Web Content Viewer
Actions
imageRUNNER 400V
Support - Multifunction
Specifications
Model Name
imageRUNNER 400V
Type
Digital Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Fixing System
Heat Roller Method
Duty Cycle
120,000 impressions per month
Image Server Memory
Standard 32MB
Printing Resolution
600 x 600 dpi
Letter
40 ppm
First Copy Time
6 seconds from DADF or less
Multiple Copies
1 to 999
Magnification
25% to 800% in 1 % increments
Acceptable Originals
Sheet, books, 3 dimensional objects (up to 4.4 lb Bond or 2kg)
Maximum Original Size
11 x 17 (Ledger)
Standard Paper Capacity
Dual Front loading cassettes
500 sheets each
Manual Bypass
50 sheet Stack Bypass
Maximum Paper Capacity
2,050 sheets
Acceptable Paper Weights
Cassette
17 lb to 20 lb Bond
Bypass
17 lb to 32 lb Bond
Duplexing
Standard Automatic Trayless
Warm Up Time
92 seconds or less
Power Requirements
120V/60Hz
Dimension
21-1/4 x 23 x 28-3/8
(539mm x 585mm x 720mm)
Weight
Approx. 183 lb. (83.4kg)
Drum
OPC
Estimated Drum Yield
55,000 Impressions
Feeders
Description
Duplexing Automatic Document Feeder-A1 (Optional)
Statement to 11 x 17
Scanning Speed
40 sheets/Min.
Capacity
50 Sheets (Letter/20 lb.)
Paper Weights
up to 28lb
Power Source
24V from Main unit
Dimensions
6-3/8 x 25-3/8 x 20-3/4
(161mm x 645mm x 527mm)
Weight
Approx. 31 lb. (14.1kg)
Paper Supply Options
Description
Cassette Feeding Unit-S1 (Optional)
Number Of Cassettes
2
Paper Capacity
2 x 500 Sheets
(Total: 1,000 Sheets)
Paper Sizes
Top Drawer: Statement, Statement-R, Letter,Letter-R
Bottom Drawer: Statement, Statement-R, Letter,Letter-R, Legal, 11 x 17
Paper Weights
Up to 20 lb. Bond
Power Source
From Main Unit
Dimensions
17-7/8 x 23 x 26-1/4
(453mm x 585mm x 665mm)
Weight
Approx. 86.4 lb. (39.2kg)
Output Options
Finishers Output Trays
Description
Finisher-E1 (Optional)
Number Of Trays
one tray
Top Tray
1,000 Sheets (Letter)
Staple Capacity
30 Sheets (Letter)
15 Sheets (Legal, 11 x 17)
Staple Positions
Top Corner
Power Source
120V/60Hz Shared
Dimensions
14-1/4 x 21-3/4 x 22-5/8
(363mm x 553mm x 574mm)
Weight
Approx. 26.4 lb. (12kg)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 400V that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
