Web Content Viewer
Actions
imageRUNNER 3530
Support - Multifunction
Specifications
Model Name
imageRUNNER 3530
Type
Digital, Multifunction Imaging System
Imaging System
Laser Electrostatic Transfer
Developing System
Dry Mono Component
Fixing System
RAPID Fusing System™
Duty Cycle
130,000
Image Server Memory
Standard: 256MB RAM
Optional: 20GB HDD
Max Mailboxes Supported
100 (with UFR II Printer Kit-E3 or UFR II/PCL Printer Kit-E2)
Max Copy Reservation
5 Jobs
Scanning Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 600 dpi (Copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
Letter
35 ppm
First Copy Time
3.9 Seconds from Platen Glass
5.9 Seconds from Feeder
Multiple Copies
1 to 999
Magnification
25% to 400% - Platen
25% to 200% - Feeder
(in 1% increments)
Standard Paper Capacity
Dual 550-sheet Paper Cassettes (1,100 Sheets)
Manual Bypass
50 Sheets
Maximum Paper Capacity
2,250 Sheets Max.
Acceptable Paper Weights
Cassette
17 lb. to 20 lb. Bond
Bypass
17 lb. to 32 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
10 Seconds or Less from Sleep Mode
15 Seconds or Less from Main Power Off
30 Seconds from Main Power Off ( With UFR II Printer Kit-E3 or UFR II/PCL Printer Kit-E2)
Exposure Control
Automatic or Manual (9 levels)
Power Requirements
120V AC, 60Hz, 10A
Dimension
29-7/8 x 22-1/4 x 27-5/8
(761mm x 565mm x 700mm)
Weight
Approx. 152 lb. (69kg)
Estimated Toner Yield
24,000 @ 6% Coverage
Drum
Organic Photo Conductor (OPC)
Estimated Drum Yield
85,000 Impressions
Feeders
Description
Duplexing Automatic Document Feeder-N1 (Optional)
Acceptable Originals
Statement to 11 x 17
Scanning Speed
Up to 45 Images per Minute (ipm)
Capacity
50 Sheets (20 lb. Bond/Letter)
Paper Weights
13 lb. to 32 lb. Bond
Power Source
From Main Unit
Dimensions
8-7/8 x 22-1/4 x 21-1/4
(122mm x 565mm x 538mm)
Weight
Approx. 18.7 lb. (8.5kg)
Paper Supply Options
Description
Cassette Feeding Unit-Y2 (Optional)
Number Of Cassettes
2
Paper Capacity
(1,100 Sheets/20 lb. Bond)
Paper Sizes
Statement-R to 11 x 17
Paper Weights
Power Source
From Main Unit
Dimensions
(251mm x 565mm x 700mm)
Weight
Approx. 50.7 lb. (23kg)
Description
Envelope Feeder Attachment-C1 (Optional)
Paper Capacity
approx. 50 envelopes
or 1-1/4 (31.75mm)
Paper Sizes
All Envelopes
Dimensions
3-1/4 x 12-1/8 x 11-5/8
(82mm x 306mm x 295mm)
Weight
Approx. 2.4 lb (1.1kg)
Output Options
Finishers Output Trays
Description
Inner 2-Way Tray-D1 (Optional)
Paper Size
Number Of Trays
2
Top Tray
100 Sheets (Letter)
50 Sheets (Other Sizes)
Lower Tray
250 Sheets (Letter)
100 Sheets (Other Sizes)
Dimensions
6 x 7 x 21-1/2
(151mm x 176mm x 546mm)
Weight
Approx. 8.6 lb (3.9kg)
Description
Finisher-S1 (Optional)
Number Of Trays
1 Tray (Second Tray Optional)
Top Tray
Group Mode: 1,000 Sheets (Letter, Statement)
500 Sheets (11 x 17, Legal, Letter-R)
Staple Mode:1,000 Sheets/30 Sets (Letter)
500 Sheets/30 Sets (11 x 17,Legal, Letter-R)
Staple Capacity
50 sheets (Letter)
Staple Positions
Corner Stapling
(11 x 17, Legal, Letter, Letter-R)
Power Source
From Main Unit
Dimensions
11-7/8 x 18-7/8 x 20-1/2
(300mm x 480mm x 520mm)
Weight
Approx. 26.5 lb. (12kg)
Description
Finisher-S1 with Additional Finisher Tray-B1 (Optional)
Top Tray
Staple Mode: 300 Sheets/30 Sets per Tray (Letter)
150 Sheets/per Tray (11 x 17,Legal, Letter)
Group Mode: 300 sheets per tray (Letter, Statement)
150 sheets per tray (11x17, legal, letter)
Description
Puncher Unit-R1 (Option for Finisher-S1)
Paper Weights
17 lb.- 32 lb. Bond
Paper Size
2 Hole: Legal, Letter-R
3 Hole: 11 x 17, Letter
Power Source
From Main Unit
Dimensions
6-7/8 x 19-7/8 x 5-1/8
(175mm x 505mm x 130mm)
Weight
Approx. 8.6 lb. (3.9kg)
Fax Board
Description
Super G3 Fax Board-Q1 (Optional)
Applicable Line
Public Switched Telephone
Network (PSTN)
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds
G3MR: Approx. 13 Seconds
G3MH: Approx. 13 Seconds
JBIG: Approx. 2.6 Seconds
Memory
Image Memory: Approx. 8,000 Pages
Print Board
Description
UFR II Printer Kit-E3, UFR II/PCL Printer Kit-E2 (Optional)
Processor
Canon Custom Processor Shared
Standard Memory
256MB-Shared
Hard Disk
20GB-Shared
PDL Support
UFR II Printer Kit-E3: UFR II
UFR II/PCL Printer Kit-E2: PCL 5e, PCL 6, UFR II
Interface Connections
Standard: RJ-45 (10/100Base-T), USB 2.0 High-speed
Other Features
Other Optional Accessories and Utilities Platen Cover Type H
Cabinet-P1
Braille Label Kit-A1
Document Tray-J1
Card Reader-C1
Card Sets
imageRUNNER Security Kit-A2
eCopy Suite
Wireless LAN Kit (Available 2H-2005)
Removable HDD Kit (Available 2H-2005)
Copy Tray-J1 (Option for Inner 2-Way Tray and Finisher-S1)
ENERGY STAR Qualified
Awards
2006 BLI Pick of the Year Award
BLI 2006 Reliability Certified
BLI 2006 Highly Recommended
#1 Ease of Use Monochrome MFP Customer Survey
#1 Best Monochrome MFP's Customer Survey
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 3530 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
