Web Content Viewer
Actions
imageRUNNER 4570
Support - Multifunction
Features
Operating at 45 pages-per-minute, the imageRUNNER 4570 is equipped with a 20GB Hard Disk Drive and 512MB RAM, providing users with exceptional productivity and reliability.
With a scanning resolution of 600 x 600 dpi, enhanced copy resolution of 1200 x 600 dpi, and enhanced print resolution of 2400 x 600 dpi, the imageRUNNER 4570 delivers superior quality for the most faithful reproduction of text and images.
Incorporating Canon's MEAP™ (Multifunctional Embedded Application Platform) architecture, the imageRUNNER 4570's applications can be customized to meet unique business needs. The customized applications run from the imageRUNNER 4570 control panel streamlining document workflows.
The full-color user interface panel and intuitively-designed device drivers provide user-friendly operation for both walk-up and desktop environments.
Compact, space-saving design with an optional internal finisher that offers optional hole-punching and sorting capabilities.
Supports a host of Internet-enabled capabilities to offer the tightest possible integration across entire corporate networks and web-based information systems.
Provides greater security measures for online information sharing and storage needs.
Designed with Canon's RAPID Fusing Technology to significantly reduce energy consumption and improve productivity.
An optional 50-sheet capacity Duplexing Automatic Document Feeder makes quick work of scanning multi-page and different-size originals.
With a standard paper capacity of 1,150 sheets, which can be expanded to 4,750 sheets, the imageRUNNER 4570 has been designed to meet the volume requirements of any workgroup.
The Mail Box functions of the imageRUNNER 4570 serve as a centralized system for information-sharing, on-site document storage and print-on-demand applications.
Add network printing to provide maximum flexibility and performance for busy corporate workgroups and departments.
The imageRUNNER 4570 can be equipped with an optional single- or dual-line Super G3 fax board for the ability to transmit faxes at impressive speeds.
With its Universal Send™ technology, the imageRUNNER 4570 allows users to scan directly into the device for distribution to multiple destinations. Advanced Send modes such as searchable PDF (OCR) and Encrypted PDF can be added for an even more sophisticated solution.
With Remote UI, features and functions of the imageRUNNER 4570 are controlled and accessed right from a user's desktop.
Specifications
Model Name
imageRUNNER 4570
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Mono Component Toner
Projection
Fixing System
RAPID Fusing System™
Duty Cycle
170,000 impressions per month
Image Server Memory
Standard 512MB RAM/20GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 jobs
Interpolated Resolution
1200 dpi x 600 dpi (Copy)
2400 dpi x 600 dpi (Print)
Halftone
256 Gradations of Gray
First Copy Time
3.9 Seconds from Platen Glass
5.9 Seconds from Feeder
Multiple Copies
1 to 999
Magnification
25% to 400% in 1% increments
Preset Enlargements
25% to 400%- Platen
25% to 200%-Feeder
Standard Paper Capacity
1,100 sheets
Maximum Paper Capacity
4,750 sheets
Acceptable Paper Weights
Cassette
17 lb. to 20 lb. Bond
Bypass
17 lb. to 32 lb. Bond
Warm Up Time
10 Seconds or Less from Sleep Mode
30 Seconds from Main Power Off
Exposure Control
Automatic or Manual (9 levels)
Power Requirements
120VAC, 60Hz, 10A
Dimension
29-7/8 x 22-1/4 x 27-5/8
(761mm x 565mm x 700mm)
Weight
190 lb. (86.2kg)
Estimated Toner Yield
24,000 @ 6% Coverage
Drum
Organic Photo Conductor (OPC)
Estimated Drum Yield
Estimated Yield: 85,000 Impressions
Feeders
Description
Duplexing Automatic Document Feeder-N1
Acceptable Originals
Statement to 11 x 17
Scanning Speed
