Web Content Viewer
Actions
imageRUNNER 5000V
Support - Multifunction
Features
Operating at 50 pages-per-minute (LTR), the imageRUNNER 5000V is equipped with a 5.1GB Hard Disk Drive and 192MB RAM, providing users with exceptional productivity and reliability.
With a scanning resolution of up to 600 x 600 dpi, enhanced copy resolution of up to 1200 x 600 dpi, and enhanced print resolution of up to 2400 x 600 dpi, the imageRUNNER 5000V delivers superior quality for the faithful reproduction of text and images.
An LCD Touch Panel Display and intuitively designed device drivers provide user-friendly operation for both walk-up and remote users.
With its standard Automatic Document Feeder, the imageRUNNER 5000V makes quick work of multi-paged, double-sided and mixed-size originals. It can handle up to 100 originals and can accept paper weights up to 32lb. Bond.
Users can add the optional Finisher-F1 (REM) for any corner or side margin stapling capabilities. The Finisher-F1 can also be configured with a hole punch unit for more advanced document finishing.
With a standard paper capacity of 4,150 sheets the imageRUNNER 5000V can meet the requirements of large corporate departments.
The Mail Box function of the imageRUNNER 5000V serves as a centralized system for information-sharing, on-site document storage and print-on-demand applications.
Standard network printing capabilities can benefit multiple users in a shared environment. This feature delivers printing capabilities with support for PCL 5e/6 and PostScript® 3™ emulation.
Pull hardcopy-based information into existing electronic workflows with the standard Network ScanGear utility.
Optional eCopy support is available for advanced document distribution capabilities.
With Remote UI, features and functions of the imageRUNNER 5000V are controlled and accessed right from a desktop.
The imageRUNNER 5000V device's manufacturing status as an imageRUNNER Factory-produced New Model helps reduce waste and conserve natural resources. An imageRUNNER Factory-produced New Model is manufactured by converting an existing Canon product into a new model. This model contains new, reconditioned, or recovered parts and fully meets Canon's new product performance and reliability specifications.
Specifications
Model Name
imageRUNNER 5000V
Type
Monochrome Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Image Server Memory
Standard 192MB RAM + 5.1GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Interpolated Resolution
Copy Resolution: 1200 x 600 dpi
Print Resolution: 2400 x 600 dpi
Halftone
256 gradations of gray
Letter
50 cpm
Letter R
39 cpm
Legal
36 cpm
Ledger
30 cpm
First Copy Time
3.8 Seconds or Less from Platen Glass
5.1 Seconds or Less from ADF
Multiple Copies
1 to 999
Magnification
25% to 400% in 1% Increments (from glass)
Acceptable Originals
Sheets, Books, 3-Dimensional Items (Up to 4.4 lb.)
Maximum Original Size
11 x 17 (Ledger)Max. Copy Size: 11 x 17 (Ledger)
Min. Copy Size: 4 x 5-7/8
Standard Paper Capacity
Dual Front-Loading Trays (1,500 Sheets Each)
Dual Front-Loading Cassettes (550 Sheets Each)
Manual Bypass
50-Sheet Stack Bypass
Maximum Paper Capacity
4,150 sheets
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond (550-Sheet Cassettes), 17 lb. Bond to 110lb. Index (1,500 Sheet Drawers)
Bypass
17 lb. Bond to 110 lb. Index
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
5 Minutes or Less
Power Requirements
120V AC, 60Hz, 15A
Dimension
44-3/4 x 25-3/8 x 29-1/4
(1136mm x 643mm x 743mm)
Weight
Approximately 462 lb. (210kg)
Toner
Magnetic Negative Toner
Estimated Toner Yield
33,000 Images (at 6% Coverage)
Drum
Amorphous Silicon
Estimated Drum Yield
3,000,000 Impressions
Feeders
Description
Automatic Document Feeder (Standard)
Statement to 11 x 17
Capacity
100 Sheets (Letter/20 lb.)
Paper Weights
13 lb. to 32 lb. Bond
Output Options
Finishers Output Trays
Description
Finisher-F1 (REM) (Optional)
Number Of Trays
2 Trays
Top Tray
1,000 Sheets (Letter, Statement-R) 500 Sheets (Letter-R, Legal, 11 x 17) Staple Mode: Max. 30 Sets (All Sizes)
Lower Tray
Staple Capacity
50 Sheets (Letter, Statement)
30 Sheets (Letter-R, Legal, 11 x 17)
Staple Positions
1-Any Corner
2-Side Margin
Power Source
Directly from Main Unit
Dimensions
41-3/8 x 26-3/8 x 24-1/4
(1052mm x 669mm x 614mm)
Weight
Approximately 70.5 lb. (32kg)Puncher Unit-B1 (REM) (Option for Finisher-F1)
Max. Paper Weight: 17 lb. Bond to 110 lb. Index
Punch Types: 2-Hole, 3-Hole (Auto Change)
3-Hole (Letter, 11 x 17)
2-Hole (Legal, Letter-R)
Punch Dust Stock: Approximately 3,000 Sheets
Power Source: Directly from Main Unit
Dimensions (H x W x D): 34-7/8 x 3 x 24-1/4
(886mm x 75.5mm x 614.4mm)
Weight: 11.9 lb. (5.4kg)
Print Board
Description
Network Printing (Standard) Specifications
Processor
Canon Custom Processor
Standard Memory
192MB(Std./Max.) -- Shared
Hard Disk
5.1GB -- Shared
PDL Support
PCL 5e, PCL 6, PostScript 3 Emulation Internal Fonts: 136 PostScript Fonts
80 PCL Roman Fonts
32 PCL Bar-code Fonts
Interface Connections: 10/100Base-TX (RJ-45), IEEE 1284
Protocol Stacks
IPX/SPX: Ethernet II, Ethernet 802.2, Ethernet 802.3, Ethernet SNAP
TCP/IP: Ethernet II
AppleTalk® Phase II: Ethernet SNAP
Network OS: Novell® NetWare® v.3.2, 4.1, 4.11, 4.2, 5, 5.1, 6, 6.5 (IPX/SPX)
Windows® 98/Me (TCP/IP)
Windows NT® 4.0 (TCP/IP)
Windows 2000, XP, Server 2003 (TCP/IP)
Solaris™ 1.1x, 2.5x or Later (TCP/IP)
Apple®Macintosh® 7.5 or Higher (PPD)imageRUNNER Factory-produced New Model:
This imageRUNNER Factory-produced New Model has been disassembled to a predetermined standard by the original equipment manufacturer, and manufactured with a new serial number. This model contains new, reconditioned and/or recovered parts and fully meets the manufacturer's new product performance and reliability specifications. (This product contains reconditioned parts and materials.)
ENERGY STAR Qualified
Brochures
Loading...
 Return to Top
