 dpi
Halftone
256 Gradations of Gray
Letter
33 cpm/ppm
First Copy Time
6 Seconds or Less (from ADF)
Multiple Copies
1 to 999
Magnification
25% - 800%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Sheets, Books and 3-Dimensional Objects (up to 4.4 lbs./2 kg)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 500 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
5,550 Sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
Statement to Ledger
Acceptable Paper Weights
Cassette
17 - 22 lb. Bond
Bypass
17 - 22 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
81 Seconds or Less
Exposure Control
Automatic or Manual (Text or Photo)
Power Requirements
115V, 60Hz
Dimension
27-1/8 x 28-3/8 x 26-3/8
(689mm x 691mm x 645mm)
Weight
215 lbs.
Toner
GPR-2 Black Toner
Estimated Toner Yield
10,600 Images (6% Coverage)
Drum
GPR-2 Drum Unit
Estimated Drum Yield
55,000 Impressions
Feeders
Description
Automatic Document Feeder DADF-A1 (Optional)
Statement to Ledger
Scanning Speed
33 opm
Capacity
50 Sheets (Letter)
Paper Weights
13 - 28 lb. Bond
Different Size Originals
Standard
Power Source
Directly from Main Unit
Dimensions
25-3/8 x 20-1/2 x 5-7/8
(645mm x 521mm x 50mm)
Weight
32.6 lbs.
Description
Automatic Document Feeder DADF-B1 (Optional)
Statement to Ledger
Scanning Speed
33 opm
Capacity
30 Sheets (Letter)
Paper Weights
13 - 28 lb. Bond
Standard
Power Source
Dimensions
Weight
32.6 lbs.
Paper Supply Options
Description
Cassette Feeding Unit-S1 (Optional)
Number Of Cassettes
2
Paper Capacity
1,000 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
17 - 22 lb. Bond
Power Source
Dimensions
23 x 26-1/4 x 20-1/2
(453mm x 585mm x 619mm)
Weight
88.2 lbs.
Description
Cassette Feeding Module-R1 (Optional)
Number Of Cassettes
4
Paper Capacity
2,000 Sheets
Paper Sizes
Statement to Ledger
Paper Weights
17 - 22 lb. Bond
Power Source
Dimensions
Weight
106 lbs.
Description
Paper Deck-B1 (Optional)
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
17 - 22 lb. Bond
Power Source
Dimensions
20-1/2 x 12-3/4 x 23
(519mm x 323mm x 583mm)
Weight
68.3 lbs.
Output Options
Finishers Output Trays
Description
Stapler Stacker Finisher-E1 (Optional)
Paper Size
Statement to Ledger
Number Of Trays
1
Top Tray
1,000 Sheets (Letter)
Staple Capacity
Up to 30 Sheets
Staple Positions
1 - Top Corner
Power Source
Dimensions
14-1/4 x 21-3/4 x 22-5/8
Weight
26.4 lbs.
Description
Multi-Position Auto Stapler-C1 (Optional)
Paper Size
Statement to Ledger
Number Of Trays
3 (4 - including Interrupt Tray)
Top Tray
300 Sheets (Letter)
Middle Tray
750 Sheets (Letter)
Lower Tray
200 Sheets (Letter)
Staple Capacity
Up to 50 Sheets
Staple Positions
Multiposition Stapling
1 - Top Corner
2 - Side Margin (Book Staple)
Power Source
Dimensions
41-1/4 x 26-3/8 x 22-7/8
Weight
71.8 lbs.
Description
Saddle-Stitch Finisher-C2 (Optional)
Paper Size
Statement to Ledger
Number Of Trays
5 (Including Interrupt Tray and Saddle-Stitch Tray)
Top Tray
300 Sheets (Letter)
Middle Tray
750 Sheets (Letter)
Lower Tray
200 Sheets (Letter)
Saddle Stitch Tray
300 Sheets
Staple Capacity
Up to 50 Sheets
Staple Positions
1 - Top Corner
3 - Saddle-Stitch
Stapling Capacity
15 Sheets (Letter/Ledger)
Fold Type
V-Folding Standard
Power Source
Dimensions
Weight
99.2 lbs.
Fax Board
Description
Super G3 Fax Board-F1 (Optional)
Applicable Line
Public Switched Telephone Network
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
2.8 Seconds
Data Compression
MH, MR, MMR, JBIG
Memory
32MB
Maximum Memory
96MB
One Touch Speed Dialing Locations
60 Locations
Coded Speed Dialing Locations
140 Locations
Description
Super G3 Multi-Line Fax Board-A1 (Optional)
Applicable Line
Compatibility
G3
Modem Speed
33,600 bps
Transmission Speed
2.8 Seconds
Data Compression
MH, MR, MMR, JBIG
Memory
32MB
Maximum Memory
96MB
60 Locations
140 Locations
Print Board
Description
Network Printer Board-K1 (Optional)
Processor
MIPS R5000 200 MHz RISC Processor
Standard Memory
32MB
Maximum Memory
64MB
Hard Disk
4.2GB
Continuous Print Speed
33 ppm (Letter)
PDL Support
PCL5e
PCL Fonts
45 Fonts
Interface Connections
Ethernet (10/100BaseT)
IEEE 1284 (Parallel)
Token Ring (Optional)
Print Controller Technology
Compression and Decompression
Resolution Enhancement Technology
Direct EPS File Printing
RIP-While-Print®
Font and Forms Downloading
Continuous Print™
Other Features
Access to Full Finishing Features
Internet Connectivity
NetSpot Supported
Spooling Support
Automatic Job Recovery
Description
Network Multi-PDL Printer Board-P1 (Optional)
Processor
Pentium III 500MHz Processor
Standard Memory
128MB
Hard Disk
10 GB
33 ppm (Letter)
PDL Support
PCL5e, PCL6, PostScript 3
Postscript Fonts
136 Fonts
PCL Fonts
80 Fonts
Ethernet (10 base-T/100 base-TX)
PostScript Font Management
RIP-While-Print®
Continuous Print™
Other Features
Fax Capability
Halftone Support
Finishing Options Support
Fiery Link Tools
Canon LPR Utility
Awards
Pick of the Year - Buyers Laboratory Inc.
Editor's Choice - Better Buys for Business
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 330S that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