28 Images per Minute (ipm) (Letter @600 dpi), 45 ipm (Letter @ 300 dpi)
Capacity
50 Sheets (20 lb. Bond/Letter)
Paper Weights
13 lb. to 32 lb. Bond
Power Source
From Main Unit
Dimensions
8-7/8 x 22-1/4 x 21-1/4
(122mm x 565mm x 538mm)
Weight
Approx. 18.7 lb. (8.5kg)
Paper Supply Options
Description
Cassette Feeding Unit-Y2
Paper Capacity
Dual 550-sheet Paper Cassettes
(1,100 Sheets/20 lb. Bond)
Paper Sizes
Statement-R to 11 x 17
Paper Weights
Power Source
From Main Unit
Dimensions
(251mm x 565mm x 700mm)
Weight
Approx. 50.7 lb. (23kg)
Description
Envelope Feeder Attachment-C1
Paper Capacity
Approx. 50 Envelopes
or 1-1/4 (31.75mm)
Paper Sizes
COM10, DL, Monarch, ISO-B5,ISO-C5, Yougata-4
Dimensions
3-1/4 x 12-1/8 x 11-5/8
(82mm x 306mm x 295mm)
Weight
Approx. 2.4 lb (1.1kg)
Description
Paper Deck-Q1
Paper Capacity
2,500 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
17 lb. to 28 lb. Bond
Power Source
From the Main Unit
Dimensions
18-5/8 x 14-5/8 x 23-1/4
(473mm x 372mm x 591mm)
Weight
Approx. 65.3 lb (29.6kg)
Output Options
Finishers Output Trays
Description
Inner 2-Way Tray-D1
Paper Size
Number Of Trays
2 trays
Top Tray
100 Sheets (Letter)
50 Sheets (Other Sizes)
Lower Tray
250 Sheets (Letter)
100 Sheets (Other Sizes)
Dimensions
6 x 7 x 21-1/2
(151mm x 176mm x 546mm)
Weight
Approx. 8.6 lb (3.9kg)
Description
Additional Finisher Tray-B1 (Option for Finisher-S1)
Top Tray
Group Mode: 300 Sheets per Tray (Letter,Statement)
Staple Mode: 300 Sheets/30 Sets per Tray (Letter)150 Sheets/per Tray (11 x 17,Legal, Letter)150 Sheets/30 Sets (11 x 17, Legal)
Dimensions
3-1/8 x 7-7/8 x 15-5/8
(80mm x 200mm x 395mm)
Weight
Approx. 3.7 lb. (1.7kg)
Description
Finisher-S1
Number Of Trays
1 Tray (Second Tray Optional)
Top Tray
Group Mode:1,000 Sheets (Letter, Statement)
500 Sheets (11 x 17, Legal, Letter-R)
Staples Mode: 1,000 Sheets/30 Sets (Letter)
500 Sheets/30 Sets (11 x 17,Legal, Letter-R)
Staple Capacity
50 Sheets (Letter-Up to 20 lb. Bond)
Staple Positions
Corner Stapling
Power Source
From Main Unit
Dimensions
11-7/8 x 18-7/8 x 20-1/2
(300mm x 480mm x 520mm)
Weight
Approx. 26.5 lb. (12kg)
Description
Copy Tray-J1 (Option for Inner 2-Way Tray and Finisher-S1)
Top Tray
150 Sheets (Letter)
75 Sheets (Other Sizes)
Dimensions
4-3/4 x 13-5/8 x 13-7/8
(120mm x 347mm x 351mm)
Weight
Approx. 1 lb. (471kg)
Description
Finisher-Q3 / Saddle Finisher-Q4
Number Of Trays
2 trays
Top Tray
Group Mode: 1,000 sheets (Letter,Statement)
500 sheets (11 x 17, Legal,Letter-R)
Staple Mode: 1,000 sheets / 30 sets (Letter)
500 sheets / 30 sets (11 x 17, Legal, Letter-R)
Staple Capacity
50 sheets (Letter)
30 sheets (Letter-R, Legal, 11 x 17)
Staple Positions
Corner, Double
Paper Sizes
Stapling Capacity
15 sheets
Fold Type
V-fold
Fax Board
Description
Super G3 Fax Board-Q1/G3 Multi-Line Fax Board-D1
Applicable Line
Public Switched Telephone Network (PSTN)
Compatibility
G3
Modem Speed
33,600 kpbs
Transmission Speed
3 spp
Memory
image memory: Approx. 8,000 pages
Print Board
Description
Multi-PDL Printer Kit-E1
Processor
Canon Custom Processor Shared
Standard Memory
RAM: 512MB-Shared
Hard Disk
20 GB - Shared
PDL Support
PCL 5e, PCL 6, PostScript® 3™Emulation, UFR II
Postscript Fonts
136 Scalable Fonts
PCL Fonts
80 Scalable Fonts
Interface Connections
Standard: RJ-45 (10/100Base-T) USB 2.0 High-speed
Other Features
Other Optional Accessories and Utilities:
Puncher Unit-R1
Puncher Unit-M1 (Option for Finisher-Q3 and Saddle Finisher-Q4)
Platen Cover Type-H
Cabinet-P1
Accessibility Handle-A1
Braille Label Kit-A1
Document Tray-J1
Card Reader-C1
Card Sets
Universal Send Kit-B1 and Universal Send PDF Enhancement Kit-B1
imageRUNNER Security Kit-A2
eCopy Suite/ShareScan OP
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 4570 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
